45 m_intensity(obj.m_intensity),
46 m_returnByte(obj.m_returnByte),
47 m_classification(obj.m_classification),
48 m_scanAngleRank(obj.m_scanAngleRank),
49 m_userData(obj.m_userData),
50 m_pointSourceID(obj.m_pointSourceID),
51 m_gpsTime(obj.m_gpsTime)
83 m_record(obj.m_record)
89 if (
this != ©_this)
180 std::ios_base::fmtflags f = out.flags();
182 out << std::setiosflags(std::ios_base::fixed) << std::setprecision(8);
virtual ossim_uint16 getIntensity() const
virtual void readStream(std::istream &in)
Initialize record from stream.
Container class for LAS point record type 1.
virtual ossim_uint16 getBlue() const
virtual ossim_int32 getY() const
const ossimLasPointRecord1 & operator=(const ossimLasPointRecord1 ©_this)
virtual ossim_uint16 getRed() const
virtual ossim_uint8 getReturnNumber() const
OSSIM_DLL ossimByteOrder byteOrder()
ossim_int8 m_scanAngleRank
ossim_uint8 m_classification
unsigned short ossim_uint16
virtual ossim_uint8 getEdgeFlag() const
void swap()
Performs a swap if system byte order is not little endian.
virtual ~ossimLasPointRecord1()
destructor
virtual ossim_uint16 getGreen() const
const ossimLasPointRecord1Data & operator=(const ossimLasPointRecord1Data &obj)
virtual ossim_int32 getX() const
ossimLasPointRecord1Data m_record
std::basic_istream< char > istream
Base class for char input streams.
virtual ossim_int32 getZ() const
ossim_uint16 m_pointSourceID
default constructor
ossimLasPointRecord1Data()
unsigned char ossim_uint8
virtual ossim_uint8 getNumberOfReturns() const
std::basic_ostream< char > ostream
Base class for char output streams.
virtual void writeStream(std::ostream &out)
Writes record to stream.
