Public Member Functions | Protected Member Functions | Private Attributes | List of all members
ossimFileWalker::ossimFileWalkerJob Class Reference
Private ossimJob class. More...
Inheritance diagram for ossimFileWalker::ossimFileWalkerJob:
ossimJob
 ossimFileWalkerJob (ossimFileProcessorInterface *fpi, const ossimFilename &file)
 Constructor that takes file processor pointer and file. More...
- Public Member Functions inherited from ossimJob
 ossimJob ()
virtual void start ()
 Main entry point to the job. More...
std::shared_ptr< ossimJobgetSharedFromThis ()
 This is a convenience method to get the shared representation of this pointer. More...
std::shared_ptr< const ossimJobgetSharedFromThis () const
void setPercentComplete (double value)
 When the pernet complete is set for the job it will call any callbacks and nofity percentCompleteChanged. More...
void setPriority (double value)
 sets the priority of the job More...
double priority () const
virtual void release ()
 If derived interfaces implement a block this will allow one to release. More...
State state () const
virtual void resetState (int value)
 Will clear out the state and the call setState. More...
virtual void setState (int value, bool on=true)
 Will allow you to set the state of the job. More...
bool isCanceled () const
virtual void cancel ()
 Sets the state if the object as cancelled. More...
virtual void ready ()
 Sets the state if the object as ready. More...
virtual void running ()
 Sets the state if the object as running. More...
virtual void finished ()
 Sets the state if the object as finished. More...
bool isReady () const
bool isStopped () const
bool isFinished () const
bool isRunning () const
void setCallback (std::shared_ptr< ossimJobCallback > callback)
void setName (const ossimString &value)
 Sets the name of a job. More...
const ossimStringname () const
void setId (const ossimString &value)
const ossimStringid () const
void setDescription (const ossimString &value)
const ossimStringdescription () const
std::shared_ptr< ossimJobCallbackcallback ()
virtual void run ()
 Defines pure virtual ossimJob::start. More...
Private Attributes
ossimFileProcessorInterfacem_fileProcessor
ossimFilename m_file
Additional Inherited Members
- Public Types inherited from ossimJob
enum  State {
  ossimJob_NONE = 0, ossimJob_READY = 1, ossimJob_RUNNING = 2, ossimJob_CANCEL = 4,
  ossimJob_FINISHED = 8, ossimJob_ALL = (ossimJob_READY|ossimJob_RUNNING|ossimJob_CANCEL|ossimJob_FINISHED)
This is a Bit vector. More...
typedef std::list< std::shared_ptr< ossimJob > > List
- Protected Attributes inherited from ossimJob
std::mutex m_jobMutex
ossimString m_name
ossimString m_description
ossimString m_id
State m_state
double m_priority
std::shared_ptr< ossimJobCallbackm_callback
Detailed Description
Definition at line 151 of file ossimFileWalker.h.
◆ ossimFileWalkerJob()
ossimFileWalker::ossimFileWalkerJob::ossimFileWalkerJob ( ossimFileProcessorInterface fpi,
const ossimFilename file
Parameters
fpiossimFileProcessorInterface pointer
fileThe file to process.
Definition at line 494 of file ossimFileWalker.cpp.
497  : m_fileProcessor( fpi ),
498  m_file( file )
499 {
500 }
ossimFileProcessorInterface * m_fileProcessor
Member Function Documentation
◆ run()
void ossimFileWalker::ossimFileWalkerJob::run ( )
protectedvirtual
This executes the call to m_processFileCallBackPtr.
Implements ossimJob.
Definition at line 502 of file ossimFileWalker.cpp.
References ossimFileWalker::m_fileProcessor, and ossimFileProcessorInterface::processFile().
503 {
504  if ( m_fileProcessor && m_file.size() )
505  {
507  }
508 }
std::string::size_type size() const
Definition: ossimString.h:405
virtual void processFile(const ossimFilename &file)=0
Pure virtual processFile method.
Member Data Documentation
◆ m_file
ossimFilename ossimFileWalker::ossimFileWalkerJob::m_file
private
Definition at line 172 of file ossimFileWalker.h.
◆ m_fileProcessor
ossimFileProcessorInterface* ossimFileWalker::ossimFileWalkerJob::m_fileProcessor
private
Definition at line 171 of file ossimFileWalker.h.
