ossim2dTo2dShiftTransform Class Reference
#include <ossim2dTo2dShiftTransform.h>
Inheritance diagram for ossim2dTo2dShiftTransform:
ossim2dTo2dTransform ossimObject ossimReferenced
Public Member Functions
 ossim2dTo2dShiftTransform (const ossimDpt &shift=ossimDpt(0.0, 0.0))
 Constructor to initialize the shift transform. More...
 ossim2dTo2dShiftTransform (const ossim2dTo2dShiftTransform &src)
 Copy constructor. More...
 Duplication method that duplicates this object. More...
const ossim2dTo2dShiftTransformoperator= (const ossim2dTo2dShiftTransform &src)
 operator = allows one to copy the contents of the class through a common = operator. More...
virtual void forward (const ossimDpt &input, ossimDpt &output) const
 Apply the shift to the input. More...
virtual void forward (ossimDpt &modify_this) const
 Apply the shift to the input and put the result in the same variable. More...
virtual void inverse (const ossimDpt &input, ossimDpt &output) const
 Negate the shift to the input and put the result in output. More...
virtual void inverse (ossimDpt &modify_this) const
 Negate the shift operation and put the result in the same variable. More...
 Saves the state of this object. More...
 loads the state of this object from a keywordlist. More...
 Print the contents of the class and pass to the derived class. More...
- Public Member Functions inherited from ossim2dTo2dTransform
virtual const ossim2dTo2dTransformoperator= (const ossim2dTo2dTransform &rhs)
virtual ossimDpt getOrigin () const
void setConvergenceThreshold (const double &new_threshold)
void setMaxIterations (int new_max_iters)
void setDxDy (const ossimDpt &dxdy)
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
Protected Member Functions
virtual ~ossim2dTo2dShiftTransform ()
- Protected Member Functions inherited from ossim2dTo2dTransform
 ossim2dTo2dTransform ()
virtual ~ossim2dTo2dTransform ()
virtual ~ossimReferenced ()
Protected Attributes
ossimDpt m_shift
 TYPE_DATA
- Protected Attributes inherited from ossim2dTo2dTransform
double theConvergenceThreshold
int theMaxIterations
ossimDpt theDxDy
Detailed Description
Definition at line 13 of file ossim2dTo2dShiftTransform.h.
◆ ossim2dTo2dShiftTransform() [1/2]
ossim2dTo2dShiftTransform::ossim2dTo2dShiftTransform ( const ossimDpt shift = ossimDpt(0.0,0.0))
inline
Definition at line 19 of file ossim2dTo2dShiftTransform.h.
◆ ossim2dTo2dShiftTransform() [2/2]
ossim2dTo2dShiftTransform::ossim2dTo2dShiftTransform ( const ossim2dTo2dShiftTransform src)
inline
Copy constructor.
Definition at line 27 of file ossim2dTo2dShiftTransform.h.
◆ ~ossim2dTo2dShiftTransform()
virtual ossim2dTo2dShiftTransform::~ossim2dTo2dShiftTransform ( )
inlineprotectedvirtual
Definition at line 120 of file ossim2dTo2dShiftTransform.h.
120 {}
Member Function Documentation
◆ dup()
virtual ossimObject* ossim2dTo2dShiftTransform::dup ( ) const
inlinevirtual
Definition at line 35 of file ossim2dTo2dShiftTransform.h.
35 {return new ossim2dTo2dShiftTransform(*this);}
ossim2dTo2dShiftTransform(const ossimDpt &shift=ossimDpt(0.0, 0.0))
◆ forward() [1/2]
virtual void ossim2dTo2dShiftTransform::forward ( const ossimDpt input,
ossimDpt output
) const
inlinevirtual
Parameters
inputThe value to shift.
outputthe shifted value.
Implements ossim2dTo2dTransform.
Definition at line 57 of file ossim2dTo2dShiftTransform.h.
59  {
60  output = input + m_shift;
61  }
◆ forward() [2/2]
virtual void ossim2dTo2dShiftTransform::forward ( ossimDpt modify_this) const
inlinevirtual
Parameters
modify_thisThe value to shift. The result is placed back into this value.
Reimplemented from ossim2dTo2dTransform.
Definition at line 67 of file ossim2dTo2dShiftTransform.h.
References ossimDpt::x, and ossimDpt::y.
68  {
69  modify_this.x += m_shift.x;
70  modify_this.y += m_shift.y;
71  }
double y
Definition: ossimDpt.h:165
double x
Definition: ossimDpt.h:164
◆ inverse() [1/2]
virtual void ossim2dTo2dShiftTransform::inverse ( const ossimDpt input,
ossimDpt output
) const
inlinevirtual
Parameters
inputThe value to apply the negated shift.
Definition at line 79 of file ossim2dTo2dShiftTransform.h.
81  {
82  output = input - m_shift;
83  }
◆ inverse() [2/2]
virtual void ossim2dTo2dShiftTransform::inverse ( ossimDpt modify_this) const
inlinevirtual
Parameters
Definition at line 90 of file ossim2dTo2dShiftTransform.h.
91  {
92  modify_this.x -= m_shift.x;
93  modify_this.y -= m_shift.y;
94  }
double y
double x
◆ loadState()
bool ossim2dTo2dShiftTransform::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
virtual
Definition at line 13 of file ossim2dTo2dShiftTransform.cpp.
References ossimString::empty(), ossimKeywordlist::find(), ossim2dTo2dTransform::loadState(), m_shift, and ossimDpt::toPoint().
15 {
16  bool result = ossim2dTo2dTransform::loadState(kwl, prefix);
17
18  ossimString shift = kwl.find(prefix, "shift");
19  if(!shift.empty())
20  {
21  m_shift.toPoint(shift);
22  }
23
24  return result;
25 }
void toPoint(const std::string &s)
Initializes this point from string.
Definition: ossimDpt.cpp:192
bool empty() const
Definition: ossimString.h:411
◆ operator=()
const ossim2dTo2dShiftTransform& ossim2dTo2dShiftTransform::operator= ( const ossim2dTo2dShiftTransform src)
inline
The = is passed to the derived class.
Definition at line 41 of file ossim2dTo2dShiftTransform.h.
References m_shift, and ossim2dTo2dTransform::operator=().
42  {
43  if(this == &src) return *this;
44
45  ossim2dTo2dTransform::operator =(*this); // call base classes equal operator
46  m_shift = src.m_shift;
47
48  return *this;
49  }
virtual const ossim2dTo2dTransform & operator=(const ossim2dTo2dTransform &rhs)
◆ print()
virtual std::ostream& ossim2dTo2dShiftTransform::print ( std::ostream &  out) const
inlinevirtual
Definition at line 110 of file ossim2dTo2dShiftTransform.h.
References ossim2dTo2dTransform::print().
111  {
113
114  out << "shift: " << m_shift;
115
116  return out;
117  }
Generic print method.
◆ saveState()
bool ossim2dTo2dShiftTransform::saveState ( ossimKeywordlist kwl,
) const
virtual
Definition at line 4 of file ossim2dTo2dShiftTransform.cpp.
References ossimKeywordlist::add(), m_shift, ossim2dTo2dTransform::saveState(), and ossimDpt::toString().
6 {
7  bool result = ossim2dTo2dTransform::saveState(kwl, prefix);
8  kwl.add(prefix, "shift", m_shift.toString(), true);
9
10  return result;
11 }
ossimString toString(ossim_uint32 precision=15) const
Definition: ossimDpt.cpp:160
Member Data Documentation
◆ m_shift
ossimDpt ossim2dTo2dShiftTransform::m_shift
protected
Definition at line 122 of file ossim2dTo2dShiftTransform.h.
Referenced by loadState(), operator=(), and saveState().
◆ TYPE_DATA
ossim2dTo2dShiftTransform::TYPE_DATA
protected
Definition at line 124 of file ossim2dTo2dShiftTransform.h.
