vpfio.h
Go to the documentation of this file.
1 /* SCCS_ID[] = @(#) vpfio.h 1.6 8/13/91 */
2
3 /* ========================================================================
4
5  Environmental Systems Research Institute (ESRI) Applications Programming
6
7  Project: Conversion from ARC/INFO to VPF
8  Original Coding: David Flinn July 1991
9  Modifications:
10
11  ======================================================================== */
12
13 #ifndef _VPF_IO_
14 #define _VPF_IO_
15
16 #include <stdio.h>
17 #ifdef __cplusplus
18 extern "C" {
19 #endif
21 /* These are all the metacharacters used to parse out input text files */
22
23 #define COMPONENT_SEPERATOR ';'
24 #define LINE_CONTINUE '\\'
25 #define SPACE ' '
26 #define TEXT_NULL "-"
27 #define COMMENT_CHAR '"'
28 #define FIELD_COUNT '='
29 #define FIELD_SEPERATOR ','
30 #define END_OF_FIELD ':'
31 #define FIELD_PARTITION '^'
32 #define NEXT_ELEMENT '|'
33 #define COMMENT '#'
34 #define NEW_LINE '\n'
35 #define VARIABLE_COUNT '*'
36 #define TAB '\t'
37
38 /* Now set up the macros to read in data from disk and to write */
39
40 /* #if __MSDOS__ */
41 #if 0
42
43 #define Read_Vpf_Char(tobuffer,fromtable,count)\
44  fread(tobuffer,sizeof(char),count,fromtable)
45
46 #define Read_Vpf_Short(tobuffer,fromtable,count)\
47  fread(tobuffer,sizeof(short int),count,fromtable)
48
49 #define Read_Vpf_Int(tobuffer,fromtable,count)\
50  fread(tobuffer,sizeof(ossim_int32),count,fromtable)
51
52 #define Read_Vpf_Float(tobuffer,fromtable,count)\
53  fread(tobuffer,sizeof(float),count,fromtable)
54
55 #define Read_Vpf_Double(tobuffer,fromtable,count)\
56  fread(tobuffer,sizeof(double),count,fromtable)
57
58 #define Read_Vpf_Date(tobuffer,fromtable,count)\
59  fread(tobuffer,sizeof(date_type)-1,count,fromtable)
60
61 #define Read_Vpf_Coordinate(tobuffer,fromtable,count)\
62  fread(tobuffer,sizeof(coordinate_type),count,fromtable)
63
64 #define Read_Vpf_CoordinateZ(tobuffer,fromtable,count)\
65  fread(tobuffer,sizeof(tri_coordinate_type),count,fromtable)
66
67 #define Read_Vpf_DoubleCoordinate(tobuffer,fromtable,count)\
68  fread(tobuffer,sizeof(double_coordinate_type),count,fromtable)
69
70 #define Read_Vpf_DoubleCoordinateZ(tobuffer,fromtable,count)\
71  fread(tobuffer,sizeof(double_tri_coordinate_type), \
72  count,fromtable)
73
74 #define Write_Vpf_Char(tobuffer,fromfile,count)\
75  fwrite(tobuffer,sizeof(char),count,fromfile)
76
77 #define Write_Vpf_Short(tobuffer,fromfile,count)\
78  fwrite(tobuffer,sizeof(short int),count,fromfile)
79
80 #define Write_Vpf_Int(tobuffer,fromfile,count)\
81  fwrite(tobuffer,sizeof(ossim_int32),count,fromfile)
82
83 #define Write_Vpf_Float(tobuffer,fromfile,count)\
84  fwrite(tobuffer,sizeof(float),count,fromfile)
85
86 #define Write_Vpf_Double(tobuffer,fromfile,count)\
87  fwrite(tobuffer,sizeof(double),count,fromfile)
88
89 #define Write_Vpf_Date(tobuffer,fromfile,count)\
90  fwrite(tobuffer,sizeof(char)*20,count,fromfile)
91
92 #define Write_Vpf_Coordinate(tobuffer,fromfile,count)\
93  fwrite(tobuffer,sizeof(float)*2,count,fromfile)
94
95 #define Write_Vpf_CoordinateZ(tobuffer,fromfile,count)\
96  fwrite(tobuffer,sizeof(float)*3,count,fromfile)
97
98 #define Write_Vpf_DoubleCoordinate(tobuffer,fromfile,count)\
99  fwrite(tobuffer,sizeof(double)*2,count,fromfile)
100
101 #define Write_Vpf_DoubleCoordinateZ(tobuffer,fromfile,count)\
102  fwrite(tobuffer,sizeof(double)*3,count,fromfile)
103
104 #else /* Now the UNIX subroutine calls */
105
106
107 /* types */
108 typedef enum {
122 } VpfDataType ;
123
124 #define Read_Vpf_Char(tobuffer,fromfile,count)\
125  VpfRead(tobuffer,VpfChar,count,fromfile)
126
127 #define Read_Vpf_Short(tobuffer,fromfile,count)\
128  VpfRead(tobuffer,VpfShort,count,fromfile)
129
130 #define Read_Vpf_Int(tobuffer,fromfile,count)\
131  VpfRead(tobuffer,VpfInteger,count,fromfile)
132
133 #define Read_Vpf_Float(tobuffer,fromfile,count)\
134  VpfRead(tobuffer,VpfFloat,count,fromfile)
135
136 #define Read_Vpf_Double(tobuffer,fromfile,count)\
137  VpfRead(tobuffer,VpfDouble,count,fromfile)
138
139 #define Read_Vpf_Date(tobuffer,fromfile,count)\
140  VpfRead(tobuffer,VpfDate,count,fromfile)
141
142 #define Read_Vpf_Coordinate(tobuffer,fromfile,count)\
143  VpfRead(tobuffer,VpfCoordinate,count,fromfile)
144
145 #define Read_Vpf_CoordinateZ(tobuffer,fromfile,count)\
146  VpfRead(tobuffer,VpfTriCoordinate,count,fromfile)
147
148 #define Read_Vpf_DoubleCoordinate(tobuffer,fromfile,count)\
149  VpfRead(tobuffer,VpfDoubleCoordinate,count,fromfile)
150
151 #define Read_Vpf_DoubleCoordinateZ(tobuffer,fromfile,count)\
152  VpfRead(tobuffer,VpfDoubleTriCoordinate,count,fromfile)
153
154 #define Write_Vpf_Char(tobuffer,fromfile,count)\
155  VpfWrite(tobuffer,VpfChar,count,fromfile)
156
157 #define Write_Vpf_Short(tobuffer,fromfile,count)\
158  VpfWrite(tobuffer,VpfShort,count,fromfile)
159
160 #define Write_Vpf_Int(tobuffer,fromfile,count)\
161  VpfWrite(tobuffer,VpfInteger,count,fromfile)
162
163 #define Write_Vpf_Float(tobuffer,fromfile,count)\
164  VpfWrite(tobuffer,VpfFloat,count,fromfile)
165
166 #define Write_Vpf_Double(tobuffer,fromfile,count)\
167  VpfWrite(tobuffer,VpfDouble,count,fromfile)
168
169 #define Write_Vpf_Date(tobuffer,fromfile,count)\
170  VpfWrite(tobuffer,VpfDate,count,fromfile)
171
172 #define Write_Vpf_Coordinate(tobuffer,fromfile,count)\
173  VpfWrite(tobuffer,VpfCoordinate,count,fromfile)
174
175 #define Write_Vpf_CoordinateZ(tobuffer,fromfile,count)\
176  VpfWrite(tobuffer,VpfTriCoordinate,count,fromfile)
177
178 #define Write_Vpf_DoubleCoordinate(tobuffer,fromfile,count)\
179  VpfWrite(tobuffer,VpfDoubleCoordinate,count,fromfile)
180
181 #define Write_Vpf_DoubleCoordinateZ(tobuffer,fromfile,count)\
182  VpfWrite(tobuffer,VpfDoubleTriCoordinate,count,fromfile)
183
184 /* subroutines */
185
186 ossim_int32 VpfRead ( void *to, VpfDataType type, ossim_int32 count, FILE *from ) ;
187
188 ossim_int32 VpfWrite( void *from, VpfDataType type, ossim_int32 count, FILE *to );
189
190 #ifdef __cplusplus
191 }
192 #endif
193
194 #endif /* if __MSDOS__ */
195 #endif /* ifndef _VPF_IO_ */
196
197
198
199
200
201
202
203
Definition: vpfio.h:115
Definition: vpfio.h:110
Definition: vpfio.h:116
VpfDataType
Definition: vpfio.h:108
Definition: vpfio.h:109
ossim_int32 VpfWrite(void *from, VpfDataType type, ossim_int32 count, FILE *to)
ossim_int32 VpfRead(void *to, VpfDataType type, ossim_int32 count, FILE *from)
int ossim_int32
