progress.h
Go to the documentation of this file.
1 /* Copyright (C) 2001-2015 Peter Selinger.
2  This file is part of Potrace. It is free software and it is covered
3  by the GNU General Public License. See the file COPYING for details. */
4
5 /* operations on potrace_progress_t objects, which are defined in
6  potracelib.h. Note: the code attempts to minimize runtime overhead
7  when no progress monitoring was requested. It also tries to
8  minimize excessive progress calculations beneath the "epsilon"
9  threshold. */
10
11 #ifndef PROGRESS_H
12 #define PROGRESS_H
13
14 /* structure to hold progress bar callback data */
15 struct progress_s {
16  void (*callback)(double progress, void *privdata); /* callback fn */
17  void *data; /* callback function's private data */
18  double min, max; /* desired range of progress, e.g. 0.0 to 1.0 */
19  double epsilon; /* granularity: can skip smaller increments */
20  double b; /* upper limit of subrange in superrange units */
21  double d_prev; /* previous value of d */
22 };
23 typedef struct progress_s progress_t;
24
25 /* notify given progress object of current progress. Note that d is
26  given in the 0.0-1.0 range, which will be scaled and translated to
27  the progress object's range. */
28 static inline void progress_update(double d, progress_t *prog) {
29  double d_scaled;
30
31  if (prog != NULL && prog->callback != NULL) {
32  d_scaled = prog->min * (1-d) + prog->max * d;
33  if (d == 1.0 || d_scaled >= prog->d_prev + prog->epsilon) {
34  prog->callback(prog->min * (1-d) + prog->max * d, prog->data);
35  prog->d_prev = d_scaled;
36  }
37  }
38 }
39
40 /* start a subrange of the given progress object. The range is
41  narrowed to [a..b], relative to 0.0-1.0 coordinates. If new range
42  is below granularity threshold, disable further subdivisions. */
43 static inline void progress_subrange_start(double a, double b, const progress_t *prog, progress_t *sub) {
44  double min, max;
45
46  if (prog == NULL || prog->callback == NULL) {
47  sub->callback = NULL;
48  return;
49  }
50
51  min = prog->min * (1-a) + prog->max * a;
52  max = prog->min * (1-b) + prog->max * b;
53
54  if (max - min < prog->epsilon) {
55  sub->callback = NULL; /* no further progress info in subrange */
56  sub->b = b;
57  return;
58  }
59  sub->callback = prog->callback;
60  sub->data = prog->data;
61  sub->epsilon = prog->epsilon;
62  sub->min = min;
63  sub->max = max;
64  sub->d_prev = prog->d_prev;
65  return;
66 }
67
68 static inline void progress_subrange_end(progress_t *prog, progress_t *sub) {
69  if (prog != NULL && prog->callback != NULL) {
70  if (sub->callback == NULL) {
71  progress_update(sub->b, prog);
72  } else {
73  prog->d_prev = sub->d_prev;
74  }
75  }
76 }
77
78 #endif /* PROGRESS_H */
79
double b
Definition: progress.h:20
double max
Definition: progress.h:18
double d_prev
Definition: progress.h:21
double min
void * data
Definition: progress.h:17
void(* callback)(double progress, void *privdata)
Definition: progress.h:16
if(yy_init)
double epsilon
Definition: progress.h:19
#define max(a, b)
Definition: auxiliary.h:76
#define min(a, b)
Definition: auxiliary.h:75
