Public Member Functions | Static Public Member Functions | Protected Member Functions | Static Protected Attributes | List of all members
ossim::StreamFactory Class Reference
#include <ossimStreamFactory.h>
Inheritance diagram for ossim::StreamFactory:
ossim::StreamFactoryBase
virtual ~StreamFactory ()
virtual std::shared_ptr< ossim::istreamcreateIstream (const std::string &connectionString, const ossimKeywordlist &options=ossimKeywordlist(), std::ios_base::openmode mode=std::ios_base::in|std::ios_base::binary) const
virtual std::shared_ptr< ossim::ostreamcreateOstream (const std::string &connectionString, const ossimKeywordlist &options=ossimKeywordlist(), std::ios_base::openmode mode=std::ios_base::out|std::ios_base::binary) const
virtual std::shared_ptr< ossim::iostreamcreateIOstream (const std::string &connectionString, const ossimKeywordlist &options=ossimKeywordlist(), std::ios_base::openmode mode=std::ios_base::in|std::ios_base::out|std::ios_base::binary) const
virtual bool exists (const std::string &connectionString, bool &continueFlag) const
 Methods to test if connection exists. More...
- Public Member Functions inherited from ossim::StreamFactoryBase
virtual ~StreamFactoryBase ()
static StreamFactoryinstance ()
 StreamFactory ()
 StreamFactory (const StreamFactory &)
static StreamFactorym_instance = 0
Detailed Description
Definition at line 22 of file ossimStreamFactory.h.
◆ ~StreamFactory()
ossim::StreamFactory::~StreamFactory ( )
virtual
Definition at line 33 of file ossimStreamFactory.cpp.
34 {
35 }
◆ StreamFactory() [1/2]
ossim::StreamFactory::StreamFactory ( )
protected
Definition at line 139 of file ossimStreamFactory.cpp.
140 {
141 }
◆ StreamFactory() [2/2]
ossim::StreamFactory::StreamFactory ( const StreamFactory )
protected
Definition at line 144 of file ossimStreamFactory.cpp.
145 {
146 }
Member Function Documentation
◆ createIOstream()
std::shared_ptr< ossim::iostream > ossim::StreamFactory::createIOstream ( const std::string &  connectionString,
const ossimKeywordlist options = ossimKeywordlist(),
std::ios_base::openmode  mode = std::ios_base::in|std::ios_base::out|std::ios_base::binary
) const
virtual
Implements ossim::StreamFactoryBase.
Definition at line 94 of file ossimStreamFactory.cpp.
98 {
99  return std::shared_ptr<ossim::iostream>(0);
100 }
◆ createIstream()
std::shared_ptr< ossim::istream > ossim::StreamFactory::createIstream ( const std::string &  connectionString,
std::ios_base::openmode  mode = std::ios_base::in|std::ios_base::binary
) const
virtual
Definition at line 46 of file ossimStreamFactory.cpp.
References ossimFilename::exists().
50 {
51  std::shared_ptr<ossim::istream> result(0);
52  ossimFilename f = connectionString;
53  if ( f.exists() )
54  {
55  // there is a bug in gcc < 5.0 and we can't use constructors in the
56  // C++11 build. Will refactor to do a new ifstream then use open
57  //
58  std::shared_ptr<ossim::ifstream> testResult =
59  std::make_shared<ossim::ifstream>();
60  testResult->open(connectionString.c_str(), mode);
61  if(!testResult->is_open())
62  {
63  testResult.reset();
64  }
65
66  result = testResult;
67  }
68
69  return result;
70 }
bool exists() const
◆ createOstream()
std::shared_ptr< ossim::ostream > ossim::StreamFactory::createOstream ( const std::string &  connectionString,
std::ios_base::openmode  mode = std::ios_base::out|std::ios_base::binary
) const
virtual
Definition at line 72 of file ossimStreamFactory.cpp.
76 {
77  std::shared_ptr<ossim::ostream> result(0);
78
79  std::shared_ptr<ossim::ofstream> testResult =
80  std::make_shared<ossim::ofstream>();
81  testResult->open(connectionString.c_str(), mode);
82  if ( testResult->is_open() )
83  {
84  result = testResult;
85  }
86  else
87  {
88  testResult.reset();
89  }
90
91  return result;
92 }
◆ exists()
bool ossim::StreamFactory::exists ( const std::string &  connectionString,
bool &  continueFlag
) const
virtual
Parameters
connectionString
continueFlagInitializes by this, if set to false, indicates factory handles file/url and no more factory checks are necessary. If true, connection is not handled by this factory.
Returns
true on success, false, if not.
Definition at line 102 of file ossimStreamFactory.cpp.
References ossimString::downcase(), ossimFilename::OSSIM_EXIST, and ossimString::substr().
103 {
104  bool result = false;
105  if ( connectionString.size() )
106  {
107  std::string file;
108  std::size_t pos = connectionString.find( "://" );
109  if ( pos != std::string::npos )
110  {
111  // is url:
112  ossimString protocol = connectionString.substr( 0, pos );
113  if ( (protocol.downcase() == "file") && ( connectionString.size() > pos+3) )
114  {
115  // Strip off "file://" for access(...) function:
116  file = connectionString.substr( pos+3 );
117  }
118  }
119  else // not a url
120  {
121  file = connectionString;
122  }
123
124  if ( file.size() )
125  {
126  // Set continueFlag to false to stop downstream factory exists checks.
127  continueFlag = false;
128 #if defined(_WIN32)
129  result = (_access(file.c_str(), ossimFilename::OSSIM_EXIST) == 0);
130 #else
131  result = ((access(file.c_str(), ossimFilename::OSSIM_EXIST)) == 0);
132 #endif
133  }
134  }
135  return result;
136 }
std::string substr(std::string::size_type pos=0, std::string::size_type n=std::string::npos) const
Equivalent to basic_string(*this, pos, n).
Definition: ossimString.h:910
◆ instance()
ossim::StreamFactory * ossim::StreamFactory::instance ( )
static
Definition at line 37 of file ossimStreamFactory.cpp.
38 {
39  if(!m_instance)
40  {
42  }
43  return m_instance;
44 }
static StreamFactory * m_instance
Member Data Documentation
◆ m_instance
ossim::StreamFactory * ossim::StreamFactory::m_instance = 0
staticprotected
Definition at line 65 of file ossimStreamFactory.h.
