13 #ifndef ossimLasPointRecord2_HEADER 14 #define ossimLasPointRecord2_HEADER 1 virtual ~ossimLasPointRecord2()
destructor
virtual ossim_uint8 getNumberOfReturns() const
ossim_uint8 m_numberOfReturns
char ossim_int8
Previous DLL import export section.
BitFlags(const BitFlags &obj)
ossimLasPointRecord2Data m_record
const ossimLasPointRecord2Data & operator=(const ossimLasPointRecord2Data &obj)
BitFlags(ossim_uint8 value)
ossim_uint8 m_scanDirection
virtual void readStream(std::istream &in)
Initialize record from stream.
unsigned short ossim_uint16
virtual ossim_uint16 getRed() const
ossim_uint8 m_returnNumber
ossim_uint8 m_classification
const BitFlags & operator=(const BitFlags &obj)
virtual ossim_int32 getX() const
virtual ossim_uint8 getEdgeFlag() const
ossim_uint16 m_pointSourceId
virtual void writeStream(std::ostream &out)
Writes record to stream.
virtual ossim_uint16 getBlue() const
ossimLasPointRecord2Data()
virtual ossim_uint8 getReturnNumber() const
virtual ossim_int32 getZ() const
virtual ossim_uint16 getGreen() const
std::basic_istream< char > istream
Base class for char input streams.
virtual ossim_int32 getY() const
void swap()
Performs a swap if system byte order is not little endian.
const ossimLasPointRecord2 & operator=(const ossimLasPointRecord2 ©_this)
virtual ossim_uint16 getIntensity() const
ossim_uint8 m_edgeOfFlightLine
OSSIM Interface for LAS point record types.
ossim_int8 m_scanAngleRank
Container class for LAS point record type 2.
default constructor
unsigned char ossim_uint8
std::basic_ostream< char > ostream
Base class for char output streams.
