ossimAnnotationMultiPolyLineObject Class Reference
#include <ossimAnnotationMultiPolyLineObject.h>
Inheritance diagram for ossimAnnotationMultiPolyLineObject:
ossimAnnotationObject ossimObject ossimReferenced
Public Member Functions
 ossimAnnotationMultiPolyLineObject ()
 ossimAnnotationMultiPolyLineObject (const vector< ossimPolyLine > &multiPoly, unsigned char r, unsigned char g, unsigned char b, long thickness)
 ossimAnnotationMultiPolyLineObject (const ossimAnnotationMultiPolyLineObject &rhs)
virtual void applyScale (double x, double y)
virtual void draw (ossimRgbImage &anImage) const
virtual bool intersects (const ossimDrect &rect) const
virtual ossimAnnotationObjectgetNewClippedObject (const ossimDrect &rect) const
 Generic print method. More...
virtual void getBoundingRect (ossimDrect &rect) const
virtual void addPolyLine (const ossimPolyLine &poly)
virtual void addPoint (ossim_uint32 polygonIndex, const ossimDpt &pt)
virtual void setMultiPolyLine (const vector< ossimPolyLine > &multiPoly)
virtual void computeBoundingRect ()
virtual bool isPointWithin (const ossimDpt &imagePoint) const
const std::vector< ossimPolyLine > & getMultiPolyLine () const
- Public Member Functions inherited from ossimAnnotationObject
virtual ~ossimAnnotationObject ()
 ossimAnnotationObject (ossim_uint8 r=255, ossim_uint8 g=255, ossim_uint8 b=255, ossim_uint8 thickness=1)
virtual void applyScale (const ossimDpt &scale)
virtual ossimDrect getBoundingRect () const
virtual void setColor (ossim_uint8 r, ossim_uint8 g, ossim_uint8 b)
void getColor (ossim_uint8 &r, ossim_uint8 &g, ossim_uint8 &b) const
ossim_uint8 getThickness () const
virtual void setThickness (ossim_uint8 thickness)
 Saves the current state of this object. More...
virtual ossimString getName () const
virtual void setName (const ossimString &name)
ossim_uint32 getId () const
virtual ossim_uint32 setId ()
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
Protected Member Functions
virtual ~ossimAnnotationMultiPolyLineObject ()
virtual ~ossimReferenced ()
Protected Attributes
vector< ossimPolyLinetheMultiPolyLine
ossimDrect theBoundingRect
- Protected Attributes inherited from ossimAnnotationObject
ossim_uint8 theRed
ossim_uint8 theGreen
ossim_uint8 theBlue
ossim_uint8 theThickness
ossimString theName
ossim_uint32 theId
Additional Inherited Members
- Static Public Member Functions inherited from ossimAnnotationObject
static ossim_uint32 getNextId ()
static void restIdCounter ()
- Static Protected Attributes inherited from ossimAnnotationObject
static ossim_uint32 theIdCounter = 0
Detailed Description
Definition at line 17 of file ossimAnnotationMultiPolyLineObject.h.
◆ ossimAnnotationMultiPolyLineObject() [1/3]
ossimAnnotationMultiPolyLineObject::ossimAnnotationMultiPolyLineObject ( )
Definition at line 18 of file ossimAnnotationMultiPolyLineObject.cpp.
Referenced by dup().
20 {
22 }
ossimAnnotationObject(ossim_uint8 r=255, ossim_uint8 g=255, ossim_uint8 b=255, ossim_uint8 thickness=1)
◆ ossimAnnotationMultiPolyLineObject() [2/3]
ossimAnnotationMultiPolyLineObject::ossimAnnotationMultiPolyLineObject ( const vector< ossimPolyLine > &  multiPoly,
unsigned char  r,
unsigned char  g,
unsigned char  b,
long  thickness
Definition at line 24 of file ossimAnnotationMultiPolyLineObject.cpp.
References computeBoundingRect(), and theMultiPolyLine.
29  :ossimAnnotationObject(r, g, b, thickness)
30 {
31  theMultiPolyLine = multiPoly;
33 }
◆ ossimAnnotationMultiPolyLineObject() [3/3]
ossimAnnotationMultiPolyLineObject::ossimAnnotationMultiPolyLineObject ( const ossimAnnotationMultiPolyLineObject rhs)
Definition at line 214 of file ossimAnnotationMultiPolyLineObject.cpp.
215  : ossimAnnotationObject(rhs),
218 {
219 }
◆ ~ossimAnnotationMultiPolyLineObject()
ossimAnnotationMultiPolyLineObject::~ossimAnnotationMultiPolyLineObject ( )
protectedvirtual
Definition at line 35 of file ossimAnnotationMultiPolyLineObject.cpp.
36 {
37 }
Member Function Documentation
◆ addPoint()
void ossimAnnotationMultiPolyLineObject::addPoint ( ossim_uint32  polygonIndex,
const ossimDpt pt
virtual
Definition at line 231 of file ossimAnnotationMultiPolyLineObject.cpp.
References theMultiPolyLine.
233 {
234  if(polygonIndex < theMultiPolyLine.size())
235  {
236  theMultiPolyLine[polygonIndex].addPoint(pt);
237  }
238 }
◆ addPolyLine()
void ossimAnnotationMultiPolyLineObject::addPolyLine ( const ossimPolyLine poly)
virtual
Definition at line 226 of file ossimAnnotationMultiPolyLineObject.cpp.
227 {
228  theMultiPolyLine.push_back(poly);
229 }
◆ applyScale()
void ossimAnnotationMultiPolyLineObject::applyScale ( double  x,
double  y
virtual
Implements ossimAnnotationObject.
Definition at line 39 of file ossimAnnotationMultiPolyLineObject.cpp.
References computeBoundingRect(), theMultiPolyLine, x, and y.
41 {
42  for(ossim_uint32 i =0; i<theMultiPolyLine.size(); ++i)
43  {
44  theMultiPolyLine[i] *= ossimDpt(x, y);
45  }
47  // theBoundingRect *= ossimDpt(x,y);
48 }
ossim_uint32 x
ossim_uint32 y
unsigned int ossim_uint32
◆ computeBoundingRect()
void ossimAnnotationMultiPolyLineObject::computeBoundingRect ( )
virtual
Definition at line 162 of file ossimAnnotationMultiPolyLineObject.cpp.
References ossimDrect::combine(), ossimDrect::hasNans(), ossimDrect::height(), ossimDrect::makeNan(), theBoundingRect, theMultiPolyLine, ossimAnnotationObject::theThickness, ossimDrect::ul(), ossimDrect::width(), ossimIpt::x, and ossimIpt::y.
Referenced by applyScale(), ossimGeoAnnotationMultiPolyLineObject::computeBoundingRect(), ossimAnnotationMultiPolyLineObject(), and setMultiPolyLine().
163 {
164  if(theMultiPolyLine.size())
165  {
166  ossimDrect rect(theMultiPolyLine[0].getVertexList());
167
168  for(ossim_uint32 i = 1; i < theMultiPolyLine.size(); ++i)
169  {
170  ossimDrect rect2(theMultiPolyLine[i].getVertexList());
171
172  if(rect.hasNans())
173  {
174  rect = rect2;
175  }
176  else
177  {
178  if(!rect2.hasNans())
179  {
180  rect = rect.combine(rect2);
181  }
182  }
183  }
184
185  theBoundingRect = rect;
186  }
187  else
188  {
190  }
191  if(!theBoundingRect.hasNans())
192  {
193  ossimIpt origin = theBoundingRect.ul();
195  origin.y - theThickness/2,
196  origin.x + (theBoundingRect.width()-1) + theThickness/2,
197  origin.y + (theBoundingRect.height()-1) + theThickness/2);
198  }
199 }
void makeNan()
Definition: ossimDrect.h:388
ossim_float64 width() const
Definition: ossimDrect.h:522
const ossimDpt & ul() const
Definition: ossimDrect.h:339
bool hasNans() const
Definition: ossimDrect.h:396
ossim_float64 height() const
Definition: ossimDrect.h:517
ossim_int32 y
Definition: ossimIpt.h:142
ossim_int32 x
Definition: ossimIpt.h:141
◆ draw()
void ossimAnnotationMultiPolyLineObject::draw ( ossimRgbImage anImage) const
virtual
Definition at line 82 of file ossimAnnotationMultiPolyLineObject.cpp.
References ossimRgbImage::drawLine(), ossimRgbImage::getImageData(), ossimImageData::getImageRectangle(), ossimPolyLine::getNumberOfVertices(), ossimDrect::hasNans(), ossimDrect::intersects(), ossimDrect::lr(), ossimRgbImage::setDrawColor(), ossimRgbImage::setThickness(), ossimAnnotationObject::theBlue, theBoundingRect, ossimAnnotationObject::theGreen, theMultiPolyLine, ossimAnnotationObject::theRed, ossimAnnotationObject::theThickness, ossimDrect::ul(), ossimDpt::x, and ossimDpt::y.
Referenced by ossimGeoAnnotationMultiPolyLineObject::draw().
83 {
84  if(theMultiPolyLine.size()<1) return;
85  if(theBoundingRect.hasNans()) return;
86
87
89  anImage.setThickness(theThickness);
90  ossimDrect imageRect = anImage.getImageData()->getImageRectangle();
91
92  if(theBoundingRect.intersects(imageRect))
93  {
94  // we need to extend it by a couple of pixels since
95  // if a pixel lies on the edge and then another pixel is just off
96  // the edge we will get a stair step and so for several pixels
97  // the line might be inside the image rectangle but the clip
98  // algorithm will only draw 1 pixel since it thinks the first
99  // point is inside and the second point is outside and will
100  // execute the clip algorithm keeping only the first
101  // point.
102  ossimDrect clipRect(imageRect.ul().x - 10,
103  imageRect.ul().y - 10,
104  imageRect.lr().x + 10,
105  imageRect.lr().y + 10);
106
107  int j = 0;
108  for(ossim_uint32 i = 0; i < theMultiPolyLine.size(); ++i)
109  {
110  const ossimPolyLine& poly = theMultiPolyLine[i];
111  int vertexCount = poly.getNumberOfVertices();
112
113  if(vertexCount > 1)
114  {
115
116  ossimDpt start, end;
117  start = poly[0];
118  end = poly[1];
119  j = 1;
120  do
121  {
122  if(clipRect.clip(start, end))
123  {
124  anImage.drawLine(ossimIpt(start),
125  ossimIpt(end));
126  }
127  ++j;
128  start = poly[j-1];
129  end = poly[j];
130  }while(j < vertexCount);
131  }
132  else if(vertexCount == 1)
133  {
134  anImage.drawLine(ossimIpt(poly[0]),
135  ossimIpt(poly[0]));
136  }
137  }
138  }
139 }
double y
Definition: ossimDpt.h:165
void setThickness(ossim_int32 thickness)
All the drawing algorithms have thickness.
ossim_uint32 getNumberOfVertices() const
Definition: ossimPolyLine.h:70
ossimRefPtr< ossimImageData > getImageData()
Will return the image data.
virtual ossimIrect getImageRectangle() const
bool intersects(const ossimDrect &rect) const
Definition: ossimDrect.cpp:289
void drawLine(double x1, double y1, double x2, double y2)
About all the draw routines will call draw line.
void setDrawColor(ossim_uint8 r=255, ossim_uint8 g=255, ossim_uint8 b=255)
double x
Definition: ossimDpt.h:164
const ossimDpt & lr() const
Definition: ossimDrect.h:341
◆ dup()
ossimObject * ossimAnnotationMultiPolyLineObject::dup ( ) const
virtual
◆ getBoundingRect()
void ossimAnnotationMultiPolyLineObject::getBoundingRect ( ossimDrect rect) const
virtual
◆ getMultiPolyLine() [1/2]
const std::vector< ossimPolyLine > & ossimAnnotationMultiPolyLineObject::getMultiPolyLine ( ) const
◆ getMultiPolyLine() [2/2]
Definition at line 251 of file ossimAnnotationMultiPolyLineObject.cpp.
252 {
253  return theMultiPolyLine;
254 }
◆ getNewClippedObject()
ossimAnnotationObject * ossimAnnotationMultiPolyLineObject::getNewClippedObject ( const ossimDrect rect) const
virtual
Will allocate a new object that is clipped to the passed. in rect. Look at derived classes to see if the object is actually clipped or not. A new object is returned if it clips to the rect else NULL should be returned it doesn't clip.
Definition at line 71 of file ossimAnnotationMultiPolyLineObject.cpp.
References ossimObject::getClassName(), ossimNotify(), and ossimNotifyLevel_WARN.
73 {
75
77  << "ossimAnnotationMultiPolyLineObject::getNewClippedObject\n"
78  << "Not implemented for " << getClassName() << endl;
79  return result;
80 }
virtual ossimString getClassName() const
Definition: ossimObject.cpp:64
◆ intersects()
bool ossimAnnotationMultiPolyLineObject::intersects ( const ossimDrect rect) const
virtual
Definition at line 50 of file ossimAnnotationMultiPolyLineObject.cpp.
References ossimDrect::hasNans(), ossimDrect::intersects(), theBoundingRect, and theMultiPolyLine.
51 {
52  // do the quick checks first
53  //
54  if(rect.hasNans()) return false;
55  if(!rect.intersects(theBoundingRect)) return false;
56  if(theMultiPolyLine.size()<1) return false;
57
58  for(ossim_uint32 i =0; i < theMultiPolyLine.size(); ++i)
59  {
60  vector<ossimPolyLine> result;
61
62  if(theMultiPolyLine[i].clipToRect(result, rect))
63  {
64  return true;
65  }
66  }
67
68  return false;
69 }
◆ isPointWithin()
bool ossimAnnotationMultiPolyLineObject::isPointWithin ( const ossimDpt imagePoint) const
virtual
This method allows you to pick an object. It will return true or false if the point falls somewhere on an object. Look at derived classes for further information.
Reimplemented from ossimAnnotationObject.
Definition at line 201 of file ossimAnnotationMultiPolyLineObject.cpp.
References ossimDrect::pointWithin(), and theBoundingRect.
Referenced by ossimGeoAnnotationMultiPolyLineObject::isPointWithin().
202 {
203 // for(ossim_uint32 i = 0; i < theMultiPolyLine.size(); ++i)
204 // {
205 // if(theMultiPolyLine[i].isPointWithin(imagePoint))
206 // {
207 // return true;
208 // }
209 // }
210
211  return theBoundingRect.pointWithin(imagePoint);
212 }
bool pointWithin(const ossimDpt &pt, double epsilon=0.0) const
Definition: ossimDrect.h:781
◆ print()
std::ostream & ossimAnnotationMultiPolyLineObject::print ( std::ostream &  out) const
virtual
Derived classes should re-implement as they see fit.
Returns
std::ostream&
Definition at line 141 of file ossimAnnotationMultiPolyLineObject.cpp.
References ossimObject::getClassName(), ossimAnnotationObject::print(), and theMultiPolyLine.
142 {
144  out << endl;
145  out << setw(15)<<setiosflags(ios::left)<<"type:"<<getClassName() << endl
146  << setw(15)<<setiosflags(ios::left)<<"polylines:"<<theMultiPolyLine.size()<<endl;
147
148  for(ossim_uint32 i = 0; i < theMultiPolyLine.size(); ++i)
149  {
150  out << "____________________________________________________"<<endl
151  << theMultiPolyLine[i] << endl;
152  }
153  out << "____________________________________________________"<<endl;
154  return out;
155 }
◆ setMultiPolyLine()
void ossimAnnotationMultiPolyLineObject::setMultiPolyLine ( const vector< ossimPolyLine > &  multiPoly)
virtual
Member Data Documentation
◆ theBoundingRect
ossimDrect ossimAnnotationMultiPolyLineObject::theBoundingRect
protected
◆ theMultiPolyLine
vector<ossimPolyLine> ossimAnnotationMultiPolyLineObject::theMultiPolyLine
protected
