Public Member Functions | Static Public Member Functions | Protected Member Functions | Static Protected Attributes | List of all members
ossimOpenCvObjectFactory Class Reference
Factory for ossimOpenCvObject. More...
#include <ossimOpenCvObjectFactory.h>
Inheritance diagram for ossimOpenCvObjectFactory:
ossimObjectFactory ossimObject ossimReferenced
virtual ~ossimOpenCvObjectFactory ()
 virtual destructor More...
virtual ossimObjectcreateObject (const ossimString &typeName) const
 createObject that takes a class name (eg. More...
virtual ossimObjectcreateObject (const ossimKeywordlist &kwl, const char *prefix=0) const
 Creates an object given a keyword list and prefix. More...
virtual void getTypeNameList (std::vector< ossimString > &typeList) const
 Adds ossimLasWriter to the typeList. More...
- Public Member Functions inherited from ossimObjectFactory
virtual ~ossimObjectFactory ()
 ossimObject ()
virtual ~ossimObject ()
 Generic print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
static ossimOpenCvObjectFactoryinstance ()
 static method to return instance (the only one) of this class. More...
 hidden from use default constructor More...
 ossimOpenCvObjectFactory (const ossimOpenCvObjectFactory &)
 hidden from use copy constructor More...
const ossimOpenCvObjectFactoryoperator= (const ossimOpenCvObjectFactory &)
virtual ~ossimReferenced ()
static ossimOpenCvObjectFactorytheInstance = 0
 static instance of this class More...
Detailed Description
Definition at line 22 of file ossimOpenCvObjectFactory.h.
◆ ~ossimOpenCvObjectFactory()
ossimOpenCvObjectFactory::~ossimOpenCvObjectFactory ( )
virtual
virtual destructor
Definition at line 28 of file ossimOpenCvObjectFactory.cpp.
References theInstance.
29 {
30  theInstance = 0;
31 }
static ossimOpenCvObjectFactory * theInstance
◆ ossimOpenCvObjectFactory() [1/2]
ossimOpenCvObjectFactory::ossimOpenCvObjectFactory ( )
protected
Definition at line 79 of file ossimOpenCvObjectFactory.cpp.
Referenced by instance().
80 {
81 }
◆ ossimOpenCvObjectFactory() [2/2]
ossimOpenCvObjectFactory::ossimOpenCvObjectFactory ( const ossimOpenCvObjectFactory )
protected
Definition at line 83 of file ossimOpenCvObjectFactory.cpp.
84 {
85 }
Member Function Documentation
◆ createObject() [1/2]
ossimObject * ossimOpenCvObjectFactory::createObject ( const ossimString typeName) const
virtual
ossimTieMeasurementGenerator)
Parameters
typeName(class, eg. "ossimTieMeasurementGenerator").
Implements ossimObjectFactory.
Definition at line 43 of file ossimOpenCvObjectFactory.cpp.
Referenced by createObject().
45 {
46  ossimObject* result = 0;
47
48  if(typeName == "ossimTieMeasurementGenerator")
49  {
50  result = new ossimTieMeasurementGenerator;
51  }
52  return result;
53 }
◆ createObject() [2/2]
ossimObject * ossimOpenCvObjectFactory::createObject ( const ossimKeywordlist kwl,
const char *  prefix = 0
) const
virtual
Parameters
kwlThe keyword list.
prefixthe keyword list prefix.
Definition at line 56 of file ossimOpenCvObjectFactory.cpp.
References createObject(), ossimKeywordlist::find(), and ossimObject::loadState().
58 {
59  ossimObject* result = 0;
60
61  const char* type = kwl.find(prefix, "type");
62  if(type)
63  {
64  result = createObject(ossimString(type));
65  if(result)
66  {
67  result->loadState(kwl, prefix);
68  }
69  }
70
71  return result;
72 }
virtual ossimObject * createObject(const ossimString &typeName) const
◆ getTypeNameList()
void ossimOpenCvObjectFactory::getTypeNameList ( std::vector< ossimString > &  typeList) const
virtual
Parameters
typeListList to add to.
Definition at line 74 of file ossimOpenCvObjectFactory.cpp.
75 {
76  typeList.push_back(ossimString("ossimTieMeasurementGenerator"));
77 }
◆ instance()
ossimOpenCvObjectFactory * ossimOpenCvObjectFactory::instance ( )
static
Returns
pointer to instance of this class.
Definition at line 33 of file ossimOpenCvObjectFactory.cpp.
References ossimOpenCvObjectFactory(), and theInstance.
Referenced by ossimSharedLibraryFinalize(), and ossimSharedLibraryInitialize().
34 {
35  if(!theInstance)
36  {
38  }
39  return theInstance;
40 }
◆ operator=()
const ossimOpenCvObjectFactory & ossimOpenCvObjectFactory::operator= ( const ossimOpenCvObjectFactory )
protected
Definition at line 87 of file ossimOpenCvObjectFactory.cpp.
88 {
89  return *this;
90 }
Member Data Documentation
◆ theInstance
ossimOpenCvObjectFactory * ossimOpenCvObjectFactory::theInstance = 0
staticprotected
Definition at line 66 of file ossimOpenCvObjectFactory.h.
Referenced by instance(), and ~ossimOpenCvObjectFactory().
