ossimByteStreamBuffer Class Reference
#include <ossimByteStreamBuffer.h>
Inheritance diagram for ossimByteStreamBuffer:
Public Member Functions
 ossimByteStreamBuffer ()
 ossimByteStreamBuffer (char_type *buf, ossim_int64 bufSize, bool shared=true)
 ossimByteStreamBuffer (const ossimByteStreamBuffer &src)
virtual ~ossimByteStreamBuffer ()
virtual std::streambuf * setbuf (char_type *s, std::streamsize n)
void clear ()
std::streambuf * setBuf (char *buf, std::streamsize bufSize, bool shared)
virtual int overflow (int c=EOF)
char_type * buffer ()
 Returns a pointer to the buffer. More...
const char_type * buffer () const
char_type * takeBuffer ()
 The buffer is no longer managed by this stream buffer and is removed. More...
ossim_uint64 bufferSize () const
Protected Member Functions
virtual int_type pbackfail (int_type __c=traits_type::eof())
virtual pos_type seekoff (off_type offset, std::ios_base::seekdir dir, std::ios_base::openmode __mode=std::ios_base::in|std::ios_base::out)
virtual pos_type seekpos (pos_type pos, std::ios_base::openmode __mode=std::ios_base::in|std::ios_base::out)
virtual std::streamsize xsgetn (char_type *__s, std::streamsize __n)
virtual std::streamsize xsputn (const char_type *__s, std::streamsize __n)
void deleteBuffer ()
void extendBuffer (ossim_uint64 bytes)
Protected Attributes
char_type * m_buffer
ossim_int64 m_bufferSize
bool m_sharedBuffer
Detailed Description
Definition at line 23 of file ossimByteStreamBuffer.h.
◆ ossimByteStreamBuffer() [1/3]
ossimByteStreamBuffer::ossimByteStreamBuffer ( )
Definition at line 4 of file ossimByteStreamBuffer.cpp.
References m_buffer, m_bufferSize, m_sharedBuffer, and setBuf().
5  :m_buffer(0),
6  m_bufferSize(0),
7  m_sharedBuffer(false)
8 {
10 }
std::streambuf * setBuf(char *buf, std::streamsize bufSize, bool shared)
◆ ossimByteStreamBuffer() [2/3]
ossimByteStreamBuffer::ossimByteStreamBuffer ( char_type *  buf,
bool  shared = true
Definition at line 12 of file ossimByteStreamBuffer.cpp.
References setBuf().
15  :m_buffer(0),
16  m_bufferSize(0),
17  m_sharedBuffer(false)
18 {
19  setBuf(buf, bufSize, shared);
20 }
◆ ossimByteStreamBuffer() [3/3]
ossimByteStreamBuffer::ossimByteStreamBuffer ( const ossimByteStreamBuffer src)
Definition at line 22 of file ossimByteStreamBuffer.cpp.
23  :m_buffer(0),
24  m_bufferSize(0),
25  m_sharedBuffer(false)
26 {
28
29  if(src.m_buffer&&src.m_bufferSize)
30  {
31  // now align pointers to the same offset locations
32  //
33  ossim_int64 goff = src.gptr()-src.eback();
34  ossim_int64 poff = src.pptr()-src.pbase();
37  pbump(poff);
38  }
39 }
long long ossim_int64
◆ ~ossimByteStreamBuffer()
ossimByteStreamBuffer::~ossimByteStreamBuffer ( )
virtual
Definition at line 41 of file ossimByteStreamBuffer.cpp.
References deleteBuffer().
42 {
43  deleteBuffer();
44 }
Member Function Documentation
◆ buffer() [1/2]
ossimByteStreamBuffer::char_type * ossimByteStreamBuffer::buffer ( )
Definition at line 96 of file ossimByteStreamBuffer.cpp.
References m_buffer.
96 {return m_buffer;}
◆ buffer() [2/2]
const ossimByteStreamBuffer::char_type * ossimByteStreamBuffer::buffer ( ) const
Definition at line 97 of file ossimByteStreamBuffer.cpp.
97 {return m_buffer;}
◆ bufferSize()
ossim_uint64 ossimByteStreamBuffer::bufferSize ( ) const
Definition at line 113 of file ossimByteStreamBuffer.cpp.
References m_bufferSize.
113 {return m_bufferSize;}
◆ clear()
void ossimByteStreamBuffer::clear ( )
Definition at line 50 of file ossimByteStreamBuffer.cpp.
References setbuf().
51 {
52  setbuf(0,0);
53 }
virtual std::streambuf * setbuf(char_type *s, std::streamsize n)
◆ deleteBuffer()
void ossimByteStreamBuffer::deleteBuffer ( )
protected
Definition at line 314 of file ossimByteStreamBuffer.cpp.
References m_buffer, m_bufferSize, and m_sharedBuffer.
Referenced by setBuf(), and ~ossimByteStreamBuffer().
315 {
317  {
318  delete [] m_buffer;
319  }
320  m_buffer = 0;
321  m_bufferSize=0;
322 }
◆ extendBuffer()
void ossimByteStreamBuffer::extendBuffer ( ossim_uint64  bytes)
protected
Definition at line 323 of file ossimByteStreamBuffer.cpp.
References m_buffer, and m_bufferSize.
Referenced by overflow(), seekpos(), and xsputn().
324 {
325  // ossim_uint32 oldSize = m_bufferSize;
326  char* inBegin = eback();
327  char* inCur = gptr();
328  ossim_uint64 pbumpOffset = pptr()-pbase();
329
330  ossim_int64 relativeInCur = inCur-inBegin;
331
332
333  if(!m_buffer)
334  {
335  if(bytes>0)
336  {
337  m_buffer = new char[m_bufferSize + bytes];
338  }
339  }
340  else
341  {
342  if(bytes>0)
343  {
344  char* newBuf = new char[m_bufferSize + bytes];
345  std::memcpy(newBuf, m_buffer, m_bufferSize);
346  delete [] m_buffer;
347  m_buffer = newBuf;
348  }
349  }
350  m_bufferSize += bytes;
351
353  setg(m_buffer, m_buffer+relativeInCur, m_buffer + m_bufferSize);
354  pbump(pbumpOffset); // reallign to the current location
355 }
unsigned long long ossim_uint64
◆ overflow()
int ossimByteStreamBuffer::overflow ( int  c = EOF)
virtual
Definition at line 79 of file ossimByteStreamBuffer.cpp.
References extendBuffer(), m_buffer, m_bufferSize, and m_sharedBuffer.
80 {
81  if(m_sharedBuffer)
82  {
83  return EOF;
84  }
85  else
86  {
87  ossim_uint32 oldSize = m_bufferSize;
88  extendBuffer(1);
89  pbump(1);
90  m_buffer[oldSize] = (char_type)c;
91  }
92
93  return c;
94 }
unsigned int ossim_uint32
void extendBuffer(ossim_uint64 bytes)
◆ pbackfail()
ossimByteStreamBuffer::int_type ossimByteStreamBuffer::pbackfail ( int_type  __c = traits_type::eof())
protectedvirtual
Definition at line 116 of file ossimByteStreamBuffer.cpp.
117 {
118  int_type result = __c;
119  ossim_int64 delta = gptr()-eback();
120  if(delta!=0)
121  {
122  setg(m_buffer, m_buffer+(delta-1), m_buffer+m_bufferSize);
123  if(__c != traits_type::eof())
124  {
125  *gptr() = static_cast<char_type>(__c);
126  }
127  }
128  else
129  {
130  result = traits_type::eof();
131  }
132  return result;
133 }
◆ seekoff()
ossimByteStreamBuffer::pos_type ossimByteStreamBuffer::seekoff ( off_type  offset,
std::ios_base::openmode  __mode = std::ios_base::in | std::ios_base::out
protectedvirtual
Definition at line 134 of file ossimByteStreamBuffer.cpp.
136 {
137  pos_type result = pos_type(off_type(-1));
138  if((__mode & std::ios_base::in)&&
139  (__mode & std::ios_base::out))
140  {
141  // we currently will not support both input and output stream at the same time
142  //
143  return result;
144  }
145  switch(dir)
146  {
147  case std::ios_base::beg:
148  {
149  // if we are determing an absolute position from the beginning then
150  // just make sure the offset is within range of the current buffer size
151  //
152  if((offset < m_bufferSize)&&
153  (offset >=0))
154  {
155  result = pos_type(offset);
156  }
157  if(__mode & std::ios_base::in)
158  {
159  gbump(offset - (gptr() - eback()));
160  }
161  else if(__mode & std::ios_base::out)
162  {
163  pbump(offset - (pptr() - pbase()));
164  }
165  break;
166  }
167  case std::ios_base::cur:
168  {
169  // if we are determing an absolute position from the current pointer then
170  // add the offset as a relative displacment
171  //
172  pos_type newPosition = result;
173  ossim_int64 delta = 0;
174  if(__mode & std::ios_base::in)
175  {
176  delta = gptr()-eback();
177  }
178  else if(__mode & std::ios_base::out)
179  {
180  delta = pptr()-pbase();
181  }
182  newPosition = pos_type(delta + offset);
183  if((newPosition >= 0)&&(newPosition < m_bufferSize))
184  {
185  result = newPosition;
186  if(__mode & std::ios_base::in)
187  {
188  gbump(offset);
189  }
190  else if(__mode & std::ios_base::out)
191  {
192  pbump(offset);
193  }
194  }
195  break;
196  }
197  case std::ios_base::end:
198  {
199  pos_type newPosition = result;
200  ossim_int64 delta = 0;
201  if(__mode & std::ios_base::in)
202  {
203  delta = egptr()-eback();
204  }
205  else if(__mode & std::ios_base::out)
206  {
207  delta = epptr()-pbase();
208  }
209  newPosition = pos_type(delta + offset);
210  if((newPosition >= 0)&&(newPosition < m_bufferSize))
211  {
212  result = newPosition;
213  if(__mode & std::ios_base::in)
214  {
215  gbump(offset - (gptr() - eback()));
216  }
217  else if(__mode & std::ios_base::out)
218  {
219  pbump(offset - (epptr() - pptr()));
220  }
221  }
222  break;
223  }
224  default:
225  {
226  break;
227  }
228  }
229  return result;
230 }
◆ seekpos()
ossimByteStreamBuffer::pos_type ossimByteStreamBuffer::seekpos ( pos_type  pos,
protectedvirtual
Definition at line 232 of file ossimByteStreamBuffer.cpp.
233 {
234  pos_type result = pos_type(off_type(-1));
235
236  if(__mode & std::ios_base::in)
237  {
238  if(pos >= 0)
239  {
240  if(pos < m_bufferSize)
241  {
242  setg(m_buffer, m_buffer + pos, m_buffer + m_bufferSize);
243  result = pos;
244  }
245  }
246  }
247  else if(__mode & std::ios_base::out)
248  {
249  if(pos >=0)
250  {
252  if(pos < m_bufferSize)
253  {
254  pbump(pos);
255  result = pos;
256  }
257  else if(!m_sharedBuffer)
258  {
259  ossim_int64 delta = ossim_int64(pos) - m_bufferSize;
260  if(delta > 0)
261  {
262  extendBuffer(delta+1);
263  pbump(pos);
264  result = pos;
265  }
266  }
267  }
268  }
269
270  return result;
271 }
◆ setbuf()
std::streambuf * ossimByteStreamBuffer::setbuf ( char_type *  s,
std::streamsize  n
virtual
Definition at line 45 of file ossimByteStreamBuffer.cpp.
References n, and setBuf().
Referenced by clear().
46 {
47  return setBuf(s, n, false);
48 }
os2<< "> n<< " > nendobj n
◆ setBuf()
std::streambuf * ossimByteStreamBuffer::setBuf ( char *  buf,
bool  shared
Definition at line 55 of file ossimByteStreamBuffer.cpp.
References deleteBuffer(), m_buffer, m_bufferSize, and m_sharedBuffer.
Referenced by ossimByteStreamBuffer(), and setbuf().
56 {
57
58  deleteBuffer();
59  setp(0,0);
60  setg(0,0,0);
61  char_type* tempBuf = buf;
62  if(!shared&&bufSize&&buf)
63  {
64  tempBuf = new char_type[bufSize];
65  memcpy(tempBuf, buf, bufSize);
66  }
67  m_buffer = tempBuf;
68  m_sharedBuffer = shared;
69  m_bufferSize = bufSize;
70  setp(m_buffer, m_buffer+bufSize);
71  if(m_buffer)
72  {
73  setg(m_buffer, m_buffer, m_buffer+bufSize);
74  }
75
76  return this;
77 }
◆ takeBuffer()
ossimByteStreamBuffer::char_type * ossimByteStreamBuffer::takeBuffer ( )
Definition at line 102 of file ossimByteStreamBuffer.cpp.
103 {
104  char_type* result = m_buffer;
105  setp(0,0);
106  setg(0,0,0);
107  m_bufferSize = 0;
108  m_buffer = 0;
109
110  return result;
111 }
◆ xsgetn()
std::streamsize ossimByteStreamBuffer::xsgetn ( char_type *  __s,
std::streamsize  __n
protectedvirtual
Definition at line 273 of file ossimByteStreamBuffer.cpp.
274 {
275  ossim_uint64 bytesLeftToRead = egptr()-gptr();
276  ossim_uint64 bytesToRead = __n;
277
278  if(bytesToRead > bytesLeftToRead)
279  {
280  bytesToRead = bytesLeftToRead;
281  }
282  if(bytesToRead)
283  {
284  std::memcpy(__s, gptr(), bytesToRead);
285  gbump(bytesToRead); // bump the current get pointer
286  }
287  return std::streamsize(bytesToRead);
288 }
◆ xsputn()
std::streamsize ossimByteStreamBuffer::xsputn ( const char_type *  __s,
std::streamsize  __n
protectedvirtual
Definition at line 290 of file ossimByteStreamBuffer.cpp.
References extendBuffer(), and m_sharedBuffer.
291 {
292  ossim_int64 bytesLeftToWrite = epptr()-pptr();
293  ossim_int64 bytesToWrite = __n;
294  if(__n > bytesLeftToWrite)
295  {
296  if(!m_sharedBuffer)
297  {
298  extendBuffer(__n-bytesLeftToWrite);
299  }
300  else
301  {
302  bytesToWrite = bytesLeftToWrite;
303  }
304  }
305  if(bytesToWrite)
306  {
307  std::memcpy(pptr(), __s, bytesToWrite);
308  pbump(bytesToWrite);
309  }
310
311  return bytesToWrite;
312 }
Member Data Documentation
◆ m_buffer
char_type* ossimByteStreamBuffer::m_buffer
protected
◆ m_bufferSize
ossim_int64 ossimByteStreamBuffer::m_bufferSize
protected
◆ m_sharedBuffer
bool ossimByteStreamBuffer::m_sharedBuffer
protected
