Public Types | Public Member Functions | Private Member Functions | Private Attributes | List of all members
ossimTiffOverviewBuilder Class Reference
#include <ossimTiffOverviewBuilder.h>
Inheritance diagram for ossimTiffOverviewBuilder:
ossimOverviewBuilderBase ossimSource ossimProcessInterface ossimConnectableObjectListener ossimConnectableObject ossimErrorStatusInterface ossimListener ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced
Public Types
enum  { DEFAULT_COMPRESS_QUALITY =75 }
- Public Types inherited from ossimProcessInterface
enum  ossimProcessStatus {
 ossimTiffOverviewBuilder ()
 default constructor More...
virtual ~ossimTiffOverviewBuilder ()
 virtual destructor More...
void setResampleType (ossimFilterResampler::ossimFilterResamplerType resampleType)
 Supports BOX or NEAREST NEIGHBOR. More...
bool buildOverview (const ossimFilename &overview_file, bool copy_all=false)
 Builds overview file and sets "theOutputFile" to that of the overview_file. More...
virtual bool execute ()
 Calls buildOverview. More...
void setCompressionType (ossim_uint16 compression_type)
 Sets the compression type to use when building overviews. More...
void setJpegCompressionQuality (ossim_int32 quality)
 Sets the compression quality for use when using a compression type of COMPRESSION_JPEG. More...
bool getCopyAllFlag () const
 Method to return copy all flag. More...
void setInternalOverviewsFlag (bool flag)
 Sets internal overviews flag. More...
bool getInternalOverviewsFlag () const
void setCopyAllFlag (bool flag)
 Sets theCopyAllFlag. More...
virtual bool canConnectMyInputTo (ossim_int32 index, const ossimConnectableObject *obj) const
virtual bool setInputSource (ossimImageHandler *imageSource)
 Sets the input to the builder. More...
virtual void setOutputFile (const ossimFilename &file)
 Sets the output filename. More...
virtual ossimFilename getOutputFile () const
 Gets the output file name. More...
void setOutputTileSize (const ossimIpt &tileSize)
virtual bool setOverviewType (const ossimString &type)
 Sets the overview output type. More...
virtual ossimString getOverviewType () const
 Gets the overview type. More...
virtual void getTypeNameList (std::vector< ossimString > &typeList) const
 Method to populate class supported types. More...
 Method to set properties. More...
 Method to populate the list of property names. More...
- Public Member Functions inherited from ossimOverviewBuilderBase
 ossimOverviewBuilderBase ()
virtual bool setOutputWriter (ossimImageFileWriter *outputWriter)
 Sets an optional file writer to the builder. More...
virtual bool hasOverviewType (const ossimString &type) const
 Method to check if builder can handle type. More...
virtual ossim_uint32 getOverviewStopDimension () const
 Get the overview stop dimension. More...
virtual void setOverviewStopDimension (ossim_uint32 dim)
 Sets the overview stop dimension. More...
ossimHistogramMode getHistogramMode () const
 Gets the histogram accumulation mode. More...
void setHistogramMode (ossimHistogramMode mode)
 Sets the histogram accumulation mode. More...
virtual void finalize ()
 Finalize method. More...
void setBitMaskSpec (const ossimKeywordlist &bit_mask_spec)
 Specifies parameters (in KWL) for generation of an alpha (bit) mask such that any full or partial null pixels will be masked out. More...
void setScanForMinMax (bool flag)
 Turn on/off scan for min max flag. More...
bool getScanForMinMax () const
void setScanForMinMaxNull (bool flag)
 Turn on/off scan for min, max, null flag. More...
bool getScanForMinMaxNull () const
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
virtual void initialize ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
- Public Member Functions inherited from ossimProcessInterface
 ossimProcessInterface ()
virtual void abort ()
bool needsAborting () const
bool isAborted () const
bool isExecuting () const
void enableEvents ()
void disableEvents ()
 ProcessEvent. More...
virtual void disconnectInputEvent (ossimConnectionEvent &)
virtual void connectInputEvent (ossimConnectionEvent &)
virtual void propertyEvent (ossimPropertyEvent &)
virtual void refreshEvent (ossimRefreshEvent &)
 ossimListener ()
virtual ~ossimListener ()
void enableListener ()
void disableListener ()
bool writeR0 (TIFF *tif)
 Copy the full resolution image data to the output tif image. More...
bool writeRn (ossimImageHandler *imageHandler, TIFF *tif, ossim_uint32 resLevel, bool firstResLevel)
 Write reduced resolution data set to the tif file. More...
bool setTags (TIFF *tif, const ossimIrect &outputRect, ossim_int32 resLevel) const
 Set the tiff tags for the appropriate resLevel. More...
bool setGeotiffTags (const ossimImageGeometry *geom, const ossimDrect &boundingRect, ossim_uint32 resLevel, TIFF *tif)
 Writes geotiff tags. More...
TIFFopenTiff (const ossimString &filename) const
void closeTiff (TIFF *tif)
bool buildInternalOverviews () const
bool copyR0 () const
 ossimTiffOverviewBuilder (const ossimTiffOverviewBuilder &source)
ossimTiffOverviewBuilderoperator= (const ossimTiffOverviewBuilder &rhs)
Private Attributes
std::vector< ossim_uint8m_nullDataBuffer
ossim_int32 m_bytesPerPixel
ossim_int32 m_bitsPerSample
ossim_int32 m_tileWidth
ossim_int32 m_tileHeight
ossim_int32 m_tileSizeInBytes
ossim_int32 m_sampleFormat
ossim_int32 m_currentTiffDir
ossim_uint16 m_tiffCompressType
ossim_int32 m_jpegCompressQuality
ossimFilterResampler::ossimFilterResamplerType m_resampleType
std::vector< double > m_nullPixelValues
bool m_copyAllFlag
ossimString m_tempExtension
bool m_outputTileSizeSetFlag
bool m_internalOverviewsFlag
Additional Inherited Members
- Protected Member Functions inherited from ossimOverviewBuilderBase
virtual ~ossimOverviewBuilderBase ()
ossim_uint32 getRequiredResLevels (const ossimImageHandler *ih) const
 Gets the required number of res levels. More...
void initializePreferenceSettings ()
 Initializes preference settings. More...
void initializeScanOptions ()
 Checks scalar type and turns on scanning for min, max, nulls if needed. More...
virtual ~ossimReferenced ()
- Protected Attributes inherited from ossimOverviewBuilderBase
ossim_uint32 m_overviewStopDimension
ossimHistogramMode m_histoMode
ossimKeywordlist m_bitMaskSpec
ossimRefPtr< ossimImageHandlerm_imageHandler
std::vector< ossim_uint32m_originalBandList
ossimRefPtr< ossimBitMaskWriterm_maskWriter
ossimRefPtr< ossimMaskFilterm_maskFilter
ossimFilename m_outputFile
bool m_scanForMinMax
bool m_scanForMinMaxNull
bool m_scanFloatData
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
- Protected Attributes inherited from ossimProcessInterface
double thePercentComplete
ossimString theMessage
bool theEventFlag
bool theListenerEnableFlag
Detailed Description
Definition at line 33 of file ossimTiffOverviewBuilder.h.
◆ anonymous enum
anonymous enum
Enumerator
Definition at line 39 of file ossimTiffOverviewBuilder.h.
◆ ossimTiffOverviewBuilder() [1/2]
ossimTiffOverviewBuilder::ossimTiffOverviewBuilder ( )
default constructor
◆ ~ossimTiffOverviewBuilder()
virtual ossimTiffOverviewBuilder::~ossimTiffOverviewBuilder ( )
virtual
virtual destructor
◆ ossimTiffOverviewBuilder() [2/2]
ossimTiffOverviewBuilder::ossimTiffOverviewBuilder ( const ossimTiffOverviewBuilder source)
private
Member Function Documentation
◆ buildInternalOverviews()
bool ossimTiffOverviewBuilder::buildInternalOverviews ( ) const
private
Returns
true if m_internalOverviewsFlag and input image supports building internal overviews. Currently only tiff reader.
◆ buildOverview()
bool ossimTiffOverviewBuilder::buildOverview ( const ossimFilename overview_file,
bool  copy_all = false
Parameters
overview_fileThe overview file name to output.
copy_allIf set to true the entire image will be copied. This can be used to convert an image to a tiled tif.
Returns
trueon success, false on error.
Referenced by ossimImageHandler::buildOverview().
◆ canConnectMyInputTo()
virtual bool ossimTiffOverviewBuilder::canConnectMyInputTo ( ossim_int32  index,
const ossimConnectableObject obj
) const
virtual
Returns
true if input is an image handler.
Implements ossimConnectableObject.
◆ closeTiff()
void ossimTiffOverviewBuilder::closeTiff ( TIFF tif)
private
◆ copyR0()
bool ossimTiffOverviewBuilder::copyR0 ( ) const
private
Returns
true if m_copyAllFlag is set and build internal overviews is not set.
◆ execute()
virtual bool ossimTiffOverviewBuilder::execute ( )
virtual
This method uses "theOutputFile" for the file name.
If the copy_all flag is set the entire image will be copied. This can be used to convert an image to a tiled tif.
Returns
Note
If setOutputFile was not called the output name will be derived from the image name. If image was "foo.tif" the overview file will be "foo.ovr".
Implements ossimOverviewBuilderBase.
Referenced by ossimImageFileWriter::writeOverviewFile().
◆ getCopyAllFlag()
bool ossimTiffOverviewBuilder::getCopyAllFlag ( ) const
Returns
The copy all flag. If true all data will be written to the overview including R0.
◆ getInternalOverviewsFlag()
bool ossimTiffOverviewBuilder::getInternalOverviewsFlag ( ) const
Returns
The intenal overview flag.
◆ getObject() [1/2]
virtual ossimObject* ossimTiffOverviewBuilder::getObject ( )
virtual
Returns
ossimObject* to this object.
Implements ossimProcessInterface.
◆ getObject() [2/2]
virtual const ossimObject* ossimTiffOverviewBuilder::getObject ( ) const
virtual
Returns
const ossimObject* to this object.
◆ getOutputFile()
virtual ossimFilename ossimTiffOverviewBuilder::getOutputFile ( ) const
virtual
(pure virtual)
Returns
The output file name or ossimFilename::NIL if it was not set yet and the image handle has not been initialized.
Note
This is non-const as a call to this may force initialization of overview builder output file name if the it was not set already.
This will return ossimFilename::NIL unless one of was called, setInputSource or setOutputFile.
◆ getOverviewType()
virtual ossimString ossimTiffOverviewBuilder::getOverviewType ( ) const
virtual
Satisfies pure virtual from ossimOverviewBuilderBase.
Returns
The overview output type as a string.
◆ getPropertyNames()
virtual void ossimTiffOverviewBuilder::getPropertyNames ( std::vector< ossimString > &  propertyNames) const
virtual
Parameters
propertyNamesList to populate. This does not clear the list just adds to it.
◆ getTypeNameList()
virtual void ossimTiffOverviewBuilder::getTypeNameList ( std::vector< ossimString > &  typeList) const
virtual
Parameters
typeListList of ossimStrings to add to.
◆ openTiff()
TIFF* ossimTiffOverviewBuilder::openTiff ( const ossimString filename) const
private
◆ operator=()
ossimTiffOverviewBuilder& ossimTiffOverviewBuilder::operator= ( const ossimTiffOverviewBuilder rhs)
private
◆ setCompressionType()
void ossimTiffOverviewBuilder::setCompressionType ( ossim_uint16  compression_type)
Parameters
compression_typeCurrent supported types:
  • COMPRESSION_JPEG
  • COMPRESSION_LZW
  • COMPRESSION_DEFLATE
  • COMPRESSION_PACKBITS
  • COMPRESSION_NONE (default)
Referenced by ossimImageHandler::buildOverview(), and ossimImageFileWriter::writeOverviewFile().
◆ setCopyAllFlag()
void ossimTiffOverviewBuilder::setCopyAllFlag ( bool  flag)
Parameters
flagThe flag. If true all data will be written to the overview including R0.
◆ setGeotiffTags()
bool ossimTiffOverviewBuilder::setGeotiffTags ( const ossimImageGeometry geom,
const ossimDrect boundingRect,
TIFF tif
private
Parameters
geom
boundingRect
resLevelZero base, 0 being full res.
tif
Returns
◆ setInputSource()
virtual bool ossimTiffOverviewBuilder::setInputSource ( ossimImageHandler imageSource)
virtual
Parameters
imageSourceThe input to the builder.
Returns
True on successful initializion, false on error.
Reimplemented from ossimOverviewBuilderBase.
◆ setInternalOverviewsFlag()
void ossimTiffOverviewBuilder::setInternalOverviewsFlag ( bool  flag)
Parameters
flagIf true, and input source is tiff format, overviews will be built internally.
◆ setJpegCompressionQuality()
void ossimTiffOverviewBuilder::setJpegCompressionQuality ( ossim_int32  quality)
Parameters
qualityRange 1 to 100 with 100 being best quality.
◆ setOutputFile()
virtual void ossimTiffOverviewBuilder::setOutputFile ( const ossimFilename file)
virtual
Parameters
fileThe output file name.
◆ setOutputTileSize()
void ossimTiffOverviewBuilder::setOutputTileSize ( const ossimIpt tileSize)
◆ setOverviewType()
virtual bool ossimTiffOverviewBuilder::setOverviewType ( const ossimString type)
virtual
Currently handled types are: "ossim_tiff_nearest" and "ossim_tiff_box"
Parameters
typeThis should be the string representing the type. This method will do nothing if type is not handled and return false.
Returns
true if type is handled, false if not.
◆ setProperty()
virtual void ossimTiffOverviewBuilder::setProperty ( ossimRefPtr< ossimProperty property)
virtual
Parameters
propertyProperty to set.
Note
Currently supported property: name=levels, value should be list of levels separated by a comma with no spaces. Example: "2,4,8,16,32,64"
◆ setResampleType()
void ossimTiffOverviewBuilder::setResampleType ( ossimFilterResampler::ossimFilterResamplerType  resampleType)
When indexed you should probably use nearest neighbor
◆ setTags()
bool ossimTiffOverviewBuilder::setTags ( TIFF tif,
const ossimIrect outputRect,
) const
private
Level zero is the full resolution image.
Parameters
tifPointer to the tif file.
outputRectThe dimensions (zero based) of res set.
rrds_levelThe current reduced res level.
◆ writeR0()
bool ossimTiffOverviewBuilder::writeR0 ( TIFF tif)
private
◆ writeRn()
bool ossimTiffOverviewBuilder::writeRn ( ossimImageHandler imageHandler,
TIFF tif,
bool  firstResLevel
private
Parameters
firstRestLevelused to tell method that if a histogram is needed, do it on that res level.
Member Data Documentation
◆ m_bitsPerSample
ossim_int32 ossimTiffOverviewBuilder::m_bitsPerSample
private
Definition at line 286 of file ossimTiffOverviewBuilder.h.
◆ m_bytesPerPixel
ossim_int32 ossimTiffOverviewBuilder::m_bytesPerPixel
private
Definition at line 285 of file ossimTiffOverviewBuilder.h.
◆ m_copyAllFlag
bool ossimTiffOverviewBuilder::m_copyAllFlag
private
Definition at line 296 of file ossimTiffOverviewBuilder.h.
◆ m_currentTiffDir
ossim_int32 ossimTiffOverviewBuilder::m_currentTiffDir
private
Definition at line 291 of file ossimTiffOverviewBuilder.h.
◆ m_internalOverviewsFlag
bool ossimTiffOverviewBuilder::m_internalOverviewsFlag
private
Definition at line 299 of file ossimTiffOverviewBuilder.h.
◆ m_jpegCompressQuality
ossim_int32 ossimTiffOverviewBuilder::m_jpegCompressQuality
private
Definition at line 293 of file ossimTiffOverviewBuilder.h.
◆ m_nullDataBuffer
std::vector<ossim_uint8> ossimTiffOverviewBuilder::m_nullDataBuffer
private
Definition at line 284 of file ossimTiffOverviewBuilder.h.
◆ m_nullPixelValues
std::vector<double> ossimTiffOverviewBuilder::m_nullPixelValues
private
Definition at line 295 of file ossimTiffOverviewBuilder.h.
◆ m_outputTileSizeSetFlag
bool ossimTiffOverviewBuilder::m_outputTileSizeSetFlag
private
Definition at line 298 of file ossimTiffOverviewBuilder.h.
◆ m_resampleType
ossimFilterResampler::ossimFilterResamplerType ossimTiffOverviewBuilder::m_resampleType
private
Definition at line 294 of file ossimTiffOverviewBuilder.h.
◆ m_sampleFormat
ossim_int32 ossimTiffOverviewBuilder::m_sampleFormat
private
Definition at line 290 of file ossimTiffOverviewBuilder.h.
◆ m_tempExtension
ossimString ossimTiffOverviewBuilder::m_tempExtension
private
Definition at line 297 of file ossimTiffOverviewBuilder.h.
◆ m_tiffCompressType
ossim_uint16 ossimTiffOverviewBuilder::m_tiffCompressType
private
Definition at line 292 of file ossimTiffOverviewBuilder.h.
◆ m_tileHeight
ossim_int32 ossimTiffOverviewBuilder::m_tileHeight
private
Definition at line 288 of file ossimTiffOverviewBuilder.h.
◆ m_tileSizeInBytes
ossim_int32 ossimTiffOverviewBuilder::m_tileSizeInBytes
private
Definition at line 289 of file ossimTiffOverviewBuilder.h.
◆ m_tileWidth
ossim_int32 ossimTiffOverviewBuilder::m_tileWidth
private
Definition at line 287 of file ossimTiffOverviewBuilder.h.
The documentation for this class was generated from the following file:
