ossimEbcdicToAscii.cpp
Go to the documentation of this file.
1 //----------------------------------------------------------------------------
2 //
3 // License: See top level LICENSE.txt file.
4 //
5 // Author: David Burken
6 //
7 // Description: Utility class to convert to/from EBCDIC/ASCII
8 //
9 // ASCII = American National Standard Code for Information Interchange
10 //
11 // EBCDIC = Extended Binary Coded Decimal Interchange Code
12 //
13 // $Id: ossimEbcdicToAscii.cpp 9094 2006-06-13 19:12:40Z dburken $
14 //----------------------------------------------------------------------------
16
17 static const ossim_uint8 a2e[] =
18 {
19  0x00, 0x01, 0x02, 0x03, 0x37, 0x2d, 0x2e, 0x2f,
20  0x16, 0x05, 0x25, 0x0b, 0x0c, 0x0d, 0x0e, 0x0f,
21  0x10, 0x11, 0x12, 0x13, 0x3c, 0x3d, 0x32, 0x26,
22  0x18, 0x19, 0x3f, 0x27, 0x1c, 0x1d, 0x1e, 0x1f,
23  0x40, 0x4f, 0x7f, 0x7b, 0x5b, 0x6c, 0x50, 0x7d,
24  0x4d, 0x5d, 0x5c, 0x4e, 0x6b, 0x60, 0x4b, 0x61,
25  0xf0, 0xf1, 0xf2, 0xf3, 0xf4, 0xf5, 0xf6, 0xf7,
26  0xf8, 0xf9, 0x7a, 0x5e, 0x4c, 0x7e, 0x6e, 0x6f,
27  0x7c, 0xc1, 0xc2, 0xc3, 0xc4, 0xc5, 0xc6, 0xc7,
28  0xc8, 0xc9, 0xd1, 0xd2, 0xd3, 0xd4, 0xd5, 0xd6,
29  0xd7, 0xd8, 0xd9, 0xe2, 0xe3, 0xe4, 0xe5, 0xe6,
30  0xe7, 0xe8, 0xe9, 0x4a, 0xe0, 0x5a, 0x5f, 0x6d,
31  0x79, 0x81, 0x82, 0x83, 0x84, 0x85, 0x86, 0x87,
32  0x88, 0x89, 0x91, 0x92, 0x93, 0x94, 0x95, 0x96,
33  0x97, 0x98, 0x99, 0xa2, 0xa3, 0xa4, 0xa5, 0xa6,
34  0xa7, 0xa8, 0xa9, 0xc0, 0x6a, 0xd0, 0xa1, 0x07,
35  0x20, 0x21, 0x22, 0x23, 0x24, 0x15, 0x06, 0x17,
36  0x28, 0x29, 0x2a, 0x2b, 0x2c, 0x09, 0x0a, 0x1b,
37  0x30, 0x31, 0x1a, 0x33, 0x34, 0x35, 0x36, 0x08,
38  0x38, 0x39, 0x3a, 0x3b, 0x04, 0x14, 0x3e, 0xe1,
39  0x41, 0x42, 0x43, 0x44, 0x45, 0x46, 0x47, 0x48,
40  0x49, 0x51, 0x52, 0x53, 0x54, 0x55, 0x56, 0x57,
41  0x58, 0x59, 0x62, 0x63, 0x64, 0x65, 0x66, 0x67,
42  0x68, 0x69, 0x70, 0x71, 0x72, 0x73, 0x74, 0x75,
43  0x76, 0x77, 0x78, 0x80, 0x8a, 0x8b, 0x8c, 0x8d,
44  0x8e, 0x8f, 0x90, 0x9a, 0x9b, 0x9c, 0x9d, 0x9e,
45  0x9f, 0xa0, 0xaa, 0xab, 0xac, 0xad, 0xae, 0xaf,
46  0xb0, 0xb1, 0xb2, 0xb3, 0xb4, 0xb5, 0xb6, 0xb7,
47  0xb8, 0xb9, 0xba, 0xbb, 0xbc, 0xbd, 0xbe, 0xbf,
48  0xca, 0xcb, 0xcc, 0xcd, 0xce, 0xcf, 0xda, 0xdb,
49  0xdc, 0xdd, 0xde, 0xdf, 0xea, 0xeb, 0xec, 0xed,
50  0xee, 0xef, 0xfa, 0xfb, 0xfc, 0xfd, 0xfe, 0xff
51 };
52
53 static const ossim_uint8 e2a[] =
54 {
55  0x00, 0x01, 0x02, 0x03, 0x9c, 0x09, 0x86, 0x7f,
56  0x97, 0x8d, 0x8e, 0x0b, 0x0c, 0x0d, 0x0e, 0x0f,
57  0x10, 0x11, 0x12, 0x13, 0x9d, 0x85, 0x08, 0x87,
58  0x18, 0x19, 0x92, 0x8f, 0x1c, 0x1d, 0x1e, 0x1f,
59  0x80, 0x81, 0x82, 0x83, 0x84, 0x0a, 0x17, 0x1b,
60  0x88, 0x89, 0x8a, 0x8b, 0x8c, 0x05, 0x06, 0x07,
61  0x90, 0x91, 0x16, 0x93, 0x94, 0x95, 0x96, 0x04,
62  0x98, 0x99, 0x9a, 0x9b, 0x14, 0x15, 0x9e, 0x1a,
63  0x20, 0xa0, 0xa1, 0xa2, 0xa3, 0xa4, 0xa5, 0xa6,
64  0xa7, 0xa8, 0x5b, 0x2e, 0x3c, 0x28, 0x2b, 0x21,
65  0x26, 0xa9, 0xaa, 0xab, 0xac, 0xad, 0xae, 0xaf,
66  0xb0, 0xb1, 0x5d, 0x24, 0x2a, 0x29, 0x3b, 0x5e,
67  0x2d, 0x2f, 0xb2, 0xb3, 0xb4, 0xb5, 0xb6, 0xb7,
68  0xb8, 0xb9, 0x7c, 0x2c, 0x25, 0x5f, 0x3e, 0x3f,
69  0xba, 0xbb, 0xbc, 0xbd, 0xbe, 0xbf, 0xc0, 0xc1,
70  0xc2, 0x60, 0x3a, 0x23, 0x40, 0x27, 0x3d, 0x22,
71  0xc3, 0x61, 0x62, 0x63, 0x64, 0x65, 0x66, 0x67,
72  0x68, 0x69, 0xc4, 0xc5, 0xc6, 0xc7, 0xc8, 0xc9,
73  0xca, 0x6a, 0x6b, 0x6c, 0x6d, 0x6e, 0x6f, 0x70,
74  0x71, 0x72, 0xcb, 0xcc, 0xcd, 0xce, 0xcf, 0xd0,
75  0xd1, 0x7e, 0x73, 0x74, 0x75, 0x76, 0x77, 0x78,
76  0x79, 0x7a, 0xd2, 0xd3, 0xd4, 0xd5, 0xd6, 0xd7,
77  0xd8, 0xd9, 0xda, 0xdb, 0xdc, 0xdd, 0xde, 0xdf,
78  0xe0, 0xe1, 0xe2, 0xe3, 0xe4, 0xe5, 0xe6, 0xe7,
79  0x7b, 0x41, 0x42, 0x43, 0x44, 0x45, 0x46, 0x47,
80  0x48, 0x49, 0xe8, 0xe9, 0xea, 0xeb, 0xec, 0xed,
81  0x7d, 0x4a, 0x4b, 0x4c, 0x4d, 0x4e, 0x4f, 0x50,
82  0x51, 0x52, 0xee, 0xef, 0xf0, 0xf1, 0xf2, 0xf3,
83  0x5c, 0x9f, 0x53, 0x54, 0x55, 0x56, 0x57, 0x58,
84  0x59, 0x5a, 0xf4, 0xf5, 0xf6, 0xf7, 0xf8, 0xf9,
85  0x30, 0x31, 0x32, 0x33, 0x34, 0x35, 0x36, 0x37,
86  0x38, 0x39, 0xfa, 0xfb, 0xfc, 0xfd, 0xfe, 0xff
87 };
88
90 {
91 }
92
94 {
95 }
96
98 {
99  return a2e[c];
100
101 }
102
104 {
105  return e2a[c];
106 }
107
109 {
110  if (!str) return;
111
112  for (ossim_uint32 i = 0; i < size; ++i)
113  {
114  str[i] =
115  static_cast<char>(ebcdicToAscii(static_cast<ossim_uint8>(str[i])));
116  }
117 }
~ossimEbcdicToAscii()
destructor
yy_size_t size
unsigned int ossim_uint32
default constructor
ossim_uint8 asciiToEbcdic(ossim_uint8 c) const
Converts ascii character c to ebcdic character.
unsigned char ossim_uint8
ossim_uint8 ebcdicToAscii(ossim_uint8 c) const
Converts ebcdic character c to ascii character.
