Public Types | Public Member Functions | List of all members
ossimKakaduCompressorInterface Class Referenceabstract
#include <ossimKakaduCompressorInterface.h>
Inheritance diagram for ossimKakaduCompressorInterface:
Public Types
enum  ossimKakaduCompressionQuality {
  OKP_UNKNOWN = 0, OKP_USER_DEFINED = 1, OKP_NUMERICALLY_LOSSLESS = 2, OKP_VISUALLY_LOSSLESS = 3,
  OKP_LOSSY = 4, OKP_LOSSY2 = 5, OKP_LOSSY3 = 6, OKP_EPJE = 7
 ossimKakaduCompressorInterface ()
 GP: I had to add this or windows would not link with the latest compiler. More...
virtual void create (ossim::ostream *os, ossimScalarType scalar, ossim_uint32 bands, const ossimIrect &imageRect, const ossimIpt &tileSize, ossim_uint32 tilesToWrite, bool jp2)=0
 Create method. More...
virtual bool writeTile (ossimImageData &srcTile)=0
 Write tile method. More...
virtual void finish ()=0
 Finish method. More...
virtual void setAlphaChannelFlag (bool flag)=0
 Set the writer to add an alpha channel to the output. More...
virtual void setLevels (ossim_int32 levels)=0
 Sets the number of levels. More...
virtual bool setProperty (ossimRefPtr< ossimProperty > property)=0
 Will set the property whose name matches the argument "property->getName()". More...
virtual void setQualityType (ossimKakaduCompressionQuality type)=0
 Sets the quality type. More...
Detailed Description
Definition at line 29 of file ossimKakaduCompressorInterface.h.
◆ ossimKakaduCompressionQuality
◆ ossimKakaduCompressorInterface()
ossimKakaduCompressorInterface::ossimKakaduCompressorInterface ( )
Also had to put in dot.cpp for debug mode(again windows). (drb)
Definition at line 18 of file ossimKakaduCompressorInterface.cpp.
19 {
20 }
Member Function Documentation
◆ create()
virtual void ossimKakaduCompressorInterface::create ( ossim::ostream os,
ossim_uint32  bands,
const ossimIrect imageRect,
const ossimIpt tileSize,
bool  jp2
pure virtual
Create method.
Parameters
osStream to write to.
scalarScalar type of source tiles to be fed to compressor.
bandsNumber of bands in source tiles to be fed to compressor.
imageRectThe image rectangle.
tileSizeThe size of a tile.
tilesTileWriteThe number of tiles to be written. If zero, the tlm marker segment will not be used.
jp2If true jp2 header and jp2 geotiff block will be written out.
Note
Throws ossimException on error.
Implemented in ossimKakaduCompressor.
◆ finish()
virtual void ossimKakaduCompressorInterface::finish ( )
pure virtual
Finish method.
Every call to "create" should be matched by a "finish". Note the destructor calls finish.
◆ setAlphaChannelFlag()
virtual void ossimKakaduCompressorInterface::setAlphaChannelFlag ( bool  flag)
pure virtual
Parameters
flagtrue to create an alpha channel.
◆ setLevels()
virtual void ossimKakaduCompressorInterface::setLevels ( ossim_int32  levels)
pure virtual
This must be positive and at least 1. Default = 5 ( r0 - r5 )
Parameters
levelsLevels to set.
◆ setProperty()
virtual bool ossimKakaduCompressorInterface::setProperty ( ossimRefPtr< ossimProperty property)
pure virtual
Parameters
propertyObject containing property to set.
Returns
true if property was consumed, false if not.
◆ setQualityType()
virtual void ossimKakaduCompressorInterface::setQualityType ( ossimKakaduCompressionQuality  type)
pure virtual
Type enumerations: OKP_UNKNOWN = 0, OKP_USER_DEFINED = 1, OKP_NUMERICALLY_LOSSLESS = 2, OKP_VISUALLY_LOSSLESS = 3, OKP_EPJE = 4
Parameters
typeSee enumeration for types.
◆ writeTile()
virtual bool ossimKakaduCompressorInterface::writeTile ( ossimImageData srcTile)
pure virtual
Write tile method.
Writes tiles stream provided to create method. Note that tiles should be fed to compressor in left to right, top to bottom order.
Parameters
srcTileThe source tile to write.
Returns
