Public Member Functions | Public Attributes | List of all members
ossim::BlockBufInfo Class Reference
This is a utility class used by the BlockStreamBuffer. More...
#include <BlockStreamBuffer.h>
 BlockBufInfo ()
ossim_int64 getBlockIndex (ossim_int64 pos)
 Returns the index of a block. More...
bool isWithinWindow (ossim_int64 pos) const
 This just tests if the given abolute position is within a block window. More...
bool isWithinValidWindow (ossim_int64 pos) const
 This just tests if the given abolute position is within a valid window. More...
ossim_int64 getEndByte () const
 Convenient method to get the absolute byte position of the end byte. More...
const char * getBufferStart (ossim_int64 absolutePosition) const
 Get the starting address in the buffer of the absolute position. More...
const char * getBuffer () const
char * getBuffer ()
bool isLoaded () const
void setBuffer (char *bufPtr, ossim_uint32 blockSize)
 Will set the buffer and then reset the loaded flag to be false. More...
Public Attributes
ossim_int64 m_startByte
 Is the starting absolute byte offset for the buffer. More...
ossim_int64 m_blockSize
 Is the size of the buffer. More...
ossim_int64 m_validSize
 is the valid size of the buffer. More...
char * m_blockBufferPtr
 Starting address of the block. More...
bool m_blockLoaded
 Variable used to invalidate a block or specify whether the block is loaded. More...
Detailed Description
This class will hold information regarding the block that is currently loaded. It holds the start byte and the valid size and the block size of the buffer. The valid size is used because if we are at the end of a stream we could have a partial block.
Definition at line 18 of file BlockStreamBuffer.h.
◆ BlockBufInfo()
ossim::BlockBufInfo::BlockBufInfo ( )
inline
Definition at line 20 of file BlockStreamBuffer.h.
20  :
21  m_startByte(0),
22  m_blockSize(0),
23  m_validSize(0),
25  m_blockLoaded(false){
26
27  }
bool m_blockLoaded
Member Function Documentation
◆ getBlockIndex()
ossim_int64 ossim::BlockBufInfo::getBlockIndex ( ossim_int64  pos)
inline
Parameters
posIs the aboslute byte position
Returns
The block index for the abosolute position
Definition at line 36 of file BlockStreamBuffer.h.
36  {
37  ossim_int64 result = -1;
38  if(m_blockSize&&m_blockBufferPtr&&(pos>=0))
39  {
40  result = pos/m_blockSize;
41  }
42
43  return result;
44  }
long long ossim_int64
◆ getBuffer() [1/2]
const char* ossim::BlockBufInfo::getBuffer ( ) const
inline
Returns
The starting address of the block buffer
Definition at line 103 of file BlockStreamBuffer.h.
103  {
104  return m_blockBufferPtr;
105  }
◆ getBuffer() [2/2]
inline
Returns
Definition at line 110 of file BlockStreamBuffer.h.
110  {
111  return m_blockBufferPtr;
112  }
◆ getBufferStart()
const char* ossim::BlockBufInfo::getBufferStart ( ossim_int64  absolutePosition) const
inline
Parameters
absolutePositionThe absolute byte position
Returns
The starting address at the aboslute position or 0 if the absolute position is outside the windows
Definition at line 91 of file BlockStreamBuffer.h.
91  {
92  if(isWithinValidWindow(absolutePosition))
93  {
94  return m_blockBufferPtr+(absolutePosition-m_startByte);
95  }
96
97  return 0;
98  }
bool isWithinValidWindow(ossim_int64 pos) const
◆ getEndByte()
ossim_int64 ossim::BlockBufInfo::getEndByte ( ) const
inline
Returns
Definition at line 80 of file BlockStreamBuffer.h.
80  {
81  if(m_validSize>=0) return m_startByte+(m_validSize);
82  return m_startByte;
83  }
◆ isLoaded()
bool ossim::BlockBufInfo::isLoaded ( ) const
inline
Returns
true if the the block is valid and loaded or false otherwise.
Definition at line 118 of file BlockStreamBuffer.h.
118 {return m_blockLoaded;}
bool m_blockLoaded
◆ isWithinValidWindow()
bool ossim::BlockBufInfo::isWithinValidWindow ( ossim_int64  pos) const
inline
A valid window represents partial blocks.
Parameters
posAbsolute position
Returns
true if we are inside the defined window and false otherwise.
Definition at line 68 of file BlockStreamBuffer.h.
68  {
69  return (m_blockLoaded&&
70  (pos>=m_startByte)&&
71  (pos<getEndByte()));
72  }
bool m_blockLoaded
ossim_int64 getEndByte() const
◆ isWithinWindow()
bool ossim::BlockBufInfo::isWithinWindow ( ossim_int64  pos) const
inline
We will usually call
See also
isWithinValidWindow.
Parameters
Returns
Definition at line 54 of file BlockStreamBuffer.h.
54  {
55  return (m_blockLoaded&&
56  (pos>=m_startByte)&&
57  (pos<(m_startByte+m_blockSize)));
58  }
bool m_blockLoaded
◆ setBuffer()
void ossim::BlockBufInfo::setBuffer ( char *  bufPtr,
inline
Parameters
bufPtris the starting address of the block buffer
blockSizeis the size of the buffer
Definition at line 127 of file BlockStreamBuffer.h.
128  {
129  m_blockBufferPtr = bufPtr;
130  m_blockSize = blockSize;
131  m_blockLoaded = false;
132  }
bool m_blockLoaded
Member Data Documentation
◆ m_blockBufferPtr
char* ossim::BlockBufInfo::m_blockBufferPtr
This is not managed by this class and will not be deleted.
Definition at line 155 of file BlockStreamBuffer.h.
Referenced by ossim::BlockStreamBuffer::BlockStreamBuffer().
◆ m_blockLoaded
bool ossim::BlockBufInfo::m_blockLoaded
Definition at line 160 of file BlockStreamBuffer.h.
◆ m_blockSize
ossim_int64 ossim::BlockBufInfo::m_blockSize
Definition at line 142 of file BlockStreamBuffer.h.
◆ m_startByte
ossim_int64 ossim::BlockBufInfo::m_startByte
Definition at line 137 of file BlockStreamBuffer.h.
◆ m_validSize
ossim_int64 ossim::BlockBufInfo::m_validSize
In most cases this is equal to the blockSize but if at the end of a stream you could have a partial buffer.
Definition at line 149 of file BlockStreamBuffer.h.
The documentation for this class was generated from the following file:
