#include <ossimWebResponse.h>
Public Types | |
typedef std::vector< char > | ByteBuffer |
ossimWebResponse () | |
virtual std::istream * | getInputStream ()=0 |
This might have to change in the future if we start doing other protocols such as ftp scp, ... More... | |
void | copyAllDataFromInputStream (ByteBuffer &buffer) |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimObject * | dup () const |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual ossimString | getDescription () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=0) |
virtual std::ostream & | print (std::ostream &out) const |
Generic print method. More... | |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
virtual void | accept (ossimVisitor &visitor) |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
Public Attributes | |
TYPE_DATA | |
virtual | ~ossimReferenced () |
Definition at line 7 of file ossimWebResponse.h.
typedef std::vector<char> ossimWebResponse::ByteBuffer |
Definition at line 10 of file ossimWebResponse.h.
inline |
Definition at line 11 of file ossimWebResponse.h.
void ossimWebResponse::copyAllDataFromInputStream | ( | ByteBuffer & | buffer | ) |
Definition at line 6 of file ossimWebResponse.cpp.
References getInputStream().
Referenced by ossim::CurlStreamBuffer::loadBlock().
pure virtual |
etc.
We currently will return the main input stream that can be used to read the bytes returned from the request. If you need access to say a header stream from an http protocol then you can dynamic_cast to an ossimHttpResponse.
Implemented in ossimHttpResponse.
Referenced by copyAllDataFromInputStream().
ossimWebResponse::TYPE_DATA |
Definition at line 25 of file ossimWebResponse.h.
