Public Member Functions | Private Attributes | List of all members
ossimDirectoryData Class Reference
#include <ossimDirectoryData.h>
 ossimDirectoryData (const ossimFilename &dirname)
 ~ossimDirectoryData ()
bool isOk () const
void setFlags (int flags)
int getFlags () const
void rewind ()
bool read (ossimFilename &filename)
Private Attributes
DIR * theDir
ossimFilename theDirectoryName
int theFlags
Detailed Description
Definition at line 21 of file ossimDirectoryData.h.
◆ ossimDirectoryData()
ossimDirectoryData::ossimDirectoryData ( const ossimFilename dirname)
Definition at line 29 of file ossimDirectoryData.cpp.
References ossimString::c_str(), ossimString::length(), n, theDir, and theDirectoryName.
30  : theDirectoryName(dirname)
31 {
32  theDir = NULL;
33
34  // throw away the trailing slashes
35  size_t n = theDirectoryName.length();
36  if(n > 0)
37  {
38
39  while ( n > 0 && theDirectoryName[--n] == '/' )
40  ;
41
42 // theDirectoryName.Truncate(n + 1);
43
44  // do open the dir
45  theDir = opendir(theDirectoryName.c_str());
46  }
47 }
std::string::size_type length() const
Definition: ossimString.h:408
os2<< "> n<< " > nendobj n
const char * c_str() const
Definition: ossimString.h:396
◆ ~ossimDirectoryData()
ossimDirectoryData::~ossimDirectoryData ( )
Definition at line 49 of file ossimDirectoryData.cpp.
References theDir.
50 {
51  if ( theDir )
52  {
53  if ( closedir(theDir) != 0 )
54  {
55  // ERROR closing directory
56  }
57  }
58 }
Member Function Documentation
◆ getFlags()
int ossimDirectoryData::getFlags ( ) const
Definition at line 142 of file ossimDirectoryData.cpp.
References theFlags.
143 {
144  return theFlags;
145 }
◆ isOk()
bool ossimDirectoryData::isOk ( ) const
inline
Definition at line 27 of file ossimDirectoryData.h.
Referenced by ossimDirectory::open().
27 { return theDir != NULL; }
◆ read()
bool ossimDirectoryData::read ( ossimFilename filename)
Definition at line 60 of file ossimDirectoryData.cpp.
References ossimFilename::dirCat(), ossimFilename::isDir(), ossimFilename::isFile(), ossimString::match(), ossimFilename::NIL, ossimDirectory::OSSIM_DIR_DIRS, ossimDirectory::OSSIM_DIR_DOTDOT, ossimDirectory::OSSIM_DIR_FILES, theDir, theDirectoryName, and theFlags.
Referenced by ossimDirectory::getNext().
61 {
62  filename = ossimFilename::NIL;
63  dirent *de = (dirent *)NULL; // just to silent compiler warnings
64  bool matches = false;
65  ossimFilename temp;
66
67  while ( !matches )
68  {
69  de = readdir(theDir);
70  if ( !de )
71  {
72  return false;
73  }
74
75  temp = theDirectoryName.dirCat(de->d_name);
76
77  //***
78  // NOTE:
79  // The check for "." and ".." did not work so added pattern match check.
80  //***
81
82  // Check for "." and ".." match at the end of the name.
83  ossimString s = temp.match("\\.$|\\.\\.$");
84
85  // don't return "." and ".." unless asked for
86  if ( (temp == "..") ||
87  (temp == ".") ||
88  (s == ".") ||
89  (s == "..") )
90  {
92  {
93  matches = true;
94  }
95  }
96  else if((temp.isDir()) &&
98  {
99  matches = true;
100  }
101  else if((temp.isFile()) &&
103  {
104  matches = true;
105  }
106  else
107  {
108  matches = false;
109  }
110  }
111
112  if (matches)
113  {
114  filename = temp;//de->d_name;
115  }
116
117  return matches;
118 }
ossimString match(const char *regularExpressionPattern) const
Returns from found pattern to end of pattern.
static const ossimFilename NIL
This was taken from Wx widgets for performing touch and access date stamps.
Definition: ossimFilename.h:40
bool isDir() const
bool isFile() const
ossimFilename dirCat(const ossimFilename &file) const
◆ rewind()
void ossimDirectoryData::rewind ( )
Definition at line 147 of file ossimDirectoryData.cpp.
References theDir.
Referenced by ossimDirectory::getFirst().
148 {
149  rewinddir(theDir);
150 }
◆ setFlags()
void ossimDirectoryData::setFlags ( int  flags)
Definition at line 137 of file ossimDirectoryData.cpp.
138 {
139  theFlags = flags;
140 }
Member Data Documentation
◆ theDir
DIR* ossimDirectoryData::theDir
private
Definition at line 36 of file ossimDirectoryData.h.
Referenced by ossimDirectoryData(), read(), rewind(), and ~ossimDirectoryData().
◆ theDirectoryName
ossimFilename ossimDirectoryData::theDirectoryName
private
Definition at line 37 of file ossimDirectoryData.h.
Referenced by ossimDirectoryData(), and read().
◆ theFlags
int ossimDirectoryData::theFlags
private
Definition at line 38 of file ossimDirectoryData.h.
Referenced by getFlags(), read(), and setFlags().
