ossimKakaduNitfOverviewBuilder Class to build overviews from the Kakadu library. More...
#include <ossimKakaduNitfOverviewBuilder.h>
ossimKakaduNitfOverviewBuilder () | |
default constructor More... | |
virtual | ~ossimKakaduNitfOverviewBuilder () |
virtual destructor More... | |
virtual bool | execute () |
Builds the overviews. More... | |
virtual void | setOutputFile (const ossimFilename &file) |
Sets the output filename. More... | |
virtual ossimFilename | getOutputFile () const |
Returns the output. More... | |
virtual bool | setOverviewType (const ossimString &type) |
Sets the overview output type. More... | |
virtual ossimString | getOverviewType () const |
Gets the overview type. More... | |
virtual void | getTypeNameList (std::vector< ossimString > &typeList) const |
Method to populate class supported types. More... | |
virtual ossimObject * | getObject () |
virtual const ossimObject * | getObject () const |
virtual bool | canConnectMyInputTo (ossim_int32 index, const ossimConnectableObject *obj) const |
virtual void | setProperty (ossimRefPtr< ossimProperty > property) |
Method to set properties. More... | |
virtual void | getPropertyNames (std::vector< ossimString > &propertyNames) const |
Method to populate the list of property names. More... | |
virtual std::ostream & | print (std::ostream &out) const |
print method. More... | |
ossimOverviewBuilderBase () | |
virtual bool | setOutputWriter (ossimImageFileWriter *outputWriter) |
Sets an optional file writer to the builder. More... | |
virtual bool | setInputSource (ossimImageHandler *imageSource) |
Sets the input to the builder. More... | |
virtual bool | hasOverviewType (const ossimString &type) const |
Method to check if builder can handle type. More... | |
virtual ossim_uint32 | getOverviewStopDimension () const |
Get the overview stop dimension. More... | |
virtual void | setOverviewStopDimension (ossim_uint32 dim) |
Sets the overview stop dimension. More... | |
ossimHistogramMode | getHistogramMode () const |
Gets the histogram accumulation mode. More... | |
void | setHistogramMode (ossimHistogramMode mode) |
Sets the histogram accumulation mode. More... | |
virtual void | finalize () |
Finalize method. More... | |
void | setBitMaskSpec (const ossimKeywordlist &bit_mask_spec) |
Specifies parameters (in KWL) for generation of an alpha (bit) mask such that any full or partial null pixels will be masked out. More... | |
void | setScanForMinMax (bool flag) |
Turn on/off scan for min max flag. More... | |
bool | getScanForMinMax () const |
void | setScanForMinMaxNull (bool flag) |
Turn on/off scan for min, max, null flag. More... | |
bool | getScanForMinMaxNull () const |
ossimSource (ossimObject *owner=0) | |
ossimSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimSource () |
virtual bool | isSourceEnabled () const |
virtual void | enableSource () |
virtual void | disableSource () |
virtual bool | getEnableFlag () const |
virtual void | setEnableFlag (bool flag) |
virtual bool | isInitialized () const |
virtual void | setInitializedFlag (bool flag) |
virtual void | initialize () |
virtual ossimRefPtr< ossimProperty > | getProperty (const ossimString &name) const |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=0) |
ossimConnectableObject (ossimObject *owner=0) | |
Base constructor of this object. More... | |
ossimConnectableObject (ossimObject *owner, ossim_int32 inputListSize, ossim_int32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimConnectableObject () |
void | setId (const ossimId &id) |
All connectable objects will have id's. More... | |
const ossimId & | getId () const |
Will allow us to get this object's id. More... | |
const ossimObject * | getOwner () const |
Fetches the current owner, most likely a container but not limited to one. More... | |
virtual void | changeOwner (ossimObject *owner) |
Permits changing the object's owner. More... | |
virtual void | setDescription (const ossimString &description) |
virtual ossimString | getDescription () const |
virtual bool | isConnected (ossimConnectableObjectDirectionType direction=CONNECTABLE_DIRECTION_INPUT) const |
will check the direction specified to see if all slots are full. More... | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findConnectableObject(const ossimId &id)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObjectOfType(RTTItypeid typeId, ossimConnectableObjectDirectionType directionType, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObjectOfType(const ossimString &obj, ossimConnectableObjectDirectionType directionType, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findInputObjectOfType(const ossimString &className)) | |
virtual ossim_int32 | findInputIndex (const ossimConnectableObject *object) |
Return a valid index of the input list if the passed in object is found else return -1. More... | |
virtual ossim_int32 | findInputIndex (const ossimId &id) |
Return a valid index of the input list if the passed id is found else return -1. More... | |
virtual ossim_int32 | findOutputIndex (const ossimConnectableObject *object) |
Return a valid index of the output list if the passed in object is found else return -1. More... | |
virtual ossim_int32 | findOutputIndex (const ossimId &id) |
virtual ossim_int32 | getMyInputIndexToConnectTo (ossimConnectableObject *object) const |
Should return the first available index to connect to. More... | |
virtual ossim_int32 | getMyOutputIndexToConnectTo (ossimConnectableObject *object) const |
virtual bool | canConnectMyOutputTo (ossim_int32 myOutputIndex, const ossimConnectableObject *object) const |
default implementation is to allow anyone to connect to us. More... | |
virtual void | disconnect (ossimConnectableObject *object=0) |
Will disconnect the object passed in. More... | |
virtual void | disconnect (const ossimId &id) |
virtual ossimRefPtr< ossimConnectableObject > | disconnectMyInput (ossim_int32 inputIndex, bool disconnectOutputFlag=true, bool createEventFlag=true) |
Will disconnect the object at the given input index and generate a connection event. More... | |
virtual void | disconnectMyInput (ossimConnectableObject *input, bool disconnectOutputFlag=true, bool createEventFlag=true) |
Finds the index of the passed in input and calls disconnectMyInput(inputIndex, disconnectOutputFlag, createEventFlag);. More... | |
virtual void | disconnectMyInputs (ConnectableObjectList &inputList, bool disconnectOutputFlag=true, bool createEventFlag=true) |
virtual ossimRefPtr< ossimConnectableObject > | disconnectMyOutput (ossim_int32 outputIndex, bool disconnectInputFlag=true, bool createEventFlag=true) |
Will disconnect the object at the given output index and generate a connection event. More... | |
virtual void | disconnectMyOutput (ossimConnectableObject *output, bool disconnectInputFlag=true, bool createEventFlag=true) |
Will disconnect the output object. More... | |
virtual void | disconnectMyOutputs (ConnectableObjectList &outputList, bool disconnectOutputFlag=true, bool createEventFlag=true) |
virtual void | disconnectAllInputs () |
Will disconnect all of the input objects. More... | |
virtual void | disconnectAllOutputs () |
Will disconnect all of the output objects. More... | |
virtual ossim_int32 | connectMyInputTo (ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true) |
Will try to connect this objects input to the passed in object. More... | |
virtual ossim_int32 | connectMyInputTo (ossim_int32 inputIndex, ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true) |
Will connect the specified input to the passed in object. More... | |
virtual bool | connectMyInputTo (ConnectableObjectList &inputList, bool makeOutputConnection=true, bool createEventFlag=true) |
virtual ossim_int32 | connectMyOutputTo (ossimConnectableObject *outputObject, bool makeInputConnection=true, bool createEventFlag=true) |
Will try to connect this objects output to the passed in object. More... | |
virtual bool | connectMyOutputTo (ConnectableObjectList &outputList, bool makeInputConnection=true, bool createEventFlag=true) |
virtual bool | connectInputList (ConnectableObjectList &inputList) |
Will disconnect itself from all inputs and reset to the passed in input list. More... | |
virtual bool | connectOutputList (ConnectableObjectList &outputList) |
Will disconnect itself from all outputs and reset to the passed in output list. More... | |
virtual ossim_uint32 | getNumberOfInputs () const |
Returns the number of input objects. More... | |
virtual ossim_uint32 | getNumberOfOutputs () const |
Return the number of output objects. More... | |
ossimConnectableObject * | getInput (ossim_uint32 index=0) |
returns the object at the specified index. More... | |
const ossimConnectableObject * | getInput (ossim_uint32 index=0) const |
ossimConnectableObject * | getOutput (ossim_uint32 index=0) |
const ossimConnectableObject * | getOutput (ossim_uint32 index=0) const |
virtual void | setNumberOfInputs (ossim_int32 numberOfInputs) |
Will set the number of inputs. More... | |
virtual bool | getInputListIsFixedFlag () const |
virtual bool | getOutputListIsFixedFlag () const |
virtual void | setNumberOfOutputs (ossim_int32 numberOfInputs) |
Will set the number of outputs. More... | |
const ConnectableObjectList & | getInputList () const |
const ConnectableObjectList & | getOutputList () const |
ConnectableObjectList & | getInputList () |
ConnectableObjectList & | getOutputList () |
OSSIM_DEPRECATE_METHOD (virtual void findAllObjectsOfType(ConnectableObjectList &result, const RTTItypeid &typeInfo, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual void findAllObjectsOfType(ConnectableObjectList &result, const ossimString &className, bool recurse=true)) | |
virtual void | propagateEventToOutputs (ossimEvent &event) |
virtual void | propagateEventToInputs (ossimEvent &event) |
virtual void | setProperty (const ossimString &name, const ossimString &value) |
virtual ossim_uint32 | saveStateOfAllInputs (ossimKeywordlist &kwl, bool saveThisStateFlag=true, ossim_uint32 objectIndex=1, const char *prefix=0) const |
Save the state of all inputs to a keyword list. More... | |
virtual bool | fillContainer (ossimConnectableContainer &container) |
Inserts this object and all of its children and inputs into the container provided. More... | |
bool | moveInputUp (const ossimId &id) |
Moves the input connection matching id up one in the connection list. More... | |
bool | moveInputDown (const ossimId &id) |
Moves the input connection matching id down one in the connection list. More... | |
bool | moveInputToTop (const ossimId &id) |
Moves the input connection matching id to the top of the connection list. More... | |
bool | moveInputToBottom (const ossimId &id) |
Moves the input connection matching id to the bottom of the connection list. More... | |
virtual void | accept (ossimVisitor &visitor) |
We will add a visitor interface for all connectable objects. More... | |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimObject * | dup () const |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
ossimListenerManager () | |
virtual | ~ossimListenerManager () |
virtual void | fireEvent (ossimEvent &event) |
virtual bool | addListener (ossimListener *listener) |
virtual bool | removeListener (ossimListener *listener) |
virtual bool | findListener (ossimListener *listener) |
ossimPropertyInterface () | |
virtual | ~ossimPropertyInterface () |
virtual ossimString | getPropertyValueAsString (const ossimString &name) const |
void | getPropertyList (std::vector< ossimRefPtr< ossimProperty > > &propertyList) const |
void | setProperties (std::vector< ossimRefPtr< ossimProperty > > &propertyList) |
ossimErrorStatusInterface () | |
virtual | ~ossimErrorStatusInterface () |
virtual ossimErrorCode | getErrorStatus () const |
virtual ossimString | getErrorStatusString () const |
virtual void | setErrorStatus (ossimErrorCode error_status) const |
virtual void | setErrorStatus () const |
virtual void | clearErrorStatus () const |
bool | hasError () const |
ossimProcessInterface () | |
virtual | ~ossimProcessInterface () |
virtual void | abort () |
bool | needsAborting () const |
bool | isAbortRequested () const |
bool | isAborted () const |
bool | isExecuting () const |
ossimProcessStatus | getProcessStatus () const |
virtual void | setProcessStatus (ossimProcessStatus processStatus) |
virtual double | getPercentComplete () const |
virtual void | setPercentComplete (double percentComplete) |
virtual ossimListenerManager * | getManager () |
void | enableEvents () |
void | disableEvents () |
void | setCurrentMessage (const ossimString &message) |
ossimConnectableObjectListener () | |
virtual | ~ossimConnectableObjectListener () |
virtual void | processEvent (ossimEvent &event) |
ProcessEvent. More... | |
virtual void | objectDestructingEvent (ossimObjectDestructingEvent &) |
virtual void | connectionEvent (ossimConnectionEvent &) |
virtual void | disconnectInputEvent (ossimConnectionEvent &) |
virtual void | disconnectOutputEvent (ossimConnectionEvent &) |
virtual void | connectInputEvent (ossimConnectionEvent &) |
virtual void | connectOutputEvent (ossimConnectionEvent &) |
virtual void | propertyEvent (ossimPropertyEvent &) |
virtual void | addObjectEvent (ossimContainerEvent &) |
virtual void | removeObjectEvent (ossimContainerEvent &) |
virtual void | containerEvent (ossimContainerEvent &) |
virtual void | refreshEvent (ossimRefreshEvent &) |
ossimListener () | |
virtual | ~ossimListener () |
void | enableListener () |
void | disableListener () |
void | setListenerEnableFlag (bool flag) |
bool | isListenerEnabled () const |
bool | getListenerEnableFlag () const |
Private Member Functions | |
void | setImagField (ossimNitfImageHeaderV2_1 *hdr, ossim_uint32 startingResLevel) const |
Set the Image Magnification (IMAG) field in the form of "/2 ". More... | |
Private Attributes | |
ossimFilename | m_outputFile |
ossimFilename | m_outputFileTmp |
ossimKakaduCompressor * | m_compressor |
Definition at line 32 of file ossimKakaduNitfOverviewBuilder.h.
ossimKakaduNitfOverviewBuilder::ossimKakaduNitfOverviewBuilder | ( | ) |
default constructor
Definition at line 66 of file ossimKakaduNitfOverviewBuilder.cpp.
virtual destructor
Definition at line 90 of file ossimKakaduNitfOverviewBuilder.cpp.
References m_compressor, and ossimOverviewBuilderBase::m_imageHandler.
Implements ossimConnectableObject.
Definition at line 748 of file ossimKakaduNitfOverviewBuilder.cpp.
References PTR_CAST.
Implements ossimOverviewBuilderBase.
Definition at line 149 of file ossimKakaduNitfOverviewBuilder.cpp.
Implements ossimProcessInterface.
Definition at line 738 of file ossimKakaduNitfOverviewBuilder.cpp.
Definition at line 743 of file ossimKakaduNitfOverviewBuilder.cpp.
Returns the output.
This will be derived from the input file if not explicitly set.
Definition at line 106 of file ossimKakaduNitfOverviewBuilder.cpp.
References ossimImageHandler::getNumberOfEntries(), ossimOverviewBuilderBase::m_imageHandler, m_outputFile, ossimFilename::NIL, and ossimRefPtr< T >::valid().
Satisfies pure virtual from ossimOverviewBuilderInterface.
Definition at line 137 of file ossimKakaduNitfOverviewBuilder.cpp.
propertyNames | List to populate. This does not clear the list just adds to it. |
Definition at line 725 of file ossimKakaduNitfOverviewBuilder.cpp.
References ossimKakaduCompressor::getPropertyNames(), and m_compressor.
typeList | List of ossimStrings to add to. |
Definition at line 142 of file ossimKakaduNitfOverviewBuilder.cpp.
print method.
Reimplemented from ossimProcessInterface.
Definition at line 731 of file ossimKakaduNitfOverviewBuilder.cpp.
private |
hdr | The nitf image header. |
starting | resolution level. |
Definition at line 761 of file ossimKakaduNitfOverviewBuilder.cpp.
References ossimNitfImageHeaderV2_1::setImageMagnification(), ossimString::size(), and ossimString::toString().
file | The output file name. |
Definition at line 101 of file ossimKakaduNitfOverviewBuilder.cpp.
References m_outputFile.
Currently handled types are: "ossim_tiff_nearest" and "ossim_tiff_box"
type | This should be the string representing the type. This method will do nothing if type is not handled and return false. |
Definition at line 121 of file ossimKakaduNitfOverviewBuilder.cpp.
property | Property to set. |
Definition at line 716 of file ossimKakaduNitfOverviewBuilder.cpp.
References m_compressor, ossimKakaduCompressor::setProperty(), and ossimRefPtr< T >::valid().
private |
Definition at line 150 of file ossimKakaduNitfOverviewBuilder.h.
Referenced by getPropertyNames(), setProperty(), and ~ossimKakaduNitfOverviewBuilder().
private |
Definition at line 148 of file ossimKakaduNitfOverviewBuilder.h.
Referenced by getOutputFile(), and setOutputFile().
private |
Definition at line 149 of file ossimKakaduNitfOverviewBuilder.h.
