The ossim overview builder factory. More...
#include <ossimOverviewBuilderFactory.h>
virtual | ~ossimOverviewBuilderFactory () |
virtual destructor More... | |
virtual ossimOverviewBuilderBase * | createBuilder (const ossimString &typeName) const |
Creates a builder from a string. More... | |
virtual void | getTypeNameList (std::vector< ossimString > &typeList) const |
Method to populate a list of supported types for the factory. More... | |
ossimOverviewBuilderFactoryBase () | |
default constructor hidden from use More... | |
virtual | ~ossimOverviewBuilderFactoryBase () |
virtual ossimObject * | createObject (const ossimString &typeName) const |
virtual ossimObject * | createObject (const ossimKeywordlist &kwl, const char *prefix=0) const |
virtual | ~ossimObjectFactory () |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimObject * | dup () const |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual ossimString | getDescription () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=0) |
virtual std::ostream & | print (std::ostream &out) const |
Generic print method. More... | |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
virtual void | accept (ossimVisitor &visitor) |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
static ossimOverviewBuilderFactory * | instance () |
static instance method. More... | |
Private Member Functions | |
ossimOverviewBuilderFactory () | |
ossimOverviewBuilderFactory (const ossimOverviewBuilderFactory &obj) | |
copy constructor hidden from use More... | |
void | operator= (const ossimOverviewBuilderFactory &rhs) |
operator= hidden from use. More... | |
Static Private Attributes | |
static ossimOverviewBuilderFactory * | theInstance = 0 |
virtual | ~ossimReferenced () |
Definition at line 26 of file ossimOverviewBuilderFactory.h.
virtual destructor
Definition at line 27 of file ossimOverviewBuilderFactory.cpp.
References theInstance.
private |
Definition at line 54 of file ossimOverviewBuilderFactory.cpp.
Referenced by instance().
private |
Definition at line 58 of file ossimOverviewBuilderFactory.cpp.
This should match a string from the getTypeNameList() method. Pure virtual.
Implements ossimOverviewBuilderFactoryBase.
Definition at line 32 of file ossimOverviewBuilderFactory.cpp.
References ossimRefPtr< T >::get(), ossimOverviewBuilderBase::hasOverviewType(), ossimRefPtr< T >::release(), and ossimOverviewBuilderBase::setOverviewType().
registered to this registry. Pure virtual.
typeList | List of ossimStrings to add to. |
Definition at line 47 of file ossimOverviewBuilderFactory.cpp.
References ossimOverviewBuilderBase::getTypeNameList().
static |
Definition at line 18 of file ossimOverviewBuilderFactory.cpp.
References ossimOverviewBuilderFactory(), and theInstance.
Referenced by ossimInit::initializeDefaultFactories().
private |
staticprivate |
Definition at line 64 of file ossimOverviewBuilderFactory.h.
Referenced by instance(), and ~ossimOverviewBuilderFactory().
