Public Member Functions | Protected Attributes | Friends | List of all members
ossimErrorStatusInterface Class Reference
#include <ossimErrorStatusInterface.h>
Inheritance diagram for ossimErrorStatusInterface:
ossimCcfHead ossimDtedAcc ossimDtedDsi ossimDtedHdr ossimDtedRecord ossimDtedUhl ossimDtedVol ossimERS ossimFfL7 ossimFont ossimFormosatDimapSupportData ossimGeoid ossimGeoTiff ossimKeywordlist ossimOverviewSequencer ossimplugins::ossimPleiadesDimapSupportData ossimplugins::ossimSpot6DimapSupportData ossimProjection ossimQuickbirdRpcHeader ossimQuickbirdTile ossimSource ossimSpotDimapSupportData ossimXmlAttribute ossimXmlDocument ossimXmlNode
 ossimErrorStatusInterface ()
bool hasError () const
ossimErrorCode theErrorStatus
Friends
OSSIMDLLEXPORT std::ostream & operator<< (std::ostream &out, const ossimErrorStatusInterface &obj)
Detailed Description
class ossimErrorStatusInterface Provides common interfaces for error handling.
Note: For error codes and associated strings use the ossimErrorCodes class.
Definition at line 29 of file ossimErrorStatusInterface.h.
◆ ossimErrorStatusInterface()
ossimErrorStatusInterface::ossimErrorStatusInterface ( )
Definition at line 20 of file ossimErrorStatusInterface.cpp.
21  :
23 {}
static const ossimErrorCode OSSIM_OK
◆ ~ossimErrorStatusInterface()
ossimErrorStatusInterface::~ossimErrorStatusInterface ( )
virtual
Definition at line 25 of file ossimErrorStatusInterface.cpp.
26 {}
Member Function Documentation
◆ clearErrorStatus()
void ossimErrorStatusInterface::clearErrorStatus ( ) const
virtual
◆ getErrorStatus()
ossimErrorCode ossimErrorStatusInterface::getErrorStatus ( ) const
virtual
return theErrorStatus
Definition at line 28 of file ossimErrorStatusInterface.cpp.
References theErrorStatus.
Referenced by ossimDtedElevationDatabase::createCell(), ossimSensorModelFactory::createProjection(), ossimChipProcTool::execute(), ossimFgdcFileWriter::find(), ossimQbTileFilesHandler::getImageGeometry(), ossimDtedInfo::getProperty(), ossimSpot5Model::initFromMetadata(), ossimSensorModelFactory::isLandsat(), ossimDemUtil::isUsgsDem(), ossimCastTileSourceFilter::loadState(), ossimSpot5Model::loadState(), ossimElevImageSource::loadState(), ossimRangeDomeTileSource::loadState(), ossimNitfXmlDataContentDes::loadValueFromXml(), ossimDtedInfo::open(), ossimAffineProjection::ossimAffineProjection(), ossimplugins::ossimFormosatModel::ossimFormosatModel(), ossimGeoidEgm96::ossimGeoidEgm96(), ossimWarpProjection::ossimWarpProjection(), ossimplugins::ossimSpot6DimapSupportData::parseXmlFile(), ossimplugins::ossimPleiadesDimapSupportData::parseXmlFile(), ossimDtedInfo::print(), ossimElevImageSource::saveState(), ossimRangeDomeTileSource::saveState(), ossimPointCloudImageHandler::saveState(), ossimImageHandler::saveState(), ossimGeneralRasterElevHandler::setFilename(), ossimOverviewBuilderBase::setInputSource(), ossimSpot5Model::setupOptimizer(), ossimGeneralRasterWriter::writeFile(), ossimJpegWriter::writeFile(), ossimKmlSuperOverlayWriter::writeFile(), ossimKakaduJp2Writer::writeFile(), ossimKakaduNitfWriter::writeFile(), ossimWriter::writeFile(), ossimPngWriter::writeFile(), and ossimGeneralRasterWriter::writeStream().
29 {
30  return theErrorStatus;
31 }
◆ getErrorStatusString()
ossimString ossimErrorStatusInterface::getErrorStatusString ( ) const
virtual
return theErrorStatus as an ossimString
Definition at line 33 of file ossimErrorStatusInterface.cpp.
References ossimErrorCodes::getErrorString(), ossimErrorCodes::instance(), and theErrorStatus.
Referenced by print().
34 {
36 }
ossimString getErrorString(ossimErrorCode error_code) const
static ossimErrorCodes * instance()
◆ hasError()
bool ossimErrorStatusInterface::hasError ( ) const
Returns
true if theErrorStatus != ossimErrorCodes::OSSIM_OK.
Definition at line 53 of file ossimErrorStatusInterface.cpp.
References ossimErrorCodes::OSSIM_OK, and theErrorStatus.
Referenced by ossimOverviewSequencer::getNextTile().
54 {
56 }
◆ print()
std::ostream & ossimErrorStatusInterface::print ( std::ostream &  out) const
virtual
Returns
std::ostream&
Note
Derived classes should only have to implement a virtual print, not an operator<< funtion as it's implemented here.
Reimplemented in ossimHistogramRemapper, ossimKeywordlist, ossimTiffTileSource, ossimGeoTiff, ossimMapProjection, ossimWatermarkFilter, ossimElevManager, ossimGdalOverviewBuilder, ossimElevSource, ossimplugins::ossimGeometricSarSensorModel, ossimPixelFlipper, ossimImageElevationDatabase, ossimSensorModel, ossimKakaduNitfOverviewBuilder, ossimTiledElevationDatabase, ossimElevationCellDatabase, ossimPiecewiseRemapper, ossimLambertConformalConicProjection, ossimRpcModel, ossimFcsiModel, ossimplugins::ossimRadarSat2Model, ossimplugins::ossimTerraSarModel, ossimplugins::ossimRadarSat2RPCModel, ossimplugins::ossimEnvisatAsarModel, ossimLlxyProjection, ossimSarModel, ossimElevCellHandler, ossimTransMercatorProjection, ossimRpcProjection, ossimGdalOgrVectorAnnotation, ossimProjection, ossimLandSatModel, ossimRsmModel, ossimUtmProjection, ossimElevationDatabase, ossimAffineProjection, ossimWarpProjection, ossimERS, ossimCoarseGridModel, ossimplugins::ossimFormosatModel, ossimplugins::ossimPleiadesModel, ossimplugins::ossimSpot6Model, ossimGeneralRasterElevationDatabase, ossimSpot5Model, ossimAdjMapModel, ossimDtedElevationDatabase, ossimHsiRemapper, ossimBilinearProjection, ossimplugins::ossimTileMapModel, ossimTableRemapper, ossimSource, ossimCcfHead, ossimAOD, ossimAtCorrRemapper, ossimGammaRemapper, ossimNitfMapModel, ossimHistogramEqualization, ossimImageSourceHistogramFilter, and ossimPolynomProjection.
Definition at line 58 of file ossimErrorStatusInterface.cpp.
References getErrorStatusString(), and theErrorStatus.
Referenced by operator<<(), ossimCcfHead::print(), ossimSource::print(), and ossimProjection::print().
59 {
60  out << "ossimErrorStatusInterface::print"
61  << "\ntheErrorStatus: " << theErrorStatus
62  << "\ntheErrorStatus string: " << getErrorStatusString()
63  << std::endl;
64  return out;
65 }
virtual ossimString getErrorStatusString() const
◆ setErrorStatus() [1/2]
void ossimErrorStatusInterface::setErrorStatus ( ossimErrorCode  error_status) const
virtual
Sets theErrorStatus to error_status.
Definition at line 38 of file ossimErrorStatusInterface.cpp.
39 {
40  theErrorStatus = error_status;
41 }
◆ setErrorStatus() [2/2]
void ossimErrorStatusInterface::setErrorStatus ( ) const
virtual
Set theErrorStatus to ossimErrorCodes::OSSIM_ERROR.
Definition at line 43 of file ossimErrorStatusInterface.cpp.
References ossimErrorCodes::OSSIM_ERROR, and theErrorStatus.
Referenced by ossimAOD::allocate(), ossimSpotDimapSupportData::convertTimeStamp(), ossimFormosatDimapSupportData::convertTimeStamp(), ossimSpotDimapSupportData::getInterpolatedLookAngle(), ossimFormosatDimapSupportData::getInterpolatedLookAngle(), ossimSpotDimapSupportData::getLagrangeInterpolation(), ossimFormosatDimapSupportData::getLagrangeInterpolation(), ossimOverviewSequencer::getNextTile(), ossimSpotDimapSupportData::getPixelLookAngleX(), ossimSpotDimapSupportData::getPixelLookAngleY(), ossimFormosatDimapSupportData::initFramePoints(), ossimSpotDimapSupportData::initFramePoints(), ossimGammaRemapper::initialize(), ossimSpotDimapSupportData::initImageId(), ossimFormosatDimapSupportData::initImageId(), ossimplugins::ossimRadarSat2Model::InitLut(), ossimSpotDimapSupportData::initMetadataVersion(), ossimFormosatDimapSupportData::initMetadataVersion(), ossimplugins::ossimRadarSat2Model::InitRefNoiseLevel(), ossimSpotDimapSupportData::initSceneSource(), ossimFormosatDimapSupportData::initSceneSource(), ossimEnviCgModel::loadEnviGeocFile(), ossimRS1SarModel::loadState(), ossimQuickbirdRpcHeader::open(), ossimplugins::ossimRadarSat2RPCModel::open(), ossimTiffWriter::openTiff(), ossimAffineProjection::ossimAffineProjection(), ossimAOD::ossimAOD(), ossimElevImageSource::ossimElevImageSource(), ossimGammaRemapper::ossimGammaRemapper(), ossimGeneralRasterElevHandler::ossimGeneralRasterElevHandler(), ossimQuickbirdRpcModel::ossimQuickbirdRpcModel(), ossimRS1SarModel::ossimRS1SarModel(), ossimWarpProjection::ossimWarpProjection(), ossimplugins::ossimSpot6DimapSupportData::parseDatasetContent(), ossimplugins::ossimPleiadesDimapSupportData::parseDatasetContent(), ossimplugins::ossimSpot6DimapSupportData::parseDatasetSources(), ossimplugins::ossimPleiadesDimapSupportData::parseDatasetSources(), ossimNitfRsmModel::parseFile(), ossimNitfRpcModel::parseFile(), ossimplugins::ossimSpot6DimapSupportData::parseGeometricData(), ossimplugins::ossimPleiadesDimapSupportData::parseGeometricData(), ossimplugins::ossimSpot6DimapSupportData::parseMetadataIdentificationDIMAPv2(), ossimplugins::ossimPleiadesDimapSupportData::parseMetadataIdentificationDIMAPv2(), ossimQuickbirdRpcModel::parseNitfFile(), ossimSpotDimapSupportData::parsePart1(), ossimFormosatDimapSupportData::parsePart1(), ossimFormosatDimapSupportData::parsePart2(), ossimSpotDimapSupportData::parsePart2(), ossimFormosatDimapSupportData::parsePart3(), ossimSpotDimapSupportData::parsePart3(), ossimFormosatDimapSupportData::parsePart4(), ossimSpotDimapSupportData::parsePart4(), ossimplugins::ossimSpot6DimapSupportData::parseRadiometricData(), ossimplugins::ossimPleiadesDimapSupportData::parseRadiometricData(), ossimplugins::ossimSpot6DimapSupportData::parseRasterData(), ossimplugins::ossimPleiadesDimapSupportData::parseRasterData(), ossimplugins::ossimSpot6DimapSupportData::parseRPCMetadata(), ossimplugins::ossimPleiadesDimapSupportData::parseRPCMetadata(), ossimQuickbirdRpcModel::parseTiffFile(), ossimplugins::ossimSpot6DimapSupportData::parseXmlFile(), ossimplugins::ossimPleiadesDimapSupportData::parseXmlFile(), ossimXmlDocument::read(), ossimRS1SarModel::saveState(), and ossimTiffWriter::writeTiffTags().
44 {
46 }
static const ossimErrorCode OSSIM_ERROR
◆ operator<<
OSSIMDLLEXPORT std::ostream& operator<< ( std::ostream &  out,
const ossimErrorStatusInterface obj
friend
Definition at line 67 of file ossimErrorStatusInterface.cpp.
69 {
70  return obj.print(out);
71 }
Member Data Documentation
◆ theErrorStatus
ossimErrorCode ossimErrorStatusInterface::theErrorStatus
mutableprotected
