Classes | Macros | Functions
vpftidx.h File Reference
#include <ossim/vpfutil/set.h>
#include <ossim/base/ossimConstants.h>
Go to the source code of this file.
Classes
struct  ThematicIndexHeader
struct  ThematicIndexDirectory
Macros
#define THEMATIC_INDEX_HEADER_SIZE   60
#define DIRECTORY_SIZE   (sizeof(ossim_int32)*2)
#define MAX_ID   32767 /* Threshold between S and I ids */
Functions
set_type read_thematic_index (char *tablename, char *value)
ThematicIndex open_thematic_index (char *tablename)
set_type search_thematic_index (ThematicIndex *themindex, char *value)
void close_thematic_index (ThematicIndex *themindex)
set_type read_gazetteer_index (char *vpfname, char *query_str)
set_type search_gazetteer_index (ThematicIndex *idx, char *query_str)
ossim_int32 read_gazetteer_index_directory (ThematicIndexDirectory **gid, ThematicIndexHeader *gi, FILE *idx_fp)
ossim_int32 write_thematic_index_header (ThematicIndexHeader h, FILE *fp)
ossim_int32 read_thematic_index_header (ThematicIndexHeader *h, FILE *fp)
ossim_int32 write_thematic_index_directory (ThematicIndexHeader h, ThematicIndexDirectory *d, ossim_int32 size, FILE *fp)
ossim_int32 write_gazetteer_index_directory (ThematicIndexHeader h, ThematicIndexDirectory *d, ossim_int32 size, FILE *fp)
ossim_int32 create_thematic_index (char indextype, char *tablename, char *idxname, char *columnname, char *idx_set)
ossim_int32 create_gazetteer_index (char *tablename, char *idx_fname, char *columnname, char *idx_set)
Macro Definition Documentation
◆ DIRECTORY_SIZE
Definition at line 59 of file vpftidx.h.
◆ MAX_ID
Definition at line 61 of file vpftidx.h.
◆ THEMATIC_INDEX_HEADER_SIZE
Definition at line 57 of file vpftidx.h.
Function Documentation
◆ close_thematic_index()
void close_thematic_index ( ThematicIndex themindex)
◆ create_gazetteer_index()
ossim_int32 create_gazetteer_index ( char *  tablename,
char *  idx_fname,
char *  columnname,
char *  idx_set
◆ create_thematic_index()
ossim_int32 create_thematic_index ( char  indextype,
char *  tablename,
char *  idxname,
char *  columnname,
char *  idx_set
◆ open_thematic_index()
ThematicIndex open_thematic_index ( char *  tablename)
◆ read_gazetteer_index()
set_type read_gazetteer_index ( char *  vpfname,
char *  query_str
◆ read_gazetteer_index_directory()
ossim_int32 read_gazetteer_index_directory ( ThematicIndexDirectory **  gid,
ThematicIndexHeader gi,
FILE *  idx_fp
◆ read_thematic_index()
set_type read_thematic_index ( char *  tablename,
char *  value
◆ read_thematic_index_header()
ossim_int32 read_thematic_index_header ( ThematicIndexHeader h,
FILE *  fp
◆ search_gazetteer_index()
set_type search_gazetteer_index ( ThematicIndex idx,
char *  query_str
◆ search_thematic_index()
set_type search_thematic_index ( ThematicIndex themindex,
char *  value
◆ write_gazetteer_index_directory()
ossim_int32 write_gazetteer_index_directory ( ThematicIndexHeader  h,
ThematicIndexDirectory d,
ossim_int32  size,
FILE *  fp
◆ write_thematic_index_directory()
ossim_int32 write_thematic_index_directory ( ThematicIndexHeader  h,
ossim_int32  size,
FILE *  fp
◆ write_thematic_index_header()
ossim_int32 write_thematic_index_header ( ThematicIndexHeader  h,
FILE *  fp
