include
ossim
matrix
include.h
Go to the documentation of this file.
1
//$$ include.h include files required by various versions of C++
2
3
#ifndef INCLUDE_LIB
4
#define INCLUDE_LIB
5
6
#define use_namespace // define name spaces
7
#include <
ossim/base/ossimConstants.h
8
#define SETUP_C_SUBSCRIPTS // allow element access via A[i][j]
9
10
// Activate just one of the following 3 statements
11
12
//#define SimulateExceptions // use simulated exceptions
13
#define UseExceptions // use C++ exceptions
14
//#define DisableExceptions // do not use exceptions
15
16
17
//#define TEMPS_DESTROYED_QUICKLY // for compilers that delete
18
// temporaries too quickly
19
20
//#define TEMPS_DESTROYED_QUICKLY_R // the same thing but applied
21
// to return from functions only
22
23
//#define DO_FREE_CHECK // check news and deletes balance
24
25
#define USING_DOUBLE // elements of type double
26
//#define USING_FLOAT // elements of type float
27
28
#define bool_LIB 0 // for compatibility with my older libraries
29
30
//#define ios_format_flags ios::fmtflags // for Gnu 3 and Intel for Linux
31
32
33
//#define _STANDARD_ // using standard library
34
35
//#define use_float_h // use float.h for precision data
36
37
38
//#define HAS_INT64 // if unsigned _int64 is recognised
39
// used by newran03
40
41
// comment out next line if Exception causes a problem
42
#define TypeDefException
43
44
//*********************** end of options set by user ********************
45
46
#ifdef use_namespace
47
namespace
RBD_COMMON
48
#endif
49
50
51
#ifdef USING_FLOAT // set precision type to float
52
typedef
float
Real
53
typedef
double
long_Real
54
#endif
55
56
#ifdef USING_DOUBLE // set precision type to double
57
typedef
double
Real
58
//typedef long double long_Real;
59
typedef
double
long_Real
60
#endif
61
62
63
64
65
#endif
66
67
68
69
namespace
RBD_COMMON
70
namespace
RBD_LIBRARIES
// access all my libraries
71
72
using namespace
RBD_COMMON
73
74
#endif
75
76
77
#endif
RBD_COMMON::long_Real
double long_Real
Definition:
include.h:59
RBD_COMMON::Real
double Real
Definition:
include.h:57
ossimConstants.h
RBD_LIBRARIES
Definition:
include.h:70
RBD_COMMON
Definition:
include.h:47
Generated on Fri Aug 3 2018 08:46:44 for OSSIM - Open Source Software Image Map by
