13 #ifndef ossimCeosData_HEADER 14 #define ossimCeosData_HEADER
const ossimFilename & leaderFile() const
radi_data_rec radiDataRec
struct pdr8_htab_rec htab
dataset_sum_rec * theDataSetSumRec
struct att_vect_rec att_vect[20]
const pdr8_hist_rec * pdr8HistRec() const
const qual_sum_rec * qualSumRec() const
void dumpSdrHistRec(std::ostream &) const
struct radi_dset_rec dset[1]
struct rad_unc_rec rad_unc[16]
const ossimFilename & trailerFile() const
ossim_int16 sar_chan_code
void dumpPdr16HistRec(std::ostream &) const
radi_comp_rec * theRadiCompRec
struct pos_vect_rec pos_vect[64]
char err_phas_coef[4][16]
void dump(std::ostream &strm=std::clog) const
dataset_sum_rec dataSetSumRec
ossimReferenced allows for shared object ref counting if the reference count ever gets to 0 or less i...
struct dopcen_est_rec dopcen_est[20]
struct misreg_rec misreg[16]
pdr8_hist_rec pdr8HistRec
const att_data_rec * attDataRec() const
const imop_desc_rec * imopDescRec() const
pos_data_rec * thePosDataRec
void dumpDataSetSumRec(std::ostream &) const
map_proj_rec * theMapProjRec
ossimFilename theLeaderFileName
pdr8_hist_rec * thePdr8HistRec
void dumpQualSumRec(std::ostream &) const
radi_data_rec * theRadiDataRec
struct srgr_coefset_rec srgr_coefset[20]
const radi_data_rec * radiDataRec() const
struct acq_date_rec acq_date
const ossimFilename & imageFile() const
SarTrailerFile theSarTrailerFile
char utm_stand_par[2][16]
void dumpVolDescRec(std::ostream &) const
proc_parm_rec * theProcParmRec
const pdr16_hist_rec * pdr16HistRec() const
ossimFilename theVolDirFileName
struct sdr_prefix_rec prefix
void dumpPosDataRec(std::ostream &) const
void dumpRadiCompRec(std::ostream &) const
ossim_int32 sizeOfNextRec(FILE *)
const sdr_hist_rec * sdrHistRec() const
char aux_datum_shift[3][16]
pdr16_hist_rec pdr16HistRec
void dumpTextRec(std::ostream &) const
const text_rec * textRec() const
void dumpPdr8HistRec(std::ostream &) const
att_data_rec * theAttDataRec
char rng_phas_coef[4][16]
void dumpRadiDataRec(std::ostream &) const
file_pntr_rec imageOptionsFilePntrRec
imop_desc_rec theImopDescRec
char nsp_stand_par[4][16]
const pos_data_rec * posDataRec() const
vol_desc_rec * theVolDescRec
void dumpImopDescRec(std::ostream &) const
void dumpProcParmRec(std::ostream &) const
file_pntr_rec leaderFilePntrRec
struct comp_dset_rec dset[4]
struct pix_count_rec pix_count[20]
file_pntr_rec trailerFilePntrRec
proc_parm_rec procParmRec
pdr16_hist_rec * thePdr16HistRec
char nsp_stand_mer[3][16]
radi_comp_rec radiCompRec
ossim_int32 n_right_pixel
char slow_time_coef[5][22]
const proc_parm_rec * procParmRec() const
char img_cumu_dist[3][16]
VolumeDirectoryFile theVolumeDirectory
ossimCeosData(const ossimFilename &volDirFile, const ossimFilename &leaderFile, const ossimFilename &imageFile, const ossimFilename &trailerFile)
ossimFilename theImageFileName
qual_sum_rec * theQualSumRec
void dumpAttDataRec(std::ostream &) const
const dataset_sum_rec * dataSetSumRec() const
SarLeaderFile theSarLeaderFile
char num_state_vectors[4]
const ossimFilename & volDirFile() const
struct pdr16_htab_rec htab[2]
const radi_comp_rec * radiCompRec() const
unsigned char ossim_uint8
std::basic_ostream< char > ostream
Base class for char output streams.
struct pdr_prefix_rec prefix
struct beam_info_rec beam_info[4]
const map_proj_rec * mapProjRec() const
void dumpMapProjRec(std::ostream &) const
ossimFilename theTrailerFileName
const vol_desc_rec * volDescRec() const
sdr_hist_rec * theSdrHistRec
