13 #ifndef ossimLasPointRecord0_HEADER 14 #define ossimLasPointRecord0_HEADER 1
char ossim_int8
Previous DLL import export section.
virtual ossim_uint16 getGreen() const
ossim_uint8 m_classification
virtual ossim_uint16 getIntensity() const
virtual ossim_int32 getX() const
void swap()
Performs a swap if system byte order is not little endian.
ossim_int8 m_scanAngleRank
const ossimLasPointRecord0Data & operator=(const ossimLasPointRecord0Data &obj)
unsigned short ossim_uint16
Container class for LAS point record type 1.
virtual ossim_int32 getY() const
virtual ossim_uint16 getBlue() const
virtual ossim_uint16 getRed() const
virtual ossim_uint8 getEdgeFlag() const
const ossimLasPointRecord0 & operator=(const ossimLasPointRecord0 ©_this)
ossimLasPointRecord0()
default constructor
ossim_uint16 m_pointSourceID
virtual void writeStream(std::ostream &out)
Writes record to stream.
ossimLasPointRecord0Data m_record
std::basic_istream< char > istream
Base class for char input streams.
virtual ossim_uint8 getNumberOfReturns() const
virtual void readStream(std::istream &in)
Initialize record from stream.
OSSIM Interface for LAS point record types.
virtual ossim_uint8 getReturnNumber() const
virtual ossim_int32 getZ() const
virtual ~ossimLasPointRecord0()
destructor
unsigned char ossim_uint8
ossimLasPointRecord0Data()
std::basic_ostream< char > ostream
Base class for char output streams.
