Public Member Functions | Static Public Member Functions | Protected Member Functions | Protected Attributes | Static Protected Attributes | List of all members
ossimCustomEditorWindowRegistry Class Reference
#include <ossimCustomEditorWindowRegistry.h>
Inheritance diagram for ossimCustomEditorWindowRegistry:
ossimCustomEditorWindowFactoryBase ossimObjectFactory ossimObject ossimReferenced
virtual ~ossimCustomEditorWindowRegistry ()
bool registerFactory (ossimCustomEditorWindowFactoryBase *factory)
virtual ossimCustomEditorWindowcreateCustomEditor (ossimObject *obj, void *parent=NULL) const
virtual ossimCustomEditorWindowcreateCustomEditor (const ossimString &classType, void *parent=NULL) const
virtual ossimObjectcreateObject (const ossimString &typeName) const
virtual ossimObjectcreateObject (const ossimKeywordlist &kwl, const char *prefix=0) const
virtual void * createPopupEditor (ossimObject *obj, void *parent=NULL) const
virtual void * createPanelEditor (ossimObject *obj, void *parent=NULL) const
virtual void getTypeNameList (std::vector< ossimString > &typeList) const
- Public Member Functions inherited from ossimObjectFactory
virtual ~ossimObjectFactory ()
 ossimObject ()
virtual ~ossimObject ()
 Generic print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
static ossimCustomEditorWindowRegistryinstance ()
 ossimCustomEditorWindowRegistry (const ossimCustomEditorWindowRegistry &)
void operator= (const ossimCustomEditorWindowRegistry &)
virtual ~ossimReferenced ()
std::vector< ossimCustomEditorWindowFactoryBase * > theFactoryList
static ossimCustomEditorWindowRegistrytheInstance =0
Detailed Description
Definition at line 19 of file ossimCustomEditorWindowRegistry.h.
◆ ~ossimCustomEditorWindowRegistry()
ossimCustomEditorWindowRegistry::~ossimCustomEditorWindowRegistry ( )
virtual
Definition at line 17 of file ossimCustomEditorWindowRegistry.cpp.
References theInstance.
18 {
19  theInstance = 0;
20 }
static ossimCustomEditorWindowRegistry * theInstance
◆ ossimCustomEditorWindowRegistry() [1/2]
ossimCustomEditorWindowRegistry::ossimCustomEditorWindowRegistry ( )
inlineprotected
Definition at line 49 of file ossimCustomEditorWindowRegistry.h.
Referenced by instance().
49 {}
◆ ossimCustomEditorWindowRegistry() [2/2]
ossimCustomEditorWindowRegistry::ossimCustomEditorWindowRegistry ( const ossimCustomEditorWindowRegistry )
inlineprotected
Definition at line 50 of file ossimCustomEditorWindowRegistry.h.
50 {}
Member Function Documentation
◆ createCustomEditor() [1/2]
ossimCustomEditorWindow * ossimCustomEditorWindowRegistry::createCustomEditor ( ossimObject obj,
void *  parent = NULL
) const
virtual
Implements ossimCustomEditorWindowFactoryBase.
Definition at line 44 of file ossimCustomEditorWindowRegistry.cpp.
References theFactoryList.
46 {
47  ossimCustomEditorWindow* result = 0;
48  int i = 0;
49
50  for(i = 0; (i < (int)theFactoryList.size())&&(!result); ++i)
51  {
52  result = theFactoryList[i]->createCustomEditor(obj, parent);
53  }
54
55  return result;
56 }
◆ createCustomEditor() [2/2]
ossimCustomEditorWindow * ossimCustomEditorWindowRegistry::createCustomEditor ( const ossimString classType,
) const
virtual
Definition at line 57 of file ossimCustomEditorWindowRegistry.cpp.
59 {
60  ossimCustomEditorWindow* result = 0;
61  int i = 0;
62
63  for(i = 0; (i < (int)theFactoryList.size())&&(!result); ++i)
64  {
65  result = theFactoryList[i]->createCustomEditor(classType, parent);
66  }
67
68  return result;
69 }
◆ createObject() [1/2]
ossimObject * ossimCustomEditorWindowRegistry::createObject ( const ossimString typeName) const
virtual
Creates an object given a type name.
Implements ossimObjectFactory.
Definition at line 71 of file ossimCustomEditorWindowRegistry.cpp.
72 {
73  ossimObject* result = 0;
74  unsigned long index = 0;
75
76  while((index < theFactoryList.size()) &&(!result))
77  {
78  result = theFactoryList[index]->createObject(typeName);
79  ++index;
80  }
81  return result;
82 }
◆ createObject() [2/2]
ossimObject * ossimCustomEditorWindowRegistry::createObject ( const ossimKeywordlist kwl,
const char *  prefix = 0
) const
virtual
Creates and object given a keyword list.
Definition at line 84 of file ossimCustomEditorWindowRegistry.cpp.
86 {
87  ossimObject* result = 0;
88  unsigned long index = 0;
89
90  while((index < theFactoryList.size()) &&(!result))
91  {
92  result = theFactoryList[index]->createObject(kwl,
93  prefix);
94  ++index;
95  }
96
97  return result;
98 }
◆ createPanelEditor()
void * ossimCustomEditorWindowRegistry::createPanelEditor ( ossimObject obj,
) const
virtual
Returns a native GUI child window without a popup.
Definition at line 116 of file ossimCustomEditorWindowRegistry.cpp.
118 {
119  void* result = 0;
120  unsigned long index = 0;
121
122  while((index < theFactoryList.size()) &&(!result))
123  {
124  result = theFactoryList[index]->createPanelEditor(obj,
125  parent);
126  ++index;
127  }
128
129  return result;
130 }
◆ createPopupEditor()
void * ossimCustomEditorWindowRegistry::createPopupEditor ( ossimObject obj,
) const
virtual
Returns a native GUI Editor with popup
Definition at line 100 of file ossimCustomEditorWindowRegistry.cpp.
102 {
103  void* result = 0;
104  unsigned long index = 0;
105
106  while((index < theFactoryList.size()) &&(!result))
107  {
108  result = theFactoryList[index]->createPopupEditor(obj,
109  parent);
110  ++index;
111  }
112
113  return result;
114 }
◆ getTypeNameList()
void ossimCustomEditorWindowRegistry::getTypeNameList ( std::vector< ossimString > &  typeList) const
virtual
This should return the type name of all objects in all factories. This is the name used to construct the objects dynamially and this name must be unique.
Definition at line 132 of file ossimCustomEditorWindowRegistry.cpp.
133 {
134  std::vector<ossimCustomEditorWindowFactoryBase*>::const_iterator iter = theFactoryList.begin();
135  std::vector<ossimString> result;
136
137  while(iter != theFactoryList.end())
138  {
139  result.clear();
140  (*iter)->getTypeNameList(result);
141
142  typeList.insert(typeList.end(),
143  result.begin(),
144  result.end());
145  ++iter;
146  }
147 }
◆ instance()
ossimCustomEditorWindowRegistry * ossimCustomEditorWindowRegistry::instance ( )
static
Definition at line 22 of file ossimCustomEditorWindowRegistry.cpp.
References ossimCustomEditorWindowRegistry(), and theInstance.
Referenced by ossimCustomEditorWindowRegistryGetInstance().
23 {
24  if(!theInstance)
25  {
27  }
28
29  return theInstance;
30 }
◆ operator=()
void ossimCustomEditorWindowRegistry::operator= ( const ossimCustomEditorWindowRegistry )
inlineprotected
Definition at line 51 of file ossimCustomEditorWindowRegistry.h.
51 {}
◆ registerFactory()
bool ossimCustomEditorWindowRegistry::registerFactory ( ossimCustomEditorWindowFactoryBase factory)
Definition at line 32 of file ossimCustomEditorWindowRegistry.cpp.
33 {
34  bool result = false;
35  if(factory)
36  {
37  theFactoryList.push_back(factory);
38  result = true;
39  }
40
41  return result;
42 }
Member Data Documentation
◆ theFactoryList
std::vector<ossimCustomEditorWindowFactoryBase*> ossimCustomEditorWindowRegistry::theFactoryList
protected
◆ theInstance
ossimCustomEditorWindowRegistry * ossimCustomEditorWindowRegistry::theInstance =0
staticprotected
Definition at line 55 of file ossimCustomEditorWindowRegistry.h.
Referenced by instance(), and ~ossimCustomEditorWindowRegistry().
