ossimKeywordlist.cpp
Go to the documentation of this file.
1 //---
2 //
3 // License: MIT
4 //
5 // Description: This class provides capabilities for keywordlists.
6 //
7 //---
8 // $Id$
9
14
15 #include <ossim/base/ossimNotify.h>
16 #include <ossim/base/ossimRefPtr.h>
17 #include <ossim/base/ossimRegExp.h>
19 #include <ossim/base/ossimTrace.h>
21
22 #include <algorithm>
23 #include <fstream>
24 #include <list>
25 #include <memory>
26 #include <sstream>
27 #include <utility>
28
30
31 static ossimTrace traceDebug("ossimKeywordlist:debug");
32
33 #ifdef OSSIM_ID_ENABLED
34 static const bool TRACE = false;
35 static const char OSSIM_ID[] = "$Id: ossimKeywordlist.cpp 23632 2015-11-19 20:43:06Z dburken $";
36 #endif
37
38 const std::string ossimKeywordlist::NULL_KW = "";
39
41 :m_map(src.m_map),
42 m_delimiter(src.m_delimiter),
43 m_preserveKeyValues(src.m_preserveKeyValues),
44 m_expandEnvVars(src.m_expandEnvVars)
45 {
46 }
47
48 ossimKeywordlist::ossimKeywordlist(const std::map<std::string, std::string>& keywordMap)
49 :m_map(keywordMap),
50 m_delimiter(DEFAULT_DELIMITER),
51 m_preserveKeyValues(true),
52 m_expandEnvVars(true)
53 {
54
55 }
56
58  bool expandEnvVars)
59 :
60 m_map(),
61 m_delimiter(delimiter),
62 m_preserveKeyValues(true),
63 m_expandEnvVars(expandEnvVars)
64 {
65 #ifdef OSSIM_ID_ENABLED
66  if (TRACE) ossimNotify(ossimNotifyLevel_DEBUG) << OSSIM_ID << std::endl;
67 #endif
68 }
69
71  char delimiter,
72  bool ignoreBinaryChars,
73  bool expandEnvVars)
74 :
75 m_map(),
76 m_delimiter(delimiter),
77 m_preserveKeyValues(true),
78 //m_lineContinuationCharacter('\\'),
79 m_expandEnvVars(expandEnvVars)
80 {
81  ossimFilename in_file(file);
82
83  if (!parseFile(in_file, ignoreBinaryChars))
84  {
86  }
87 }
88
90  char delimiter,
91  bool ignoreBinaryChars,
92  bool expandEnvVars)
93 :
94 m_map(),
95 m_delimiter(delimiter),
96 m_preserveKeyValues(true),
97 m_expandEnvVars(expandEnvVars)
98
99 {
100  if (!parseFile(file, ignoreBinaryChars))
101  {
103  }
104 }
105
107 {
108  m_map.clear();
109 }
110
112 {
113  m_expandEnvVars = flag;
114 }
115
117 {
118  return m_expandEnvVars;
119 }
120
121 bool ossimKeywordlist::addFile(const char* file)
122 {
123  ossimFilename in_file(file);
124
125  return parseFile(in_file);
126 }
127
129 {
130  return parseFile(file);
131 }
132
133 void ossimKeywordlist::addList(const ossimKeywordlist &src, bool overwrite)
134 {
135  KeywordMap::const_iterator i = src.m_map.begin();
136
137  while (i != src.m_map.end())
138  {
139  addPair( (*i).first, (*i).second, overwrite );
140  i++;
141  }
142 }
143
145  const char* prefix,
146  bool stripPrefix)
147 {
148  std::map<std::string, std::string>::const_iterator iter = kwl.m_map.begin();
149
150  ossimRegExp regExp;
151
152  // Check for null prefix.
153  std::string tmpPrefix;
154  if (prefix) tmpPrefix = prefix;
155
156  regExp.compile(("^("+tmpPrefix+")").c_str());
157
158  while(iter != kwl.m_map.end())
159  {
160  ossimString newKey;
161
162  if(regExp.find( (*iter).first.c_str()))
163  {
164  newKey = (*iter).first;
165  if(stripPrefix && prefix)
166  {
167  newKey = newKey.substitute(prefix, "");
168
169  }
170
171  addPair(newKey.string(), (*iter).second, true);
172  }
173  ++iter;
174  }
175 }
176
177 void ossimKeywordlist::add(const char* prefix,
178  const ossimKeywordlist& kwl,
179  bool overwrite)
180 {
181  std::string p = prefix ? prefix : "";
182  std::map<std::string, std::string>::const_iterator iter = kwl.m_map.begin();
183  while(iter != kwl.m_map.end())
184  {
185  std::string k( p + (*iter).first );
186  addPair( k, (*iter).second, overwrite );
187  ++iter;
188  }
189 }
190
191 void ossimKeywordlist::addPair(const std::string& key,
192  const std::string& value,
193  bool overwrite)
194 {
195  if ( key.size() )
196  {
197  ossimString v = value;
198  if ( m_expandEnvVars == true )
199  {
201  }
202
203  KeywordMap::iterator i = getMapEntry(key);
204
205  if (i == m_map.end())
206  {
207  m_map.insert(std::make_pair(key, v.string()));
208  }
209  else if (overwrite)
210  {
211  (*i).second = v.string();
212  }
213  }
214 }
215
216 void ossimKeywordlist::addPair(const std::string& prefix,
217  const std::string& key,
218  const std::string& value,
219  bool overwrite)
220 {
221  std::string k(prefix + key);
222  addPair(k, value, overwrite);
223 }
224
225 void ossimKeywordlist::add(const char* key,
226  const char* value,
227  bool overwrite)
228 {
229  if ( key )
230  {
231  std::string k(key);
232  std::string v(value?value:"");
233  addPair(k, v, overwrite);
234  }
235 }
236
237 void ossimKeywordlist::add(const char* prefix,
238  const char* key,
239  const char* value,
240  bool overwrite)
241 {
242  if ( key )
243  {
244  std::string k(prefix ? (std::string(prefix)+std::string(key)) : key);
245  std::string v(value ? value : "");
246  addPair(k, v, overwrite);
247  }
248 }
249
250 void ossimKeywordlist::add(const char* key,
251  char value,
252  bool overwrite)
253 {
254  if ( key )
255  {
256  std::string k(key);
257  std::string v(1, value);
258  addPair(k, v, overwrite);
259  }
260 }
261
262 void ossimKeywordlist::add(const char* prefix,
263  const char* key,
264  char value,
265  bool overwrite)
266 {
267  if ( key )
268  {
269  std::string k(prefix ? (std::string(prefix)+std::string(key)) : key);
270  std::string v(1, value);
271  addPair(k, v, overwrite);
272  }
273 }
274
275 void ossimKeywordlist::add(const char* key,
276  ossim_int16 value,
277  bool overwrite)
278 {
279  if ( key )
280  {
281  std::string k(key);
282  std::string v = ossimString::toString(value).string();
283  addPair(k, v, overwrite);
284  }
285 }
286
287 void ossimKeywordlist::add(const char* prefix,
288  const char* key,
289  ossim_int16 value,
290  bool overwrite)
291 {
292  if ( key )
293  {
294  std::string k(prefix ? (std::string(prefix)+std::string(key)) : key);
295  std::string v = ossimString::toString(value).string();
296  addPair(k, v, overwrite);
297  }
298 }
299
300 void ossimKeywordlist::add(const char* key,
301  ossim_uint16 value,
302  bool overwrite)
303 {
304  if ( key )
305  {
306  std::string k(key);
307  std::string v = ossimString::toString(value).string();
308  addPair(k, v, overwrite);
309  }
310 }
311
312 void ossimKeywordlist::add(const char* prefix,
313  const char* key,
314  ossim_uint16 value,
315  bool overwrite)
316 {
317  if ( key )
318  {
319  std::string k(prefix ? (std::string(prefix)+std::string(key)) : key);
320  std::string v = ossimString::toString(value).string();
321  addPair(k, v, overwrite);
322  }
323 }
324
325 void ossimKeywordlist::add(const char* key,
326  ossim_int32 value,
327  bool overwrite)
328 {
329  if ( key )
330  {
331  std::string k(key);
332  std::string v = ossimString::toString(value).string();
333  addPair(k, v, overwrite);
334  }
335 }
336
337 void ossimKeywordlist::add(const char* prefix,
338  const char* key,
339  ossim_int32 value,
340  bool overwrite)
341 {
342  if ( key )
343  {
344  std::string k(prefix ? (std::string(prefix)+std::string(key)) : key);
345  std::string v = ossimString::toString(value).string();
346  addPair(k, v, overwrite);
347  }
348 }
349
350 void ossimKeywordlist::add(const char* key,
351  ossim_uint32 value,
352  bool overwrite)
353 {
354  if ( key )
355  {
356  std::string k(key);
357  std::string v = ossimString::toString(value).string();
358  addPair(k, v, overwrite);
359  }
360 }
361
362 void ossimKeywordlist::add(const char* prefix,
363  const char* key,
364  ossim_uint32 value,
365  bool overwrite)
366 {
367  if ( key )
368  {
369  std::string k(prefix ? (std::string(prefix)+std::string(key)) : key);
370  std::string v = ossimString::toString(value).string();
371  addPair(k, v, overwrite);
372  }
373 }
374
375 void ossimKeywordlist::add(const char* key,
376  ossim_int64 value,
377  bool overwrite)
378 {
379  if ( key )
380  {
381  std::string k(key);
382  std::string v = ossimString::toString(value).string();
383  addPair(k, v, overwrite);
384  }
385 }
386
387 void ossimKeywordlist::add(const char* prefix,
388  const char* key,
389  ossim_int64 value,
390  bool overwrite)
391 {
392  if ( key )
393  {
394  std::string k(prefix ? (std::string(prefix)+std::string(key)) : key);
395  std::string v = ossimString::toString(value).string();
396  addPair(k, v, overwrite);
397  }
398 }
399
400 void ossimKeywordlist::add(const char* key,
401  ossim_uint64 value,
402  bool overwrite)
403 {
404  if ( key )
405  {
406  std::string k(key);
407  std::string v = ossimString::toString(value).string();
408  addPair(k, v, overwrite);
409  }
410 }
411
412 void ossimKeywordlist::add(const char* prefix,
413  const char* key,
414  ossim_uint64 value,
415  bool overwrite)
416 {
417  if ( key )
418  {
419  std::string k(prefix ? (std::string(prefix)+std::string(key)) : key);
420  std::string v = ossimString::toString(value).string();
421  addPair(k, v, overwrite);
422  }
423 }
424
425 void ossimKeywordlist::add(const char* key,
426  ossim_float32 value,
427  bool overwrite,
428  int precision)
429 {
430  if ( key )
431  {
432  std::string k(key);
433  std::string v = ossimString::toString(value, precision).string();
434  addPair(k, v, overwrite);
435  }
436 }
437
438 void ossimKeywordlist::add(const char* prefix,
439  const char* key,
440  ossim_float32 value,
441  bool overwrite,
442  int precision)
443 {
444  if ( key )
445  {
446  std::string k(prefix ? (std::string(prefix)+std::string(key)) : key);
447  std::string v = ossimString::toString(value, precision).string();
448  addPair(k, v, overwrite);
449  }
450 }
451
452 void ossimKeywordlist::add(const char* key,
453  ossim_float64 value,
454  bool overwrite,
455  int precision)
456 {
457  if ( key )
458  {
459  std::string k(key);
460  std::string v = ossimString::toString(value, precision).string();
461  addPair(k, v, overwrite);
462  }
463 }
464
465 void ossimKeywordlist::add(const char* prefix,
466  const char* key,
467  ossim_float64 value,
468  bool overwrite,
469  int precision)
470 {
471  if ( key )
472  {
473  std::string k(prefix ? (std::string(prefix)+std::string(key)) : key);
474  std::string v = ossimString::toString(value, precision).string();
475  addPair(k, v, overwrite);
476  }
477 }
478
479 bool ossimKeywordlist::write(const char* file,
480  const char* comment) const
481 {
482  std::ofstream filename(file);
483  if (!filename)
484  {
486  <<"ossimKeywordlist::write, Error opening file: "
487  << file << std::endl;
488  return false;
489  }
490
491  if ( comment != 0 )
492  {
493  ossimString commentStr("// ");
494  commentStr += comment;
495
496  // Write out the input comment to the first line.
497  filename << commentStr.c_str() << std::endl;
498  }
499
500  writeToStream(filename);
501
502  filename.close();
503
504  return true;
505 }
506
508 {
509  std::ostringstream out;
510  writeToStream(out);
511
512 #if 0
513  KeywordMap::const_iterator i;
514  ossimString result;
515
516  for(i = m_map.begin(); i != m_map.end(); i++)
517  {
518  result += (*i).first;
519  result += delimiter_str().c_str();
520  result += " ";
521  result += (*i).second;
522  result += '\n';
523  }
524 #endif
525  return ossimString(out.str());
526 }
527
529 {
530  std::ostringstream out;
531  writeToStream(out);
532
533  result = out.str();
534 #if 0
535  KeywordMap::const_iterator i;
536
537  for(i = m_map.begin(); i != m_map.end(); i++)
538  {
539  result += (*i).first;
540  result += delimiter_str().c_str();
541  result += " ";
542  result += (*i).second;
543  result += '\n';
544  }
545 #endif
546 }
547
549 {
550  KeywordMap::const_iterator i;
551  ossimString value;
552  ossimRegExp reg("\n|\r| $|^ ");
553  for(i = m_map.begin(); i != m_map.end(); ++i)
554  {
555  value = (*i).second;
556  if(!value.empty())
557  {
558  if(reg.find(value))
559  {
560  value = "\"\"\"" + value + "\"\"\"";
561  }
562  }
563  // value = value.substitute('\n', "\\\n", true);
564  out << (*i).first << delimiter_str().c_str() << " "
565  << value << std::endl;
566  }
567 }
568
569 bool ossimKeywordlist::hasKey( const std::string& key ) const
570 {
571  bool result = false;
572  KeywordMap::const_iterator i = m_map.find(key);
573  if (i != m_map.end())
574  {
575  result = true;
576  }
577  return result;
578 }
579
580 const std::string& ossimKeywordlist::findKey(const std::string& key) const
581 {
582  // std::string result;
583  KeywordMap::const_iterator i = m_map.find(key);
584  if (i != m_map.end())
585  {
586  // result = (*i).second;
587  return (*i).second;
588  }
590 }
591
592 const std::string& ossimKeywordlist::findKey(const std::string& prefix,
593  const std::string& key) const
594 {
595  std::string k = prefix+key;
596  return findKey(k);
597 }
598
599 const char* ossimKeywordlist::find(const char* key) const
600 {
601  const char* result = 0;
602  if (key)
603  {
604  std::string k = key;
605  KeywordMap::const_iterator i = m_map.find( k );
606  if (i != m_map.end())
607  {
608  result = (*i).second.c_str();
609  }
610  }
611  return result;
612 }
613
614 const char* ossimKeywordlist::find(const char* prefix,
615  const char* key) const
616 {
617  const char* result = 0;
618  if (key)
619  {
620  std::string k;
621  if (prefix) k = prefix;
622  k += key;
623  KeywordMap::const_iterator i = m_map.find( k );
624  if (i != m_map.end())
625  {
626  result = (*i).second.c_str();
627  }
628  }
629  return result;
630 }
631
632 void ossimKeywordlist::remove(const char * key)
633 {
634  ossimString k = key?key:"";
635
636  KeywordMap::iterator i = m_map.find(k);
637
638  if(i != m_map.end())
639  {
640  m_map.erase(i);
641  }
642 }
643
644 void ossimKeywordlist::remove(const char* prefix, const char * key)
645 {
646  if (key)
647  {
648  ossimString k;
649  if (prefix) k = prefix;
650  k += key;
651
652  KeywordMap::iterator i = m_map.find(k);
653
654  if(i != m_map.end())
655  {
656  m_map.erase(i);
657  }
658  }
659 }
660
662 {
663  ossim_uint32 count = 0;
664
665  if (str)
666  {
667  KeywordMap::const_iterator i = m_map.begin();
668
669  while (i != m_map.end())
670  {
671  if ( ossimString((*i).first).contains(str) )
672  {
673  ++count;
674  }
675  ++i;
676  }
677  }
678
679  return count;
680 }
681
683  const char* key) const
684 {
685  if ( key ) // Must have key, sometimes no prefix.
686  {
687  std::string k(prefix ? (std::string(prefix)+std::string(key)) : key);
688  return numberOf(k.c_str());
689  }
690  return 0;
691 }
692
694 {
695  m_map.clear();
696 }
697
698 ossimKeywordlist::KeywordMap::iterator
700 {
701  if (key)
702  {
703  std::string k = key;
704  return m_map.find(k);
705  }
706  else
707  {
708  return m_map.end();
709  }
710 }
711
712 ossimKeywordlist::KeywordMap::iterator
713 ossimKeywordlist::getMapEntry(const std::string& key)
714 {
715  return m_map.find(key);
716 }
717
718 ossimKeywordlist::KeywordMap::iterator
720 {
721  return m_map.find(key.string());
722 }
723
724
725 //*******************************************************************
726 // Private Method:
727 //*******************************************************************
729  bool ignoreBinaryChars)
730 {
731  bool result = false;
732
733  std::shared_ptr<ossim::istream> is = ossim::StreamFactoryRegistry::instance()->
734  createIstream( file.string() );
735  if ( is )
736  {
737  m_currentlyParsing = file;
738  result = parseStream(*is, ignoreBinaryChars);
739  is.reset();
740  }
741
742  return result;
743 }
744
745 bool ossimKeywordlist::parseStream(ossim::istream& is, bool /* ignoreBinaryChars */)
746 {
747  return parseStream(is);
748 }
749
750 bool ossimKeywordlist::parseString(const std::string& inString)
751 {
752  ossim::istringstream in(inString);
753
754  return parseStream(in);
755 }
756
758 {
759  if((c>=0x20&&c<=0x7e))
760  {
761  return true;
762  }
763  switch(c)
764  {
765  case '\n':
766  case '\r':
767  case '\t':
768  return true;
769  }
770  return false;
771 }
772
774 {
775  int c = in.peek();
776  while( !in.fail() &&
777  ( (c == ' ') || (c == '\t') || (c == '\n') || (c == '\r') ) )
778  {
779  in.ignore(1);
780  c = in.peek();
781  }
782 }
783
785 {
787  char c = (char)in.peek();
788  if(c == '/')
789  {
790  sequence += (char)in.get();
791  c = in.peek();
792  if(c == '/')
793  {
794  result = KeywordlistParseState_OK;
795  sequence += c;
796  while(!in.bad()&&!in.eof())
797  {
798  c = (char)in.get();
799  if (in.bad() || in.eof())
800  break;
801
803  {
805  break;
806  }
807  if((c == '\n')|| (c == '\r'))
808  break;
809
810  sequence += c;
811  }
812  }
813  }
814  return result;
815 }
816
819 {
821
822  char c = (char)in.peek();
823  while (c == '#')
824  {
825  // Read the line as one big value:
826  ossimString sequence;
827  status = readValue(sequence, in);
828  if (status)
829  break;
830
831  ossimString directive = sequence.before(" ");
832
833  // Check for external KWL include file:
834  if (directive == "#include")
835  {
836  ossimFilename includeFile = sequence.after(" ");
837  if (includeFile.empty())
838  break; // ignore bogus preproc line
839  includeFile.trim("\"");
840  includeFile.expandEnvironmentVariable();
841
842  // The filename can be either relative to the current file being parsed or absolute:
843  if (includeFile.string()[0] != '/')
844  includeFile = m_currentlyParsing.path() + "/" + includeFile;
845
846  // Save the current path in case the new one contains it's own include directive!
847  ossimFilename savedCurrentPath = m_currentlyParsing;
848  addFile(includeFile); // Quietly ignore any errors loading external KWL.
849  m_currentlyParsing = savedCurrentPath;
850  }
851
852 // else if (directive == "#add_new_directive_here")
853 // {
854 // process directive
855 // }
856
858  break;
859  }
860  return status;
861 }
862
864 {
866  if(!sequence.empty())
867  {
868  if(*(sequence.begin()+(sequence.size()-1)) == m_delimiter)
869  {
870  sequence = ossimString(sequence.begin(), sequence.begin() + (sequence.size()-1));
872  }
873  }
874  // not a comment so read til key delimeter
875  while(!in.eof() && in.good())
876  {
877  ossim_uint8 c = in.get();
879  {
880  if ( (c == '\n') || (c == '\r') )
881  {
882  // Hit end of line with no delimiter.
883  if ( in.peek() == EOF )
884  {
885  //---
886  // Allowing on last line only.
887  // Note the empty key will trigger parseStream to return true.
888  //---
889  sequence.clear();
890  result = KeywordlistParseState_OK;
891  break;
892  }
893  else // Line with no delimiter.
894  {
895  // mal formed input stream for keyword list specification
897  break;
898  }
899  }
900  else if(c != m_delimiter)
901  {
902  sequence += (char)c;
903  }
904  else // at m_delimiter
905  {
906  result = KeywordlistParseState_OK;
907  sequence = sequence.trim();
908  break;
909  }
910  }
911  else
912  {
913  // mal formed input stream for keyword list specification
915  break;
916  }
917  }
918  // we never found a delimeter so we are mal formed
919  if(!sequence.empty()&&(result!=KeywordlistParseState_OK))
920  {
922  }
923  return result;
924 }
925
927 {
929
930  ossim_int32 quoteCount = 0; // mark as not set
931
932  // make sure we check for a blank value
933  while(!in.eof()&&!in.bad())
934  {
935  if(in.peek() == ' '||
936  in.peek() == '\t')
937  {
938  in.ignore();
939  }
940  else if(in.peek() == '\n' ||
941  in.peek() == '\r')
942  {
943  in.ignore();
944  return result;
945  }
946  else
947  {
948  break;
949  }
950  }
951  // The ifstream object will end in '�' (character 255 or -1) if the end-of-file indicator
952  // will not be set(e.g \n). In this case, end-of-file conditions would never be detected.
953  // add EOF (which is actually the integer -1 or 255) check here.
954  // Reference link http://www.cplusplus.com/forum/general/33821/
955  while(!in.eof()&&!in.bad()&&in.peek()!=EOF)
956  {
957  ossim_uint8 c = in.get();
959  {
960  if(((c == '\n'||c=='\r') && !quoteCount) || in.eof())
961  {
962  break;
963  }
964  sequence += (char)c;
965  if(sequence.size() >2)
966  {
967  if(quoteCount < 1)
968  {
969  //---
970  // If string has leading tripple quoted bump the "quoteCount" so
971  // we start skipping line breaks, preserving paragraph style strings.
972  //---
973  if(ossimString(sequence.begin(), sequence.begin()+3) == "\"\"\"")
974  {
975  ++quoteCount;
976  }
977  }
978  else // check for ending quotes
979  {
980  if(ossimString(sequence.begin() + sequence.size()-3, sequence.end()) == "\"\"\"")
981  {
982  ++quoteCount;
983  }
984  }
985  }
986  if(quoteCount > 1)
987  {
988  //---
989  // Have leading and trailing tripple quotes. Some tiff writers, e.g. Space
990  // Imaging are using four quotes. Below code strips all quotes from each end.
991  //---
992  char quote = '"';
993  std::string::size_type startPos = sequence.string().find_first_not_of(quote);
994  std::string::size_type stopPos = sequence.string().find_last_not_of(quote);
995  if ( ( startPos != std::string::npos ) && (stopPos != std::string::npos) )
996  {
997  sequence = sequence.string().substr( startPos, stopPos-startPos+1 );
998  }
999  break;
1000  }
1001  }
1002  else
1003  {
1005  break;
1006  }
1007  }
1008  return result;
1009 }
1010
1012 {
1014  if(keyState & KeywordlistParseState_BAD_STREAM) return keyState;
1015  ossimKeywordlist::KeywordlistParseState valueState = readValue(value, in);
1016  return static_cast<ossimKeywordlist::KeywordlistParseState>( (static_cast<int>(keyState) |
1017  static_cast<int>(valueState)) );
1018 }
1019
1021 {
1022  if (!is) // Check stream state.
1023  {
1024  return false;
1025  }
1026  ossimString key;
1027  ossimString value;
1028  ossimString sequence;
1030  while(!is.eof() && !is.bad())
1031  {
1032  skipWhitespace(is);
1033  if(is.eof() || is.bad())
1034  return true; // we skipped to end so valid keyword list
1035
1036  state = readPreprocDirective(is);
1038  return false;
1039
1040  // if we failed a preprocessor directive parse then try comment parse.
1041  if(state == KeywordlistParseState_FAIL)
1042  {
1043  state = readComments(sequence, is);
1045  return false;
1046  }
1047
1048  // if we failed a comment parse then try key value parse.
1049  if(state == KeywordlistParseState_FAIL)
1050  {
1051  key = sequence; // just in case there is a 1 token look ahead residual for a single slash test.
1052  ossimKeywordlist::KeywordlistParseState testKeyValueState = readKeyAndValuePair(key, value, is);
1053  if(testKeyValueState == KeywordlistParseState_OK)
1054  {
1055  key = key.trim();
1056  if(key.empty())
1057  return true;
1058
1059  if ( m_expandEnvVars == true )
1060  value = value.expandEnvironmentVariable();
1061  m_map.insert(std::make_pair(key.string(), value.string()));
1062  }
1063  else if(testKeyValueState & KeywordlistParseState_BAD_STREAM)
1064  {
1065  return false;
1066  }
1067 #if 0
1068  // Commented out to allow an invalid line in keyword list without
1069  // erroring out, effectively skipping bad line. drb - 01 Sep. 2001
1070  else
1071  {
1072  return false;
1073  }
1074 #endif
1075  }
1076  else if(state & KeywordlistParseState_BAD_STREAM)
1077  {
1078  return false;
1079  }
1080  sequence = key = value = "";
1081  }
1082
1083  return true;
1084 }
1085
1086 void ossimKeywordlist::getSortedList(std::vector<ossimString>& prefixValues,
1087  const ossimString &prefixKey)const
1088 {
1089  ossimString regExpression = ossimString("^(") + prefixKey+ "[0-9]+)";
1090  prefixValues.clear();
1091  std::vector<ossimString> keys;
1092  getSubstringKeyList(keys, regExpression);
1093  ossim_uint32 nKeys = (long)keys.size();
1094
1095  ossim_uint32 offset = (int)ossimString(prefixKey).size();
1096  ossim_uint32 idx = 0;
1097  std::vector<ossim_uint32> numberList(nKeys);
1098  for(idx = 0; idx < (ossim_uint32)numberList.size();++idx)
1099  {
1100  ossimString numberStr(keys[idx].begin() + offset,
1101  keys[idx].end());
1102  numberList[idx] = numberStr.toInt();
1103  }
1104  std::sort(numberList.begin(), numberList.end());
1105
1106  for(idx=0;idx < (ossim_uint32)numberList.size();++idx)
1107  {
1108  prefixValues.push_back(prefixKey+ossimString::toString(numberList[idx]));
1109  }
1110 }
1111
1112 std::vector<ossimString> ossimKeywordlist::findAllKeysThatContains(const ossimString &searchString)const
1113 {
1114  KeywordMap::const_iterator i;
1115  std::vector<ossimString> result;
1116
1117  for(i = m_map.begin(); i != m_map.end(); ++i)
1118  {
1119  if( ossimString((*i).first).contains(searchString))
1120  {
1121  result.push_back((*i).first);
1122  }
1123  }
1124
1125  return result;
1126 }
1127
1128 void ossimKeywordlist::findAllKeysThatMatch( std::vector<ossimString>& result,
1129  const ossimString &regularExpression ) const
1130 {
1131  KeywordMap::const_iterator i;
1132  ossimRegExp regExp;
1133  regExp.compile(regularExpression.c_str());
1134  for(i = m_map.begin(); i != m_map.end(); ++i)
1135  {
1136  if(regExp.find( (*i).first.c_str()))
1137  {
1138  result.push_back((*i).first);
1139  }
1140  }
1141 }
1142
1144  const ossimString &regularExpression ) const
1145 {
1146  ossim_uint32 result = 0;
1147  KeywordMap::const_iterator i;
1148  ossimRegExp regExp;
1149  regExp.compile(regularExpression.c_str());
1150  for(i = m_map.begin(); i != m_map.end(); ++i)
1151  {
1152  if(regExp.find( (*i).first.c_str()))
1153  {
1154  ++result;
1155  }
1156  }
1157  return result;
1158 }
1159
1161  const ossimString &regularExpression)const
1162 {
1163  KeywordMap::const_iterator i;
1164  std::vector<ossimString> result;
1165  ossimRegExp regExp;
1166
1167  regExp.compile(regularExpression.c_str());
1168
1169  for(i = m_map.begin(); i != m_map.end(); ++i)
1170  {
1171  if(regExp.find( (*i).first.c_str()))
1172  {
1173  kwl.addPair((*i).first, (*i).second);
1174  }
1175  }
1176 }
1177
1179 {
1180  KeywordMap::const_iterator i;
1181  std::vector<ossimString> result;
1182  ossimRegExp regExp;
1183
1184  regExp.compile(regularExpression.c_str());
1185
1186  for(i = m_map.begin(); i != m_map.end(); ++i)
1187  {
1188  if(regExp.find( (*i).first.c_str()))
1189  {
1190  result.push_back((*i).first);
1191  }
1192  }
1193  for(ossim_uint32 i2 = 0; i2 < result.size(); ++i2)
1194  {
1195  remove(result[i2]);
1196  }
1197 }
1198
1199 std::vector<ossimString> ossimKeywordlist::getSubstringKeyList(const ossimString& regularExpression)const
1200 {
1201  std::vector<ossimString> result;
1202  getSubstringKeyList(result, regularExpression);
1203  return result;
1204 }
1205
1206 void ossimKeywordlist::getSubstringKeyList(std::vector<ossimString>& result,
1207  const ossimString& regularExpression)const
1208 {
1209  KeywordMap::const_iterator i;
1210  ossimRegExp regExp;
1211
1212  regExp.compile(regularExpression.c_str());
1213
1214  for(i = m_map.begin(); i != m_map.end(); ++i)
1215  {
1216  if(regExp.find( (*i).first.c_str()))
1217  {
1218  ossimString value = ossimString((*i).first.begin()+regExp.start(),
1219  (*i).first.begin()+regExp.start()+regExp.end());
1220
1221  if(std::find(result.begin(), result.end(), value) == result.end())
1222  {
1223  result.push_back(value);
1224  }
1225  }
1226  }
1227 }
1228
1230 {
1231  KeywordMap::const_iterator i;
1232  std::vector<ossimString> currentList;
1233  getSubstringKeyList(currentList, regularExpression);
1234  return (ossim_uint32)currentList.size();
1235 }
1236
1238 {
1239  ossimKeywordlist tempKwl = *this;
1240
1241  clear();
1242
1243  KeywordMap::const_iterator values = tempKwl.m_map.begin();
1244
1245  while(values != tempKwl.m_map.end())
1246  {
1247  std::string newKey = prefix.string() + (*values).first;
1248  addPair(newKey, (*values).second, true);
1249  ++values;
1250  }
1251 }
1252
1254  const ossimString& regularExpression)
1255 {
1256  ossimKeywordlist tempKwl = *this;
1257
1258  clear();
1259
1260  KeywordMap::const_iterator values = tempKwl.m_map.begin();
1261  ossimRegExp regExp;
1262
1263  regExp.compile(regularExpression.c_str());
1264
1265  while(values != tempKwl.m_map.end())
1266  {
1267  std::string newKey = prefix.string()+(*values).first;
1268  if(regExp.find( (*values).first.c_str()))
1269  {
1270
1271  addPair(newKey, (*values).second, true);
1272  }
1273  else
1274  {
1275  addPair((*values).first, (*values).second, true);
1276  }
1277  ++values;
1278  }
1279 }
1280
1282 {
1283  ossimKeywordlist tempKwl = *this;
1284
1285  clear();
1286
1287  KeywordMap::const_iterator values = tempKwl.m_map.begin();
1288  ossimRegExp regExp;
1289
1290  regExp.compile(regularExpression.c_str());
1291
1292  while(values != tempKwl.m_map.end())
1293  {
1294  std::string newKey = (*values).first;
1295  if(regExp.find( (*values).first.c_str()))
1296  {
1297  newKey.erase(newKey.begin()+regExp.start(),
1298  newKey.begin()+regExp.start()+regExp.end());
1299
1300  addPair(newKey, (*values).second, true);
1301  }
1302  else
1303  {
1304  addPair(newKey, (*values).second, true);
1305  }
1306  ++values;
1307  }
1308 }
1309
1311 {
1312  return (ossim_uint32)m_map.size();
1313 }
1314
1316 {
1317  return m_map;
1318 }
1319
1321 {
1322  return m_map;
1323 }
1324
1326 {
1327  m_delimiter = del;
1328 }
1329
1331 {
1332  char tmp[2];
1333  tmp[0] = m_delimiter;
1334  tmp[1] = '\0';
1335  return ossimString(tmp);
1336 }
1337
1338 //*******************************************************************
1339 // Public Method:
1340 //*******************************************************************
1342 {
1343  writeToStream(os);
1344 #if 0
1345  KeywordMap::const_iterator i;
1346
1347  for(i = m_map.begin(); i != m_map.end(); ++i)
1348  {
1349  os << (*i).first << delimiter_str().c_str() << " "
1350  << (*i).second << std::endl;
1351  }
1352 #endif
1353  return os;
1354 }
1355
1356 //*******************************************************************
1357 // friend function:
1358 //*******************************************************************
1360  const ossimKeywordlist& kwl)
1361 {
1362  kwl.print(os);
1363
1364  return os;
1365 }
1366
1368 {
1369  return (m_map == kwl.m_map);
1370  /*
1371  if(this==&kwl) return true;
1372  std::map<std::string, std::string>::const_iterator iter = m_map.begin();
1373
1374  while(iter != m_map.end())
1375  {
1376  const char* value = kwl.find((*iter).first.c_str());
1377
1378  if(ossimString(value) != (*iter).second)
1379  {
1380  return false;
1381  }
1382  ++iter;
1383  }
1384
1385  return true;
1386  */
1387 }
1388
1390 {
1391  return (m_map != kwl.m_map);
1392 }
1393
1395 {
1396  KeywordMap tempMap;
1397  KeywordMap::iterator iter = m_map.begin();
1398
1399  while(iter != m_map.end())
1400  {
1401  ossimString k(iter->first);
1402  tempMap.insert(std::make_pair(k.downcase().string(), iter->second));
1403  ++iter;
1404  }
1405  m_map = tempMap;
1406
1407  return *this;
1408 }
1409
1411 {
1412  KeywordMap tempMap;
1413  KeywordMap::iterator iter = m_map.begin();
1414
1415  while(iter != m_map.end())
1416  {
1417  ossimString k(iter->first);
1418  tempMap.insert(std::make_pair(k.upcase().string(), iter->second));
1419  ++iter;
1420  }
1421  m_map = tempMap;
1422
1423  return *this;
1424 }
1425
1427 {
1428  KeywordMap::iterator iter = m_map.begin();
1429
1430  while(iter != m_map.end())
1431  {
1432  iter->second = ossimString(iter->second).trim(valueToTrim).string();
1433  ++iter;
1434  }
1435
1436  return *this;
1437 }
1438
1440 {
1441  ossimKeywordlist result(*this);
1442  result.trimAllValues(valueToTrim);
1443  return result;
1444 }
1445
1446
1447 //*************************************************************************************************
1452 //*************************************************************************************************
1454  const char* keyword,
1455  const char* prefix) const
1456 {
1457  bool found = true;
1458  const char* val_str = find(prefix, keyword);
1459  if (val_str)
1460  {
1461  found = true;
1462  ossimString yesno (val_str);
1463  yesno.upcase();
1464  if ((yesno == "YES") || (yesno == "TRUE") || (yesno == "1"))
1465  rtn_val = true;
1466  else if ((yesno == "NO") || (yesno == "FALSE") || (yesno == "0"))
1467  rtn_val = false;
1468  else
1469  found = false;
1470  }
1471  else
1472  found = false;
1473
1474  return found;
1475 }
1476
1478 {
1479  for(ossimString::const_iterator it = value.begin(); it != value.end();++it)
1480  {
1481  switch(*it)
1482  {
1483  case '&':
1484  case '<':
1485  case '>':
1486  case '"':
1487  case '\'':
1488  {
1489  return true;
1490  }
1491  default:
1492  {
1493  break;
1494  }
1495  }
1496
1497  }
1498  return false;
1499 }
1500
1501 bool ossimKeywordlist::isValidTag(const std::string& value)const
1502 {
1503  std::string::const_iterator textChars = value.begin();
1504  bool result = true;
1505  if(!isalpha(*(textChars) ))
1506  {
1507  result = false;
1508  }
1509  else if(!value.empty())
1510  {
1511  for(++textChars;textChars!=value.end();++textChars)
1512  {
1513  if(!isalnum(*(textChars) ))
1514  {
1515  result = false;
1516  break;
1517  }
1518  }
1519  }
1520  else
1521  {
1522  result = false;
1523  }
1524
1525  return result;
1526 }
1527
1529 {
1530  ossimString::iterator iter = value.begin();
1531
1532  while(iter!=value.end())
1533  {
1534  if(!(isdigit(*iter) ||
1535  isalpha(*iter)||
1536  (*iter=='/')))
1537  {
1538  *iter = '_';
1539  }
1540  ++iter;
1541  }
1542 }
1543
1544 void ossimKeywordlist::toXML(std::ostream& out, const std::string& rootTag)const
1545 {
1546  std::string rootTagStr = rootTag;
1547  if (!isValidTag(rootTagStr))
1548  {
1549  rootTagStr = "info";
1550  }
1551
1552  ossimRefPtr<ossimXmlNode> metadata = new ossimXmlNode;
1553  metadata->setTag("metadata");
1554  ossimKeywordlist::KeywordMap::const_iterator iter = m_map.begin();
1555  while(iter != m_map.end())
1556  {
1557  ossimString path = iter->first;
1558  bool outputValue = true;
1559  ossimString value = iter->second;
1560  if(path.contains("unformatted_tag_data"))
1561  {
1562  ossimString temp = value.trim();
1563  if(ossimString(temp.begin(), temp.begin()+5) == "<?xml")
1564  {
1565  value = "XML not converted";
1566  outputValue = false;
1567  }
1568  }
1569
1570  if(outputValue)
1571  {
1572  bool tagOk = true;
1573  path = path.substitute(".", "/", true);
1575  std::vector<ossimString> splitValues;
1576  path.split(splitValues,"/");
1577  if(splitValues.size())
1578  {
1579  splitValues[splitValues.size()-1] = splitValues[splitValues.size()-1].downcase();
1580  ossim_uint32 idx = 0;
1581  for(idx = 0; ((idx < splitValues.size()-1)&&tagOk);++idx)
1582  {
1583  if(!isValidTag(splitValues[idx]))
1584  {
1585  tagOk = false;
1586  }
1587  splitValues[idx] = splitValues[idx].upcase();
1588  }
1589  }
1590  if(tagOk)
1591  {
1592  path.join(splitValues, "/");
1593  ossimRefPtr<ossimXmlNode> node = metadata->addNode(path.c_str(), value);
1594  if(isSpecialXmlCharacters(value))
1595  {
1596  node->setCDataFlag(true);
1597  }
1598  }
1599  }
1600  ++iter;
1601  }
1602
1603  if( 1 ) // tmp dbr !m_includeMetadataTagName)
1604  {
1605  out << "<?xml version=\"1.0\" encoding=\"UTF-8\"?>" << std::endl
1606  << "<" << rootTagStr << ">\n";
1607
1608  const ossimXmlNode::ChildListType& children = metadata->getChildNodes();
1609  ossimXmlNode::ChildListType::const_iterator iter = children.begin();
1610  while(iter != children.end())
1611  {
1612  out << *(iter->get());
1613  ++iter;
1614  }
1615  out << "\n</" << rootTagStr << ">" << std::endl;
1616  }
1617  else
1618  {
1619  out << *(metadata.get()) << std::endl;
1620  }
1621 }
1622
1623
1624 void ossimKeywordlist::toJSON(std::ostream& out, const std::string& rootTag)const
1625 {
1626  const std::string C = ": "; // colon
1627  const std::string DQ = "\""; // double Quote
1628  const std::string LB = "{"; // left bracket
1629  const std::string CNL = ",\n"; // coma, new line
1630  const std::string NL = "\n"; // new line
1631  const std::string RB = "}"; // left bracket
1632  const std::string S = " "; // space
1633  ossim_uint32 nameCount = 0;
1634  ossimString lastObject;
1635  ossim_uint32 indentCount = 3;
1636  ossim_uint32 indentOffset = 3;
1637
1638  bool stringify = true;
1639  bool closeObject = false;
1640  std::vector<ossimString> objectStack;
1641
1642  // Opening bracket:
1643  out << LB;
1644
1645  if( rootTag.size() )
1646  {
1647  if ( stringify )
1648  {
1649  indentOffset = indentCount;
1650  std::string indent(indentCount, ' ');
1651  out << NL << indent;
1652  }
1653  else
1654  {
1655  out << NL;
1656  }
1657  // Note: not adding rootTag to object stack
1658  out << DQ << rootTag << DQ << C << LB << NL;
1659  }
1660
1661  ossimKeywordlist::KeywordMap::const_iterator iter = m_map.begin();
1662  while(iter != m_map.end())
1663  {
1664  bool outputValue = true;
1665  ossimString key = iter->first;
1666  ossimString value = iter->second;
1667  value = value.trim(); // remove spaces
1668
1669 #if 0
1670  if(key.contains("unformatted_tag_data"))
1671  {
1672  ossimString temp = value.trim();
1673  if(ossimString(temp.begin(), temp.begin()+5) == "<?xml")
1674  {
1675  value = "data not converted";
1676  outputValue = false;
1677  }
1678  }
1679 #endif
1680
1681  if ( outputValue && key.size() )
1682  {
1683  std::vector<ossimString> keys;
1684  key.split(keys,".");
1685
1686  if ( keys.size() )
1687  {
1688  // The last key is the name so grab it now and pop it off the stack:
1689  ossimString name = keys[keys.size()-1];
1690  keys.pop_back();
1691
1692  bool sameObject = isSame( keys, objectStack );
1693  if ( !sameObject && keys.size() )
1694  {
1695  for ( ossim_uint32 i = 0; i < keys.size(); ++i )
1696  {
1697  if ( i < objectStack.size() )
1698  {
1699  if ( keys[i] == objectStack[i] )
1700  {
1701  // On stack already. Nothng to do. Go to next key.
1702  continue;
1703  }
1704  else
1705  {
1706  // Different object:
1707  while ( i < objectStack.size() )
1708  {
1709  // Write bracket, then pop:
1710  if ( stringify )
1711  {
1712  std::string indent(indentOffset+(indentCount*objectStack.size()), ' ');
1713  out << NL << indent << RB;
1714  }
1715  else
1716  {
1717  out << NL << RB;
1718  }
1719  objectStack.pop_back();
1720  nameCount = 0;
1721  closeObject = true;
1722  if ( objectStack.size() )
1723  {
1724  lastObject = objectStack[objectStack.size()-1];
1725  }
1726  else
1727  {
1728  lastObject.clear();
1729  }
1730  }
1731  }
1732  }
1733
1734  //---
1735  // New object:
1736  // If we had written a key:value for previos object, do a
1737  // newline and zero it out.
1738  //---
1739  if ( nameCount )
1740  {
1741  out << CNL;
1742  nameCount = 0;
1743  }
1744
1745  objectStack.push_back( keys[i] );
1746
1747  if ( closeObject )
1748  {
1749  out << CNL;
1750  closeObject = false;
1751  }
1752
1753  if ( stringify )
1754  {
1755  std::string indent(indentOffset+(indentCount*objectStack.size()), ' ');
1756  out << indent;
1757  }
1758  out << DQ << keys[i] << DQ << C << LB << NL;
1759  }
1760
1761  // Final check if keys shrunk, pop objects off the object stack.
1762  while ( keys.size() < objectStack.size() )
1763  {
1764  // Write bracket then pop:
1765  if ( stringify )
1766  {
1767  std::string indent(indentOffset+(indentCount*objectStack.size()), ' ');
1768  out << NL << indent << RB;
1769  }
1770  else
1771  {
1772  out << NL << RB;
1773  }
1774  objectStack.pop_back();
1775  nameCount = 0;
1776  closeObject = true;
1777  if ( objectStack.size() )
1778  {
1779  lastObject = objectStack[objectStack.size()-1];
1780  }
1781  else
1782  {
1783  lastObject.clear();
1784  }
1785  }
1786  }
1787
1788  if ( objectStack.size() )
1789  {
1790  if ( lastObject == objectStack[objectStack.size()-1] )
1791  {
1792  out << CNL;
1793  closeObject = false;
1794  }
1795  }
1796  else if ( nameCount ) // No objects loaded on the stack.
1797  {
1798  out << CNL;
1799  }
1800
1801  // Output "key": "value"
1802  if ( stringify )
1803  {
1804  std::string indent(indentOffset+indentCount*(objectStack.size()+1), ' ');
1805  out << indent;
1806  }
1807  out << DQ << name << DQ << C << DQ << value << DQ;
1808
1809  if ( objectStack.size() )
1810  {
1811  lastObject = objectStack[objectStack.size()-1];
1812  }
1813  else
1814  {
1815  lastObject.clear();
1816  }
1817
1818  ++nameCount;
1819  }
1820  }
1821  ++iter;
1822
1823  } // Matches: while(iter != m_map.end())
1824
1825  // Close out brackets:
1826  ossim_uint32 stackSize = objectStack.size();
1827  if ( stackSize )
1828  {
1829  for ( ossim_uint32 i = stackSize; i > 0; --i )
1830  {
1831  if ( stringify )
1832  {
1833  std::string indent(indentOffset+indentCount*i, ' ');
1834  out << NL << indent << RB;
1835  }
1836  else
1837  {
1838  out << NL << RB;
1839  }
1840  }
1841  }
1842
1843  if( rootTag.size() )
1844  {
1845  if ( stringify )
1846  {
1847  std::string indent(indentCount, ' ');
1848  out << NL << indent << RB;
1849  }
1850  else
1851  {
1852  out << NL << RB;
1853  }
1854  }
1855
1856  // Closing bracket, newline with flush:
1857  out << NL << RB << std::endl;
1858 }
1859
1860 bool ossimKeywordlist::isSame( const std::vector<ossimString>& a,
1861  const std::vector<ossimString>& b ) const
1862 {
1863  bool result = true;
1864  if ( a.size() == b.size() )
1865  {
1866  for ( ossim_uint32 i = 0; i < a.size(); ++i )
1867  {
1868  if ( a[i] != b[i] )
1869  {
1870  result = false;
1871  break;
1872  }
1873  }
1874  }
1875  else
1876  {
1877  result = false;
1878  }
1879  return result;
1880 }
void clear()
Erases the entire container.
Definition: ossimString.h:432
void addPrefixToKeysThatMatch(const ossimString &prefix, const ossimString &regularExpression)
ossimString before(const ossimString &str, std::string::size_type pos=0) const
METHOD: before(str, pos) Returns string beginning at pos and ending one before the token str If strin...
void setTag(const ossimString &tag)
ossimString substitute(const ossimString &searchKey, const ossimString &replacementValue, bool replaceAll=false) const
Substitutes searchKey string with replacementValue and returns a string.
void stripPrefixFromAll(const ossimString &regularExpression)
virtual std::ostream & print(std::ostream &os) const
static ossimString upcase(const ossimString &aString)
Definition: ossimString.cpp:34
ossim_uint32 numberOf(const char *str) const
std::basic_ostringstream< char > ostringstream
Class for char output memory streams.
Definition: ossimIosFwd.h:35
ossim_uint32 getNumberOfSubstringKeys(const ossimString &regularExpression) const
ossimKeywordlist & upcaseKeywords()
#define OSSIMDLLEXPORT
std::string::iterator iterator
Definition: ossimString.h:27
const ossimString & join(const std::vector< ossimString > &stringList, const ossimString &separator)
OSSIMDLLEXPORT std::ostream & operator<<(std::ostream &os, const ossimKeywordlist &kwl)
std::vector< ossimString > findAllKeysThatContains(const ossimString &searchString) const
KeywordlistParseState readKey(ossimString &sequence, ossim::istream &in) const
bool addFile(const char *file)
const std::string & findKey(const std::string &key) const
Find methods that take std::string(s).
float ossim_float32
const ossimXmlNode::ChildListType & getChildNodes() const
ossimKeywordlist & downcaseKeywords()
bool contains(char aChar) const
Definition: ossimString.h:58
bool hasKey(const std::string &key) const
Checks for key in map.
void addList(const ossimKeywordlist &src, bool overwrite=true)
KeywordlistParseState readComments(ossimString &sequence, ossim::istream &in) const
Numeric to string methods.
void toXML(std::ostream &out, const std::string &rootTag="info") const
Outputs in xml format.
void change_delimiter(char del)
std::string::const_iterator const_iterator
Definition: ossimString.h:26
void addPair(const std::string &key, const std::string &value, bool overwrite=true)
static const ossimErrorCode OSSIM_ERROR
static StreamFactoryRegistry * instance()
bool getExpandEnvVarsFlag(void) const
ossimRefPtr< ossimXmlNode > addNode(const ossimString &relPath, const ossimString &text="")
unsigned short ossim_uint16
void findAllKeysThatMatch(std::vector< ossimString > &result, const ossimString &regularExpression) const
Finds keys that match regular expression.
virtual bool write(const char *file, const char *comment=0) const
Methods to dump the ossimKeywordlist to a file on disk.
void skipWhitespace(ossim::istream &in) const
std::string::iterator end()
Definition: ossimString.h:423
KeywordlistParseState readPreprocDirective(ossim::istream &in)
ossim_uint32 getNumberOfKeysThatMatch(const ossimString &regularExpression) const
Gets number keys that match regular expression.
std::vector< ossimRefPtr< ossimXmlNode > > ChildListType
Definition: ossimXmlNode.h:30
void removeKeysThatMatch(const ossimString &regularExpression)
void push_back(char c)
Equivalent to insert(end(), c).
Definition: ossimString.h:905
double ossim_float64
bool isValidTag(const std::string &value) const
ossimString expandEnvironmentVariable() const
If the variable "$(env_var_name)" is found in the string, where "env_var_name" is any system environm...
std::map< std::string, std::string > KeywordMap
KeywordMap::iterator getMapEntry(const std::string &key)
std::string::size_type size() const
Definition: ossimString.h:405
std::string::iterator begin()
Definition: ossimString.h:420
unsigned long long ossim_uint64
unsigned int ossim_uint32
ossimString trim(const ossimString &valueToTrim=ossimString(" \\)) const
this will strip lead and trailing character passed in.
void extractKeysThatMatch(ossimKeywordlist &kwl, const ossimString &regularExpression) const
virtual void writeToStream(std::ostream &out) const
bool isSpecialXmlCharacters(const ossimString &value) const
void compile(const char *)
bool getBoolKeywordValue(bool &rtn_val, const char *keyword, const char *prefix=0) const
[OLK, Aug/2008] Sets the boolean <rtn_val> depending on value associated with keyword for values = (y...
bool operator!=(ossimKeywordlist &kwl) const
virtual bool parseString(const std::string &inString)
KeywordlistParseState readKeyAndValuePair(ossimString &key, ossimString &value, ossim::istream &in) const
ossim_uint32 start() const
Definition: ossimRegExp.h:209
void addPrefixToAll(const ossimString &prefix)
std::vector< ossimString > getSubstringKeyList(const ossimString &regularExpression) const
return status
ossim_uint32 end() const
Definition: ossimRegExp.h:217
bool operator==(ossimKeywordlist &kwl) const
void toJSON(std::ostream &out, const std::string &rootTag="info") const
Outputs in json format.
short ossim_int16
std::basic_istream< char > istream
Base class for char input streams.
Definition: ossimIosFwd.h:20
const ossimKeywordlist::KeywordMap & getMap() const
static const std::string NULL_KW
ossimKeywordlist(const ossimKeywordlist &src)
void getSortedList(std::vector< ossimString > &prefixValues, const ossimString &prefixKey) const
This return the sorted keys if you have a list.
void setCDataFlag(bool value)
virtual bool parseStream(ossim::istream &is, bool ignoreBinaryChars)
deprecated method
ossim_uint32 getSize() const
ossimFilename m_currentlyParsing
void replaceSpecialCharacters(ossimString &value) const
long long ossim_int64
const char * c_str() const
Definition: ossimString.h:396
bool empty() const
Definition: ossimString.h:411
ossimString delimiter_str() const
bool isSame(const std::vector< ossimString > &a, const std::vector< ossimString > &b) const
bool isValidKeywordlistCharacter(ossim_uint8 c) const
std::basic_ofstream< char > ofstream
Class for char output file streams.
Definition: ossimIosFwd.h:47
virtual ossimString toString() const
std::basic_istringstream< char > istringstream
Class for char input memory streams.
Definition: ossimIosFwd.h:32
ossimString after(const ossimString &str, std::string::size_type pos=0) const
METHOD: after(str, pos) Returns string immediately after the token str.
bool parseFile(const ossimFilename &file, bool ignoreBinaryChars=false)
void setExpandEnvVarsFlag(bool flag)
bool find(const char *)
ossimFilename path() const
void remove(const char *key)
unsigned char ossim_uint8
int toInt() const
std::basic_ostream< char > ostream
Base class for char output streams.
Definition: ossimIosFwd.h:23
int ossim_int32
ossimKeywordlist & trimAllValues(const ossimString &valueToTrim=ossimString(" \\))
KeywordlistParseState readValue(ossimString &sequence, ossim::istream &in) const
const std::string & string() const
Definition: ossimString.h:414
