4 #ifndef ossimNitfRsmpcaTag_HEADER 5 #define ossimNitfRsmpcaTag_HEADER 1 36 virtual void clearFields();
39 const std::string& prefix=std::string() )
const;
79 char m_iid[IID_SIZE+1];
80 char m_edition[EDITION_SIZE+1];
81 char m_rsn[RSN_SIZE+1];
82 char m_csn[CSN_SIZE+1];
83 char m_rfep[FLOAT21_SIZE+1];
84 char m_cfep[FLOAT21_SIZE+1];
85 char m_rnrmo[FLOAT21_SIZE+1];
86 char m_cnrmo[FLOAT21_SIZE+1];
87 char m_xnrmo[FLOAT21_SIZE+1];
88 char m_ynrmo[FLOAT21_SIZE+1];
89 char m_znrmo[FLOAT21_SIZE+1];
90 char m_rnrmsf[FLOAT21_SIZE+1];
91 char m_cnrmsf[FLOAT21_SIZE+1];
92 char m_xnrmsf[FLOAT21_SIZE+1];
93 char m_ynrmsf[FLOAT21_SIZE+1];
94 char m_znrmsf[FLOAT21_SIZE+1];
96 char m_rnpwrx[MAXPOWER_SIZE+1];
97 char m_rnpwry[MAXPOWER_SIZE+1];
98 char m_rnpwrz[MAXPOWER_SIZE+1];
99 char m_rntrms[NUMTERMS_SIZE+1];
102 char m_rdpwrx[MAXPOWER_SIZE+1];
103 char m_rdpwry[MAXPOWER_SIZE+1];
104 char m_rdpwrz[MAXPOWER_SIZE+1];
105 char m_rdtrms[NUMTERMS_SIZE+1];
108 char m_cnpwrx[MAXPOWER_SIZE+1];
109 char m_cnpwry[MAXPOWER_SIZE+1];
110 char m_cnpwrz[MAXPOWER_SIZE+1];
111 char m_cntrms[NUMTERMS_SIZE+1];
114 char m_cdpwrx[MAXPOWER_SIZE+1];
115 char m_cdpwry[MAXPOWER_SIZE+1];
116 char m_cdpwrz[MAXPOWER_SIZE+1];
117 char m_cdtrms[NUMTERMS_SIZE+1];
std::vector< ossimString > m_rnpcf
std::vector< ossimString > m_cdpcf
std::vector< ossimString > m_cnpcf
virtual void writeStream(ossim::ostream &out)=0
virtual void parseStream(ossim::istream &in)=0
This will allow the user defined data to parse the stream.
ossim_uint32 m_rowDenNumTerms
virtual std::ostream & print(std::ostream &out, const std::string &prefix=std::string()) const
Pure virtual print method that outputs a key/value type format adding prefix to keys.
unsigned int ossim_uint32
ossim_uint32 m_colDenNumTerms
ossim_uint32 m_colNumNumTerms
std::basic_istream< char > istream
Base class for char input streams.
RSM Polynomial Coefficients: Polynomials coefficients for a section.
std::vector< ossimString > m_rdpcf
ossim_uint32 m_rowNumNumTerms
std::basic_ostream< char > ostream
Base class for char output streams.
