Public Member Functions | Private Attributes | List of all members
ossimVpfCoverage Class Reference
#include <ossimVpfCoverage.h>
 ossimVpfCoverage ()
virtual ~ossimVpfCoverage ()
bool openCoverage (ossimVpfLibrary *library, const ossimString &name, const ossimFilename &fileName)
const ossimFilenamegetPath () const
const ossimStringgetName () const
ossim_uint32 getNumberOfFeatureClasses () const
void print (ostream &out) const
bool getExtent (ossimVpfExtent &extent) const
ossimVpfLibrarygetLibrary ()
bool openFeatureClassSchema (ossimVpfFeatureClassSchema &schema)
Private Attributes
ossimVpfLibrarytheLibrary
ossimString theCoverageName
ossimFilename theCoverageNameFullPath
Detailed Description
Definition at line 23 of file ossimVpfCoverage.h.
◆ ossimVpfCoverage()
ossimVpfCoverage::ossimVpfCoverage ( )
Definition at line 19 of file ossimVpfCoverage.cpp.
20  :theLibrary(NULL),
21  theCoverageName(""),
23 {
24 }
ossimVpfLibrary * theLibrary
◆ ~ossimVpfCoverage()
ossimVpfCoverage::~ossimVpfCoverage ( )
virtual
Definition at line 26 of file ossimVpfCoverage.cpp.
References theLibrary.
27 {
28  theLibrary = NULL;
29 }
Member Function Documentation
◆ getExtent()
bool ossimVpfCoverage::getExtent ( ossimVpfExtent extent) const
Definition at line 67 of file ossimVpfCoverage.cpp.
References ossimFilename::dirCat(), ossimString::downcase(), ossimFilename::exists(), ossimVpfBoundingRecordTable::getExtent(), ossimVpfLibrary::getTileNames(), ossimVpfBoundingRecordTable::openTable(), theCoverageNameFullPath, and theLibrary.
68 {
69  bool result = false;
70  bool firstOneSetFlag = false;
71  ossimVpfExtent resultExtent;
72  ossimVpfExtent tempExtent;
73  if(theLibrary)
74  {
76  {
77  ossimVpfBoundingRecordTable boundingRecord;
78
79  if(boundingRecord.openTable(theCoverageNameFullPath.dirCat("ebr")))
80  {
81  boundingRecord.getExtent(tempExtent);
82  resultExtent = tempExtent;
83  firstOneSetFlag = true;
84  result = true;
85  }
86  }
88  {
89  ossimVpfBoundingRecordTable boundingRecord;
90
91  if(boundingRecord.openTable(theCoverageNameFullPath.dirCat("fbr")))
92  {
93  boundingRecord.getExtent(tempExtent);
94
95  if(!firstOneSetFlag)
96  {
97  resultExtent = tempExtent;
98  firstOneSetFlag = true;
99  }
100  else
101  {
102  resultExtent = resultExtent + tempExtent;
103  }
104
105  result = true;
106  }
107  }
108  std::vector<ossimString> tileNames;
109
110  theLibrary->getTileNames(tileNames);
111
112  for(int i = 0; i < (int)tileNames.size(); ++i)
113  {
114  ossimFilename tileName = tileNames[0];
115  ossimFilename tileDir;
116  if(theCoverageNameFullPath.dirCat(tileName).exists())
117  {
118  tileDir = theCoverageNameFullPath.dirCat(tileName);
119  }
120  else if(theCoverageNameFullPath.dirCat(tileName.downcase()).exists())
121  {
122  tileDir = theCoverageNameFullPath.dirCat(tileName.downcase());
123  }
124  if(tileDir != "")
125  {
126  if(tileDir.dirCat("ebr").exists())
127  {
128  ossimVpfBoundingRecordTable boundingRecord;
129
130  if(boundingRecord.openTable(tileDir.dirCat("ebr")))
131  {
132  boundingRecord.getExtent(tempExtent);
133
134  if(!firstOneSetFlag)
135  {
136  resultExtent = tempExtent;
137  firstOneSetFlag = true;
138  }
139  else
140  {
141  resultExtent = resultExtent + tempExtent;
142  }
143
144  result = true;
145  }
146  }
147  if(tileDir.dirCat("fbr").exists())
148  {
149  ossimVpfBoundingRecordTable boundingRecord;
150
151  if(boundingRecord.openTable(tileDir.dirCat("fbr")))
152  {
153  boundingRecord.getExtent(tempExtent);
154
155  if(!firstOneSetFlag)
156  {
157  resultExtent = tempExtent;
158  firstOneSetFlag = true;
159  }
160  else
161  {
162  resultExtent = resultExtent + tempExtent;
163  }
164
165  result = true;
166  }
167  }
168  }
169  }
170  }
171
172  extent = resultExtent;
173
174  return result;
175 }
virtual bool openTable(const ossimFilename &tableName)
void getTileNames(std::vector< ossimString > &tileNames) const
bool exists() const
void getExtent(ossimVpfExtent &extent) const
ossimFilename dirCat(const ossimFilename &file) const
◆ getLibrary()
ossimVpfLibrary * ossimVpfCoverage::getLibrary ( )
◆ getName()
const ossimString & ossimVpfCoverage::getName ( ) const
Definition at line 53 of file ossimVpfCoverage.cpp.
References theCoverageName.
54 {
55  return theCoverageName;
56 }
◆ getNumberOfFeatureClasses()
ossim_uint32 ossimVpfCoverage::getNumberOfFeatureClasses ( ) const
◆ getPath()
const ossimFilename & ossimVpfCoverage::getPath ( ) const
◆ openCoverage()
bool ossimVpfCoverage::openCoverage ( ossimVpfLibrary library,
const ossimString name,
const ossimFilename fileName
Definition at line 31 of file ossimVpfCoverage.cpp.
References ossimFilename::dirCat(), ossimFilename::exists(), theCoverageName, theCoverageNameFullPath, and theLibrary.
Referenced by ossimVpfLibrary::getCoverage().
34 {
35  bool result = true;
36  theCoverageName = name;
37  theCoverageNameFullPath = fullPath;
38  theLibrary = library;
39
41  {
42  result = false;
43  }
44
45  return result;
46 }
bool exists() const
◆ openFeatureClassSchema()
bool ossimVpfCoverage::openFeatureClassSchema ( ossimVpfFeatureClassSchema schema)
◆ print()
void ossimVpfCoverage::print ( ostream &  out) const
Definition at line 58 of file ossimVpfCoverage.cpp.
References ossimFilename::dirCat(), ossimVpfTable::openTable(), ossimVpfTable::print(), and theCoverageNameFullPath.
59 {
60  ossimVpfTable table;
61  if(table.openTable(theCoverageNameFullPath.dirCat("fcs")))
62  {
63  table.print(out);
64  }
65 }
virtual void print(std::ostream &out) const
Member Data Documentation
◆ theCoverageName
ossimString ossimVpfCoverage::theCoverageName
private
Definition at line 44 of file ossimVpfCoverage.h.
Referenced by getName(), and openCoverage().
◆ theCoverageNameFullPath
ossimFilename ossimVpfCoverage::theCoverageNameFullPath
private
will hold the full path to this coverage.
Definition at line 49 of file ossimVpfCoverage.h.
Referenced by getExtent(), getPath(), openCoverage(), and print().
◆ theLibrary
ossimVpfLibrary* ossimVpfCoverage::theLibrary
private
Definition at line 43 of file ossimVpfCoverage.h.
Referenced by getExtent(), getLibrary(), openCoverage(), and ~ossimVpfCoverage().
