Public Member Functions | Public Attributes | List of all members
ossim::BlockIStream Class Reference
Allows one to adapt any input stream to be block aligned for any read it will internally read overlapping blocks filling the request. More...
#include <BlockIStream.h>
Inheritance diagram for ossim::BlockIStream:
 BlockIStream (std::shared_ptr< ossim::istream > adaptStream, ossim_uint64 blockSize=4096)
 Constructor must be initialized with an inputstream. More...
virtual ~BlockIStream ()
 Destructor will set any shared pointer to 0. More...
Public Attributes
std::shared_ptr< ossim::istreamm_adaptStream
 Maintain a shared pointer to the stream we are adapting to be block aligned. More...
BlockStreamBuffer m_blockStreamBuffer
 The buffer where all the block align implementation resides. More...
Detailed Description
Example:
ossim_uint64 blockSize = 4096
std::shared_ptr<ossim::BlockReader> reader = std::make_shared<ossim::BlockReader>(streamToAdapt, blockSize)
reader->seekg(10);
reader->read(buf, 100);
This will read a block of data from 0-4095 and then fill the buffer with 100 bytes of data.
if another call to: reader->read(buf, 10) it will not reload the block but instead read from memory
Definition at line 29 of file BlockIStream.h.
◆ BlockIStream() [1/2]
ossim::BlockIStream::BlockIStream ( std::shared_ptr< ossim::istream adaptStream,
inline
Parameters
adaptStreamCurrenlty a required parameter and is initialized on construction. Takes an input istream to force block aligned requests
blockSizeSpecify the block size to use
Definition at line 40 of file BlockIStream.h.
41  :
43  m_adaptStream(adaptStream),
44  m_blockStreamBuffer(adaptStream.get(), blockSize)
45  {
46  }
std::shared_ptr< ossim::istream > m_adaptStream
Definition: BlockIStream.h:59
std::basic_istream< char > istream
Base class for char input streams.
Definition: ossimIosFwd.h:20
Definition: BlockIStream.h:66
◆ ~BlockIStream() [1/2]
virtual ossim::BlockIStream::~BlockIStream ( )
inlinevirtual
Definition at line 51 of file BlockIStream.h.
References m_adaptStream.
51  {
52  m_adaptStream = 0;
53  }
◆ BlockIStream() [2/2]
inline
Parameters
Definition at line 40 of file ossimBlockIStream.h.
41  :
45  {
46  }
◆ ~BlockIStream() [2/2]
inlinevirtual
Definition at line 51 of file ossimBlockIStream.h.
51  {
53  }
Member Data Documentation
◆ m_adaptStream
std::shared_ptr< ossim::istream > ossim::BlockIStream::m_adaptStream
Definition at line 59 of file BlockIStream.h.
Referenced by ~BlockIStream().
◆ m_blockStreamBuffer
BlockStreamBuffer ossim::BlockIStream::m_blockStreamBuffer
Definition at line 66 of file BlockIStream.h.
