Public Types | Public Member Functions | Static Public Member Functions | Protected Member Functions | Protected Attributes | Static Protected Attributes | List of all members
ossim::CurlHeaderCache Class Reference
#include <CurlHeaderCache.h>
Public Types
typedef std::shared_ptr< CurlHeaderCacheNodeNode_t
typedef std::string Key_t
typedef ossim_int64 TimeIndex_t
typedef std::map< Key_t, Node_tCacheType
typedef std::map< TimeIndex_t, Key_tCacheTimeIndexType
 CurlHeaderCache ()
virtual ~CurlHeaderCache ()
bool getCachedFilesize (const Key_t &key, ossim_int64 &filesize) const
void addHeader (const Key_t &key, Node_t &node)
void setMaxCacheEntries (ossim_int64 maxEntries)
void touchEntry (const Key_t &key)
static std::shared_ptr< CurlHeaderCacheinstance ()
void shrinkEntries ()
void touchEntryProtected (const Key_t &key)
std::mutex m_mutex
CacheType m_cache
CacheTimeIndexType m_cacheTime
ossim_int64 m_maxCacheEntries
static std::shared_ptr< CurlHeaderCachem_instance
Detailed Description
Definition at line 27 of file CurlHeaderCache.h.
Member Typedef Documentation
◆ CacheTimeIndexType
Definition at line 34 of file CurlHeaderCache.h.
◆ CacheType
Definition at line 33 of file CurlHeaderCache.h.
◆ Key_t
typedef std::string ossim::CurlHeaderCache::Key_t
Definition at line 31 of file CurlHeaderCache.h.
◆ Node_t
Definition at line 30 of file CurlHeaderCache.h.
◆ TimeIndex_t
Definition at line 32 of file CurlHeaderCache.h.
◆ CurlHeaderCache()
ossim::CurlHeaderCache::CurlHeaderCache ( )
Definition at line 7 of file CurlHeaderCache.cpp.
◆ ~CurlHeaderCache()
ossim::CurlHeaderCache::~CurlHeaderCache ( )
virtual
Definition at line 13 of file CurlHeaderCache.cpp.
14 {
15  m_cache.clear();
16 }
Member Function Documentation
◆ addHeader()
void ossim::CurlHeaderCache::addHeader ( const Key_t key,
Node_t node
Definition at line 49 of file CurlHeaderCache.cpp.
References ossimTimer::instance(), and ossimTimer::tick().
50 {
51  std::unique_lock<std::mutex> lock(m_mutex);
52  if(m_maxCacheEntries<=0) return;
53  CacheType::const_iterator iter = m_cache.find(key);
54  if(iter != m_cache.end())
55  {
56  iter->second->m_filesize = node->m_filesize;
58  }
59  else
60  {
61  if(m_cache.size() >= m_maxCacheEntries)
62  {
63  shrinkEntries();
64  }
65  node->m_timestamp = ossimTimer::instance()->tick();
66  m_cache.insert( std::make_pair(key, node) );
67  m_cacheTime.insert( std::make_pair(node->m_timestamp, key) );
68  }
69 }
static ossimTimer * instance()
Definition: ossimTimer.cpp:19
void touchEntryProtected(const Key_t &key)
Timer_t tick() const
Get the timers tick value.
Definition: ossimTimer.cpp:95
◆ getCachedFilesize()
bool ossim::CurlHeaderCache::getCachedFilesize ( const Key_t key,
ossim_int64 filesize
) const
Definition at line 28 of file CurlHeaderCache.cpp.
References touchEntryProtected().
29 {
30  std::unique_lock<std::mutex> lock(m_mutex);
31  bool result = false;
32  if(m_maxCacheEntries<=0) return result;
33  CacheType::const_iterator iter = m_cache.find(key);
34
35  if(iter != m_cache.end())
36  {
37  filesize = iter->second->m_filesize;
38  result = true;
39  }
40  if(result)
41  {
42  ossim::CurlHeaderCache* curlHeaderConstPtr = const_cast<ossim::CurlHeaderCache*>(this);
43  curlHeaderConstPtr->touchEntryProtected(key);
44  }
45
46  return result;
47 }
◆ instance()
std::shared_ptr< ossim::CurlHeaderCache > ossim::CurlHeaderCache::instance ( )
static
Definition at line 18 of file CurlHeaderCache.cpp.
19 {
20  if(!m_instance)
21  {
22  m_instance = std::make_shared<CurlHeaderCache>();
23  }
24
25  return m_instance;
26 }
static std::shared_ptr< CurlHeaderCache > m_instance
◆ setMaxCacheEntries()
void ossim::CurlHeaderCache::setMaxCacheEntries ( ossim_int64  maxEntries)
◆ shrinkEntries()
void ossim::CurlHeaderCache::shrinkEntries ( )
protected
Definition at line 96 of file CurlHeaderCache.cpp.
97 {
98  ossim_int64 targetSize = static_cast<ossim_int64>(0.2*m_maxCacheEntries);
99
100  if(m_cacheTime.empty()) return;
101  if(targetSize >= m_cache.size())
102  {
103  m_cache.clear();
104  m_cacheTime.clear();
105  return;
106  }
107
108  CacheTimeIndexType::iterator iter = m_cacheTime.begin();
109
110  while(targetSize > 0)
111  {
112  m_cache.erase(iter->second);
113  iter = m_cacheTime.erase(iter);
114  --targetSize;
115  }
116 }
long long ossim_int64
◆ touchEntry()
void ossim::CurlHeaderCache::touchEntry ( const Key_t key)
Definition at line 71 of file CurlHeaderCache.cpp.
72 {
73  // I think unique lock is recursive but need to test first
74  // So for now we will wrap with a touchEntryProtected that does not lock
75  // so all public methods are locking.
76  //
77  std::unique_lock<std::mutex> lock(m_mutex);
79 }
◆ touchEntryProtected()
void ossim::CurlHeaderCache::touchEntryProtected ( const Key_t key)
protected
Definition at line 81 of file CurlHeaderCache.cpp.
Referenced by getCachedFilesize().
82 {
83  CacheType::iterator iter = m_cache.find(key);
84  if(iter!=m_cache.end())
85  {
86  CacheTimeIndexType::iterator cacheTimeIter = m_cacheTime.find(iter->second->m_timestamp);
87  if(cacheTimeIter!=m_cacheTime.end())
88  {
89  m_cacheTime.erase(cacheTimeIter);
90  iter->second->m_timestamp = ossimTimer::instance()->tick();
91  m_cacheTime.insert( std::make_pair(iter->second->m_timestamp, key) );
92  }
93  }
94 }
Member Data Documentation
◆ m_cache
CacheType ossim::CurlHeaderCache::m_cache
protected
Definition at line 52 of file CurlHeaderCache.h.
◆ m_cacheTime
CacheTimeIndexType ossim::CurlHeaderCache::m_cacheTime
protected
Definition at line 53 of file CurlHeaderCache.h.
◆ m_instance
std::shared_ptr< ossim::CurlHeaderCache > ossim::CurlHeaderCache::m_instance
staticprotected
Definition at line 49 of file CurlHeaderCache.h.
◆ m_maxCacheEntries
ossim_int64 ossim::CurlHeaderCache::m_maxCacheEntries
protected
Definition at line 54 of file CurlHeaderCache.h.
◆ m_mutex
std::mutex ossim::CurlHeaderCache::m_mutex
mutableprotected
Definition at line 50 of file CurlHeaderCache.h.
