Public Member Functions | Static Public Member Functions | Private Member Functions | List of all members
ossimKakaduOverviewBuilderFactory Class Reference
The ossim overview builder factory. More...
#include <ossimKakaduOverviewBuilderFactory.h>
Inheritance diagram for ossimKakaduOverviewBuilderFactory:
ossimOverviewBuilderFactoryBase ossimObjectFactory ossimObject ossimReferenced
virtual ~ossimKakaduOverviewBuilderFactory ()
 virtual destructor More...
virtual ossimOverviewBuilderBasecreateBuilder (const ossimString &typeName) const
 Creates a builder from a string. More...
virtual void getTypeNameList (std::vector< ossimString > &typeList) const
 Method to populate a list of supported types for the factory. More...
- Public Member Functions inherited from ossimOverviewBuilderFactoryBase
 ossimOverviewBuilderFactoryBase ()
 default constructor hidden from use More...
virtual ~ossimOverviewBuilderFactoryBase ()
virtual ossimObjectcreateObject (const ossimString &typeName) const
virtual ossimObjectcreateObject (const ossimKeywordlist &kwl, const char *prefix=0) const
- Public Member Functions inherited from ossimObjectFactory
virtual ~ossimObjectFactory ()
 ossimObject ()
virtual ~ossimObject ()
 Generic print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
static ossimKakaduOverviewBuilderFactoryinstance ()
 static instance method. More...
 ossimKakaduOverviewBuilderFactory (const ossimKakaduOverviewBuilderFactory &obj)
 copy constructor hidden from use More...
void operator= (const ossimKakaduOverviewBuilderFactory &rhs)
 operator= hidden from use. More...
Additional Inherited Members
virtual ~ossimReferenced ()
Detailed Description
Definition at line 27 of file ossimKakaduOverviewBuilderFactory.h.
◆ ~ossimKakaduOverviewBuilderFactory()
ossimKakaduOverviewBuilderFactory::~ossimKakaduOverviewBuilderFactory ( )
virtual
virtual destructor
Definition at line 21 of file ossimKakaduOverviewBuilderFactory.cpp.
22 {
23 }
◆ ossimKakaduOverviewBuilderFactory() [1/2]
ossimKakaduOverviewBuilderFactory::ossimKakaduOverviewBuilderFactory ( )
private
Definition at line 45 of file ossimKakaduOverviewBuilderFactory.cpp.
46 {
47 }
◆ ossimKakaduOverviewBuilderFactory() [2/2]
ossimKakaduOverviewBuilderFactory::ossimKakaduOverviewBuilderFactory ( const ossimKakaduOverviewBuilderFactory obj)
private
Definition at line 49 of file ossimKakaduOverviewBuilderFactory.cpp.
51 {
52 }
Member Function Documentation
◆ createBuilder()
ossimOverviewBuilderBase * ossimKakaduOverviewBuilderFactory::createBuilder ( const ossimString typeName) const
virtual
This should match a string from the getTypeNameList() method. Pure virtual.
Returns
Pointer to ossimOverviewBuilderInterface or NULL is not found within registered factories.
Implements ossimOverviewBuilderFactoryBase.
Definition at line 25 of file ossimKakaduOverviewBuilderFactory.cpp.
References ossimOverviewBuilderBase::hasOverviewType(), and ossimRefPtr< T >::release().
27 {
29  if ( result->hasOverviewType(typeName) == false )
30  {
31  result = 0;
32  }
33
34  return result.release();
35 }
virtual bool hasOverviewType(const ossimString &type) const
Method to check if builder can handle type.
T * release()
Definition: ossimRefPtr.h:93
ossimKakaduNitfOverviewBuilder Class to build overviews from the Kakadu library.
◆ getTypeNameList()
void ossimKakaduOverviewBuilderFactory::getTypeNameList ( std::vector< ossimString > &  typeList) const
virtual
registered to this registry. Pure virtual.
Parameters
typeListList of ossimStrings to add to.
Definition at line 37 of file ossimKakaduOverviewBuilderFactory.cpp.
References ossimOverviewBuilderBase::getTypeNameList().
39 {
41  builder->getTypeNameList(typeList);
42  builder = 0;
43 }
virtual void getTypeNameList(std::vector< ossimString > &typeList) const =0
Method to populate class supported types.
◆ instance()
ossimKakaduOverviewBuilderFactory * ossimKakaduOverviewBuilderFactory::instance ( )
static
Definition at line 15 of file ossimKakaduOverviewBuilderFactory.cpp.
Referenced by ossimSharedLibraryFinalize(), and ossimSharedLibraryInitialize().
16 {
18  return &inst;
19 }
◆ operator=()
void ossimKakaduOverviewBuilderFactory::operator= ( const ossimKakaduOverviewBuilderFactory rhs)
private
Definition at line 54 of file ossimKakaduOverviewBuilderFactory.cpp.
56 {
57 }
