Public Types | Public Member Functions | Protected Member Functions | Protected Attributes | List of all members
ossim::FactoryListBase< T > Class Template Reference
#include <FactoryListBase.h>
Public Types
typedef std::vector< T > FactoryListType
typedef std::vector< ossimStringTypeNameList
 FactoryListBase ()
void addFactory (T factory)
 This is for backward compatability and calls registerFactory for simple adds. More...
bool isFactoryRegistered (T factory) const
 Public access method to determine if a factory is already registered to this list. More...
void registerFactory (T factory, bool pushToFrontFlag=false)
 Will register a factory to the factory list. More...
void unregisterFactory (T factory)
 Will remove the factory from the registry. More...
void unregisterAllFactories ()
 Will remove all factories from the registry. More...
void registerFactoryToFront (T factory)
 Inserts the factory to the front of the list. More...
void registerFactoryBefore (T factory, T beforeThisFactory)
 Will insert the factory before the beforeThisFactory. More...
bool findFactory (T factory) const
 Utility to find a factory in the list. More...
ossim::RWLock m_rwlock
FactoryListType m_factoryList
Detailed Description
template<class T>
class ossim::FactoryListBase< T >
Definition at line 20 of file FactoryListBase.h.
Member Typedef Documentation
◆ FactoryListType
template<class T>
typedef std::vector<T> ossim::FactoryListBase< T >::FactoryListType
Definition at line 23 of file FactoryListBase.h.
◆ TypeNameList
template<class T>
typedef std::vector<ossimString> ossim::FactoryListBase< T >::TypeNameList
Definition at line 24 of file FactoryListBase.h.
◆ FactoryListBase()
template<class T>
ossim::FactoryListBase< T >::FactoryListBase ( )
inline
Definition at line 26 of file FactoryListBase.h.
26 {}
Member Function Documentation
◆ addFactory()
template<class T>
void ossim::FactoryListBase< T >::addFactory ( factory)
inline
Definition at line 31 of file FactoryListBase.h.
32  {
33  registerFactory(factory);
34  }
void registerFactory(T factory, bool pushToFrontFlag=false)
◆ findFactory()
template<class T>
bool ossim::FactoryListBase< T >::findFactory ( factory) const
inlineprotected
◆ isFactoryRegistered()
template<class T>
bool ossim::FactoryListBase< T >::isFactoryRegistered ( factory) const
inline
Definition at line 40 of file FactoryListBase.h.
41  {
42  if(!factory) return false;
43  ScopeReadLock scopedReadLock(m_rwlock);
44
45  return findFactory(factory);
46  }
bool findFactory(T factory) const
◆ registerFactory()
template<class T>
void ossim::FactoryListBase< T >::registerFactory ( factory,
bool  pushToFrontFlag = false
inline
Will append the passed in factory if not already registered to the list.
Definition at line 52 of file FactoryListBase.h.
Referenced by ossim::FactoryListBase< std::shared_ptr< ossim::StateFactoryBase< std::shared_ptr< ossim::ImageHandlerState > > > >::addFactory().
53  {
54  if(!factory) return;
55  ScopeWriteLock scopedWriteLock(m_rwlock);
56  if(!findFactory(factory))
57  {
58  if (pushToFrontFlag)
59  {
60  m_factoryList.insert(m_factoryList.begin(), factory);
61  }
62  else
63  {
64  m_factoryList.push_back(factory);
65  }
66  }
67  }
◆ registerFactoryBefore()
template<class T>
void ossim::FactoryListBase< T >::registerFactoryBefore ( factory,
beforeThisFactory
inline
If not found it will do a simple append.
Definition at line 110 of file FactoryListBase.h.
111  {
112  ScopeWriteLock scopedWriteLock(m_rwlock);
113
114  if(!findFactory(factory))
115  {
116  ossim_uint32 idx = 0;
117  for(idx = 0; idx < m_factoryList.size(); ++idx)
118  {
119  if(beforeThisFactory == m_factoryList[idx])
120  {
121  m_factoryList.insert(m_factoryList.begin() + idx, factory);
122  return;
123  }
124  }
125  m_factoryList.push_back(factory);
126  }
127  }
unsigned int ossim_uint32
◆ registerFactoryToFront()
template<class T>
void ossim::FactoryListBase< T >::registerFactoryToFront ( factory)
inline
Definition at line 97 of file FactoryListBase.h.
98  {
99  ScopeWriteLock scopedWriteLock(m_rwlock);
100  if(!findFactory(factory))
101  {
102  m_factoryList.insert(m_factoryList.begin(), factory);
103  }
104  }
◆ unregisterAllFactories()
template<class T>
void ossim::FactoryListBase< T >::unregisterAllFactories ( )
inline
Definition at line 88 of file FactoryListBase.h.
89  {
90  ScopeWriteLock scopedWriteLock(m_rwlock);
91  m_factoryList.clear();
92  }
◆ unregisterFactory()
template<class T>
void ossim::FactoryListBase< T >::unregisterFactory ( factory)
inline
Definition at line 71 of file FactoryListBase.h.
72  {
73  ScopeWriteLock scopedWriteLock(m_rwlock);
74  ossim_uint32 idx = 0;
75  for(idx = 0; idx < m_factoryList.size(); ++idx)
76  {
77  if(factory == m_factoryList[idx])
78  {
79  m_factoryList.erase(m_factoryList.begin() + idx);
80  return;
81  }
82  }
83  }
Member Data Documentation
◆ m_factoryList
template<class T>
FactoryListType ossim::FactoryListBase< T >::m_factoryList
protected
◆ m_rwlock
template<class T>
ossim::RWLock ossim::FactoryListBase< T >::m_rwlock
mutableprotected
The documentation for this class was generated from the following file:
