Public Member Functions | Static Public Member Functions | Private Attributes | List of all members
ossimVpfFeatureClass Class Reference
#include <ossimVpfFeatureClass.h>
 ossimVpfFeatureClass ()
bool openFeatureClass (const ossimString &featureClassName, const ossimFilename &featureClassFullPath, const ossimFilename &table1, const ossimString &columnNameIdTable1, const ossimFilename &table2, const ossimString &columnNameIdTable2)
const ossimStringgetName () const
ossimFilename getTable1 () const
ossimFilename getTable2 () const
static bool isPrimitive (const ossimString &featureName)
static bool isSimpleFeature (const ossimString &featureName)
static bool isComplexFeature (const ossimString &featureName)
static bool isFeature (const ossimString &featureName)
static bool isJoin (const ossimString &featureName)
Private Attributes
ossimFilename theFeatureClassFullPath
ossimString theFeatureClassName
ossimFilename theTableName1
ossimString theColumnNameId1
ossimFilename theTableName2
ossimString theColumnNameId2
Detailed Description
Definition at line 9 of file ossimVpfFeatureClass.h.
◆ ossimVpfFeatureClass()
ossimVpfFeatureClass::ossimVpfFeatureClass ( )
Definition at line 16 of file ossimVpfFeatureClass.cpp.
17 {
18 }
Member Function Documentation
◆ getName()
const ossimString & ossimVpfFeatureClass::getName ( ) const
Definition at line 51 of file ossimVpfFeatureClass.cpp.
52 {
53  return theFeatureClassName;
54
55 }
◆ getTable1()
ossimFilename ossimVpfFeatureClass::getTable1 ( ) const
Definition at line 143 of file ossimVpfFeatureClass.cpp.
References ossimFilename::dirCat().
144 {
146 }
ossimFilename dirCat(const ossimFilename &file) const
◆ getTable2()
ossimFilename ossimVpfFeatureClass::getTable2 ( ) const
Definition at line 148 of file ossimVpfFeatureClass.cpp.
149 {
151 }
◆ isComplexFeature()
bool ossimVpfFeatureClass::isComplexFeature ( const ossimString featureName)
static
This just specifies if the input is a comples feature.
.cft Complex feature table.
Definition at line 107 of file ossimVpfFeatureClass.cpp.
References ossimString::downcase(), and ossimString::trim().
108 {
109  const char* suffix = strrchr(featureName.trim(), '.');
110
111  if (!suffix)
112  {
113  return false;
114  }
115
116  ossimString value = ossimString(suffix).downcase();
117
118  return (value == ".cft");
119 }
ossimString trim(const ossimString &valueToTrim=ossimString(" \\)) const
this will strip lead and trailing character passed in.
◆ isFeature()
bool ossimVpfFeatureClass::isFeature ( const ossimString featureName)
static
Will use the isComplexFeature and isSimpleFeature to determine if the input is a feature
Definition at line 121 of file ossimVpfFeatureClass.cpp.
122 {
123  return (isSimpleFeature(featureName) || isComplexFeature(featureName));
124 }
static bool isComplexFeature(const ossimString &featureName)
static bool isSimpleFeature(const ossimString &featureName)
◆ isJoin()
bool ossimVpfFeatureClass::isJoin ( const ossimString featureName)
static
Will specifiy if it is a join table.
Some of the join table type are:
.cjt Complex join table .pjt Point join table .ljt Line join table .ajt area join table .tjt text join table
Definition at line 126 of file ossimVpfFeatureClass.cpp.
References ossimString::c_str(), and ossimString::downcase().
127 {
128  ossimString value = strrchr(featureName.c_str(), '.');
129  if(value == "")
130  {
131  return false;
132  }
133
134  value = value.downcase();
135
136  return ( (value == ".cjt")||
137  (value == ".pjt")||
138  (value == ".ljt")||
139  (value == ".ajt")||
140  (value == ".tjt"));
141 }
const char * c_str() const
Definition: ossimString.h:396
◆ isPrimitive()
bool ossimVpfFeatureClass::isPrimitive ( const ossimString featureName)
static
This will specify if this feature is a primitive. the names of certain primitives are:
end Entity node primitive cnd Connected node primitive edg Edge Primitive fac Face Primitive txt Text primitive
Definition at line 57 of file ossimVpfFeatureClass.cpp.
Referenced by ossimVpfFeatureClassSchema::setFeatureClassMapping().
58 {
59  // make sure we have forward slashes
60  ossimFilename filename(featureName.trim());
61  // filename.convertBackToForwardSlashes();
62
63  ossimString copyOfFeature = filename;
64
65  // find
66  const char* temp = strrchr(copyOfFeature.c_str(), '/');
67
68  ossimString value;
69  if(temp)
70  {
71  ++temp;
72  value = temp;
73  }
74  else
75  {
76
77  value = copyOfFeature;
78  }
79
80  value = value.downcase();
81  return( (value == "end") ||
82  (value == "cnd") ||
83  (value == "edg") ||
84  (value == "fac") ||
85  (value == "txt") );
86 }
◆ isSimpleFeature()
bool ossimVpfFeatureClass::isSimpleFeature ( const ossimString featureName)
static
This just specifies if the input is a simple feature.
Some of the simple features are:
.pft Point feature table .lft Line feature table .aft area feature table .tft text feature table
Definition at line 88 of file ossimVpfFeatureClass.cpp.
References ossimString::c_str(), ossimString::downcase(), and ossimString::trim().
89 {
90  // find the suffix
91  ossimString value = strrchr(featureName.trim().c_str(), '.');
92
93  // the suffix will be null or empty string if not found.
94  if(value == "")
95  {
96  return false;
97  }
98  // make case insensitive
99  value = value.downcase();
100
101  return ( (value == ".pft")||
102  (value == ".lft")||
103  (value == ".aft")||
104  (value == ".tft"));
105 }
◆ openFeatureClass()
bool ossimVpfFeatureClass::openFeatureClass ( const ossimString featureClassName,
const ossimFilename featureClassFullPath,
const ossimFilename table1,
const ossimString columnNameIdTable1,
const ossimFilename table2,
const ossimString columnNameIdTable2
Will initialize the feature class for this coverage and do some validation.
Definition at line 21 of file ossimVpfFeatureClass.cpp.
References ossimVpfTable::openTable().
27 {
28  theFeatureClassFullPath = featureClassFullPath;
29  theFeatureClassName = featureClassName;
30  theTableName1 = table1;
31  theColumnNameId1 = columnNameIdTable1;
32  theTableName2 = table2;
33  theColumnNameId2 = columnNameIdTable2;
34
35  ossimVpfTable t1;
36  ossimVpfTable t2;
37
38  ossimFilename t1Name = getTable1();
39  ossimFilename t2Name = getTable2();
40
41  if((!t1.openTable(t1Name))||
42  (!t2.openTable(t2Name)))
43  {
44
45  return false;
46  }
47
48  return true;
49 }
virtual bool openTable(const ossimFilename &tableName)
ossimFilename getTable2() const
ossimFilename getTable1() const
Member Data Documentation
◆ theColumnNameId1
ossimString ossimVpfFeatureClass::theColumnNameId1
private
Definition at line 86 of file ossimVpfFeatureClass.h.
◆ theColumnNameId2
ossimString ossimVpfFeatureClass::theColumnNameId2
private
Definition at line 88 of file ossimVpfFeatureClass.h.
◆ theFeatureClassFullPath
ossimFilename ossimVpfFeatureClass::theFeatureClassFullPath
private
Definition at line 83 of file ossimVpfFeatureClass.h.
◆ theFeatureClassName
ossimString ossimVpfFeatureClass::theFeatureClassName
private
Definition at line 84 of file ossimVpfFeatureClass.h.
◆ theTableName1
ossimFilename ossimVpfFeatureClass::theTableName1
private
Definition at line 85 of file ossimVpfFeatureClass.h.
◆ theTableName2
ossimFilename ossimVpfFeatureClass::theTableName2
private
Definition at line 87 of file ossimVpfFeatureClass.h.
