ATP::AutoTiePoint Class Reference
Base class for all automatic tiepoints. More...
#include <AutoTiePoint.h>
Inheritance diagram for ATP::AutoTiePoint:
ossim::TiePoint ossim::JsonInterface
Public Member Functions
 AutoTiePoint ()
 AutoTiePoint (const AutoTiePoint &copy_me)
 AutoTiePoint (std::shared_ptr< AtpGenerator > generator, const std::string &id)
 Constructs given two images and a point on the REF image. More...
 AutoTiePoint (const Json::Value &tp_json_node)
 Creates new tiepoint from JSON object formatted as: { "id": <unsigned int>="">, // may be ignored if not valid "type": "M"|"A"|"G" For “manual”, “auto”, or “GCP-associated” "imagePoints: [ { "imageId": <string>, "x": <double>, "y": <double>, "covariance": [ cxx, cyy, cxy ], "gcpId": <string> Only if associated with a GCP } ] }. More...
virtual ~AutoTiePoint ()
void setRefImagePt (const ossimDpt &imagePt)
 Sets the reference image's image point (in image space) for this tiepoint. More...
void setRefViewPt (const ossimDpt &viewPt)
 Sets the reference image's view point (in view space) for this tiepoint. More...
bool getVectorResidual (ossimDpt &residual) const
 Returns the vector residual (CMP-REF) of current active peak (in view space) via argument. More...
bool getRefImagePoint (ossimDpt &image_pt) const
 Returns the center location of the reference patch (the feature) in image-space. More...
bool getCmpImagePoint (ossimDpt &image_pt) const
 Fetches the comparison image point for current best peak. Returns false if no valid peak. More...
 Stream output dump of object. More...
std::vector< MatchPoint > & matchPoints ()
 Access to peaks list for GUI debug display. More...
void addImageMatch (const ossimDpt &cmpPt, double confidenceValue=1.0)
 Inserts match in image space by confidence in descending order. More...
void addViewMatch (const ossimDpt &cmpViewPt, double confidenceValue=1.0)
unsigned int getNumMatches () const
 Returns the total number of peaks in the list. More...
bool hasValidMatch () const
 Returns true if there is a valid peak in the list. More...
bool getConfidenceMeasure (double &confidence) const
 Returns the correlation value of current active peak via argument. Returns true if valid. More...
bool getRefViewPoint (ossimDpt &view_pt) const
 Returns the center location of the reference patch (the feature) in view-space. More...
bool getRefGroundPoint (ossimGpt &gpt) const
 Returns the center location of the reference patch (the feature) in geographic. More...
bool getCmpViewPoint (ossimDpt &view_pt, unsigned int peak_idx=0) const
 Fetches the comparison view point for current best peak, or for the peak indicated if provided. More...
bool bumpActiveMatch ()
 Removes the active match and sets the next peak as active. More...
virtual void saveJSON (Json::Value &json) const
- Public Member Functions inherited from ossim::TiePoint
 TiePoint ()
 TiePoint (const TiePoint &copy)
virtual ~TiePoint ()
unsigned int getImageCount () const
const std::string & getTiePointId () const
void setTiePointId (const std::string &id)
void getImagePoint (unsigned int index, std::string &imageId, ossimDpt &imagePoint, NEWMAT::SymmetricMatrix &cov) const
 Fetches the image point coordinates along with image ID and GCP ID if available. More...
void setImagePoint (std::shared_ptr< Image > image, const ossimDpt &imagePoint, const NEWMAT::SymmetricMatrix &cov)
 Sets image point value and associated measurement covariance for specified image ID. More...
Type getType () const
void setType (Type t)
const std::string & getGcpId () const
void setGcpId (const std::string &id)
virtual void loadJSON (const Json::Value &json)
- Public Member Functions inherited from ossim::JsonInterface
 JsonInterface ()
virtual ~JsonInterface ()
Protected Member Functions
virtual void recomputeResidual ()
 Recomputes active peak's residual after a model adjustment or change in peak. More...
Protected Attributes
std::shared_ptr< AtpGeneratorm_generator
std::vector< MatchPointm_matchPoints
ossimDpt m_refViewPt
ossimDpt m_cmpViewPt
ossimDpt m_residual
double m_relativeError
 Uncertainty in position of feature in CMP image. More...
- Protected Attributes inherited from ossim::TiePoint
Type m_type
std::string m_tiePointId
std::vector< std::shared_ptr< Image > > m_images
std::vector< ossimDptm_imagePoints
std::vector< NEWMAT::SymmetricMatrix > m_covariances
double m_gsd
std::string m_gcpId
Additional Inherited Members
- Public Types inherited from ossim::TiePoint
enum  Type { UNASSIGNED, MANUAL, AUTO, GCP }
- Static Protected Attributes inherited from ossim::TiePoint
static int s_runningId = 1
Detailed Description
These differ from tiepoint base class in that it is guarantied to represent a single image pair. Therefore, residuals between the pair can be computed without referencing image ids, etc. TODO: Eventually need to generalize to permit N-way auto-tiepoints, at which point it should merge with TiePoint base class.
Definition at line 30 of file AutoTiePoint.h.
◆ AutoTiePoint() [1/4]
ATP::AutoTiePoint::AutoTiePoint ( )
Definition at line 18 of file AutoTiePoint.cpp.
19 : m_relativeError(0),
20  m_generator(0)
21 {
22 }
Definition: AutoTiePoint.h:134
std::shared_ptr< AtpGenerator > m_generator
Definition: AutoTiePoint.h:129
◆ AutoTiePoint() [2/4]
ATP::AutoTiePoint::AutoTiePoint ( const AutoTiePoint copy_me)
Definition at line 24 of file AutoTiePoint.cpp.
References m_matchPoints.
25  : TiePoint (copy),
26  m_generator(copy.m_generator),
27  m_refViewPt(copy.m_refViewPt),
28  m_cmpViewPt(copy.m_cmpViewPt),
29  m_residual(copy.m_residual),
30  m_relativeError(copy.m_relativeError)
31 {
32  for (size_t i=0; i<copy.m_matchPoints.size(); ++i)
33  m_matchPoints.push_back(copy.m_matchPoints[i]);
34 }
Definition: AutoTiePoint.h:131
std::vector< MatchPoint > m_matchPoints
Definition: AutoTiePoint.h:130
Definition: AutoTiePoint.h:132
◆ AutoTiePoint() [3/4]
ATP::AutoTiePoint::AutoTiePoint ( std::shared_ptr< AtpGenerator generator,
const std::string &  id
The matching is still to be established.
Parameters
overlapThe combiner source representing the overlap between REF and CMP images. Tie point ID
◆ AutoTiePoint() [4/4]
ATP::AutoTiePoint::AutoTiePoint ( const Json::Value &  tp_json_node)
Definition at line 55 of file AutoTiePoint.cpp.
56 : TiePoint(tp_json_node),
57  m_relativeError(0),
58  m_generator(0)
59 {
60 }
◆ ~AutoTiePoint()
ATP::AutoTiePoint::~AutoTiePoint ( )
virtual
Definition at line 62 of file AutoTiePoint.cpp.
63 {
64  m_matchPoints.clear();
65 }
Member Function Documentation
◆ addImageMatch()
void ATP::AutoTiePoint::addImageMatch ( const ossimDpt cmpPt,
double  confidenceValue = 1.0
Definition at line 154 of file AutoTiePoint.cpp.
References ossim::TiePoint::m_imagePoints, m_matchPoints, m_residual, ossimDpt::makeNan(), and recomputeResidual().
Referenced by addViewMatch().
155 {
156  // Check if we will be inserting in first position. If so, need to set m_cmpViewPt and
157  // m_residual data members to this (active) active peak info:
158  if (m_matchPoints.size() == 0)
159  {
160  if (m_imagePoints.empty())
161  {
162  ossimDpt nanRefPt;
163  nanRefPt.makeNan();
164  m_imagePoints.push_back(nanRefPt);
165  }
166  if (m_imagePoints.size() == 1)
167  m_imagePoints.push_back(cmpImagePt);
168  else
169  m_imagePoints[1] = cmpImagePt;
170
172  }
173
174  // Instantiate a new peak. Insert this peak into the map, where it is ordered by peak value:
175  m_matchPoints.emplace_back(MatchPoint(cmpImagePt, confidenceValue, m_residual));
176 }
std::vector< ossimDpt > m_imagePoints
Definition: TiePoint.h:116
virtual void recomputeResidual()
Recomputes active peak&#39;s residual after a model adjustment or change in peak.
void makeNan()
Definition: ossimDpt.h:65
◆ addViewMatch()
void ATP::AutoTiePoint::addViewMatch ( const ossimDpt cmpViewPt,
Definition at line 207 of file AutoTiePoint.cpp.
References addImageMatch(), m_cmpViewPt, m_generator, and m_matchPoints.
208 {
209  // Need to compute what the CMP image point is for the peak:
210  ossimDpt cmpImagePt;
211  m_generator->getCmpIVT()->viewToImage(cmpViewPt, cmpImagePt);
212
213  // Check if we will be inserting in first position. If so, need to set m_cmpViewPt and
214  // m_residual data members to this (active) active peak info:
215  if (m_matchPoints.size() == 0)
216  m_cmpViewPt = cmpViewPt;
217
218  addImageMatch(cmpImagePt, confidenceValue);
219 }
void addImageMatch(const ossimDpt &cmpPt, double confidenceValue=1.0)
◆ bumpActiveMatch()
bool ATP::AutoTiePoint::bumpActiveMatch ( )
Returns TRUE unless there are no more active matches.
Definition at line 192 of file AutoTiePoint.cpp.
References m_matchPoints, and recomputeResidual().
193 {
194  m_matchPoints.erase(m_matchPoints.begin());
195  if (m_matchPoints.empty())
196  return false;
197
199  return true;
200 }
◆ getCmpImagePoint()
bool ATP::AutoTiePoint::getCmpImagePoint ( ossimDpt image_pt) const
Definition at line 73 of file AutoTiePoint.cpp.
References ossim::TiePoint::m_imagePoints.
74 {
75  if ((m_imagePoints.size() < 2) || m_imagePoints[1].isNan())
76  return false;
77  image_point = m_imagePoints[1];
78  return true;
79 }
◆ getCmpViewPoint()
bool ATP::AutoTiePoint::getCmpViewPoint ( ossimDpt view_pt,
unsigned int  peak_idx = 0
) const
Definition at line 229 of file AutoTiePoint.cpp.
References m_cmpViewPt.
230 {
231  if (peak_idx == 0)
232  {
233  view_point = m_cmpViewPt; // last known point, may be invalid.
234  return true;
235  }
236
237  return false;
238 }
◆ getConfidenceMeasure()
bool ATP::AutoTiePoint::getConfidenceMeasure ( double &  confidence) const
Definition at line 178 of file AutoTiePoint.cpp.
References hasValidMatch(), and m_matchPoints.
179 {
180  // Check for empty list or if we are at the end of the list (no points remaining):
181  if ((!hasValidMatch()))
182  {
183  confidence = 0;
184  return false;
185  }
186
187  // The first peak in the list is always the best peak:
188  confidence = m_matchPoints.begin()->getConfidenceMeasure();
189  return true;
190 }
bool hasValidMatch() const
◆ getNumMatches()
unsigned int ATP::AutoTiePoint::getNumMatches ( ) const
inline
Definition at line 95 of file AutoTiePoint.h.
95 { return (unsigned int) m_matchPoints.size(); }
◆ getRefGroundPoint()
bool ATP::AutoTiePoint::getRefGroundPoint ( ossimGpt gpt) const
Returns false if point not yet defined. Note that there may not be any valid peak.
Definition at line 258 of file AutoTiePoint.cpp.
References ossimDpt::isNan(), m_generator, m_refViewPt, and ossimGpt::makeNan().
259 {
260  gpt.makeNan();
261  if (m_refViewPt.isNan())
262  return false;
263
264  m_generator->getRefIVT()->getViewGeometry()->localToWorld(m_refViewPt, gpt);
265  return true;
266 }
void makeNan()
Definition: ossimGpt.h:130
bool isNan() const
Definition: ossimDpt.h:72
◆ getRefImagePoint()
bool ATP::AutoTiePoint::getRefImagePoint ( ossimDpt image_pt) const
Returns false if point not yet defined. Note that there not be any valid peak.
Definition at line 81 of file AutoTiePoint.cpp.
82 {
83  if (m_imagePoints.empty() || m_imagePoints[0].isNan())
84  return false;
85  image_point = m_imagePoints[0];
86  return true;
87 }
◆ getRefViewPoint()
bool ATP::AutoTiePoint::getRefViewPoint ( ossimDpt view_pt) const
Definition at line 221 of file AutoTiePoint.cpp.
References ossimDpt::isNan(), and m_refViewPt.
222 {
223  view_point = m_refViewPt;
224  if (m_refViewPt.isNan())
225  return false;
226  return true;
227 }
bool isNan() const
◆ getVectorResidual()
bool ATP::AutoTiePoint::getVectorResidual ( ossimDpt residual) const
Definition at line 67 of file AutoTiePoint.cpp.
References m_residual.
68 {
69  residual = m_residual;
70  return true;
71 }
◆ hasValidMatch()
bool ATP::AutoTiePoint::hasValidMatch ( ) const
Definition at line 202 of file AutoTiePoint.cpp.
Referenced by getConfidenceMeasure().
203 {
204  return !m_matchPoints.empty();
205 }
◆ matchPoints()
std::vector<MatchPoint>& ATP::AutoTiePoint::matchPoints ( )
inline
Definition at line 86 of file AutoTiePoint.h.
86 { return m_matchPoints; }
◆ print()
ostream & ATP::AutoTiePoint::print ( std::ostream &  out) const
virtual
Reimplemented from ossim::TiePoint.
Definition at line 129 of file AutoTiePoint.cpp.
References DEG_PER_RAD, ossim::TiePoint::m_imagePoints, m_matchPoints, m_residual, ossim::TiePoint::m_tiePointId, ossim_hdf5::print(), ossimDpt::x, and ossimDpt::y.
130 {
131  double azimuth = atan2(m_residual.x, - m_residual.y)*DEG_PER_RAD;
132  if (azimuth < 0.0)
133  azimuth += 360.0;
134
135  out << "\nDump of AutoTiePoint ID = " << m_tiePointId;
136  out << "\n refImgPt = " << m_imagePoints[0];
137  out << "\n residual (p) = " << m_residual;
138  out << "\n azimuth deg = " << azimuth;
139  TiePoint::print(out);
140  if (m_matchPoints.size() == 0)
141  {
142  out<<"\n No matches.";
143  }
144  else
145  {
146  out<<"\n Matches:";
147  for (size_t i=0; i<m_matchPoints.size(); ++i)
148  out<<"\n "<<m_matchPoints[i];
149  }
150
151  return out;
152 }
#define DEG_PER_RAD
double y
Definition: ossimDpt.h:165
std::ostream & print(H5::H5File *file, std::ostream &out)
Print method.
Definition: ossimH5Util.cpp:41
Definition: TiePoint.h:114
double x
Definition: ossimDpt.h:164
◆ recomputeResidual()
void ATP::AutoTiePoint::recomputeResidual ( )
protectedvirtual
Residuals are in view space for this type.
Definition at line 240 of file AutoTiePoint.cpp.
References m_cmpViewPt, m_generator, ossim::TiePoint::m_imagePoints, m_refViewPt, m_residual, and ossimDpt::makeNan().
Referenced by addImageMatch(), and bumpActiveMatch().
241 {
242  if (!m_generator)
244
245  if (m_imagePoints.size() < 2)
246  return;
247
248  // Since the REF input projection may have changed, recompute the REF view pt data member:
249  m_generator->getRefIVT()->imageToView(m_imagePoints[0], m_refViewPt);
250
251  // Establish the view-space coordinates of the peak given the peak's image point (in REF imae)
252  // in order to compute residual:
253  m_generator->getCmpIVT()->imageToView(m_imagePoints[1], m_cmpViewPt);
254
256 }
void makeNan()
◆ saveJSON()
void ATP::AutoTiePoint::saveJSON ( Json::Value &  json) const
virtual
Definition at line 109 of file AutoTiePoint.cpp.
References ossimGpt::azimuthTo(), ossimGpt::distanceTo(), m_cmpViewPt, m_generator, m_matchPoints, and m_refViewPt.
110 {
111  TiePoint::saveJSON(json_node);// ID
112  if (m_matchPoints.empty())
113  return;
114  json_node["confidence"] = m_matchPoints[0].getConfidenceMeasure();
115
116  auto geom = m_generator->getRefIVT()->getViewGeometry();
117  if (geom)
118  {
119  ossimGpt refGpt, cmpGpt;
120  geom->localToWorld(m_refViewPt, refGpt);
121  geom->localToWorld(m_cmpViewPt, cmpGpt);
122  Json::Value residual;
123  residual["range"] = refGpt.distanceTo(cmpGpt);
124  residual["azimuth"] = refGpt.azimuthTo(cmpGpt);
125  json_node["residual"] = residual;
126  }
127 }
double azimuthTo(const ossimGpt &arg_gpt) const
METHOD: azimuthTo(ossimGpt) Computes the great-circle starting azimuth (i.e., at this gpt) to the arg...
Definition: ossimGpt.cpp:446
double distanceTo(const ossimGpt &arg_gpt) const
METHOD: distanceTo(ossimGpt) Computes straight-line distance in meters between this and arg gpt: ...
Definition: ossimGpt.cpp:431
◆ setRefImagePt()
void ATP::AutoTiePoint::setRefImagePt ( const ossimDpt imagePt)
Definition at line 89 of file AutoTiePoint.cpp.
References m_generator, ossim::TiePoint::m_imagePoints, and m_refViewPt.
90 {
91  if (m_imagePoints.empty())
92  m_imagePoints.push_back(imagePt);
93  else
94  m_imagePoints[0] = imagePt;
95  m_generator->getRefIVT()->imageToView(imagePt, m_refViewPt);
96 }
◆ setRefViewPt()
void ATP::AutoTiePoint::setRefViewPt ( const ossimDpt viewPt)
Definition at line 98 of file AutoTiePoint.cpp.
99 {
100  m_refViewPt = viewPt;
101  ossimDpt imagePt;
102  m_generator->getRefIVT()->viewToImage(viewPt, imagePt);
103  if (m_imagePoints.empty())
104  m_imagePoints.push_back(imagePt);
105  else
106  m_imagePoints[0] = imagePt;
107 }
Member Data Documentation
◆ m_cmpViewPt
ossimDpt ATP::AutoTiePoint::m_cmpViewPt
protected
Definition at line 132 of file AutoTiePoint.h.
Referenced by addViewMatch(), getCmpViewPoint(), recomputeResidual(), and saveJSON().
◆ m_generator
std::shared_ptr<AtpGenerator> ATP::AutoTiePoint::m_generator
protected
◆ m_matchPoints
std::vector<MatchPoint> ATP::AutoTiePoint::m_matchPoints
protected
◆ m_refViewPt
ossimDpt ATP::AutoTiePoint::m_refViewPt
protected
◆ m_relativeError
double ATP::AutoTiePoint::m_relativeError
protected
Definition at line 134 of file AutoTiePoint.h.
◆ m_residual
ossimDpt ATP::AutoTiePoint::m_residual
protected
Definition at line 133 of file AutoTiePoint.h.
Referenced by addImageMatch(), getVectorResidual(), print(), and recomputeResidual().
