Classes | Public Member Functions | Private Attributes | List of all members
ossimKMeansClustering Class Reference
#include <ossimKMeansClustering.h>
Inheritance diagram for ossimKMeansClustering:
ossimReferenced
Classes
class  Cluster
 ossimKMeansClustering ()
 ~ossimKMeansClustering ()
void setNumClusters (ossim_uint32 K)
template<class T >
void setSamples (T *samples, ossim_uint32 num_entries)
template<class T >
void setPopulations (T *populations, ossim_uint32 num_entries)
bool computeKmeans ()
ossim_uint32 getNumClusters () const
double getMean (ossim_uint32 groupId) const
double getSigma (ossim_uint32 groupId) const
double getMinValue (ossim_uint32 groupId) const
double getMaxValue (ossim_uint32 groupId) const
const ossimKMeansClustering::ClustergetCluster (ossim_uint32 i) const
void setVerbose (bool v=true) const
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
Private Attributes
ossim_uint32 m_numEntries
double * m_samples
double * m_populations
std::vector< Clusterm_clusters
bool m_clustersValid
bool m_verbose
Additional Inherited Members
virtual ~ossimReferenced ()
Detailed Description
Definition at line 25 of file ossimKMeansClustering.h.
◆ ossimKMeansClustering()
ossimKMeansClustering::ossimKMeansClustering ( )
Definition at line 13 of file ossimKMeansClustering.cpp.
◆ ~ossimKMeansClustering()
ossimKMeansClustering::~ossimKMeansClustering ( )
Definition at line 23 of file ossimKMeansClustering.cpp.
References m_clusters, m_populations, and m_samples.
24 {
25  delete m_samples;
26  delete m_populations;
27  m_clusters.clear();
28 }
std::vector< Cluster > m_clusters
Member Function Documentation
◆ computeKmeans()
bool ossimKMeansClustering::computeKmeans ( )
Definition at line 37 of file ossimKMeansClustering.cpp.
References m_clusters, m_clustersValid, m_numEntries, m_populations, m_samples, m_verbose, max, min, n, OSSIM_DEFAULT_MAX_PIX_DOUBLE, and OSSIM_DEFAULT_MIN_PIX_DOUBLE.
Referenced by ossimShorelineTool::autoComputeThreshold(), and ossimKMeansFilter::computeKMeans().
38 {
39  if ((m_numEntries == 0) || (m_samples == 0))
40  return false;
41
42  if (m_verbose)
43  std::cout.precision(6);
44
45  // If populations aren't provided, assume only 1 of each sample:
46  if (m_populations == 0)
47  {
48  m_populations = new double [m_numEntries];
49  for (ossim_uint32 i=0; i<m_numEntries; ++i)
50  m_populations[i] = 1.0;
51  }
52
53  // Scan for min and max:
54  double overall_min = OSSIM_DEFAULT_MAX_PIX_DOUBLE;
55  double overall_max = OSSIM_DEFAULT_MIN_PIX_DOUBLE;
56  for (ossim_uint32 i=0; i<m_numEntries; i++)
57  {
58  if (m_populations[i] == 0)
59  continue;
60
61  if (m_samples[i] < overall_min)
62  overall_min = m_samples[i];
63  else if (m_samples[i] > overall_max)
64  overall_max = m_samples[i];
65  }
66
67  double max_delta = overall_max - overall_min;
68  // double convergenceThreshold = 0.1*(max_delta)/m_numEntries;
69  ossim_uint32 numClusters = m_clusters.size();
70  double* variances = new double [numClusters];
71  ossim_uint32* priorCounts = new ossim_uint32 [numClusters];
72  double interm_samples = (overall_max - overall_min) / numClusters;
73  double mean_i = overall_min + interm_samples / 2.0; // initial mean for cluster 0;
74  double bound = overall_min;
75  for (ossim_uint32 gid=0; gid<numClusters; ++gid)
76  {
77  //Initialize cluster with even spread and initial mean:
78  m_clusters[gid].min = bound;
79  bound += interm_samples;
80  m_clusters[gid].max = bound;
81  m_clusters[gid].mean = mean_i;
82  m_clusters[gid].new_mean = 0;
83  mean_i += interm_samples;
84  m_clusters[gid].n = 0;
85  m_clusters[gid].sigma = 1.0;
86  variances[gid] = 0.0;
87  priorCounts[gid] = 0;
88  }
89  double delta, min_delta;
90  // ossim_uint32 best_gid, np, iters = 0, max_iters = 20;
91  ossim_uint32 best_gid, iters = 0, max_iters = 20;
92  bool converged = false;
93
94  // Loop until converged on best solution:
95  while (!converged && (iters < max_iters))
96  {
97  converged = true; // prove otherwise
98  ++iters;
99
100  for (ossim_uint32 gid=0; gid<numClusters; ++gid)
101  {
102  m_clusters[gid].min = overall_max;
103  m_clusters[gid].max = overall_min;
104  }
105
106  for (ossim_uint32 i=0; i<m_numEntries; i++)
107  {
108  if ( m_populations[i] == 0)
109  continue;
110
111  // Find the current cluster:
112  best_gid = 0;
113  min_delta = OSSIM_DEFAULT_MAX_PIX_DOUBLE;
114  for (ossim_uint32 gid=0; gid<numClusters; ++gid)
115  {
116  delta = fabs((m_samples[i] - m_clusters[gid].mean));
117  if (delta < min_delta)
118  {
119  min_delta = delta;
120  best_gid = gid;
121  }
122  }
123
124  // Possible update of min/max for current cluster:
125  if (m_samples[i] < m_clusters[best_gid].min)
126  m_clusters[best_gid].min = m_samples[i];
127  else if (m_samples[i] > m_clusters[best_gid].max)
128  m_clusters[best_gid].max = m_samples[i];
129
130  // Accumulate sample for the new mean for this cluster:
131  m_clusters[best_gid].new_mean += m_populations[i]*m_samples[i];
132  m_clusters[best_gid].n += m_populations[i];
133
134  // Add this bin's contribution to the cluster stats. Use the sigma member as accumulator,
135  // normalize later:
136  delta = m_clusters[best_gid].mean - m_samples[i];
137  variances[best_gid] += m_populations[i]*delta*delta;
138
139  } // End loop over bins
140
141  // Finished processing all input pixels for this iteration. Update the means:
142  for (ossim_uint32 gid=0; gid<numClusters; ++gid)
143  {
144  // Compute new mean from accumulation:
145  if (m_clusters[gid].n)
146  {
147  m_clusters[gid].new_mean /= m_clusters[gid].n;
148  m_clusters[gid].sigma = sqrt(variances[gid] / m_clusters[gid].n);
149  variances[gid] = 0.0;
150  }
151
152  //if (fabs(m_clusters[gid].mean - m_clusters[gid].new_mean) > convergenceThreshold )
153  if (m_clusters[gid].n != priorCounts[gid])
154  converged = false;
155
156 // if (m_verbose)
157 // {
158 // cout<<"iteration: "<<iters<<endl;
159 // cout<<"cluster["<<gid<<"].mean = "<<m_clusters[gid].mean<<endl;
160 // cout<<"cluster["<<gid<<"].new_mean = "<<m_clusters[gid].new_mean<<endl;
161 // cout<<"cluster["<<gid<<"].sigma = "<<m_clusters[gid].sigma<<endl;
162 // cout<<"cluster["<<gid<<"].n = "<<(int)m_clusters[gid].n<<" prior: "<<priorCounts[gid]<<endl;
163 // cout<<"cluster["<<gid<<"].min = "<<m_clusters[gid].min<<endl;
164 // cout<<"cluster["<<gid<<"].max = "<<m_clusters[gid].max<<endl;
165 // cout << endl;
166 // }
167  if (m_clusters[gid].n)
168  m_clusters[gid].mean = m_clusters[gid].new_mean;
169
170  if (!converged)
171  {
172  priorCounts[gid] = m_clusters[gid].n;
173  m_clusters[gid].n = 0;
174  m_clusters[gid].new_mean = 0;
175  }
176  }
177  } // End overall loop for convergence:
178
179  if (m_verbose)
180  {
181  cout<<"\nossimKMeansClustering Summary ("<<iters<<" iterations):"<<endl;
182  for (ossim_uint32 gid=0; gid<numClusters; gid++)
183  {
184  cout<<"\n cluster["<<gid<<"] n = "<<(int)m_clusters[gid].n<<endl;
185  cout<<" mean = "<<m_clusters[gid].mean<<endl;
186  cout<<" sigma = "<<m_clusters[gid].sigma<<endl;
187  cout<<" min = "<<m_clusters[gid].min<<endl;
188  cout<<" max = "<<m_clusters[gid].max<<endl;
189  }
190  cout << endl;
191  }
192
193  delete [] variances;
194  delete [] priorCounts;
195  m_clustersValid = true;
196  return true;
197
198 }
#define OSSIM_DEFAULT_MAX_PIX_DOUBLE
#define OSSIM_DEFAULT_MIN_PIX_DOUBLE
os2<< "> n<< " > nendobj n
unsigned int ossim_uint32
#define max(a, b)
Definition: auxiliary.h:76
#define min(a, b)
Definition: auxiliary.h:75
◆ getCluster()
const ossimKMeansClustering::Cluster * ossimKMeansClustering::getCluster ( ossim_uint32  i) const
Definition at line 233 of file ossimKMeansClustering.cpp.
References m_clusters.
Referenced by ossimKMeansFilter::getTile(), and ossimKMeansFilter::saveState().
234 {
235  if (i >= m_clusters.size())
236  return 0;
237  return &(m_clusters[i]);
238 }
◆ getMaxValue()
double ossimKMeansClustering::getMaxValue ( ossim_uint32  groupId) const
Definition at line 224 of file ossimKMeansClustering.cpp.
References m_clusters, and ossim::nan().
225 {
226  if (clusterId >= m_clusters.size())
227  return ossim::nan();
228
229  return m_clusters[clusterId].max;
230 }
double nan()
Definition: ossimCommon.h:135
◆ getMean()
double ossimKMeansClustering::getMean ( ossim_uint32  groupId) const
Definition at line 200 of file ossimKMeansClustering.cpp.
201 {
202  if (clusterId >= m_clusters.size())
203  return ossim::nan();
204
205  return m_clusters[clusterId].mean;
206 }
double nan()
◆ getMinValue()
double ossimKMeansClustering::getMinValue ( ossim_uint32  groupId) const
Definition at line 216 of file ossimKMeansClustering.cpp.
217 {
218  if (clusterId >= m_clusters.size())
219  return ossim::nan();
220
221  return m_clusters[clusterId].min;
222 }
double nan()
◆ getNumClusters()
ossim_uint32 ossimKMeansClustering::getNumClusters ( ) const
inline
Definition at line 50 of file ossimKMeansClustering.h.
Referenced by ossimKMeansFilter::computeKMeans().
50 { return m_clusters.size(); }
◆ getSigma()
double ossimKMeansClustering::getSigma ( ossim_uint32  groupId) const
Definition at line 208 of file ossimKMeansClustering.cpp.
209 {
210  if (clusterId >= m_clusters.size())
211  return ossim::nan();
212
213  return m_clusters[clusterId].sigma;
214 }
double nan()
◆ setNumClusters()
void ossimKMeansClustering::setNumClusters ( ossim_uint32  K)
Definition at line 30 of file ossimKMeansClustering.cpp.
References m_clusters, and m_clustersValid.
31 {
32  m_clusters.clear();
33  m_clusters.resize(K);
34  m_clustersValid = false;
35 }
◆ setPopulations()
template<class T >
void ossimKMeansClustering::setPopulations ( T *  populations,
Definition at line 81 of file ossimKMeansClustering.h.
References m_clustersValid, and m_populations.
83 {
84  if ((num_entries == 0) || (populations == 0))
85  return;
86
87  m_clustersValid = false;
88  m_populations = new double[num_entries];
89  for (ossim_uint32 i=0; i<num_entries; i++)
90  m_populations[i] = (double) populations[i];
91 }
◆ setSamples()
template<class T >
void ossimKMeansClustering::setSamples ( T *  samples,
Definition at line 69 of file ossimKMeansClustering.h.
References m_clustersValid, m_numEntries, and m_samples.
70 {
71  if ((num_entries == 0) || (samples == 0))
72  return;
73
74  m_clustersValid = false;
75  m_numEntries = num_entries;
76  m_samples = new double[num_entries];
77  for (ossim_uint32 i=0; i<num_entries; i++)
78  m_samples[i] = (double) samples[i];
79 }
◆ setVerbose()
void ossimKMeansClustering::setVerbose ( bool  v = true) const
inline
Definition at line 58 of file ossimKMeansClustering.h.
Member Data Documentation
◆ m_clusters
std::vector<Cluster> ossimKMeansClustering::m_clusters
private
◆ m_clustersValid
bool ossimKMeansClustering::m_clustersValid
private
Definition at line 65 of file ossimKMeansClustering.h.
Referenced by computeKmeans(), setNumClusters(), setPopulations(), and setSamples().
◆ m_numEntries
ossim_uint32 ossimKMeansClustering::m_numEntries
private
Definition at line 61 of file ossimKMeansClustering.h.
Referenced by computeKmeans(), and setSamples().
◆ m_populations
double* ossimKMeansClustering::m_populations
private
Definition at line 63 of file ossimKMeansClustering.h.
Referenced by computeKmeans(), setPopulations(), and ~ossimKMeansClustering().
◆ m_samples
double* ossimKMeansClustering::m_samples
private
Definition at line 62 of file ossimKMeansClustering.h.
Referenced by computeKmeans(), setSamples(), and ~ossimKMeansClustering().
◆ m_verbose
bool ossimKMeansClustering::m_verbose
mutableprivate
Definition at line 66 of file ossimKMeansClustering.h.
Referenced by computeKmeans().
