Public Member Functions | Protected Member Functions | Private Attributes | List of all members
ossimAtbPointSource Class Reference
#include <ossimAtbPointSource.h>
Inheritance diagram for ossimAtbPointSource:
ossimReferenced
 ossimAtbPointSource ()
 ossimAtbPointSource (ossimGridRemapSource *remap_source, const ossimDpt &view_point)
void setRemapSource (ossimGridRemapSource *image_source)
ossimGridRemapSourcegetRemapSource ()
void setViewPoint (const ossimDpt &view_point)
const ossimDptgetViewPoint () const
void getSourceValue (void *value)
void setKernelSize (int side_size)
void setGridRemapEngine (ossimGridRemapEngine *engine)
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
virtual ~ossimAtbPointSource ()
virtual ~ossimReferenced ()
Private Attributes
ossimRefPtr< ossimGridRemapSourcetheRemapSource
ossimDpt theViewPoint
ossimRefPtr< ossimGridRemapEnginetheGridRemapEngine
int theKernelSize
bool theViewPointIsValid
Detailed Description
CLASS: ossimAtbPointSource
Definition at line 34 of file ossimAtbPointSource.h.
◆ ossimAtbPointSource() [1/2]
ossimAtbPointSource::ossimAtbPointSource ( )
Definition at line 37 of file ossimAtbPointSource.cpp.
38  : theRemapSource (0),
40  theKernelSize (DEFAULT_KERNEL_SIZE),
41  theViewPointIsValid (false)
42 {
43  static const char MODULE[] = "ossimAtbPointSource Default Constructor";
44  if (traceExec()) CLOG << "entering..." << endl;
45
46  if (traceExec()) CLOG << "returning..." << endl;
47 }
#define CLOG
Definition: ossimTrace.h:23
ossimRefPtr< ossimGridRemapEngine > theGridRemapEngine
ossimRefPtr< ossimGridRemapSource > theRemapSource
◆ ossimAtbPointSource() [2/2]
ossimAtbPointSource::ossimAtbPointSource ( ossimGridRemapSource remap_source,
const ossimDpt view_point
Definition at line 54 of file ossimAtbPointSource.cpp.
56  : theRemapSource (source),
57  theGridRemapEngine (source->getRemapEngine()),
58  theKernelSize (DEFAULT_KERNEL_SIZE),
59  theViewPointIsValid (false)
60 {
61  static const char MODULE[] = "ossimAtbPointSource Default Constructor";
62  if (traceExec()) CLOG << "entering..." << endl;
63
64  setViewPoint(view_point);
65
66  if (traceExec()) CLOG << "returning..." << endl;
67 }
#define CLOG
void setViewPoint(const ossimDpt &view_point)
◆ ~ossimAtbPointSource()
ossimAtbPointSource::~ossimAtbPointSource ( )
protectedvirtual
Definition at line 74 of file ossimAtbPointSource.cpp.
75 {
76 }
Member Function Documentation
◆ getRemapSource()
ossimGridRemapSource* ossimAtbPointSource::getRemapSource ( )
inline
Returns the reference to the remapper feeding this source.
Definition at line 50 of file ossimAtbPointSource.h.
References ossimRefPtr< T >::get(), and theRemapSource.
50 { return theRemapSource.get(); }
◆ getSourceValue()
void ossimAtbPointSource::getSourceValue ( void *  value)
Returns the computed value vector corresponding to the region about the view point. The ATB Remap engine performs the actual computation, since the definition of "value" is algorithm dependent (the value may be in a different color space).
Definition at line 132 of file ossimAtbPointSource.cpp.
133 {
134  static const char MODULE[] = "ossimAtbPointSource::getSourceValue()";
135  if (traceExec()) CLOG << "entering..." << endl;
136
137  //***
138  // Verify that members are initialized before processing:
139  //***
141  {
142  CLOG <<"ERROR: This object was not properly initialized before attempting"
143  <<" to compute target value! Returning usassigned vector..."<<endl;
144  return;
145  }
146
147  //***
148  // Extract the data kernel from the image chain:
149  //***
150  ossimIpt kernel_2d_size (theKernelSize, theKernelSize);
151  ossimIpt kernel_ul (theViewPoint - kernel_2d_size/2.0);
152  ossimIpt kernel_lr (kernel_ul.x + kernel_2d_size.x - 1,
153  kernel_ul.y + kernel_2d_size.y - 1);
154  ossimIrect kernel_rect (kernel_ul, kernel_lr);
155  ossimRefPtr<ossimImageData> kernel_data =
156  theRemapSource->getTile(kernel_rect);
157
158  //***
159  // Fetch the value of the data kernel. Note: this is not necessarily in
160  // the same color space as the pixels. It depends on which engine is being
161  // utilized:
162  //***
163  theGridRemapEngine->computeSourceValue(kernel_data, value_vector);
164
165 // delete kernel_data;
166
167  if (traceExec()) CLOG << "returning..." << endl;
168  return;
169 }
#define CLOG
virtual ossimRefPtr< ossimImageData > getTile(const ossimIrect &origin, ossim_uint32 resLevel=0)
virtual void computeSourceValue(ossimRefPtr< ossimImageData > &source, void *result)=0
◆ getViewPoint()
const ossimDpt& ossimAtbPointSource::getViewPoint ( ) const
inline
Returns the view point corresponding to this point source.
Definition at line 60 of file ossimAtbPointSource.h.
References theViewPoint.
60 { return theViewPoint; }
◆ setGridRemapEngine()
void ossimAtbPointSource::setGridRemapEngine ( ossimGridRemapEngine engine)
inline
Sets the ATB remap engine reference owned by the controller. This engine is the only object that understands how to compute remap parameters from pixel data. This permits easily modifying the ATB algorithm without the support classes such as this one.
Definition at line 82 of file ossimAtbPointSource.h.
References theGridRemapEngine.
83  { theGridRemapEngine = engine; }
◆ setKernelSize()
void ossimAtbPointSource::setKernelSize ( int  side_size)
Method to set the kernel size used in computing statistics. The kernel will be resized to NxN.
Definition at line 179 of file ossimAtbPointSource.cpp.
180 {
181  static const char MODULE[] = "ossimAtbPointSource::setKernelSize()";
182  if (traceExec()) CLOG << "entering..." << endl;
183
184  theKernelSize = side_size;
185
186  if (traceExec()) CLOG << "returning..." << endl;
187  return;
188 }
#define CLOG
◆ setRemapSource()
void ossimAtbPointSource::setRemapSource ( ossimGridRemapSource image_source)
Sets the pointer of the source of pixels used to compute the stats.
Definition at line 84 of file ossimAtbPointSource.cpp.
85 {
86  static const char MODULE[] = "ossimAtbPointSource::setRemapSource()";
87  if (traceExec()) CLOG << "entering..." << endl;
88
89  theRemapSource = source;
90
91  //***
92  // Also fetch the remap engine which should be a derived ossimAtbRemapEngine:
93  //***
95
96  if (traceExec()) CLOG << "returning..." << endl;
97  return;
98 }
#define CLOG
ossimGridRemapEngine * getRemapEngine()
◆ setViewPoint()
void ossimAtbPointSource::setViewPoint ( const ossimDpt view_point)
Sets the view coordinates corresponding to this point.
Definition at line 107 of file ossimAtbPointSource.cpp.
108 {
109  static const char MODULE[] = "ossimAtbPointSource::setViewPoint()";
110  if (traceExec()) CLOG << "entering..." << endl;
111
112  theViewPoint = view_point;
113
114  if ((theRemapSource.valid()) &&
116  theViewPointIsValid = true;
117  else
118  theViewPointIsValid = false;
119
120  if (traceExec()) CLOG << "returning..." << endl;
121  return;
122 }
This will return the bounding rect of the source.
#define CLOG
bool valid() const
Definition: ossimRefPtr.h:75
bool pointWithin(const ossimIpt &pt) const
Definition: ossimIrect.h:729
Member Data Documentation
◆ theGridRemapEngine
ossimRefPtr<ossimGridRemapEngine> ossimAtbPointSource::theGridRemapEngine
private
Definition at line 91 of file ossimAtbPointSource.h.
Referenced by setGridRemapEngine().
◆ theKernelSize
int ossimAtbPointSource::theKernelSize
private
Definition at line 92 of file ossimAtbPointSource.h.
◆ theRemapSource
ossimRefPtr<ossimGridRemapSource> ossimAtbPointSource::theRemapSource
private
Definition at line 89 of file ossimAtbPointSource.h.
Referenced by getRemapSource().
◆ theViewPoint
ossimDpt ossimAtbPointSource::theViewPoint
private
Definition at line 90 of file ossimAtbPointSource.h.
Referenced by getViewPoint().
◆ theViewPointIsValid
bool ossimAtbPointSource::theViewPointIsValid
private
Definition at line 93 of file ossimAtbPointSource.h.
