Public Types | Public Member Functions | Protected Attributes | List of all members
ossimJobMultiThreadQueue Class Reference
This allocates a thread pool used to listen on a shared job queue. More...
#include <ossimJobMultiThreadQueue.h>
Public Types
typedef std::vector< std::shared_ptr< ossimJobThreadQueue > > ThreadQueueList
 ossimJobMultiThreadQueue (std::shared_ptr< ossimJobQueue > q=0, ossim_uint32 nThreads=0)
 allows one to create a pool of threads with a shared job queue More...
virtual ~ossimJobMultiThreadQueue ()
 Will cancel all threads and wait for completion and clear the thread queue list. More...
std::shared_ptr< ossimJobQueuegetJobQueue ()
const std::shared_ptr< ossimJobQueuegetJobQueue () const
void setJobQueue (std::shared_ptr< ossimJobQueue > q)
 set the job queue to all threads More...
void setNumberOfThreads (ossim_uint32 nThreads)
 Will set the number of threads. More...
ossim_uint32 getNumberOfThreads () const
ossim_uint32 numberOfBusyThreads () const
bool areAllThreadsBusy () const
bool hasJobsToProcess () const
void cancel ()
 Allows one to cancel all threads. More...
void waitForCompletion ()
 Allows on to wait for all thread completions. More...
std::mutex m_mutex
std::shared_ptr< ossimJobQueuem_jobQueue
ThreadQueueList m_threadQueueList
Detailed Description
#include <memory>
#include <iostream>
class TestJob : public ossimJob
public:
TestJob(){}
protected:
virtual void run()
class MyCallback : public ossimJobCallback
public:
MyCallback(){}
virtual void started(std::shared_ptr<ossimJob> job)
std::cout << "Started job\n";
virtual void finished(std::shared_ptr<ossimJob> job)
std::cout << "Finished job\n";
int main(int argc, char *argv[])
int nThreads = 5;
int nJobs = 10;
std::shared_ptr<ossimJobQueue> jobQueue = std::make_shared<ossimJobQueue>();
std::shared_ptr<ossimJobMultiThreadQueue> jobThreadQueue = std::make_shared<ossimJobMultiThreadQueue>(jobQueue, nThreads);
for(int i = 0; i < nJobs; ++i)
std::shared_ptr<TestJob> job = std::make_shared<TestJob>();
job->setCallback(std::make_shared<MyCallback>());
jobQueue->add(job);
while(jobThreadQueue->hasJobsToProcess())
std::cout << "Finished and cancelling thread queue\n";
jobThreadQueue->cancel();
jobThreadQueue->waitForCompletion();
return 0;
Definition at line 69 of file ossimJobMultiThreadQueue.h.
Member Typedef Documentation
◆ ThreadQueueList
typedef std::vector<std::shared_ptr<ossimJobThreadQueue> > ossimJobMultiThreadQueue::ThreadQueueList
Definition at line 72 of file ossimJobMultiThreadQueue.h.
◆ ossimJobMultiThreadQueue()
ossimJobMultiThreadQueue::ossimJobMultiThreadQueue ( std::shared_ptr< ossimJobQueue q = 0,
ossim_uint32  nThreads = 0
Definition at line 3 of file ossimJobMultiThreadQueue.cpp.
References setNumberOfThreads().
5 :m_jobQueue(q?q:std::make_shared<ossimJobQueue>())
6 {
7  setNumberOfThreads(nThreads);
8 }
void setNumberOfThreads(ossim_uint32 nThreads)
std::shared_ptr< ossimJobQueue > m_jobQueue
◆ ~ossimJobMultiThreadQueue()
ossimJobMultiThreadQueue::~ossimJobMultiThreadQueue ( )
virtual
Definition at line 10 of file ossimJobMultiThreadQueue.cpp.
References cancel(), m_threadQueueList, and waitForCompletion().
11 {
12  cancel();
14  m_threadQueueList.clear();
15 }
void cancel()
void waitForCompletion()
Member Function Documentation
◆ areAllThreadsBusy()
bool ossimJobMultiThreadQueue::areAllThreadsBusy ( ) const
Returns
true if all threads are busy and false otherwise
Definition at line 82 of file ossimJobMultiThreadQueue.cpp.
References m_mutex, and m_threadQueueList.
83 {
84  std::lock_guard<std::mutex> lock(m_mutex);
85  ossim_uint32 idx = 0;
86  ossim_uint32 queueSize = m_threadQueueList.size();
87  for(idx = 0; idx < queueSize;++idx)
88  {
89  if(!m_threadQueueList[idx]->isProcessingJob()) return false;
90  }
91
92  return true;
93 }
unsigned int ossim_uint32
◆ cancel()
void ossimJobMultiThreadQueue::cancel ( )
Definition at line 111 of file ossimJobMultiThreadQueue.cpp.
References m_threadQueueList.
Referenced by ~ossimJobMultiThreadQueue().
112 {
113  for(auto thread:m_threadQueueList)
114  {
115  thread->cancel();
116  }
117 }
◆ getJobQueue() [1/2]
std::shared_ptr< ossimJobQueue > ossimJobMultiThreadQueue::getJobQueue ( )
Returns
the job queue
Definition at line 17 of file ossimJobMultiThreadQueue.cpp.
References m_jobQueue, and m_mutex.
18 {
19  std::lock_guard<std::mutex> lock(m_mutex);
20  return m_jobQueue;
21 }
◆ getJobQueue() [2/2]
const std::shared_ptr< ossimJobQueue > ossimJobMultiThreadQueue::getJobQueue ( ) const
Returns
the job queue
Definition at line 22 of file ossimJobMultiThreadQueue.cpp.
23 {
24  std::lock_guard<std::mutex> lock(m_mutex);
25  return m_jobQueue;
26 }
◆ getNumberOfThreads()
ossim_uint32 ossimJobMultiThreadQueue::getNumberOfThreads ( ) const
Returns
Definition at line 63 of file ossimJobMultiThreadQueue.cpp.
64 {
65  std::lock_guard<std::mutex> lock(m_mutex);
66  return static_cast<ossim_uint32>( m_threadQueueList.size() );
67 }
◆ hasJobsToProcess()
bool ossimJobMultiThreadQueue::hasJobsToProcess ( ) const
Returns
true if it has jobs that it's processing
Definition at line 95 of file ossimJobMultiThreadQueue.cpp.
96 {
97  bool result = false;
98  {
99  std::lock_guard<std::mutex> lock(m_mutex);
100  ossim_uint32 queueSize = m_threadQueueList.size();
101  ossim_uint32 idx = 0;
102  for(idx = 0; ((idx<queueSize)&&!result);++idx)
103  {
104  result = m_threadQueueList[idx]->hasJobsToProcess();
105  }
106  }
107
108  return result;
109 }
◆ numberOfBusyThreads()
ossim_uint32 ossimJobMultiThreadQueue::numberOfBusyThreads ( ) const
Returns
the number of threads that are busy
Definition at line 69 of file ossimJobMultiThreadQueue.cpp.
70 {
71  ossim_uint32 result = 0;
72  std::lock_guard<std::mutex> lock(m_mutex);
73  ossim_uint32 idx = 0;
74  ossim_uint32 queueSize = m_threadQueueList.size();
75  for(idx = 0; idx < queueSize;++idx)
76  {
77  if(m_threadQueueList[idx]->isProcessingJob()) ++result;
78  }
79  return result;
80 }
◆ setJobQueue()
void ossimJobMultiThreadQueue::setJobQueue ( std::shared_ptr< ossimJobQueue q)
Parameters
qthe job queue to set
Definition at line 27 of file ossimJobMultiThreadQueue.cpp.
References m_jobQueue, m_mutex, and m_threadQueueList.
28 {
29  std::lock_guard<std::mutex> lock(m_mutex);
30  ossim_uint32 idx = 0;
31  m_jobQueue = q;
32  for(idx = 0; idx < m_threadQueueList.size(); ++idx)
33  {
34  m_threadQueueList[idx]->setJobQueue(m_jobQueue);
35  }
36 }
◆ setNumberOfThreads()
void ossimJobMultiThreadQueue::setNumberOfThreads ( ossim_uint32  nThreads)
Definition at line 37 of file ossimJobMultiThreadQueue.cpp.
Referenced by ossimJobMultiThreadQueue().
38 {
39  std::lock_guard<std::mutex> lock(m_mutex);
40  ossim_uint32 idx = 0;
41  ossim_uint32 queueSize = m_threadQueueList.size();
42
43  if(nThreads > queueSize)
44  {
45  for(idx = queueSize; idx < nThreads;++idx)
46  {
47  std::shared_ptr<ossimJobThreadQueue> threadQueue = std::make_shared<ossimJobThreadQueue>();
48  threadQueue->setJobQueue(m_jobQueue);
49  m_threadQueueList.push_back(threadQueue);
50  }
51  }
52  else if(nThreads < queueSize)
53  {
54  ThreadQueueList::iterator iter = m_threadQueueList.begin()+nThreads;
55  while(iter != m_threadQueueList.end())
56  {
57  (*iter)->cancel();
58  iter = m_threadQueueList.erase(iter);
59  }
60  }
61 }
◆ waitForCompletion()
void ossimJobMultiThreadQueue::waitForCompletion ( )
Usually called after
See also
cancel
Definition at line 119 of file ossimJobMultiThreadQueue.cpp.
120 {
121  for(auto thread:m_threadQueueList)
122  {
123  thread->waitForCompletion();
124  }
125 }
Member Data Documentation
◆ m_jobQueue
std::shared_ptr<ossimJobQueue> ossimJobMultiThreadQueue::m_jobQueue
protected
Definition at line 140 of file ossimJobMultiThreadQueue.h.
Referenced by getJobQueue(), setJobQueue(), and setNumberOfThreads().
◆ m_mutex
std::mutex ossimJobMultiThreadQueue::m_mutex
mutableprotected
◆ m_threadQueueList
ThreadQueueList ossimJobMultiThreadQueue::m_threadQueueList
protected
