13 #ifndef ossimLasPointRecord3_HEADER 14 #define ossimLasPointRecord3_HEADER 1 char ossim_int8
Previous DLL import export section.
ossim_uint8 m_scanDirection
const ossimLasPointRecord3 & operator=(const ossimLasPointRecord3 ©_this)
ossim_uint8 m_numberOfReturns
virtual ossim_uint16 getBlue() const
virtual ossim_uint8 getEdgeFlag() const
unsigned short ossim_uint16
virtual ossim_uint16 getGreen() const
virtual ossim_int32 getY() const
ossim_uint16 m_pointSourceId
ossimLasPointRecord3()
default constructor
const ossimLasPointRecord3Data & operator=(const ossimLasPointRecord3Data &obj)
ossimLasPointRecord3Data()
BitFlags(ossim_uint8 value)
virtual ~ossimLasPointRecord3()
destructor
virtual ossim_uint16 getRed() const
Container class for LAS point record type 3.
const BitFlags & operator=(const BitFlags &obj)
std::basic_istream< char > istream
Base class for char input streams.
ossimLasPointRecord3Data m_record
ossim_uint8 m_edgeOfFlightLine
virtual ossim_int32 getX() const
virtual ossim_uint8 getReturnNumber() const
virtual ossim_uint8 getNumberOfReturns() const
virtual void readStream(std::istream &in)
Initialize record from stream.
ossim_uint8 m_classification
virtual ossim_int32 getZ() const
void swap()
Performs a swap if system byte order is not little endian.
OSSIM Interface for LAS point record types.
ossim_int8 m_scanAngleRank
virtual ossim_uint16 getIntensity() const
BitFlags(const BitFlags &obj)
virtual void writeStream(std::ostream &out)
Writes record to stream.
unsigned char ossim_uint8
std::basic_ostream< char > ostream
Base class for char output streams.
ossim_uint8 m_returnNumber
