src
vec
ossimVpfDatabaseHeaderTableValidator.cpp
Go to the documentation of this file.
1
2
// License: LGPL
3
4
// See LICENSE.txt file in the top level directory for more details.
5
6
#include <
ossim/vec/ossimVpfDatabaseHeaderTableValidator.h
7
#include <
ossim/vec/ossimVpfTable.h
8
9
ossimVpfDatabaseHeaderTableValidator::~ossimVpfDatabaseHeaderTableValidator
10
11
12
13
bool
ossimVpfDatabaseHeaderTableValidator::isValid
ossimVpfTable
& aTable)
const
14
15
// make sure the table is not null
16
if
(&aTable == NULL)
17
18
return
false
19
20
21
// and make sure that the table is not closed
22
if
(aTable.
isClosed
23
24
return
false
25
26
27
// get the table data defined in vpf_util/vpftable.h"
28
const
vpf_table_type
* data = aTable.
getVpfTableData
29
30
if
(!data)
31
32
return
false
33
34
35
// if the file is not open then we can't validate
36
if
(!data->
fp
37
38
return
false
39
40
41
// The way that we will validate is to see if the columns of a dht
42
// exist. if the column didn't exist then the position
43
// will be negative
44
long
column =
table_pos
"ID"
, *data);
45
if
(column < 0)
46
47
return
false
48
49
column =
table_pos
"VPF_VERSION"
, *data);
50
if
(column < 0)
51
52
return
false
53
54
column =
table_pos
"DATABASE_NAME"
, *data);
55
if
(column < 0)
56
57
return
false
58
59
column =
table_pos
"DATABASE_DESC"
, *data);
60
if
(column < 0)
61
62
return
false
63
64
column =
table_pos
"MEDIA_STANDARD"
, *data);
65
if
(column < 0)
66
67
return
false
68
69
column =
table_pos
"ORIGINATOR"
, *data);
70
if
(column < 0)
71
72
return
false
73
74
column =
table_pos
"ADDRESSEE"
, *data);
75
if
(column < 0)
76
77
return
false
78
79
column =
table_pos
"MEDIA_VOLUMES"
, *data);
80
if
(column < 0)
81
82
return
false
83
84
column =
table_pos
"SEQ_NUMBERS"
, *data);
85
if
(column < 0)
86
87
return
false
88
89
column =
table_pos
"NUM_DATA_SETS"
, *data);
90
if
(column < 0)
91
92
return
false
93
94
column =
table_pos
"SECURITY_CLASS"
, *data);
95
if
(column < 0)
96
97
return
false
98
99
column =
table_pos
"DOWNGRADING"
, *data);
100
if
(column < 0)
101
102
return
false
103
104
column =
table_pos
"DOWNGRADE_DATE"
, *data);
105
if
(column < 0)
106
107
return
false
108
109
column =
table_pos
"RELEASABILITY"
, *data);
110
if
(column < 0)
111
112
return
false
113
114
column =
table_pos
"TRANSMITTAL_ID"
, *data);
115
if
(column < 0)
116
117
return
false
118
119
column =
table_pos
"EDITION_NUMBER"
, *data);
120
if
(column < 0)
121
122
return
false
123
124
column =
table_pos
"EDITION_DATE"
, *data);
125
if
(column < 0)
126
127
return
false
128
129
130
return
true
131
132
vpf_table_type::fp
FILE * fp
Definition:
vpftable.h:113
table_pos
ossim_int32 table_pos(const char *field_name, vpf_table_type table)
ossimVpfTable::isClosed
virtual bool isClosed() const
Definition:
ossimVpfTable.cpp:103
virtual ~ossimVpfDatabaseHeaderTableValidator()
Definition:
ossimVpfDatabaseHeaderTableValidator.cpp:9
vpf_table_type
Definition:
vpftable.h:103
ossimVpfTable
Definition:
ossimVpfTable.h:22
ossimVpfTable::getVpfTableData
vpf_table_type * getVpfTableData()
Definition:
ossimVpfTable.h:61
virtual bool isValid(ossimVpfTable &aTable) const
Definition:
ossimVpfDatabaseHeaderTableValidator.cpp:13
ossimVpfTable.h
Generated on Fri Aug 3 2018 08:46:54 for OSSIM - Open Source Software Image Map by
