Public Member Functions | Static Public Member Functions | Protected Member Functions | Static Protected Attributes | List of all members
ossimNitfCodecFactory Class Reference
This is a convenience class that is used by the NITF handler to create the proper keywordlist from the TREs and then calls the CodecRegistry to actuall return and allocate a new codec. More...
#include <ossimNitfCodecFactory.h>
 ~ossimNitfCodecFactory ()
ossimCodecBasecreateCodec (ossimRefPtr< ossimNitfImageHeader > imageHeader)
static ossimNitfCodecFactoryinstance ()
static std::mutex m_mutex
static ossimNitfCodecFactorym_instance =0
Detailed Description
Definition at line 21 of file ossimNitfCodecFactory.h.
◆ ~ossimNitfCodecFactory()
ossimNitfCodecFactory::~ossimNitfCodecFactory ( )
Definition at line 22 of file ossimNitfCodecFactory.cpp.
References m_instance, and m_mutex.
23 {
24  std::lock_guard<std::mutex> lock(m_mutex);
25  m_instance = 0;
26 }
static ossimNitfCodecFactory * m_instance
◆ ossimNitfCodecFactory()
ossimNitfCodecFactory::ossimNitfCodecFactory ( )
protected
Definition at line 17 of file ossimNitfCodecFactory.cpp.
References m_instance.
Referenced by instance().
18 {
19  m_instance = this;
20 }
Member Function Documentation
◆ createCodec()
ossimCodecBase * ossimNitfCodecFactory::createCodec ( ossimRefPtr< ossimNitfImageHeader imageHeader)
Definition at line 40 of file ossimNitfCodecFactory.cpp.
References ossimKeywordlist::add(), ossimString::c_str(), ossimCodecFactoryRegistry::createCodec(), ossimNitfImageHeader::getCompressionCode(), ossimCodecFactoryRegistry::instance(), ossimNitfImageHeader::isCompressed(), ossimNitfImageHeader::saveState(), and ossimRefPtr< T >::valid().
41 {
42  ossimCodecBase* result=0;
43
44  if(imageHeader.valid()&&imageHeader->isCompressed())
45  {
46  ossimKeywordlist kwl;
47
48  imageHeader->saveState(kwl);
49  // rename the type to be a NITF IC compression type
50  // J2K should be C8
51  //
52  kwl.add("type", imageHeader->getCompressionCode().c_str(), true);
54  }
55
56  return result;
57 }
static ossimCodecFactoryRegistry * instance()
bool valid() const
Definition: ossimRefPtr.h:75
virtual bool saveState(ossimKeywordlist &kwl, const ossimString &prefix="") const
virtual ossimCodecBase * createCodec(const ossimString &type) const
Will loop through all registered factories trying to allocate a codec for the passed in type...
virtual ossimString getCompressionCode() const =0
const char * c_str() const
Definition: ossimString.h:396
virtual bool isCompressed() const =0
◆ instance()
ossimNitfCodecFactory * ossimNitfCodecFactory::instance ( )
static
Definition at line 29 of file ossimNitfCodecFactory.cpp.
References m_instance, m_mutex, and ossimNitfCodecFactory().
30 {
31  std::lock_guard<std::mutex> lock(m_mutex);
32  if(!m_instance)
33  {
35  }
36
37  return m_instance;
38 }
Member Data Documentation
◆ m_instance
ossimNitfCodecFactory * ossimNitfCodecFactory::m_instance =0
staticprotected
Definition at line 30 of file ossimNitfCodecFactory.h.
Referenced by instance(), ossimNitfCodecFactory(), and ~ossimNitfCodecFactory().
◆ m_mutex
std::mutex ossimNitfCodecFactory::m_mutex
staticprotected
Definition at line 29 of file ossimNitfCodecFactory.h.
Referenced by instance(), and ~ossimNitfCodecFactory().
