class ossimRectanglePartitioner Utility class to partition up a rectangle. More...
#include <ossimRectanglePartitioner.h>
ossimRectanglePartitioner () | |
default construtor More... | |
~ossimRectanglePartitioner () | |
destructor More... | |
void | binaryPartition (const ossimIrect &inputRectangle, std::vector< ossimIrect > &result, ossim_uint64 maxSizeInBytes, ossim_uint32 bands, ossim_uint32 bytesPerPixel, ossim_uint32 internalOverlapPixels=0) const |
Partitions the rectangle doing a binary split on the longest dimension until the total size is less than or equal to the "maxSizeInBytes". More... | |
Private Member Functions | |
void | splitUntilLessThanMax (ossimIrect &rect, ossim_uint64 maxSizeInBytes, ossim_uint32 bands, ossim_uint32 bytesPerPixel, ossim_uint32 internalOverlapPixels=0) const |
Recursively splits the input rectangle until the size is less than or equal to maxSizeInBytes. More... | |
void | splitRect (ossimIrect &rect) const |
Splits rectangle in half rounding up if needed. More... | |
ossim_uint64 | getSize (const ossimIrect &rect, ossim_uint32 bands, ossim_uint32 bytesPerPixel, ossim_uint32 internalOverlapPixels=0) const |
void | trace (const ossimIrect &r, const std::vector< ossimIrect > &v, ossim_uint64 maxSizeInBytes, ossim_uint32 bands, ossim_uint32 bytesPerPixel) const |
Convenience trace method. More... | |
Definition at line 27 of file ossimRectanglePartitioner.h.
ossimRectanglePartitioner::ossimRectanglePartitioner | ( | ) |
ossimRectanglePartitioner::~ossimRectanglePartitioner | ( | ) |
void ossimRectanglePartitioner::binaryPartition | ( | const ossimIrect & | inputRectangle, |
std::vector< ossimIrect > & | result, | ||
ossim_uint64 | maxSizeInBytes, | ||
ossim_uint32 | bands, | ||
ossim_uint32 | bytesPerPixel, | ||
ossim_uint32 | internalOverlapPixels = 0 |
) | const |
Initializes "result" with the resulting rectangles starting at the upper left corner.
inputRectangle | The source rectangle usually the bounding rectangle of a scene. |
result | The vector of ossimIrects to hold the result. |
maxSizeInBytes | Maximum size of the resulting rectangle partitions in bytes. |
bands | The number of bands in the image. |
bytesPerPixel. | The number of bytes per pixel for a single band. |
internalOverlapPixels | Overlap in pixels for desired partitions. (default = 0) This is added to all four sides of the rectangle so |
Definition at line 32 of file ossimRectanglePartitioner.cpp.
References ossimIrect::hasNans(), ossimNotify(), and ossimNotifyLevel_WARN.
private |
rect | Rectangle to give size for in bytes. |
internalOverlapPixels | Overlap in pixels. (default = 0) |
Definition at line 210 of file ossimRectanglePartitioner.cpp.
References ossimIrect::height(), and ossimIrect::width().
private |
input | Rectangle to split. |
Will split the longest dimension. If square will split in the lengthwise direction.
Definition at line 189 of file ossimRectanglePartitioner.cpp.
private |
rect | Input rectangle to split. |
internalOverlapPixels | Overlap in pixels for desired partitions. (default = 0) |
Definition at line 172 of file ossimRectanglePartitioner.cpp.
private |
r | Input rectangle. |
v | Vector of resulting partitioned rectangles. |
Definition at line 221 of file ossimRectanglePartitioner.cpp.
References ossimNotify(), ossimNotifyLevel_DEBUG, and ossimIrect::size().
