Public Member Functions | Static Public Member Functions | Private Member Functions | Static Private Attributes | List of all members
ossimGdalObjectFactory Class Reference
#include <ossimGdalObjectFactory.h>
Inheritance diagram for ossimGdalObjectFactory:
ossimObjectFactory ossimObject ossimReferenced
virtual ~ossimGdalObjectFactory ()
 virtual destructor More...
virtual ossimObjectcreateObject (const ossimString &typeName) const
 Object from string. More...
virtual ossimObjectcreateObject (const ossimKeywordlist &kwl, const char *prefix=0) const
 Object from keyword list. More...
virtual void getTypeNameList (std::vector< ossimString > &typeList) const
 Adds list of objects this factory supports. More...
- Public Member Functions inherited from ossimObjectFactory
virtual ~ossimObjectFactory ()
 ossimObject ()
virtual ~ossimObject ()
 Generic print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
static ossimGdalObjectFactoryinstance ()
 hidden from use default construtor. More...
 ossimGdalObjectFactory (const ossimGdalObjectFactory &rhs)
 hidden from use copy construtor. More...
const ossimGdalObjectFactoryoperator= (const ossimGdalObjectFactory &rhs)
 hidden from use operator= . More...
static ossimGdalObjectFactorytheInstance = 0
 The single instance of this class. More...
Additional Inherited Members
virtual ~ossimReferenced ()
Detailed Description
Definition at line 17 of file ossimGdalObjectFactory.h.
◆ ~ossimGdalObjectFactory()
ossimGdalObjectFactory::~ossimGdalObjectFactory ( )
virtual
virtual destructor
Definition at line 30 of file ossimGdalObjectFactory.cpp.
31 {}
◆ ossimGdalObjectFactory() [1/2]
ossimGdalObjectFactory::ossimGdalObjectFactory ( )
private
Definition at line 81 of file ossimGdalObjectFactory.cpp.
Referenced by instance().
◆ ossimGdalObjectFactory() [2/2]
ossimGdalObjectFactory::ossimGdalObjectFactory ( const ossimGdalObjectFactory rhs)
private
Definition at line 86 of file ossimGdalObjectFactory.cpp.
Member Function Documentation
◆ createObject() [1/2]
ossimObject * ossimGdalObjectFactory::createObject ( const ossimString typeName) const
virtual
Object from string.
Returns
Pointer to object or 0 if not in this factory.
Implements ossimObjectFactory.
Definition at line 33 of file ossimGdalObjectFactory.cpp.
Referenced by createObject().
35 {
36  ossimObject* result = 0;
37
38  if (typeName == "ossimShapeFile")
39  {
40  result = new ossimShapeFile();
41  }
42  else if (typeName == "ossimShapeDatabase")
43  {
44  result = new ossimShapeDatabase();
45  }
46  else if (typeName == "ossimEsriShapeFileFilter")
47  {
48  result = new ossimEsriShapeFileFilter();
49  }
50
51  return result;
52
53 }
◆ createObject() [2/2]
ossimObject * ossimGdalObjectFactory::createObject ( const ossimKeywordlist kwl,
const char *  prefix = 0
) const
virtual
Returns
Definition at line 55 of file ossimGdalObjectFactory.cpp.
References createObject(), ossimKeywordlist::find(), and ossimObject::loadState().
57 {
58  ossimObject* result = 0;
59
60  const char* type = kwl.find(prefix, "type");
61  if(type)
62  {
63  result = createObject(ossimString(type));
64  if(result)
65  {
66  result->loadState(kwl, prefix);
67  }
68  }
69
70  return result;
71 }
virtual ossimObject * createObject(const ossimString &typeName) const
Object from string.
◆ getTypeNameList()
void ossimGdalObjectFactory::getTypeNameList ( std::vector< ossimString > &  typeList) const
virtual
Definition at line 73 of file ossimGdalObjectFactory.cpp.
75 {
76  typeList.push_back(ossimString("ossimShapeFile"));
77  typeList.push_back(ossimString("ossimShapeDatabase"));
78  typeList.push_back(ossimString("ossimEsriShapeFileFilter"));
79 }
◆ instance()
ossimGdalObjectFactory * ossimGdalObjectFactory::instance ( )
static
Definition at line 21 of file ossimGdalObjectFactory.cpp.
References ossimGdalObjectFactory(), and theInstance.
Referenced by ossimSharedLibraryFinalize(), and ossimSharedLibraryInitialize().
22 {
23  if ( !theInstance )
24  {
26  }
27  return theInstance;
28 }
static ossimGdalObjectFactory * theInstance
◆ operator=()
const ossimGdalObjectFactory & ossimGdalObjectFactory::operator= ( const ossimGdalObjectFactory rhs)
private
Definition at line 92 of file ossimGdalObjectFactory.cpp.
94 {
95  return *this;
96 }
Member Data Documentation
◆ theInstance
ossimGdalObjectFactory * ossimGdalObjectFactory::theInstance = 0
staticprivate
Definition at line 56 of file ossimGdalObjectFactory.h.
