Public Member Functions | Protected Member Functions | List of all members
ossimImageSource Class Referenceabstract
#include <ossimImageSource.h>
Inheritance diagram for ossimImageSource:
ossimSource ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced ossimElevImageSource ossimImageChain ossimImageCombiner ossimImageHandler ossimImageSourceFilter ossimImageSourceSequencer ossimMaskFilter ossimMemoryImageSource ossimVideoImageSource
virtual ~ossimImageSource ()
 Method to get a tile. More...
 For RTTI support. More...
virtual ossim_uint32 getNumberOfInputBands () const =0
 Initializes bandList. More...
virtual void initialize ()=0
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
const ossimIdgetId () const
virtual bool canConnectMyInputTo (ossim_int32 myInputIndex, const ossimConnectableObject *object) const =0
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
virtual ~ossimReferenced ()
Additional Inherited Members
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
Detailed Description
Definition at line 23 of file ossimImageSource.h.
◆ ossimImageSource() [1/3]
ossimImageSource::ossimImageSource ( ossimObject owner = 0)
◆ ossimImageSource() [2/3]
ossimImageSource::ossimImageSource ( ossimObject owner,
ossim_uint32  inputListSize,
ossim_uint32  outputListSize,
bool  inputListIsFixedFlag = true,
bool  outputListIsFixedFlag = true
Definition at line 25 of file ossimImageSource.cpp.
30  :
31  ossimSource(owner, inputListSize, outputListSize,
32  inputListIsFixedFlag, outputListIsFixedFlag)
33 {
34 }
ossimSource(ossimObject *owner=0)
◆ ~ossimImageSource()
ossimImageSource::~ossimImageSource ( )
virtual
Definition at line 36 of file ossimImageSource.cpp.
37 {
38 }
◆ ossimImageSource() [3/3]
ossimImageSource::ossimImageSource ( const ossimImageSource rhs)
protected
Definition at line 370 of file ossimImageSource.cpp.
371  :ossimSource()
372 {}
Member Function Documentation
◆ getBoundingRect() [1/2]
ossimIrect ossimImageSource::getBoundingRect ( ossim_uint32  resLevel = 0) const
virtual
This will return the bounding rect of the source.
We can have several sources which are in a chain to modify the bounding image rect. lets say you are next to an image handler then it will return the bounding rect for that image. If you are at the right side of a resampler then you will get a bounding rect along the image view plane. This is going to be a very import method for both image writers, mosaics or anything that needs to operate only within the bounds of an image.
Reimplemented in ossimImageHandler, ossimMapCompositionSource, ossimImageChain, ossimImageSourceSequencer, ossimEsriShapeFileFilter, ossimMeanMedianFilter, ossimTopographicCorrectionFilter, ossimElevImageSource, ossimRLevelFilter, ossimSubImageTileSource, ossimGdalOgrVectorAnnotation, ossimAnnotationSource, ossimImageRenderer, ossimScaleFilter, ossimMemoryImageSource, ossimPolyCutter, ossimRectangleCutFilter, ossimImageCombiner, ossimFusionCombiner, ossimOrthoImageMosaic, and ossimTrimFilter.
Definition at line 160 of file ossimImageSource.cpp.
References getBoundingRect(), ossimConnectableObject::getInput(), ossimIrect::makeNan(), and PTR_CAST.
Referenced by ossimScaleFilter::allocate(), ossimWatermarkFilter::allocate(), ossimBrightnessMatch::computeInputBrightness(), ossimIntensityAdjustmentFilter::createAndPopulateGrid(), ossimElevRemapper::elevRemap(), ossimCacheTileSource::fillTile(), ossimNullPixelFlip::flipPixels(), ossimFusionCombiner::getBoundingRect(), ossimPolyCutter::getBoundingRect(), ossimMemoryImageSource::getBoundingRect(), ossimScaleFilter::getBoundingRect(), ossimAnnotationSource::getBoundingRect(), ossimSubImageTileSource::getBoundingRect(), ossimImageRenderer::getBoundingRect(), ossimRLevelFilter::getBoundingRect(), ossimTopographicCorrectionFilter::getBoundingRect(), ossimMeanMedianFilter::getBoundingRect(), ossimEsriShapeFileFilter::getBoundingRect(), ossimImageSourceSequencer::getBoundingRect(), getBoundingRect(), ossimCacheTileSource::getCacheId(), ossimIgenGenerator::getInputBoundingRect(), ossimTiledImagePatch::getTile(), ossimImageRenderer::getTileAtResLevel(), getValidImageVertices(), ossimMapCompositionSource::getViewingRect(), ossimImageToPlaneNormalFilter::initialize(), ossimIntensityAdjustmentFilter::initialize(), ossimImageSourceSequencer::initialize(), ossimWatermarkFilter::initialize(), ossimAtCorrGridRemapper::initialize(), ossimPixelFlipper::initialize(), ossimImageRenderer::initializeBoundingRects(), ossimImageCombiner::precomputeBounds(), ossimIgenGenerator::setInput(), ossimRectangleCutFilter::setRectangle(), and ossimFgdcFileWriter::writeFile().
161 {
163  if(inter)
164  {
165  return inter->getBoundingRect(resLevel);
166  }
167  ossimIrect rect;
168  rect.makeNan();
169  return rect;
170 }
#define PTR_CAST(T, p)
Definition: ossimRtti.h:321
void makeNan()
Definition: ossimIrect.h:329
◆ getBoundingRect() [2/2]
void ossimImageSource::getBoundingRect ( ossimIrect rect,
) const
virtual
Gets the bounding rectangle of the source.
This default implementation calls the getBoundingRect interface that returns a rectangle. Derived classes should override as needed.
Parameters
rectInitialized with bounding rectangle by this.
resLevelReduced resolution level if applicable.
Reimplemented in ossimImageRenderer.
Definition at line 172 of file ossimImageSource.cpp.
References getBoundingRect().
173 {
174  rect = getBoundingRect( resLevel );
175 }
◆ getDecimationFactor()
void ossimImageSource::getDecimationFactor ( ossim_uint32  resLevel,
ossimDpt result
) const
virtual
Will return the decimation factor for the given resolution level.
the decimation is the scale from Resolution 0 or full res. Usually this is a power of 2 decimation where the decimation result is 1.0/2^resoltion.
Reimplemented in ossimImageHandler, ossimGdalTileSource, ossimImageChain, ossimKakaduJ2kReader, ossimMrSidReader, ossimImageSourceSequencer, ossimElevImageSource, ossimImageRenderer, ossimTopographicCorrectionFilter, ossimMemoryImageSource, ossimVideoImageSource, ossimScaleFilter, and ossimRLevelFilter.
Definition at line 88 of file ossimImageSource.cpp.
References getDecimationFactor(), ossimConnectableObject::getInput(), and PTR_CAST.
Referenced by ossimImageRenderer::fillTile(), ossimPolyCutter::getBoundingRect(), ossimSubImageTileSource::getBoundingRect(), ossimMapCompositionSource::getBoundingRect(), ossimRLevelFilter::getDecimationFactor(), getDecimationFactor(), ossimTopographicCorrectionFilter::getDecimationFactor(), ossimImageRenderer::getDecimationFactor(), ossimImageSourceSequencer::getDecimationFactor(), ossimImageToPlaneNormalFilter::getTile(), ossimPolyCutter::getTile(), and ossimSubImageTileSource::getTile().
90 {
92  getInput(0));
93  if(inter)
94  {
95  inter->getDecimationFactor(resLevel, result);
96  }
97 }
virtual void getDecimationFactor(ossim_uint32 resLevel, ossimDpt &result) const
◆ getDecimationFactors()
void ossimImageSource::getDecimationFactors ( std::vector< ossimDpt > &  decimations) const
virtual
Will return an array of all decimations for each resolution level.
Reimplemented in ossimMemoryImageSource, and ossimVideoImageSource.
Definition at line 99 of file ossimImageSource.cpp.
References getDecimationFactors(), ossimConnectableObject::getInput(), and PTR_CAST.
Referenced by ossimImageHistogramSource::computeNormalModeHistogram(), ossimTopographicCorrectionFilter::getDecimationFactors(), getDecimationFactors(), ossimImageRenderer::getDecimationFactors(), ossimImageSourceSequencer::getDecimationFactors(), and ossimRectangleCutFilter::initialize().
100 {
102  getInput(0));
103  if(inter)
104  {
105  inter->getDecimationFactors(decimations);
106  }
107 }
virtual void getDecimationFactors(std::vector< ossimDpt > &decimations) const
◆ getImageGeometry()
ossimRefPtr< ossimImageGeometry > ossimImageSource::getImageGeometry ( )
virtual
Returns the image geometry object associated with this tile source or NULL if not defined.
The geometry contains full-to-local image transform as well as projection (image-to-world). Default implementation returns the image geometry object associated with the next
(left) input source (if any) connected to this source in the chain, or NULL.
Reimplemented in ossimImageHandler, ossimCibCadrgTileSource, ossimGpkgReader, ossimPngReader, ossimImageCacheBase, ossimKakaduJp2Reader, ossimRpfCacheTileSource, ossimLasReader, ossimImageChain, ossimH5ImageHandler, ossimMrSidReader, ossimGeoPdfReader, ossimPointCloudImageHandler, ossimMG4LidarReader, ossimJpegTileSource, ossimOpjJp2Reader, ossimHdfReader, ossimGeneralRasterTileSource, ossimUsgsDemTileSource, ossimOgrVectorTileSource, ossimAdrgTileSource, ossimKmlSuperOverlayReader, ossimDtedTileSource, ossimGdalTileSource, ossimEsriShapeFileFilter, ossimVpfTileSource, ossimRangeDomeTileSource, ossimBitMaskTileSource, ossimImageRenderer, ossimBandSeparateHandler, ossimplugins::ossimTerraSarTiffReader, ossimplugins::ossimRadarSat2TiffReader, ossimMemoryImageSource, ossimKakaduJpipHandler, ossimVideoImageHandler, ossimLandsatTileSource, ossimScaleFilter, ossimVideoImageSource, ossimGeoAnnotationSource, ossimEnviTileSource, ossimERSTileSource, ossimRLevelFilter, ossimPointCloudUtilityFilter, ossimSrtmTileSource, ossimQbTileFilesHandler, ossimDoqqTileSource, ossimQuickbirdTiffTileSource, ossimOrthoImageMosaic, ossimViirsHandler, ossimViirsHandler, and ossimQuickbirdNitfTileSource.
Definition at line 262 of file ossimImageSource.cpp.
References getImageGeometry(), ossimConnectableObject::getInput(), and PTR_CAST.
Referenced by ossimGpkgWriter::addLevels(), ossimImageRenderer::checkIVT(), ossimPotraceTool::convertToBitmap(), ossimRLevelFilter::getImageGeometry(), ossimGeoAnnotationSource::getImageGeometry(), ossimScaleFilter::getImageGeometry(), ossimImageRenderer::getImageGeometry(), getImageGeometry(), ossimElevRemapper::initialize(), ossimSFIMFusion::initialize(), ossimImageToPlaneNormalFilter::initialize(), ossimMapCompositionSource::inputMapProjection(), ossimImageRenderer::refreshEvent(), ossimGpkgWriter::writeEntry(), ossimGeomFileWriter::writeFile(), ossimERSFileWriter::writeFile(), ossimEnviHeaderFileWriter::writeFile(), ossimFgdcFileWriter::writeFile(), ossimNitfWriterBase::writeGeometry(), ossimKakaduJp2Writer::writeGeotiffBox(), ossimKakaduJp2Writer::writeGmlBox(), ossimGdalWriter::writeProjectionInfo(), and ossimWriter::writeTiffTags().
263 {
265  if ( getInput(0) )
266  {
268  if( inter )
269  {
270  result = inter->getImageGeometry();
271  }
272  }
273  return result;
274 }
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if not defined...
◆ getMaxPixelValue()
double ossimImageSource::getMaxPixelValue ( ossim_uint32  band = 0) const
virtual
Reimplemented in ossimImageHandler, ossimHistogramRemapper, ossimNitfTileSource, ossimGdalTileSource, ossimEquationCombiner, ossimLasReader, ossimTiffTileSource, ossimPointCloudImageHandler, ossimHdf5ImageHandler, ossimPngReader, ossimOgrVectorTileSource, ossimOgrGdalTileSource, ossimImageChain, ossimKakaduNitfReader, ossimPixelFlipper, ossimGeneralRasterTileSource, ossimBumpShadeTileSource, ossimIndexToRgbLutFilter, ossimOpjJp2Reader, ossimImageSourceSequencer, ossimVpfTileSource, ossimPiecewiseRemapper, ossimElevImageSource, ossimImageCacheTileSource, ossimBandSelector, ossimKMeansFilter, ossimDtedTileSource, ossimBitMaskTileSource, ossimUsgsDemTileSource, ossimTopographicCorrectionFilter, ossimRgbToIndexFilter, ossimImageHandlerMtAdaptor, ossimNBandToIndexFilter, ossimBandAverageFilter, ossimConvolutionFilter1D, ossimScalarRemapper, ossimShiftFilter, ossimImageCombiner, ossimBandMergeSource, ossimLinearStretchRemapper, ossimMemoryImageSource, ossimTwoColorView, ossimLandsatTileSource, ossimCastTileSourceFilter, ossim3x3ConvolutionFilter, ossimFftFilter, ossimHsiToRgbSource, ossimRgbToHsiSource, ossimRgbToHsvSource, ossimHsvToRgbSource, and ossimImageToPlaneNormalFilter.
Definition at line 246 of file ossimImageSource.cpp.
References ossim::defaultMax(), ossimConnectableObject::getInput(), getMaxPixelValue(), getOutputScalarType(), and PTR_CAST.
Referenced by ossim3x3ConvolutionFilter::computeNullMinMax(), ossimConvolutionFilter1D::computeNullMinMax(), ossimImageDataFactory::create(), ossimImageHistogramSource::getBinInformation(), ossimImageToPlaneNormalFilter::getMaxPixelValue(), ossimFftFilter::getMaxPixelValue(), ossim3x3ConvolutionFilter::getMaxPixelValue(), ossimCastTileSourceFilter::getMaxPixelValue(), ossimMemoryImageSource::getMaxPixelValue(), ossimBandMergeSource::getMaxPixelValue(), ossimImageCombiner::getMaxPixelValue(), ossimShiftFilter::getMaxPixelValue(), ossimConvolutionFilter1D::getMaxPixelValue(), ossimBandAverageFilter::getMaxPixelValue(), ossimNBandToIndexFilter::getMaxPixelValue(), ossimRgbToIndexFilter::getMaxPixelValue(), ossimTopographicCorrectionFilter::getMaxPixelValue(), ossimBandSelector::getMaxPixelValue(), ossimPiecewiseRemapper::getMaxPixelValue(), ossimVpfTileSource::getMaxPixelValue(), ossimImageSourceSequencer::getMaxPixelValue(), ossimPixelFlipper::getMaxPixelValue(), getMaxPixelValue(), ossimImageChain::getMaxPixelValue(), ossimOgrGdalTileSource::getMaxPixelValue(), ossimEquationCombiner::getMaxPixelValue(), ossimHistogramRemapper::getMaxPixelValue(), ossimPixelFlipper::getMinPixelValue(), ossimLinearStretchRemapper::initialize(), ossimIndexToRgbLutFilter::initialize(), ossimPixelFlipper::inRange(), and ossimHistogramRemapper::setupTable().
247 {
249  getInput(0));
250  if(inter)
251  {
252  return inter->getMaxPixelValue(band);
253  }
254
256 }
OSSIM_DLL double defaultMax(ossimScalarType scalarType)
◆ getMinPixelValue()
double ossimImageSource::getMinPixelValue ( ossim_uint32  band = 0) const
virtual
Reimplemented in ossimImageHandler, ossimHistogramRemapper, ossimNitfTileSource, ossimGdalTileSource, ossimEquationCombiner, ossimTiffTileSource, ossimLasReader, ossimHdf5ImageHandler, ossimPointCloudImageHandler, ossimOgrVectorTileSource, ossimImageChain, ossimOgrGdalTileSource, ossimPixelFlipper, ossimKakaduNitfReader, ossimGeneralRasterTileSource, ossimIndexToRgbLutFilter, ossimImageSourceSequencer, ossimVpfTileSource, ossimBumpShadeTileSource, ossimPiecewiseRemapper, ossimElevImageSource, ossimImageCacheTileSource, ossimBandSelector, ossimKMeansFilter, ossimDtedTileSource, ossimBitMaskTileSource, ossimUsgsDemTileSource, ossimTopographicCorrectionFilter, ossimRgbToIndexFilter, ossimImageHandlerMtAdaptor, ossimNBandToIndexFilter, ossimConvolutionFilter1D, ossimScalarRemapper, ossimBandAverageFilter, ossimShiftFilter, ossimImageCombiner, ossimBandMergeSource, ossimLinearStretchRemapper, ossimMemoryImageSource, ossimTwoColorView, ossimCastTileSourceFilter, ossimLandsatTileSource, ossim3x3ConvolutionFilter, ossimFftFilter, ossimHsiToRgbSource, ossimRgbToHsiSource, ossimRgbToHsvSource, ossimHsvToRgbSource, and ossimImageToPlaneNormalFilter.
Definition at line 235 of file ossimImageSource.cpp.
References ossim::defaultMin(), ossimConnectableObject::getInput(), getMinPixelValue(), getOutputScalarType(), and PTR_CAST.
Referenced by ossim3x3ConvolutionFilter::computeNullMinMax(), ossimConvolutionFilter1D::computeNullMinMax(), ossimImageDataFactory::create(), ossimImageHistogramSource::getBinInformation(), ossimPixelFlipper::getMaxPixelValue(), ossimImageToPlaneNormalFilter::getMinPixelValue(), ossimFftFilter::getMinPixelValue(), ossim3x3ConvolutionFilter::getMinPixelValue(), ossimCastTileSourceFilter::getMinPixelValue(), ossimMemoryImageSource::getMinPixelValue(), ossimBandMergeSource::getMinPixelValue(), ossimImageCombiner::getMinPixelValue(), ossimShiftFilter::getMinPixelValue(), ossimBandAverageFilter::getMinPixelValue(), ossimConvolutionFilter1D::getMinPixelValue(), ossimNBandToIndexFilter::getMinPixelValue(), ossimRgbToIndexFilter::getMinPixelValue(), ossimTopographicCorrectionFilter::getMinPixelValue(), ossimBandSelector::getMinPixelValue(), ossimPiecewiseRemapper::getMinPixelValue(), ossimVpfTileSource::getMinPixelValue(), ossimImageSourceSequencer::getMinPixelValue(), getMinPixelValue(), ossimPixelFlipper::getMinPixelValue(), ossimOgrGdalTileSource::getMinPixelValue(), ossimEquationCombiner::getMinPixelValue(), ossimHistogramRemapper::getMinPixelValue(), ossimBandAverageFilter::getNullPixelValue(), ossimLinearStretchRemapper::initialize(), ossimIndexToRgbLutFilter::initialize(), ossimPixelFlipper::inRange(), ossimHistogramRemapper::setMinOutputValue(), and ossimHistogramRemapper::setupTable().
236 {
238  getInput(0));
239  if(inter)
240  {
241  return inter->getMinPixelValue(band);
242  }
244 }
OSSIM_DLL double defaultMin(ossimScalarType scalarType)
Definition: ossimCommon.cpp:73
◆ getNullPixelValue()
double ossimImageSource::getNullPixelValue ( ossim_uint32  band = 0) const
virtual
Reimplemented in ossimImageHandler, ossimNitfTileSource, ossimGdalTileSource, ossimLasReader, ossimTiffTileSource, ossimEquationCombiner, ossimH5ImageHandler, ossimPointCloudImageHandler, ossimHdf5ImageHandler, ossimImageChain, ossimOgrVectorTileSource, ossimOgrGdalTileSource, ossimKakaduNitfReader, ossimGeneralRasterTileSource, ossimIndexToRgbLutFilter, ossimImageSourceSequencer, ossimVpfTileSource, ossimImageCacheTileSource, ossimBandSelector, ossimDtedTileSource, ossimBitMaskTileSource, ossimUsgsDemTileSource, ossimTopographicCorrectionFilter, ossimImageHandlerMtAdaptor, ossimRgbToIndexFilter, ossimNBandToIndexFilter, ossimConvolutionFilter1D, ossimScalarRemapper, ossimBandAverageFilter, ossimImageCombiner, ossimShiftFilter, ossimBandMergeSource, ossimMemoryImageSource, ossimTwoColorView, ossimFftFilter, ossimCastTileSourceFilter, ossimLandsatTileSource, ossim3x3ConvolutionFilter, ossimViirsHandler, and ossimViirsHandler.
Definition at line 223 of file ossimImageSource.cpp.
References ossim::defaultNull(), ossimConnectableObject::getInput(), getNullPixelValue(), getOutputScalarType(), and PTR_CAST.
Referenced by ossimPiecewiseRemapper::buildLinearNativeTable(), ossim3x3ConvolutionFilter::computeNullMinMax(), ossimConvolutionFilter1D::computeNullMinMax(), ossimImageDataFactory::create(), ossimCastTileSourceFilter::getNullPixelValue(), ossimFftFilter::getNullPixelValue(), ossimMemoryImageSource::getNullPixelValue(), ossimBandMergeSource::getNullPixelValue(), ossimImageCombiner::getNullPixelValue(), ossimShiftFilter::getNullPixelValue(), ossimBandAverageFilter::getNullPixelValue(), ossimNBandToIndexFilter::getNullPixelValue(), ossimRgbToIndexFilter::getNullPixelValue(), ossimTopographicCorrectionFilter::getNullPixelValue(), ossimBandSelector::getNullPixelValue(), ossimVpfTileSource::getNullPixelValue(), getNullPixelValue(), ossimImageSourceSequencer::getNullPixelValue(), ossimOgrGdalTileSource::getNullPixelValue(), ossimEquationCombiner::getNullPixelValue(), ossimLinearStretchRemapper::getTile(), ossimKMeansFilter::getTile(), ossimBandLutFilter::getTile(), ossimIndexToRgbLutFilter::getTile(), ossimNBandToIndexFilter::initialize(), and ossimPixelFlipper::inRange().
224 {
226  getInput(0));
227  if(inter)
228  {
229  return inter->getNullPixelValue(band);
230  }
231
233 }
OSSIM_DLL double defaultNull(ossimScalarType scalarType)
◆ getNumberOfDecimationLevels()
ossim_uint32 ossimImageSource::getNumberOfDecimationLevels ( ) const
virtual
Will return the number of resolution levels.
Note: resolution level 0 is included in the return count.
Reimplemented in ossimImageHandler, ossimLasReader, ossimGpkgReader, ossimImageChain, ossimPointCloudImageHandler, ossimTiffTileSource, ossimKakaduJ2kReader, ossimKakaduJp2Reader, ossimMrSidReader, ossimMG4LidarReader, ossimImageSourceSequencer, ossimElevImageSource, ossimOgrGdalTileSource, ossimOgrVectorTileSource, ossimBitMaskTileSource, ossimImageRenderer, ossimCcfTileSource, ossimGdalTileSource, ossimTopographicCorrectionFilter, ossimOpjJp2Reader, ossimKakaduNitfReader, ossimVpfTileSource, ossimScaleFilter, ossimImageHandlerMtAdaptor, ossimMemoryImageSource, ossimVideoImageSource, and ossimKakaduJpipHandler.
Definition at line 109 of file ossimImageSource.cpp.
References ossimConnectableObject::getInput(), getNumberOfDecimationLevels(), and PTR_CAST.
Referenced by ossimBrightnessMatch::computeInputBrightness(), ossimImageRenderer::fillTile(), ossimTopographicCorrectionFilter::getNumberOfDecimationLevels(), getNumberOfDecimationLevels(), ossimImageRenderer::getNumberOfDecimationLevels(), ossimImageSourceSequencer::getNumberOfDecimationLevels(), ossimImageRenderer::getTileAtResLevel(), ossimPixelFlipper::initialize(), ossimCacheTileSource::initializeRlevelCache(), and ossimTiledImagePatch::isValidRLevel().
110 {
112  getInput(0));
113  if(inter)
114  {
115  return inter->getNumberOfDecimationLevels();
116  }
117  return 0;
118 }
virtual ossim_uint32 getNumberOfDecimationLevels() const
◆ getNumberOfInputBands()
virtual ossim_uint32 ossimImageSource::getNumberOfInputBands ( ) const
pure virtual
◆ getNumberOfOutputBands()
ossim_uint32 ossimImageSource::getNumberOfOutputBands ( ) const
virtual
Reimplemented in ossimCibCadrgTileSource, ossimLasReader, ossimRpfCacheTileSource, ossimImageCacheBase, ossimBumpShadeTileSource, ossimIndexToRgbLutFilter, ossimImageCacheTileSource, ossimNitfTileSource, ossimGeoPdfReader, ossimKakaduJp2Reader, ossimTiffTileSource, ossimKakaduJ2kReader, ossimBandSelector, ossimMG4LidarReader, ossimMrSidReader, ossimAdrgTileSource, ossimH5ImageHandler, ossimPngReader, ossimHdfReader, ossimDtedTileSource, ossimOgrGdalTileSource, ossimHdf5ImageHandler, ossimBitMaskTileSource, ossimOgrVectorTileSource, ossimGpkgReader, ossimGdalTileSource, ossimCcfTileSource, ossimOpjJp2Reader, ossimJpegTileSource, ossimTopographicCorrectionFilter, ossimGeneralRasterTileSource, ossimKmlSuperOverlayReader, ossimUsgsDemTileSource, ossimImageHandlerMtAdaptor, ossimHsiRemapper, ossimElevImageSource, ossimVpfTileSource, ossimRgbToIndexFilter, ossimNBandToIndexFilter, ossimKakaduJpipHandler, ossimVideoImageHandler, ATP::AtpTileSource, ossimVideoImageSource, ossimBandMergeSource, ossimMemoryImageSource, ossimAnnotationSource, ossimRgbToGreyFilter, ossimBandAverageFilter, ossimMapCompositionSource, ossimTwoColorView, ossimPointCloudUtilityFilter, ossimFftFilter, ossimImageToPlaneNormalFilter, ossimRgbToHsiSource, and ossimRgbToHsvSource.
Definition at line 323 of file ossimImageSource.cpp.
References getNumberOfInputBands().
Referenced by ossimLinearStretchRemapper::allocate(), ossimTableRemapper::allocate(), ossimWatermarkFilter::allocate(), ossimPiecewiseRemapper::buildLinearNativeTable(), ossimPiecewiseRemapper::buildTable(), ossimBandAverageFilter::checkWeights(), ossimImageHistogramSource::computeFastModeHistogram(), ossimImageHistogramSource::computeNormalModeHistogram(), ossim3x3ConvolutionFilter::computeNullMinMax(), ossimConvolutionFilter1D::computeNullMinMax(), ossimBandMergeSource::computeNumberOfInputBands(), ossimImageStatisticsSource::computeStatisticsTemplate(), ATP::AtpGenerator::constructChain(), ossimMultiBandHistogram::create(), ossimImageDataFactory::create(), ossimSingleImageChain::createRenderedChain(), ossimInfo::getImageInfo(), ossimBandMergeSource::getMaxPixelValue(), ossimImageCombiner::getMaxPixelValue(), ossimBandAverageFilter::getMaxPixelValue(), ossimBandMergeSource::getMinPixelValue(), ossimImageCombiner::getMinPixelValue(), ossimBandAverageFilter::getMinPixelValue(), ossimBandMergeSource::getNullPixelValue(), ossimImageCombiner::getNullPixelValue(), ossimImageSourceFilter::getNumberOfInputBands(), ossimImageSourceSequencer::getNumberOfInputBands(), ossimImageToPlaneNormalFilter::getNumberOfOutputBands(), ossimFftFilter::getNumberOfOutputBands(), ossimTwoColorView::getNumberOfOutputBands(), ossimBandAverageFilter::getNumberOfOutputBands(), ossimAnnotationSource::getNumberOfOutputBands(), ossimRgbToGreyFilter::getNumberOfOutputBands(), ossimNBandToIndexFilter::getNumberOfOutputBands(), ossimRgbToIndexFilter::getNumberOfOutputBands(), ossimImageHandlerMtAdaptor::getNumberOfOutputBands(), ossimTopographicCorrectionFilter::getNumberOfOutputBands(), ossimIndexToRgbLutFilter::getNumberOfOutputBands(), ossimImageHandler::getOverviewTile(), ossimClosestToCenterCombiner::getTile(), ossimLinearStretchRemapper::getTile(), ossimBumpShadeTileSource::getTile(), ossimGdalDataset::init(), ossimFusionCombiner::initialize(), ossimHistoMatchRemapper::initialize(), ossimImageCombiner::initialize(), ossimLinearStretchRemapper::initialize(), ossimAnnotationSource::initialize(), ossimBandClipFilter::initialize(), ossimWatermarkFilter::initialize(), ossimTwoColorView::initialize(), ossimOverviewSequencer::initialize(), ossimEquationCombiner::initialize(), ossimChipperUtil::initializePsmChain(), ossimPiecewiseRemapper::initMinMax(), ossimPointCloudImageHandler::initTile(), ossimTiledElevationDatabase::isCompatible(), ossimNBandToIndexFilter::isSourceEnabled(), ossimTiffWriter::openTiff(), ossimPiecewiseRemapper::saveState(), ossimPdfWriter::setupInputChain(), ossimPiecewiseRemapper::setupTable(), ossimNitf20Writer::writeBlockBandSeparate(), ossimNitfWriter::writeBlockBandSeparate(), ossimNitf20Writer::writeBlockBandSequential(), ossimNitfWriter::writeBlockBandSequential(), ossimERSFileWriter::writeFile(), ossimEnviHeaderFileWriter::writeFile(), ossimJpegWriter::writeFile(), ossimWriter::writeTiffTags(), and ossimTiffWriter::writeTiffTags().
324 {
325  return getNumberOfInputBands();
326 }
virtual ossim_uint32 getNumberOfInputBands() const =0
◆ getObject() [1/2]
virtual ossimObject* ossimImageSource::getObject ( )
inlinevirtual
For RTTI support.
overrides ossimImageSource get object to return the correct casted base pointer for RTTI casting
Definition at line 67 of file ossimImageSource.h.
Referenced by ossimSFIMFusion::initialize(), and ossimLocalCorrelationFusion::initialize().
67 { return this; }
◆ getObject() [2/2]
virtual const ossimObject* ossimImageSource::getObject ( ) const
inlinevirtual
For RTTI support.
Definition at line 74 of file ossimImageSource.h.
74 { return this; }
◆ getOutputBandList()
void ossimImageSource::getOutputBandList ( std::vector< ossim_uint32 > &  bandList) const
virtual
This implementation initializes to the zero based order of input bands. Derived classes that are band selectors should override.
Parameters
bandListInitialized by this.
Reimplemented in ossimGeneralRasterTileSource, ossimImageChain, ossimTiffTileSource, ossimBandSelector, and ossimImageSourceFilter.
Definition at line 306 of file ossimImageSource.cpp.
Referenced by ossimHistogramEqualization::allocate(), ossimTopographicCorrectionFilter::allocate(), ossimBandSelector::checkPassThrough(), ossimImageSourceFilter::getOutputBandList(), ossimBandSelector::getOutputBandList(), ossimTiffTileSource::getOutputBandList(), ossimImageChain::getOutputBandList(), if(), ossimImageHandler::isIdentityBandList(), ossimOverviewBuilderBase::setInputSource(), ossimImageHandler::setOutputBandList(), and ossimImageHandler::setOutputToInputBandList().
307 {
308  const ossim_uint32 INPUT_BANDS = getNumberOfInputBands();
309  if ( INPUT_BANDS )
310  {
311  bandList.resize( INPUT_BANDS );
312  for ( ossim_uint32 band = 0; band < INPUT_BANDS; ++band )
313  {
314  bandList[band] = band;
315  }
316  }
317  else
318  {
319  bandList.clear();
320  }
321 }
unsigned int ossim_uint32
◆ getOutputScalarType()
ossimScalarType ossimImageSource::getOutputScalarType ( ) const
virtual
Reimplemented in ossimCibCadrgTileSource, ossimRpfCacheTileSource, ossimEquationCombiner, ossimTiffTileSource, ossimImageChain, ossimLasReader, ossimPngReader, ossimPixelFlipper, ossimNitfTileSource, ossimPointCloudImageHandler, ossimGpkgReader, ossimGdalTileSource, ossimOgrVectorTileSource, ossimAdrgTileSource, ossimOgrGdalTileSource, ossimCcfTileSource, ossimDtedTileSource, ossimGeoPdfReader, ossimKakaduJp2Reader, ossimKmlSuperOverlayReader, ossimH5ImageHandler, ossimOpjJp2Reader, ossimBumpShadeTileSource, ossimImageSourceSequencer, ossimIndexToRgbLutFilter, ossimHdf5ImageHandler, ossimKakaduJ2kReader, ossimUsgsDemTileSource, ossimBandLutFilter, ossimJpegTileSource, ossimElevImageSource, ossimMG4LidarReader, ossimMrSidReader, ossimVpfTileSource, ossimHdfReader, ossimGeneralRasterTileSource, ossimTiledImageHandler, ossimRangeDomeTileSource, ossimImageCacheTileSource, ossimBitMaskTileSource, ossimTopographicCorrectionFilter, ossimBandSeparateHandler, ossimKMeansFilter, ossimImageHandlerMtAdaptor, ossimKakaduJpipHandler, ossimRgbToIndexFilter, ossimLinearStretchRemapper, ossimNBandToIndexFilter, ossimVideoImageHandler, ossimSlopeFilter, ossimImageCombiner, ossimVideoImageSource, ATP::AtpTileSource, ossimLandsatTileSource, ossimMemoryImageSource, ossimAnnotationSource, ossimFftFilter, ossimScalarRemapper, ossimTwoColorView, ossimTableRemapper, ossimRgbToGreyFilter, ossimMapCompositionSource, ossimPointCloudUtilityFilter, ossimFusionCombiner, ossimImageToPlaneNormalFilter, ossimCastTileSourceFilter, ossimHsiToRgbSource, ossimRgbToHsiSource, ossimRgbToHsvSource, and ossimHsvToRgbSource.
Definition at line 120 of file ossimImageSource.cpp.
References ossimConnectableObject::getInput(), getOutputScalarType(), OSSIM_SCALAR_UNKNOWN, and PTR_CAST.
Referenced by ossimWatermarkFilter::allocate(), ossim3x3ConvolutionFilter::computeNullMinMax(), ossimConvolutionFilter1D::computeNullMinMax(), ossimImageStatisticsSource::computeStatistics(), ossimConvolutionSource::convolve(), ossimMultiBandHistogram::create(), ossimImageDataFactory::create(), ossimSingleImageChain::createRenderedChain(), ossimImageHistogramSource::getBinInformation(), ossimSingleImageChain::getImageHandlerScalarType(), ossimInfo::getImageInfo(), getMaxPixelValue(), ossimImageHandler::getMaxPixelValue(), getMinPixelValue(), ossimImageHandler::getMinPixelValue(), ossimMpiMasterOverviewSequencer::getNextTile(), ossim3x3ConvolutionFilter::getNullPixelValue(), ossimConvolutionFilter1D::getNullPixelValue(), getNullPixelValue(), ossimImageHandler::getNullPixelValue(), ossimCastTileSourceFilter::getOutputScalarType(), ossimImageToPlaneNormalFilter::getOutputScalarType(), ossimFusionCombiner::getOutputScalarType(), ossimRgbToGreyFilter::getOutputScalarType(), ossimTableRemapper::getOutputScalarType(), ossimAnnotationSource::getOutputScalarType(), ossimFftFilter::getOutputScalarType(), ossimMemoryImageSource::getOutputScalarType(), ossimImageCombiner::getOutputScalarType(), ossimNBandToIndexFilter::getOutputScalarType(), ossimRgbToIndexFilter::getOutputScalarType(), ossimImageHandlerMtAdaptor::getOutputScalarType(), ossimTopographicCorrectionFilter::getOutputScalarType(), ossimIndexToRgbLutFilter::getOutputScalarType(), ossimImageSourceSequencer::getOutputScalarType(), getOutputScalarType(), ossimPixelFlipper::getOutputScalarType(), ossimEquationCombiner::getOutputScalarType(), ossimImageHandler::getProperty(), ossimBumpShadeTileSource::getTile(), ossimHistoMatchRemapper::initialize(), ossimImageCombiner::initialize(), ossimTableRemapper::initialize(), ossimWatermarkFilter::initialize(), ossimTwoColorView::initialize(), ossimChipperUtil::initializeColorReliefChain(), ossimOverviewBuilderBase::initializeScanOptions(), ossimTiledElevationDatabase::isCompatible(), ossimNBandToIndexFilter::isSourceEnabled(), ossimImageHandler::loadMetaData(), main(), ossimGeoidImage::open(), ossimOverviewSequencer::resampleTile(), ossimBandSelector::setOutputBandList(), ossimMpiSlaveOverviewSequencer::slaveProcessTiles(), and ossimERSFileWriter::writeFile().
121 {
123  getInput(0));
124  if(inter)
125  {
126  return inter->getOutputScalarType();
127  }
128
129  return OSSIM_SCALAR_UNKNOWN;
130 }
◆ getProperty()
ossimRefPtr< ossimProperty > ossimImageSource::getProperty ( const ossimString name) const
virtual
Reimplemented in ossimImageHandler, ossimCibCadrgTileSource, ossimRpfCacheTileSource, ossimLasReader, ossimTiffTileSource, ossimGdalTileSource, ossimBumpShadeTileSource, ossimPixelFlipper, ossimPointCloudImageHandler, ossimH5ImageHandler, ossimEquationCombiner, ossimNitfTileSource, ossimHdf5ImageHandler, ossimMapCompositionSource, ossimOgrGdalTileSource, ossimMaskFilter, ossimDtedTileSource, ossimAdrgTileSource, ossimCcfTileSource, ossimJpegTileSource, ossimPngReader, ossimBandSelector, ossimWatermarkFilter, ossimGpkgReader, ossimImageRenderer, ossimRangeDomeTileSource, ossimNBandToIndexFilter, ossimHistogramMatchFilter, ossimScalarRemapper, ossimPolyCutter, ossimBrightnessContrastSource, ossimGdalOgrVectorAnnotation, ossimMeanMedianFilter, ossimSlopeFilter, ossimCastTileSourceFilter, ossimConvolutionFilter1D, ossimEnviTileSource, ossimLandsatTileSource, ossimKakaduJpipHandler, ossimSrtmTileSource, ossimCacheTileSource, ossimImageSourceFilter, ossimSFIMFusion, ossimImageGaussianFilter, ossimFftFilter, ossimImageToPlaneNormalFilter, ossimEdgeFilter, ossimSICDToDetectedImage, ossimDilationFilter, ossimHsiRemapper, ossimDoqqTileSource, ossim3x3ConvolutionFilter, ossimTrimFilter, ossimImageSharpenFilter, ossimErosionFilter, ossimBrightnessMatch, and ossimDespeckleFilter.
Definition at line 328 of file ossimImageSource.cpp.
References ossimProperty::clearChangeType(), ossimString::downcase(), ossimKeywordNames::ENABLED_KW, ossimSource::getProperty(), ossimProperty::setFullRefreshBit(), and ossimRefPtr< T >::valid().
Referenced by ossimImageSourceFilter::getProperty(), ossimEquationCombiner::getProperty(), and ossimBumpShadeTileSource::getProperty().
329 {
331
332  ossimString tempName = name;
333  if(result.valid())
334  {
335  if(tempName.downcase() == ossimKeywordNames::ENABLED_KW)
336  {
337  result->clearChangeType();
338
339  // we will at least say its a radiometric change
340  //
341  result->setFullRefreshBit();
342  }
343  }
344
345  return result;
346 }
bool valid() const
Definition: ossimRefPtr.h:75
void setFullRefreshBit()
void clearChangeType()
static const char * ENABLED_KW
◆ getPropertyNames()
void ossimImageSource::getPropertyNames ( std::vector< ossimString > &  propertyNames) const
virtual
Reimplemented in ossimImageHandler, ossimCibCadrgTileSource, ossimLasReader, ossimGdalTileSource, ossimTiffTileSource, ossimBumpShadeTileSource, ossimH5ImageHandler, ossimPixelFlipper, ossimHdf5ImageHandler, ossimNitfTileSource, ossimEquationCombiner, ossimMapCompositionSource, ossimOgrGdalTileSource, ossimMaskFilter, ossimDtedTileSource, ossimAdrgTileSource, ossimCcfTileSource, ossimJpegTileSource, ossimWatermarkFilter, ossimPngReader, ossimBandSelector, ossimGpkgReader, ossimImageRenderer, ossimHistogramMatchFilter, ossimNBandToIndexFilter, ossimScalarRemapper, ossimPolyCutter, ossimBrightnessContrastSource, ossimGdalOgrVectorAnnotation, ossimMeanMedianFilter, ossimEnviTileSource, ossimLandsatTileSource, ossimSlopeFilter, ossimCastTileSourceFilter, ossimConvolutionFilter1D, ossimSrtmTileSource, ossimKakaduJpipHandler, ossimCacheTileSource, ossimImageSourceFilter, ossimTrimFilter, ossimSFIMFusion, ossimFftFilter, ossimImageGaussianFilter, ossimImageToPlaneNormalFilter, ossimEdgeFilter, ossimDoqqTileSource, ossimSICDToDetectedImage, ossimDilationFilter, ossimHsiRemapper, ossim3x3ConvolutionFilter, ossimImageSharpenFilter, ossimErosionFilter, ossimBrightnessMatch, and ossimDespeckleFilter.
Definition at line 353 of file ossimImageSource.cpp.
References ossimSource::getPropertyNames().
Referenced by ossimSFIMFusion::getPropertyNames(), ossimImageSourceFilter::getPropertyNames(), ossimMaskFilter::getPropertyNames(), ossimEquationCombiner::getPropertyNames(), ossimBumpShadeTileSource::getPropertyNames(), and ossimImageHandler::getPropertyNames().
354 {
355  ossimSource::getPropertyNames(propertyNames);
356 }
◆ getTile() [1/3]
ossimRefPtr< ossimImageData > ossimImageSource::getTile ( const ossimIpt origin,
virtual
Returns
from origin out to tile_width-1, and tile_height-1.
Reimplemented in ossimImageHandlerMtAdaptor.
Definition at line 40 of file ossimImageSource.cpp.
References getTileHeight(), getTileWidth(), ossimIpt::x, and ossimIpt::y.
Referenced by ossimImageHistogramSource::computeFastModeHistogram(), ossimHistogramRemapper::computeHistogram(), ossimHlzTool::computeHLZ(), ossimBrightnessMatch::computeInputBrightness(), ossimIntensityAdjustmentFilter::createAndPopulateGrid(), demo1(), demo3(), ossimTilePatch::fillPatch(), ossimCacheTileSource::fillTile(), ossimChipperUtil::getChip(), ossimImageCombiner::getNextTile(), ossimImageSourceSequencer::getNextTile(), ossimOverviewSequencer::getNextTile(), ossimFusionCombiner::getNormIntensity(), ossimFusionCombiner::getNormTile(), ossimKakaduNitfReader::getOverviewTile(), ossimKakaduJ2kReader::getOverviewTile(), ossimKakaduJp2Reader::getOverviewTile(), ossimImageHandler::getOverviewTile(), ossimHsvToRgbSource::getTile(), ossimIntensityAdjustmentFilter::getTile(), ossimCastTileSourceFilter::getTile(), ossimRgbToHsiSource::getTile(), ossimRgbToHsvSource::getTile(), ossimHsiToRgbSource::getTile(), ossimRgbToJpegYCbCrSource::getTile(), ossimImageToPlaneNormalFilter::getTile(), ossimJpegYCbCrToRgbSource::getTile(), ossimHistogramThreshholdFilter::getTile(), ossimHistogramEqualization::getTile(), ossimErosionFilter::getTile(), ossimMultiBandHistogramTileSource::getTile(), ossimDespeckleFilter::getTile(), ossimBrightnessMatch::getTile(), ossimTrimFilter::getTile(), ossimFftFilter::getTile(), ossimDilationFilter::getTile(), ossimSICDToDetectedImage::getTile(), ossimImageSharpenFilter::getTile(), ossim3x3ConvolutionFilter::getTile(), ossimHistoMatchRemapper::getTile(), ossimEdgeFilter::getTile(), ossimNullPixelFlip::getTile(), ossimRgbToGreyFilter::getTile(), ossimHistogramMatchFilter::getTile(), ossimBrightnessContrastSource::getTile(), ossimGammaRemapper::getTile(), ossimBandMergeSource::getTile(), ossimAOD::getTile(), ossimPolyCutter::getTile(), ossimSFIMFusion::getTile(), ossimBandSelector::getTile(), ossimMapCompositionSource::getTile(), ossimTwoColorView::getTile(), ossimRectangleCutFilter::getTile(), ossimLinearStretchRemapper::getTile(), ossimTableRemapper::getTile(), ossimShiftFilter::getTile(), ossimLocalCorrelationFusion::getTile(), ossimImageHandlerMtAdaptor::getTile(), getTile(), ossimAnnotationSource::getTile(), ossimImageGaussianFilter::getTile(), ossimConvolutionSource::getTile(), ossimSlopeFilter::getTile(), ossimBandAverageFilter::getTile(), ossimHsiRemapper::getTile(), ossimScaleFilter::getTile(), ossimNBandToIndexFilter::getTile(), ossimValueAssignImageSourceFilter::getTile(), ossimMeanMedianFilter::getTile(), ossimRgbToIndexFilter::getTile(), ossimConvolutionFilter1D::getTile(), ossimSubImageTileSource::getTile(), ossimHistogramRemapper::getTile(), ossimTiledImagePatch::getTile(), ossimGdalTileSource::getTile(), ossimKMeansFilter::getTile(), ossimBandClipFilter::getTile(), ossimBandSeparateHandler::getTile(), ossimTopographicCorrectionFilter::getTile(), ossimRLevelFilter::getTile(), ossimWatermarkFilter::getTile(), ossimMrSidReader::getTile(), ossimMG4LidarReader::getTile(), ossimGridRemapSource::getTile(), ossimPiecewiseRemapper::getTile(), ossimTiledImageHandler::getTile(), ossimBandLutFilter::getTile(), ossimIndexToRgbLutFilter::getTile(), ossimBumpShadeTileSource::getTile(), ossimImageElevationHandler::getTile(), ossimPixelFlipper::getTile(), ossimImageChain::getTile(), ossimMaskFilter::getTile(), ossimEquationCombiner::getTile(), ossimKakaduJpipHandler::getTileAtRes(), ossimImageRenderer::getTileAtResLevel(), ossimGdalDatasetRasterBand::IReadBlock(), ossimGeoidImage::offsetFromEllipsoidTemplate(), ossimGeoidImage::open(), ossimMultiThreadSequencer::ossimGetTileJob::run(), ossimScaleFilter::runFilterTemplate(), ossimImageHandlerMtAdaptor::setAdaptee(), and ossimGpkgReader::uncompressPngTile().
42 {
43  ossimIrect tileRect(origin.x,
44  origin.y,
45  origin.x + getTileWidth() - 1,
46  origin.y + getTileHeight() - 1);
47
48  return getTile(tileRect, resLevel);
49 }
virtual ossim_uint32 getTileHeight() const
Returns the default processing tile height.
virtual ossim_uint32 getTileWidth() const
Returns the default processing tile width.
ossim_int32 y
Definition: ossimIpt.h:142
ossim_int32 x
Definition: ossimIpt.h:141
◆ getTile() [2/3]
ossimRefPtr< ossimImageData > ossimImageSource::getTile ( const ossimIrect rect,
virtual
Returns
Reimplemented in ossimEquationCombiner, ossimMaskFilter, ossimImageChain, ossimPixelFlipper, ossimIndexToRgbLutFilter, ossimBumpShadeTileSource, ossimBandLutFilter, ossimCibCadrgTileSource, ossimNitfTileSource, ossimTiledImageHandler, ossimPiecewiseRemapper, ossimKakaduJp2Reader, ossimRangeDomeTileSource, ossimRpfCacheTileSource, ossimKakaduJ2kReader, ossimGeoPdfReader, ossimImageSourceSequencer, ossimGridRemapSource, ossimTiffTileSource, ossimLasReader, ossimMG4LidarReader, ossimMrSidReader, ossimWatermarkFilter, ossimBitMaskTileSource, ossimPointCloudImageHandler, ossimRLevelFilter, ossimTopographicCorrectionFilter, ossimBandSeparateHandler, ossimHdfReader, ossimImageCacheTileSource, ossimOgrGdalTileSource, ossimAdrgTileSource, ossimOgrVectorTileSource, ossimBandClipFilter, ossimKMeansFilter, ossimGdalTileSource, ossimOpjJp2Reader, ossimHistogramRemapper, ossimSubImageTileSource, ossimH5ImageHandler, ossimPngReader, ossimConvolutionFilter1D, ossimDtedTileSource, ossimKmlSuperOverlayReader, ossimVideoImageHandler, ossimMeanMedianFilter, ossimRgbToIndexFilter, ossimCcfTileSource, ossimHdf5ImageHandler, ossimValueAssignImageSourceFilter, ossimImageChainMtAdaptor, ossimMemoryImageSource, ossimNBandToIndexFilter, ossimGpkgReader, ossimVideoImageSource, ossimHsiRemapper, ossimScaleFilter, ossimBandAverageFilter, ossimElevImageSource, ossimConvolutionSource, ossimImageRenderer, ossimSlopeFilter, ossimTiledImagePatch, ossimImageGaussianFilter, ossimJpegTileSource, ossimVpfTileSource, ossimKakaduJpipHandler, ossimAnnotationSource, ossimUsgsDemTileSource, ossimGeneralRasterTileSource, ossimLocalCorrelationFusion, ossimLinearStretchRemapper, ossimShiftFilter, ossimTableRemapper, ATP::AtpTileSource, ossimRectangleCutFilter, ossimMapCompositionSource, ossimTwoColorView, ossimImageHandlerMtAdaptor, ossimBandSelector, ossimClosestToCenterCombiner, ossimSFIMFusion, ossimAOD, ossimAtCorrRemapper, ossimPolyCutter, ossimBandMergeSource, ossimBrightnessContrastSource, ossimCacheTileSource, ossimGammaRemapper, ossimHistogramMatchFilter, ossimMaxMosaic, ossimScalarRemapper, ossimNullPixelFlip, ossimRgbToGreyFilter, ossimElevationMosaic, ossimImageMosaic, ATP::ossimCorrelationSource, ATP::ossimDescriptorSource, ossimEdgeFilter, ossimHistoMatchRemapper, ossim3x3ConvolutionFilter, ossimElevRemapper, ossimFeatherMosaic, ossimDilationFilter, ossimImageSharpenFilter, ossimSICDToDetectedImage, ossimFftFilter, ossimTrimFilter, ossimBrightnessMatch, ossimDespeckleFilter, ossimMultiBandHistogramTileSource, ossimErosionFilter, ossimHistogramEqualization, ossimBlendMosaic, ossimColorNormalizedFusion, ossimHistogramThreshholdFilter, ossimCastTileSourceFilter, ossimHsiToRgbSource, ossimImageToPlaneNormalFilter, ossimJpegYCbCrToRgbSource, ossimRgbToHsiSource, ossimRgbToHsvSource, ossimRgbToJpegYCbCrSource, ossimHsvToRgbSource, and ossimIntensityAdjustmentFilter.
Definition at line 51 of file ossimImageSource.cpp.
References ossimConnectableObject::getInput(), getTile(), and PTR_CAST.
53 {
55  getInput(0));
56  if(inter)
57  {
58  return inter->getTile(rect, resLevel);
59  }
60  return NULL;
61 }
◆ getTile() [3/3]
bool ossimImageSource::getTile ( ossimImageData result,
virtual
Parameters
resultThe tile to stuff. Note The requested rectangle in full image space and bands should be set in the result tile prior to passing. This is the default implementation that is not thread-friendly as it uses the object's tile then simply copies its buffer to the provided tile. Eventually, all image sources should override this method.
Returns
true on success false on error. If return is false, result is undefined so caller should handle appropriately with makeBlank or whatever.
Note
Derived classes should override this method to most efficiently stuff result.
Reimplemented in ossimCibCadrgTileSource, ossimBumpShadeTileSource, ossimRpfCacheTileSource, ossimGeoPdfReader, ossimTiffTileSource, ossimLasReader, ossimRangeDomeTileSource, ossimPointCloudImageHandler, ossimImageCacheTileSource, ossimAdrgTileSource, ossimH5ImageHandler, ossimPngReader, ossimDtedTileSource, ossimHdfReader, ossimCcfTileSource, ossimHdf5ImageHandler, ossimGpkgReader, ossimJpegTileSource, ossimTiledImagePatch, ossimUsgsDemTileSource, ossimGeneralRasterTileSource, ossimImageHandlerMtAdaptor, ossimBandMergeSource, and ossimPointCloudUtilityFilter.
Definition at line 64 of file ossimImageSource.cpp.
References ossimImageData::getImageRectangle(), getTile(), ossimImageData::loadTile(), and status.
65 {
66  // This is the default implementation that is not thread-friendly as it uses the object's tile
67  // then simply assigns its buffer to the provided tile. Eventually, all image sources should
68  // override this method.
69  bool status = true;
70  if (result)
71  {
72  ossimIrect tileRect = result->getImageRectangle();
73  ossimRefPtr<ossimImageData> id = getTile(tileRect, resLevel);
74  if (id.valid())
75  {
76  *result = *(id.get());
77  result->loadTile(id.get()); // Deep copy
78  }
79  else
80  {
81  status = false;
82  }
83  }
84
85  return status;
86 }
virtual void loadTile(const void *src, const ossimIrect &src_rect, ossimInterleaveType il_type)
virtual ossimIrect getImageRectangle() const
return status
◆ getTileHeight()
ossim_uint32 ossimImageSource::getTileHeight ( ) const
virtual
Reimplemented in ossimCibCadrgTileSource, ossimRpfCacheTileSource, ossimTiffTileSource, ossimImageChain, ossimPngReader, ossimLasReader, ossimGdalTileSource, ossimNitfTileSource, ossimGpkgReader, ossimAdrgTileSource, ossimOgrVectorTileSource, ossimOgrGdalTileSource, ossimCcfTileSource, ossimDtedTileSource, ossimPointCloudImageHandler, ossimImageCacheBase, ossimImageSourceSequencer, ossimUsgsDemTileSource, ossimJpegTileSource, ossimVpfTileSource, ossimGeneralRasterTileSource, ossimElevImageSource, ossimImageHandlerMtAdaptor, ossimImageCombiner, and ossimCacheTileSource.
Definition at line 146 of file ossimImageSource.cpp.
References ossim::defaultTileSize(), ossimConnectableObject::getInput(), getTileHeight(), PTR_CAST, and ossimIpt::y.
Referenced by ossimRgbToGreyFilter::allocate(), ossimLinearStretchRemapper::allocate(), ossimTiledImageHandler::allocate(), ossimImageHistogramSource::computeFastModeHistogram(), ossimImageDataFactory::create(), ossimCacheTileSource::getCacheId(), ossimImageHandlerMtAdaptor::getTile(), getTile(), ossimImageRenderer::getTileAtResLevel(), ossimImageCombiner::getTileHeight(), ossimImageHandlerMtAdaptor::getTileHeight(), ossimVpfTileSource::getTileHeight(), getTileHeight(), ossimOgrGdalTileSource::getTileHeight(), ossimTiledImagePatch::initialize(), ossimImageSourceSequencer::initialize(), and ossimOverviewSequencer::initialize().
147 {
149  if(inter)
150  {
151  return inter->getTileHeight();
152  }
153
154  ossimIpt tileSize;
155  ossim::defaultTileSize(tileSize);
156
157  return tileSize.y;
158 }
OSSIM_DLL void defaultTileSize(ossimIpt &tileSize)
ossim_int32 y
◆ getTileWidth()
ossim_uint32 ossimImageSource::getTileWidth ( ) const
virtual
Reimplemented in ossimCibCadrgTileSource, ossimRpfCacheTileSource, ossimTiffTileSource, ossimImageChain, ossimLasReader, ossimPngReader, ossimGdalTileSource, ossimNitfTileSource, ossimGpkgReader, ossimOgrVectorTileSource, ossimAdrgTileSource, ossimOgrGdalTileSource, ossimCcfTileSource, ossimDtedTileSource, ossimPointCloudImageHandler, ossimImageCacheBase, ossimImageSourceSequencer, ossimUsgsDemTileSource, ossimJpegTileSource, ossimVpfTileSource, ossimElevImageSource, ossimGeneralRasterTileSource, ossimImageHandlerMtAdaptor, ossimImageCombiner, and ossimCacheTileSource.
Definition at line 132 of file ossimImageSource.cpp.
References ossim::defaultTileSize(), ossimConnectableObject::getInput(), getTileWidth(), PTR_CAST, and ossimIpt::x.
Referenced by ossimRgbToGreyFilter::allocate(), ossimLinearStretchRemapper::allocate(), ossimTiledImageHandler::allocate(), ossimImageHistogramSource::computeFastModeHistogram(), ossimImageDataFactory::create(), ossimCacheTileSource::getCacheId(), ossimImageHandlerMtAdaptor::getTile(), getTile(), ossimImageRenderer::getTileAtResLevel(), ossimImageCombiner::getTileWidth(), ossimImageHandlerMtAdaptor::getTileWidth(), ossimVpfTileSource::getTileWidth(), getTileWidth(), ossimOgrGdalTileSource::getTileWidth(), ossimTiledImagePatch::initialize(), ossimImageSourceSequencer::initialize(), and ossimOverviewSequencer::initialize().
133 {
135  getInput(0));
136  if(inter)
137  {
138  return inter->getTileWidth();
139  }
140  ossimIpt tileSize;
141  ossim::defaultTileSize(tileSize);
142
143  return tileSize.x;
144 }
ossim_int32 x
◆ getValidImageVertices()
void ossimImageSource::getValidImageVertices ( std::vector< ossimIpt > &  validVertices,
ossimVertexOrdering  ordering = OSSIM_CLOCKWISE_ORDER,
) const
virtual
ordering specifies how the vertices should be arranged.
valid image vertices is basically the tightly fit convex hull of the image. Usually an image has NULL values and are internally not upright rectangular. This can cause problems some spatial filters.
The default implementation is to return the bounding rect.
Reimplemented in ossimPointCloudImageHandler.
Definition at line 192 of file ossimImageSource.cpp.
References getBoundingRect(), ossimConnectableObject::getInput(), getValidImageVertices(), ossimIrect::ll(), ossimIrect::lr(), OSSIM_CLOCKWISE_ORDER, PTR_CAST, ossimIrect::ul(), and ossimIrect::ur().
Referenced by ossimErosionFilter::getTile(), ossimDilationFilter::getTile(), ossimTrimFilter::getValidImageVertices(), ossimSubImageTileSource::getValidImageVertices(), ossimImageRenderer::getValidImageVertices(), getValidImageVertices(), ossimImageHandler::getValidImageVertices(), ossimFeatherMosaic::initialize(), and ossimPixelFlipper::initialize().
195 {
197  getInput(0));
198  if(inter)
199  {
200  return inter->getValidImageVertices(validVertices,
201  ordering,
202  resLevel);
203  }
204  ossimIrect boundingRect = getBoundingRect(resLevel);
205  validVertices.clear();
206
207  if(ordering == OSSIM_CLOCKWISE_ORDER)
208  {
209  validVertices.push_back(boundingRect.ul());
210  validVertices.push_back(boundingRect.ur());
211  validVertices.push_back(boundingRect.lr());
212  validVertices.push_back(boundingRect.ll());
213  }
214  else
215  {
216  validVertices.push_back(boundingRect.ul());
217  validVertices.push_back(boundingRect.ll());
218  validVertices.push_back(boundingRect.lr());
219  validVertices.push_back(boundingRect.ur());
220  }
221 }
const ossimIpt & ul() const
Definition: ossimIrect.h:274
const ossimIpt & ll() const
Definition: ossimIrect.h:277
virtual void getValidImageVertices(std::vector< ossimIpt > &validVertices, ossimVertexOrdering ordering=OSSIM_CLOCKWISE_ORDER, ossim_uint32 resLevel=0) const
const ossimIpt & lr() const
Definition: ossimIrect.h:276
const ossimIpt & ur() const
Definition: ossimIrect.h:275
◆ initialize()
virtual void ossimImageSource::initialize ( )
pure virtual
Implemented in ossimImageChain, ossimMapCompositionSource, ossimEquationCombiner, ossimBumpShadeTileSource, ossimMaskFilter, ossimIndexToRgbLutFilter, ossimBandLutFilter, ossimPixelFlipper, ossimAtCorrGridRemapper, ossimKMeansFilter, ossimBandSelector, ossimElevImageSource, ossimTopographicCorrectionFilter, ossimPiecewiseRemapper, ossimRangeDomeTileSource, ossimTwoColorView, ossimBandAverageFilter, ossimWatermarkFilter, ossimMultiBandHistogramTileSource, ossimSubImageTileSource, ossimBrightnessContrastSource, ossimRgbToIndexFilter, ossimNBandToIndexFilter, ossimVideoImageSource, ossimBandClipFilter, ossimHistogramRemapper, ossimValueAssignImageSourceFilter, ossimImageHandler, ossimConvolutionFilter1D, ossimImageSourceSequencer, ossimMemoryImageSource, ossimMeanMedianFilter, ossimImageChainMtAdaptor, ossimScaleFilter, ossimAnnotationSource, ossimIntensityAdjustmentFilter, ossimLinearStretchRemapper, ossimImageRenderer, ossimConvolutionSource, ossimImageToPlaneNormalFilter, ossimLocalCorrelationFusion, ossimTableRemapper, ossimImageGaussianFilter, ossimRectangleCutFilter, ossimHsiRemapper, ossimSlopeFilter, ossimImageSourceFilter, ossimPolyCutter, ossimImageMpiMWriterSequenceConnection, ossimHistogramMatchFilter, ossimShiftFilter, ossimTiledImagePatch, ossimSFIMFusion, ossimSICDToDetectedImage, ossimBandMergeSource, ossimMaxMosaic, ossimCacheTileSource, ossimImageCombiner, ossimRgbToGreyFilter, ossimElevationMosaic, ossimImageMosaic, ossimVideoImageHandler, ossimAOD, ossimAtCorrRemapper, ossimEdgeFilter, ossimHistogramThreshholdFilter, ossimHistoMatchRemapper, ATP::AtpTileSource, ossim3x3ConvolutionFilter, ossimGammaRemapper, ossimHistogramEqualization, ossimNullPixelFlip, ossimImageMpiSWriterSequenceConnection, ossimFeatherMosaic, ossimFusionCombiner, ossimHsiToRgbSource, ossimImageSharpenFilter, ossimRgbToHsiSource, ossimRgbToHsvSource, ossimBrightnessMatch, ossimEastingNorthingCutter, ossimTrimFilter, ATP::ossimCorrelationSource, ATP::ossimDescriptorSource, ossimFftFilter, ossimHsvToRgbSource, ossimScalarRemapper, ossimDespeckleFilter, ossimElevRemapper, ossimDilationFilter, ossimJpegYCbCrToRgbSource, ossimCastTileSourceFilter, ossimErosionFilter, ossimOrthoImageMosaic, ossimBlendMosaic, and ossimLandsatTopoCorrectionFilter.
Referenced by ossimImageToPlaneNormalFilter::initialize(), ossimBandLutFilter::initialize(), ossimIndexToRgbLutFilter::initialize(), ossimBumpShadeTileSource::initialize(), and ossimHlzTool::initProcessingChain().
◆ isIndexedData()
bool ossimImageSource::isIndexedData ( ) const
virtual
Returns
Flag indicating the data contains pallete indexes.
This should be replaced by a getPhotoInterpretation().
Reimplemented in ossimGdalTileSource.
Definition at line 358 of file ossimImageSource.cpp.
References ossimConnectableObject::getInput(), isIndexedData(), and PTR_CAST.
Referenced by isIndexedData(), and ossimGdalWriter::isInputDataIndexed().
359 {
360  bool result = false;
362  if (inter)
363  {
364  result = inter->isIndexedData();
365  }
366  return result;
367 }
virtual bool isIndexedData() const
◆ loadState()
bool ossimImageSource::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
virtual
Reimplemented in ossimHistogramRemapper, ossimImageHandler, ossimCibCadrgTileSource, ossimEquationCombiner, ossimEsriShapeFileFilter, ossimLasReader, ossimKakaduJp2Reader, ossimImageChain, ossimMapCompositionSource, ossimKakaduJ2kReader, ossimPointCloudImageHandler, ossimMrSidReader, ossimGeoPdfReader, ossimMG4LidarReader, ossimBumpShadeTileSource, ossimTiffTileSource, ossimRpfCacheTileSource, ossimMaskFilter, ossimHdfReader, ossimIndexToRgbLutFilter, ossimImageSourceSequencer, ossimPixelFlipper, ossimHistogramMatchFilter, ossimNitfTileSource, ossimScaleFilter, ossimBandLutFilter, ossimBandSelector, ossimCcfTileSource, ossimOgrGdalTileSource, ossimAdrgTileSource, ossimDtedTileSource, ossimPiecewiseRemapper, ossimOgrVectorTileSource, ossimH5ImageHandler, ossimOpjJp2Reader, ossimPngReader, ossimAtCorrGridRemapper, ossimWatermarkFilter, ossimGdalTileSource, ossimKMeansFilter, ossimHdf5ImageHandler, ossimGpkgReader, ossimUsgsDemTileSource, ossimJpegTileSource, ossimImageCacheBase, ossimGeoPolyCutter, ossimTopographicCorrectionFilter, ossimKmlSuperOverlayReader, ossimRangeDomeTileSource, ossimVpfTileSource, ossimGeneralRasterTileSource, ossimElevImageSource, ossimAnnotationSource, ossimBandAverageFilter, ossimBrightnessContrastSource, ossimMeanMedianFilter, ossimTiledImagePatch, ossimMemoryImageSource, ossimGridRemapSource, ossimRgbToIndexFilter, ossimNBandToIndexFilter, ossimGdalOgrVectorAnnotation, ossimImageRenderer, ossimMultiBandHistogramTileSource, ossimScalarRemapper, ossimSubImageTileSource, ossimRLevelFilter, ossimValueAssignImageSourceFilter, ossimConvolutionFilter1D, ossimTiledImageHandler, ossimBandClipFilter, ossimKakaduJpipHandler, ossimSlopeFilter, ossimBandSeparateHandler, ossimplugins::ossimTerraSarTiffReader, ossimGeoAnnotationSource, ossimLocalCorrelationFusion, ossimplugins::ossimRadarSat2TiffReader, ossimEnviTileSource, ossimLandsatTileSource, ossimImageChainMtAdaptor, ossimHsiRemapper, ossimSFIMFusion, ossimDilationFilter, ossimCastTileSourceFilter, ossimVectorRenderer, ossimTableRemapper, ossimFftFilter, ossimImageGaussianFilter, ossimLinearStretchRemapper, ossimCacheTileSource, ossimEdgeFilter, ossimMultiThreadSequencer, ossimImageHandlerMtAdaptor, ossimMaxMosaic, ossimSrtmTileSource, ossimRgbToGreyFilter, ossimElevationMosaic, ossimImageMosaic, ossimPolyCutter, ossimErosionFilter, ossimRectangleCutFilter, ossimHistoMatchRemapper, ossim3x3ConvolutionFilter, ossimConvolutionSource, ossimImageToPlaneNormalFilter, ossimAOD, ossimAtCorrRemapper, ossimERSTileSource, ossimImageSourceFilter, ossimGammaRemapper, ossimElevRemapper, ossimImageSharpenFilter, ossimBlendMosaic, ossimBrightnessMatch, ossimImageCombiner, ossimQuickbirdNitfTileSource, ossimHistogramEqualization, ossimHistogramThreshholdFilter, ossimTrimFilter, ossimImageSourceHistogramFilter, ossimLandsatTopoCorrectionFilter, ossimVpfAnnotationSource, ossimDoqqTileSource, ossimDespeckleFilter, and ossimEastingNorthingCutter.
Definition at line 183 of file ossimImageSource.cpp.
References ossimSource::loadState().
Referenced by ossimImageChain::addAllSources(), ossimImageCombiner::loadState(), ossimERSTileSource::loadState(), ossimImageSourceFilter::loadState(), ossimImageHandlerMtAdaptor::loadState(), ossimVectorRenderer::loadState(), ossimMemoryImageSource::loadState(), ossimElevImageSource::loadState(), ossimImageSourceSequencer::loadState(), ossimMaskFilter::loadState(), and ossimImageChain::loadState().
185 {
186  return ossimSource::loadState(kwl, prefix);
187 }
Definition: ossimSource.cpp:66
◆ operator=()
const ossimImageSource & ossimImageSource::operator= ( const ossimImageSource )
protected
Definition at line 375 of file ossimImageSource.cpp.
376 {
377  return *this;
378 }
◆ saveImageGeometry() [1/2]
void ossimImageSource::saveImageGeometry ( ) const
virtual
Default method to call input's saveImageGeometry.
Reimplemented in ossimImageHandler.
Definition at line 288 of file ossimImageSource.cpp.
References ossimConnectableObject::getInput(), PTR_CAST, and saveImageGeometry().
Referenced by saveImageGeometry().
289 {
291  if (inter)
292  {
293  inter->saveImageGeometry();
294  }
295 }
virtual void saveImageGeometry() const
Default method to call input&#39;s saveImageGeometry.
◆ saveImageGeometry() [2/2]
void ossimImageSource::saveImageGeometry ( const ossimFilename geometry_file) const
virtual
Definition at line 297 of file ossimImageSource.cpp.
298 {
300  if (inter)
301  {
302  inter->saveImageGeometry(geometry_file);
303  }
304 }
◆ saveState()
bool ossimImageSource::saveState ( ossimKeywordlist kwl,
) const
virtual
Reimplemented in ossimHistogramRemapper, ossimImageHandler, ossimGeoPdfReader, ossimEsriShapeFileFilter, ossimEquationCombiner, ossimLasReader, ossimImageChain, ossimMapCompositionSource, ossimCibCadrgTileSource, ossimPointCloudImageHandler, ossimBumpShadeTileSource, ossimMaskFilter, ossimTiffTileSource, ossimHistogramMatchFilter, ossimIndexToRgbLutFilter, ossimPixelFlipper, ossimRpfCacheTileSource, ossimBandLutFilter, ossimNitfTileSource, ossimScaleFilter, ossimAtCorrGridRemapper, ossimBandSelector, ossimCcfTileSource, ossimKMeansFilter, ossimOgrGdalTileSource, ossimAdrgTileSource, ossimDtedTileSource, ossimOgrVectorTileSource, ossimPiecewiseRemapper, ossimH5ImageHandler, ossimOpjJp2Reader, ossimPngReader, ossimGdalTileSource, ossimTopographicCorrectionFilter, ossimHdf5ImageHandler, ossimGpkgReader, ossimRangeDomeTileSource, ossimBrightnessContrastSource, ossimJpegTileSource, ossimTiledImagePatch, ossimGeoPolyCutter, ossimUsgsDemTileSource, ossimWatermarkFilter, ossimKmlSuperOverlayReader, ossimBandAverageFilter, ossimVpfTileSource, ossimGeneralRasterTileSource, ossimGridRemapSource, ossimElevImageSource, ossimAnnotationSource, ossimMeanMedianFilter, ossimMemoryImageSource, ossimMultiBandHistogramTileSource, ossimSubImageTileSource, ossimRgbToIndexFilter, ossimGdalOgrVectorAnnotation, ossimNBandToIndexFilter, ossimRLevelFilter, ossimImageCacheBase, ossimImageRenderer, ossimBandClipFilter, ossimConvolutionFilter1D, ossimScalarRemapper, ossimKakaduJpipHandler, ossimTiledImageHandler, ossimValueAssignImageSourceFilter, ossimImageChainMtAdaptor, ossimBandSeparateHandler, ossimSlopeFilter, ossimLocalCorrelationFusion, ossimFftFilter, ossimplugins::ossimTerraSarTiffReader, ossimImageGaussianFilter, ossimSFIMFusion, ossimCacheTileSource, ossimGeoAnnotationSource, ossimplugins::ossimRadarSat2TiffReader, ossimLinearStretchRemapper, ossimDilationFilter, ossimEdgeFilter, ossimHsiRemapper, ossimEnviTileSource, ossimCastTileSourceFilter, ossimVectorRenderer, ossimTableRemapper, ossimImageHandlerMtAdaptor, ossim3x3ConvolutionFilter, ossimImageSourceFilter, ossimImageToPlaneNormalFilter, ossimRectangleCutFilter, ossimMaxMosaic, ossimImageSharpenFilter, ossimRgbToGreyFilter, ossimElevationMosaic, ossimErosionFilter, ossimImageMosaic, ossimPolyCutter, ossimSrtmTileSource, ossimBrightnessMatch, ossimElevRemapper, ossimImageCombiner, ossimHistogramEqualization, ossimConvolutionSource, ossimHistogramThreshholdFilter, ossimImageSourceHistogramFilter, ossimTrimFilter, ossimLandsatTopoCorrectionFilter, ossimBlendMosaic, ossimQuickbirdNitfTileSource, ossimVpfAnnotationSource, ossimDespeckleFilter, and ossimEastingNorthingCutter.
Definition at line 177 of file ossimImageSource.cpp.
References ossimSource::saveState().
Referenced by ossimImageCombiner::saveState(), ossimImageSourceFilter::saveState(), ossimImageHandlerMtAdaptor::saveState(), ossimImageRenderer::saveState(), ossimMemoryImageSource::saveState(), ossimElevImageSource::saveState(), ossimImageChain::saveState(), and ossimImageHandler::saveState().
179 {
180  return ossimSource::saveState(kwl, prefix);
181 }
Definition: ossimSource.cpp:55
◆ setImageGeometry()
void ossimImageSource::setImageGeometry ( const ossimImageGeometry geom)
virtual
Default implementation sets geometry of the first input to the geometry specified.
Definition at line 279 of file ossimImageSource.cpp.
References ossimConnectableObject::getInput(), PTR_CAST, and setImageGeometry().
Referenced by setImageGeometry().
280 {
282  if (inter)
283  {
284  inter->setImageGeometry(geom);
285  }
286 }
virtual void setImageGeometry(const ossimImageGeometry *geom)
◆ setProperty()
void ossimImageSource::setProperty ( ossimRefPtr< ossimProperty property)
virtual
Reimplemented in ossimImageHandler, ossimLasReader, ossimTiffTileSource, ossimBumpShadeTileSource, ossimGdalTileSource, ossimPixelFlipper, ossimPointCloudImageHandler, ossimNitfTileSource, ossimH5ImageHandler, ossimEquationCombiner, ossimMapCompositionSource, ossimOgrGdalTileSource, ossimHdf5ImageHandler, ossimMaskFilter, ossimWatermarkFilter, ossimBandSelector, ossimPngReader, ossimImageRenderer, ossimGpkgReader, ossimRangeDomeTileSource, ossimNBandToIndexFilter, ossimScalarRemapper, ossimHistogramMatchFilter, ossimPolyCutter, ossimBrightnessContrastSource, ossimGdalOgrVectorAnnotation, ossimMeanMedianFilter, ossimSlopeFilter, ossimCastTileSourceFilter, ossimConvolutionFilter1D, ossimKakaduJpipHandler, ossimCacheTileSource, ossimImageSourceFilter, ossimFftFilter, ossimSFIMFusion, ossimImageGaussianFilter, ossimImageToPlaneNormalFilter, ossimEdgeFilter, ossimTrimFilter, ossimSICDToDetectedImage, ossimDilationFilter, ossimHsiRemapper, ossim3x3ConvolutionFilter, ossimImageSharpenFilter, ossimErosionFilter, ossimBrightnessMatch, and ossimDespeckleFilter.
Definition at line 348 of file ossimImageSource.cpp.
References ossimSource::setProperty().
Referenced by ossimImageSourceFilter::setProperty(), ossimEquationCombiner::setProperty(), and ossimBumpShadeTileSource::setProperty().
349 {
350  ossimSource::setProperty(property);
351 }
