FactoryListBase.h
Go to the documentation of this file.
1 //**************************************************************************************************
2 //
3 // License: MIT
4 //
5 // See LICENSE.txt file in the top level directory for more details.
6 //
7 // Description: Class declaration of ossimFactoryListInterface.
8 //
9 //**************************************************************************************************
10 // $Id$
11 #ifndef ossimFactoryListBase_HEADER
12 #define ossimFactoryListBase_HEADER 1
13 #include <vector>
14 #include <ossim/base/ossimString.h>
15 #include <ossim/base/RWLock.h>
16
17 namespace ossim
18 {
19  template <class T>
21  {
22  public:
23  typedef std::vector<T> FactoryListType;
24  typedef std::vector<ossimString> TypeNameList;
25
27
31  void addFactory(T factory)
32  {
33  registerFactory(factory);
34  }
35
40  bool isFactoryRegistered(T factory)const
41  {
42  if(!factory) return false;
43  ScopeReadLock scopedReadLock(m_rwlock);
44
45  return findFactory(factory);
46  }
47
52  void registerFactory(T factory, bool pushToFrontFlag=false)
53  {
54  if(!factory) return;
55  ScopeWriteLock scopedWriteLock(m_rwlock);
56  if(!findFactory(factory))
57  {
58  if (pushToFrontFlag)
59  {
60  m_factoryList.insert(m_factoryList.begin(), factory);
61  }
62  else
63  {
64  m_factoryList.push_back(factory);
65  }
66  }
67  }
71  void unregisterFactory(T factory)
72  {
73  ScopeWriteLock scopedWriteLock(m_rwlock);
74  ossim_uint32 idx = 0;
75  for(idx = 0; idx < m_factoryList.size(); ++idx)
76  {
77  if(factory == m_factoryList[idx])
78  {
79  m_factoryList.erase(m_factoryList.begin() + idx);
80  return;
81  }
82  }
83  }
84
89  {
90  ScopeWriteLock scopedWriteLock(m_rwlock);
91  m_factoryList.clear();
92  }
93
97  void registerFactoryToFront(T factory)
98  {
99  ScopeWriteLock scopedWriteLock(m_rwlock);
100  if(!findFactory(factory))
101  {
102  m_factoryList.insert(m_factoryList.begin(), factory);
103  }
104  }
105
110  void registerFactoryBefore(T factory, T beforeThisFactory)
111  {
112  ScopeWriteLock scopedWriteLock(m_rwlock);
113
114  if(!findFactory(factory))
115  {
116  ossim_uint32 idx = 0;
117  for(idx = 0; idx < m_factoryList.size(); ++idx)
118  {
119  if(beforeThisFactory == m_factoryList[idx])
120  {
121  m_factoryList.insert(m_factoryList.begin() + idx, factory);
122  return;
123  }
124  }
125  m_factoryList.push_back(factory);
126  }
127  }
128
129  protected:
133  bool findFactory(T factory)const
134  {
135  if(!factory) return false;
136  ossim_uint32 idx = 0;
137  for(const auto& testFactory:m_factoryList)
138  {
139  if(factory == testFactory)
140  {
141  return true;
142  }
143  }
144  return false;
145  }
146
149  };
150 }
151
152 #endif
Code was derived from https://gist.github.com/mshockwave.
Definition: RWLock.h:38
FactoryListType m_factoryList
void unregisterAllFactories()
Will remove all factories from the registry.
This code was derived from https://gist.github.com/mshockwave.
Definition: Barrier.h:8
std::vector< T > FactoryListType
Inserts the factory to the front of the list.
Will register a factory to the factory list.
unsigned int ossim_uint32
bool findFactory(T factory) const
Utility to find a factory in the list.
std::vector< ossimString > TypeNameList
Will remove the factory from the registry.
This is for backward compatability and calls registerFactory for simple adds.
Will insert the factory before the beforeThisFactory.
bool isFactoryRegistered(T factory) const
Public access method to determine if a factory is already registered to this list.
