Public Member Functions | Private Attributes | Friends | List of all members
ATP::MatchPoint Class Reference
Maintains quantities associated with single matchpoint peak. More...
#include <MatchPoint.h>
 MatchPoint (const ossimDpt &cmpImagePt, double corr_value, const ossimDpt &residual=ossimDpt(0, 0))
 Constructor for creating new instance with data members provided. More...
 MatchPoint (const MatchPoint &copy)
 Copy constructor. More...
 ~MatchPoint ()
 Destructor does nothing. More...
const double & getConfidenceMeasure () const
 Const access methods. More...
const ossimDptgetImagePoint () const
 Returns the image point corresponding to the correlated feature on the CMP image. More...
void setResidual (const ossimDpt &residual)
 Sets/gets the residual associated with this peak (for APC functionality in consistency check) More...
const ossimDptgetResidual () const
Private Attributes
double m_confidence
ossimDpt m_cmpImagePt
ossimDpt m_residual
Friends
std::ostream & operator<< (std::ostream &out, const MatchPoint &cp)
Detailed Description
This consists of the image point on the query/CMP image that corresponds to the feature in the REF image, and the strength (confidence level) of the correlation (0.0 - 1.0). There will be more than one match (one instance of this class) per REF image feature maintained by the AutoTiePoint. The ATP will decide, based on match confidence and consistency with neighboring ATPs, whether a match should be considered as the correct match point.
Wish List: May eventually want to consider a 2x2 (2-D) covariance matrix to accompany the peak value.
Definition at line 26 of file MatchPoint.h.
◆ MatchPoint() [1/2]
ATP::MatchPoint::MatchPoint ( const ossimDpt cmpImagePt,
double  corr_value,
const ossimDpt residual = ossimDpt(0,0)
inline
Definition at line 31 of file MatchPoint.h.
34  : m_confidence(corr_value),
35  m_cmpImagePt (cmpImagePt),
36  m_residual (residual) {}
double m_confidence
Definition: MatchPoint.h:64
ossimDpt m_residual
Definition: MatchPoint.h:66
Definition: MatchPoint.h:65
◆ MatchPoint() [2/2]
ATP::MatchPoint::MatchPoint ( const MatchPoint copy)
inline
Copy constructor.
Definition at line 39 of file MatchPoint.h.
40  : m_confidence(copy.m_confidence),
41  m_cmpImagePt (copy.m_cmpImagePt),
42  m_residual (copy.m_residual) {}
double m_confidence
ossimDpt m_residual
◆ ~MatchPoint()
ATP::MatchPoint::~MatchPoint ( )
inline
Definition at line 45 of file MatchPoint.h.
45 { }
Member Function Documentation
◆ getConfidenceMeasure()
const double& ATP::MatchPoint::getConfidenceMeasure ( ) const
inline
Definition at line 48 of file MatchPoint.h.
References m_confidence.
48 { return m_confidence; }
double m_confidence
◆ getImagePoint()
const ossimDpt& ATP::MatchPoint::getImagePoint ( ) const
inline
Definition at line 51 of file MatchPoint.h.
References m_cmpImagePt.
51 { return m_cmpImagePt; }
◆ getResidual()
const ossimDpt& ATP::MatchPoint::getResidual ( ) const
inline
Definition at line 55 of file MatchPoint.h.
References m_residual.
55 { return m_residual; }
ossimDpt m_residual
◆ setResidual()
void ATP::MatchPoint::setResidual ( const ossimDpt residual)
inline
Definition at line 54 of file MatchPoint.h.
54 { m_residual = residual; }
ossimDpt m_residual
◆ operator<<
std::ostream& operator<< ( std::ostream &  out,
const MatchPoint cp
friend
Definition at line 57 of file MatchPoint.h.
58  {
59  out<<cp.m_cmpImagePt<<", "<<cp.m_confidence;
60  return out;
61  }
Member Data Documentation
◆ m_cmpImagePt
ossimDpt ATP::MatchPoint::m_cmpImagePt
private
Definition at line 65 of file MatchPoint.h.
Referenced by getImagePoint().
◆ m_confidence
double ATP::MatchPoint::m_confidence
private
Definition at line 64 of file MatchPoint.h.
Referenced by getConfidenceMeasure().
◆ m_residual
ossimDpt ATP::MatchPoint::m_residual
private
Definition at line 66 of file MatchPoint.h.
Referenced by getResidual(), and setResidual().
The documentation for this class was generated from the following file:
