ossimVpfDatabase Class Reference
#include <ossimVpfDatabase.h>
Public Member Functions
 ossimVpfDatabase ()
virtual ~ossimVpfDatabase ()
virtual bool openDatabase (const ossimFilename &filename)
void closeDatabase ()
ossimFilename getPath () const
long getNumberOfLibraries () const
ossimVpfLibrarygetLibrary (unsigned long libraryNumber)
ossimVpfLibrarygetLibrary (const ossimString &name)
bool isOpened () const
vector< ossimStringgetLibraryNames () const
vector< ossimStringgetLibraryNamesFullPath () const
ossimFilename getLibraryAttributeTable () const
Protected Member Functions
void initializeLibraryList ()
void deleteLibraryList ()
Protected Attributes
ossimFilename theDatabaseHeaderTable
ossimFilename theLibraryAttributeTable
vector< ossimVpfLibrary * > theVpfLibraryList
bool theOpenedFlag
Detailed Description
Definition at line 22 of file ossimVpfDatabase.h.
◆ ossimVpfDatabase()
ossimVpfDatabase::ossimVpfDatabase ( )
Initializes everything to null;
Definition at line 18 of file ossimVpfDatabase.cpp.
21  theOpenedFlag(false)
22 {
23 }
◆ ~ossimVpfDatabase()
ossimVpfDatabase::~ossimVpfDatabase ( )
virtual
Destroys any allocated space.
Definition at line 25 of file ossimVpfDatabase.cpp.
References closeDatabase(), and deleteLibraryList().
26 {
28
29  closeDatabase();
30 }
Member Function Documentation
◆ closeDatabase()
void ossimVpfDatabase::closeDatabase ( )
◆ deleteLibraryList()
void ossimVpfDatabase::deleteLibraryList ( )
protected
Definition at line 181 of file ossimVpfDatabase.cpp.
References theVpfLibraryList.
Referenced by closeDatabase(), initializeLibraryList(), and ~ossimVpfDatabase().
182 {
183  for(long idx = 0; idx <(long)theVpfLibraryList.size(); idx++)
184  {
185  delete theVpfLibraryList[idx];
186  theVpfLibraryList[idx] = 0;
187  }
188
189  theVpfLibraryList.clear();
190 }
◆ getLibrary() [1/2]
ossimVpfLibrary * ossimVpfDatabase::getLibrary ( unsigned long  libraryNumber)
Definition at line 97 of file ossimVpfDatabase.cpp.
Referenced by ossimVpfAnnotationLibraryInfo::loadState().
98 {
99
100  if(libraryNumber < theVpfLibraryList.size())
101  {
102  return theVpfLibraryList[libraryNumber];
103  }
104
105  return NULL;
106 }
◆ getLibrary() [2/2]
ossimVpfLibrary * ossimVpfDatabase::getLibrary ( const ossimString name)
Definition at line 108 of file ossimVpfDatabase.cpp.
109 {
110  for(long index = 0; index < (long)theVpfLibraryList.size(); ++index)
111  {
112  if(theVpfLibraryList[index]->getName() == name)
113  {
114  return theVpfLibraryList[index];
115  }
116  }
117
118  return NULL;
119 }
◆ getLibraryAttributeTable()
ossimFilename ossimVpfDatabase::getLibraryAttributeTable ( ) const
Definition at line 161 of file ossimVpfDatabase.cpp.
References theLibraryAttributeTable.
Referenced by ossimVpfLibrary::getExtent().
162 {
164 }
◆ getLibraryNames()
vector< ossimString > ossimVpfDatabase::getLibraryNames ( ) const
Definition at line 127 of file ossimVpfDatabase.cpp.
References ossimVpfTable::getColumnValues(), ossimVpfTable::openTable(), and theLibraryAttributeTable.
Referenced by initializeLibraryList().
128 {
129
130  ossimVpfTable table;
131
133  {
134  return table.getColumnValues("LIBRARY_NAME");
135  }
136
137  return vector<ossimString>();
138 }
std::vector< ossimString > getColumnValues(const ossimString &columnName) const
virtual bool openTable(const ossimFilename &tableName)
◆ getLibraryNamesFullPath()
vector< ossimString > ossimVpfDatabase::getLibraryNamesFullPath ( ) const
Definition at line 140 of file ossimVpfDatabase.cpp.
References ossimVpfTable::getColumnValues(), ossimVpfTable::openTable(), ossimFilename::path(), and theLibraryAttributeTable.
141 {
142  vector<ossimString> result;
143
144  ossimVpfTable table;
145
147  {
148  result = table.getColumnValues("LIBRARY_NAME");
149  }
150
151  for(long index=0; index < (long)result.size();index++)
152  {
153  result[index] = ossimString(theLibraryAttributeTable.path()) +
154  ossimString("/") +
155  result[index];
156  }
157
158  return result;
159 }
ossimFilename path() const
◆ getNumberOfLibraries()
long ossimVpfDatabase::getNumberOfLibraries ( ) const
Definition at line 92 of file ossimVpfDatabase.cpp.
93 {
94  return (long)theVpfLibraryList.size();
95 }
◆ getPath()
ossimFilename ossimVpfDatabase::getPath ( ) const
Definition at line 86 of file ossimVpfDatabase.cpp.
References ossimFilename::path(), and theLibraryAttributeTable.
87 {
88  // we can use either table name since all we need is the path
90 }
◆ initializeLibraryList()
void ossimVpfDatabase::initializeLibraryList ( )
protected
Definition at line 166 of file ossimVpfDatabase.cpp.
References deleteLibraryList(), getLibraryNames(), getPath(), ossimVpfLibrary::openLibrary(), and theVpfLibraryList.
Referenced by openDatabase().
167 {
168  // make sure the library list is deleted
170  vector<ossimString> libraryNames = getLibraryNames();
171  for(long index = 0; index < (long)libraryNames.size(); index++)
172  {
173  ossimVpfLibrary *library = new ossimVpfLibrary;
174  library->openLibrary(this,
175  libraryNames[index],
176  getPath().dirCat(libraryNames[index]));
177  theVpfLibraryList.push_back(library);
178  }
179 }
bool openLibrary(ossimVpfDatabase *database, const ossimString &name, const ossimFilename &libraryPath)
vector< ossimString > getLibraryNames() const
ossimFilename getPath() const
◆ isOpened()
bool ossimVpfDatabase::isOpened ( ) const
Definition at line 122 of file ossimVpfDatabase.cpp.
References theOpenedFlag.
Referenced by ossimVpfAnnotationSource::isOpen(), and ossimVpfAnnotationSource::openDatabase().
123 {
124  return theOpenedFlag;
125 }
◆ openDatabase()
bool ossimVpfDatabase::openDatabase ( const ossimFilename filename)
virtual
This will open a database. This will either be a dht(database header table) table or a library attribut table (lat) file. Both of these files should exist in a vpf database.
Definition at line 32 of file ossimVpfDatabase.cpp.
References ossimFilename::exists(), initializeLibraryList(), ossimVpfTable::openTable(), ossimFilename::path(), theDatabaseHeaderTable, theLibraryAttributeTable, and theOpenedFlag.
Referenced by ossimVpfAnnotationSource::openDatabase().
33 {
34  bool result = true;
35
36  ossimFilename tempFilename = filename;
37
38  // tempFilename.convertBackToForwardSlashes();
39
40  // we should have two table to look at for the database.
41  // 1) database header (dht) 2) and the Library attribute (lat)
42  theDatabaseHeaderTable = ossimFilename(tempFilename.path()).dirCat("dht");
43  theLibraryAttributeTable = ossimFilename(tempFilename.path()).dirCat("lat");
44
47  {
48  ossimVpfTable table;
49  // now lets see if they are valid tables
50  result = table.openTable(theDatabaseHeaderTable);
51  if(result&&
52  !ossimVpfDatabaseHeaderTableValidator().isValid(table))
53  {
54  result = false;
55  }
56
57  result = table.openTable(theLibraryAttributeTable);
58  if((result) &&!ossimVpfLibraryAttributeTableValidator().isValid(table))
59  {
60  result = false;
61  }
62  }
63  else
64  {
65  result = false;
66  }
67
68  if(result)
69  {
70  theOpenedFlag = true;
72  }
73
74  return result;
75 }
bool exists() const
Member Data Documentation
◆ theDatabaseHeaderTable
ossimFilename ossimVpfDatabase::theDatabaseHeaderTable
protected
This is the complete path to the Database Header Table (dht file).
Definition at line 71 of file ossimVpfDatabase.h.
Referenced by closeDatabase(), and openDatabase().
◆ theLibraryAttributeTable
ossimFilename ossimVpfDatabase::theLibraryAttributeTable
protected
This is the complete path to the library attribute table (lat file).
Definition at line 76 of file ossimVpfDatabase.h.
Referenced by closeDatabase(), getLibraryAttributeTable(), getLibraryNames(), getLibraryNamesFullPath(), getPath(), and openDatabase().
◆ theOpenedFlag
bool ossimVpfDatabase::theOpenedFlag
protected
This jhust specifies whether the database has been opened or not.
Definition at line 86 of file ossimVpfDatabase.h.
Referenced by closeDatabase(), isOpened(), and openDatabase().
◆ theVpfLibraryList
vector<ossimVpfLibrary*> ossimVpfDatabase::theVpfLibraryList
protected
Will hold a constructed set of libraries.
Definition at line 81 of file ossimVpfDatabase.h.
Referenced by deleteLibraryList(), getLibrary(), getNumberOfLibraries(), and initializeLibraryList().
