#include <ossimGdBitmapFont.h>
ossimGdBitmapFont (const ossimString &familyName, const ossimString &styleName, const ossimGdFont *gdFontPtr) | |
ossimGdBitmapFont (const ossimGdBitmapFont &rhs) | |
virtual | ~ossimGdBitmapFont () |
virtual ossimObject * | dup () const |
virtual const ossim_uint8 * | getBuf () const |
virtual const ossim_uint8 * | rasterize () |
virtual void | getBoundingBox (ossimIrect &box) |
bool | isFixed () const |
virtual void | getFixedSizes (vector< ossimIpt > &sizes) const |
ossimFont () | |
ossimFont (const ossimString &familyName, const ossimString &styleName, int horizontalPixelSize, int verticalPixelSize, int horizontalDeviceUnits=72, int verticalDeviceUnits=72) | |
ossimFont (const ossimFont &rhs) | |
virtual const ossim_uint8 * | rasterize (const ossimString &s) |
virtual void | setString (const ossimString &s) |
virtual ossimString | getFamilyName () const |
virtual ossimString | getStyleName () const |
virtual void | setRotation (double rotationInDegrees) |
virtual double | getRotation () const |
virtual void | getRotation (double &rotation) const |
virtual void | setHorizontalVerticalShear (double horizontalShear, double verticalShear) |
virtual void | setVerticalShear (double verticalShear) |
virtual void | setHorizontalShear (double horizontalShear) |
virtual double | getVerticalShear () const |
virtual double | getHorizontalShear () const |
virtual void | setScale (double horizontal, double vertical) |
virtual void | getScale (double &horizontal, double &vertical) |
virtual void | setPixelSize (int horizontalPixelSize, int verticalPixelSize) |
virtual void | setPixelSize (int pixelSize) |
virtual void | getPixelSize (int &horizontal, int &vertical) |
virtual long | getHorizontalPixelSize () const |
virtual ossimIpt | getPixelSize () const |
virtual long | getVerticalPixelSize () const |
virtual void | setDeviceDpi (int horizontalDeviceUnits, int verticalDeviceUnits) |
virtual void | getBufferRect (ossimIrect &bufRect) |
virtual ossimIrect | getBufferRect () |
virtual void | getBoundingClipBox (ossimIrect &clippedBox) |
virtual ossimIrect | getBoundingClipBox () |
virtual void | setClippingBox (const ossimIrect &clipBox=ossimIrect(0, 0, 0, 0)) |
virtual ossimIrect | getClippingBox () const |
bool | isIdentityTransform () const |
virtual void | getFontInformation (vector< ossimFontInformation > &fontInformationList) const |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual ossimString | getDescription () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=0) |
virtual std::ostream & | print (std::ostream &out) const |
Generic print method. More... | |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
virtual void | accept (ossimVisitor &visitor) |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
ossimErrorStatusInterface () | |
virtual | ~ossimErrorStatusInterface () |
virtual ossimErrorCode | getErrorStatus () const |
virtual ossimString | getErrorStatusString () const |
virtual void | setErrorStatus (ossimErrorCode error_status) const |
virtual void | setErrorStatus () const |
virtual void | clearErrorStatus () const |
bool | hasError () const |
Outputs theErrorStatus as an ossimErrorCode and an ossimString. More... | |
void | getActualScale (ossimDpt &scales) const |
void | rasterizeNormal () |
void | allocateBuffer () |
virtual | ~ossimFont () |
void | computeMatrix () |
virtual | ~ossimReferenced () |
Protected Attributes | |
const ossimGdFont * | theGdFontPtr |
long | theBufferSize |
ossim_uint8 * | theOutputBuffer |
ossimString | theStringToRasterize |
ossimString | theFamilyName |
ossimString | theStyleName |
double | theRotation |
double | theHorizontalShear |
double | theVerticalShear |
double | theHorizontalScale |
double | theVerticalScale |
int | theHorizontalPixelSize |
int | theVerticalPixelSize |
int | theHorizontalDeviceUnits |
int | theVerticalDeviceUnits |
ossimIrect | theClippingBox |
ossimIpt | theLocalOrigin |
NEWMAT::Matrix | theAffineTransform |
ossimErrorCode | theErrorStatus |
This is a wrapper for the gd library fonts. Note that this class will currently only support scaling. It will not support any other affine operation.
Definition at line 35 of file ossimGdBitmapFont.h.
ossimGdBitmapFont::ossimGdBitmapFont | ( | const ossimString & | familyName, |
const ossimString & | styleName, | ||
const ossimGdFont * | gdFontPtr | ||
ossimGdBitmapFont::ossimGdBitmapFont | ( | const ossimGdBitmapFont & | rhs | ) |
protected |
Definition at line 222 of file ossimGdBitmapFont.cpp.
References getBoundingBox(), ossimIrect::height(), theBufferSize, theOutputBuffer, and ossimIrect::width().
Referenced by rasterize().
inlinevirtual |
Implements ossimFont.
Definition at line 46 of file ossimGdBitmapFont.h.
References ossimGdBitmapFont().
protected |
This will take into consideration the point size along the horizontal and vertical and also the scale values. So the actual scale will be:
Scale*(pointSize/fixedSize);
Will return the bounding box of the last string that was set to be rasterized in pixel space
Definition at line 50 of file ossimGdBitmapFont.cpp.
References ossimGdFont::h, ossimIrect::ll(), ossimIrect::lr(), max, min, ossimString::size(), ossimFont::theAffineTransform, theGdFontPtr, ossimFont::theHorizontalPixelSize, ossimFont::theHorizontalScale, ossimFont::theRotation, ossimFont::theStringToRasterize, ossimFont::theVerticalPixelSize, ossimFont::theVerticalScale, ossimIrect::ur(), ossimGdFont::w, ossimIpt::x, and ossimIpt::y.
Referenced by allocateBuffer(), and rasterizeNormal().
inlinevirtual |
Will return the previously rasterized buffer.
Definition at line 50 of file ossimGdBitmapFont.h.
References theOutputBuffer.
You can get a list of fixed sizes supported by this font.
Definition at line 245 of file ossimGdBitmapFont.cpp.
References ossimFont::theHorizontalPixelSize, and ossimFont::theVerticalPixelSize.
inlinevirtual |
Returns true if this font is a fixed size font
Definition at line 59 of file ossimGdBitmapFont.h.
Will return an internal buffer for rasterizing and will
Definition at line 121 of file ossimGdBitmapFont.cpp.
References allocateBuffer(), rasterizeNormal(), theBufferSize, and theOutputBuffer.
protected |
Definition at line 135 of file ossimGdBitmapFont.cpp.
References ossimGdFont::data, getBoundingBox(), ossimGdFont::h, ossimIrect::height(), ossimString::length(), ossimString::size(), theGdFontPtr, theOutputBuffer, ossimFont::theStringToRasterize, ossimGdFont::w, and ossimIrect::width().
protected |
Definition at line 69 of file ossimGdBitmapFont.h.
Referenced by allocateBuffer(), ossimGdBitmapFont(), and rasterize().
protected |
Definition at line 67 of file ossimGdBitmapFont.h.
Referenced by getBoundingBox(), and rasterizeNormal().
protected |
Definition at line 70 of file ossimGdBitmapFont.h.
Referenced by allocateBuffer(), getBuf(), ossimGdBitmapFont(), rasterize(), rasterizeNormal(), and ~ossimGdBitmapFont().
