Public Member Functions | Protected Member Functions | List of all members
ossimRgbGridRemapEngine Class Reference
#include <ossimRgbGridRemapEngine.h>
Inheritance diagram for ossimRgbGridRemapEngine:
ossimGridRemapEngine ossimObject ossimReferenced
 ossimRgbGridRemapEngine ()
virtual void remapTile (const ossimDpt &origin_point, ossimGridRemapSource *remapper, ossimRefPtr< ossimImageData > &tile)
virtual void assignRemapValues (std::vector< ossimAtbPointSource *> &sources)
virtual void computeSourceValue (ossimRefPtr< ossimImageData > &source, void *result)
- Public Member Functions inherited from ossimGridRemapEngine
int getNumberOfParams () const
int getNumberOfBands () const
 ossimObject ()
virtual ~ossimObject ()
 Generic print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
virtual void computeRemapNode (ossimAtbPointSource *point_source, void *source_value, void *target_value)
- Protected Member Functions inherited from ossimGridRemapEngine
 ossimGridRemapEngine (int numParams, int numBands)
 ossimGridRemapEngine ()
virtual ~ossimGridRemapEngine ()
virtual ~ossimReferenced ()
Additional Inherited Members
- Protected Attributes inherited from ossimGridRemapEngine
int theNumberOfParams
int theNumberOfBands
Detailed Description
CLASS: ossimRgbGridRemapEngine
Definition at line 29 of file ossimRgbGridRemapEngine.h.
◆ ossimRgbGridRemapEngine()
ossimRgbGridRemapEngine::ossimRgbGridRemapEngine ( )
inline
Definition at line 32 of file ossimRgbGridRemapEngine.h.
Referenced by dup().
Member Function Documentation
◆ assignRemapValues()
void ossimRgbGridRemapEngine::assignRemapValues ( std::vector< ossimAtbPointSource *> &  sources)
virtual
Implements ossimGridRemapEngine.
Definition at line 157 of file ossimRgbGridRemapEngine.cpp.
159 {
160  static const char MODULE[] = "ossimRgbGridRemapEngine::assignRemapValues";
161  if (traceExec()) CLOG << "entering..." << endl;
162
163  int i; // index to individual sources
164
165  //***
166  // Declare a 2D array that will contain all of the contributing sources'
167  // RGB mean values. Also declare the accumulator target vector.
168  //***
169  int num_contributors = (int)sources_list.size();
170  double** contributor_pixel = new double* [num_contributors];
171  for (i=0; i<num_contributors; i++)
172  contributor_pixel[i] = new double[3];
173  double target_pixel[3] = {0.0, 0.0, 0.0};
174
175  //***
176  // Now loop over each remaining contributor and sum in its contribution:
177  //***
178  vector<ossimAtbPointSource*>::iterator source;
179  i = 0;
180  for(source=sources_list.begin();
181  source!=sources_list.end();
182  source++)
183  {
184  (*source)->getSourceValue(contributor_pixel[i]);
185
186  target_pixel[0] += contributor_pixel[i][0]/(double)num_contributors;
187  target_pixel[1] += contributor_pixel[i][1]/(double)num_contributors;
188  target_pixel[2] += contributor_pixel[i][2]/(double)num_contributors;
189
190  i++;
191  }
192
193  //***
194  // The target pixel has been established. Now need to compute the actual
195  // remap quantities that will be written to the appropriate remap grids:
196  //***
197  i = 0;
198  for(source=sources_list.begin();
199  source!=sources_list.end();
200  source++)
201  {
202  computeRemapNode(*source, contributor_pixel[i], target_pixel);
203  i++;
204  }
205
206  //***
207  // Delete locally allocated memory:
208  //***
209  for (i=0; i<num_contributors; i++)
210  delete [] contributor_pixel[i];
211  delete [] contributor_pixel;
212
213  if (traceExec()) CLOG << "returning..." << endl;
214  return;
215 }
#define CLOG
Definition: ossimTrace.h:23
virtual void computeRemapNode(ossimAtbPointSource *point_source, void *source_value, void *target_value)
◆ computeRemapNode()
void ossimRgbGridRemapEngine::computeRemapNode ( ossimAtbPointSource point_source,
void *  source_value,
void *  target_value
protectedvirtual
Definition at line 246 of file ossimRgbGridRemapEngine.cpp.
249 {
250  static const char MODULE[] = "ossimRgbGridRemapEngine::computeRemapNode";
251  if (traceExec()) CLOG << "entering..." << endl;
252
253  //***
254  // Compute the remap grid node value specific to this RGB implementation:
255  //***
256  double node[3];
257  node[0] = ((double*)target_value)[0] - ((double*)source_value)[0];
258  node[1] = ((double*)target_value)[1] - ((double*)source_value)[1];
259  node[2] = ((double*)target_value)[2] - ((double*)source_value)[2];
260
261  //***
262  // Fetch a pointer to the remapper feeding this point source in order to
263  // pass it the node value:
264  //***
265  ossimGridRemapSource* remapper = ps->getRemapSource();
266  remapper->setGridNode(ps->getViewPoint(), node);
267
268  if (traceExec()) CLOG << "returning..." << endl;
269  return;
270 }
#define CLOG
void setGridNode(const ossimDpt &view_pt, const double *value)
◆ computeSourceValue()
void ossimRgbGridRemapEngine::computeSourceValue ( ossimRefPtr< ossimImageData > &  source,
void *  result
virtual
Definition at line 221 of file ossimRgbGridRemapEngine.cpp.
223 {
224  static const char MODULE[]="ossimRgbGridRemapEngine::computeSourceValue";
225  if (traceExec()) CLOG << "entering..." << endl;
226
227  //***
228  // This engine defines "value" as the RGB vector corresponding to the mean
229  // RGB pixel value of the source data:
230  //***
231  ((double*)result)[0] = source->computeAverageBandValue(0);
232  ((double*)result)[1] = source->computeAverageBandValue(1);
233  ((double*)result)[2] = source->computeAverageBandValue(2);
234
235  if (traceExec()) CLOG << "returning..." << endl;
236  return;
237 }
#define CLOG
virtual ossim_float64 computeAverageBandValue(ossim_uint32 bandNumber=0) const
This will compute the average value for the band.
◆ dup()
ossimObject * ossimRgbGridRemapEngine::dup ( ) const
virtual
Definition at line 41 of file ossimRgbGridRemapEngine.cpp.
References ossimRgbGridRemapEngine().
42 {
43  return new ossimRgbGridRemapEngine;
44 }
◆ remapTile()
void ossimRgbGridRemapEngine::remapTile ( const ossimDpt origin_point,
ossimGridRemapSource remapper,
ossimRefPtr< ossimImageData > &  tile
virtual
Definition at line 50 of file ossimRgbGridRemapEngine.cpp.
53 {
54  static const char MODULE[] = "ossimRgbGridRemapEngine::remapTile";
55  if (traceExec()) CLOG << "entering..." << endl;
56
57  //***
58  // Fetch tile size and NULL pixel value:
59  //***
60  int width = tile->getWidth();
61  int height = tile->getHeight();
62  int offset = 0;
63  double null[3];
64
65  //***
66  // Determine null pixel values so that we can recognize a null coming in and
67  // not remap it:
68  //***
69  null[0] = tile->getNullPix(0);
70  null[1] = tile->getNullPix(1);
71  null[2] = tile->getNullPix(2);
72
73  ossimDblGrid& gridR = *(remapper->getGrid(0));
74  ossimDblGrid& gridG = *(remapper->getGrid(1));
75  ossimDblGrid& gridB = *(remapper->getGrid(2));
76
77  //***
78  // Remap according to pixel type:
79  //***
80  switch(tile->getScalarType())
81  {
82  case OSSIM_UCHAR:
83  {
84  ossim_uint8* red_buf = (ossim_uint8*)tile->getBuf(0);
85  ossim_uint8* grn_buf = (ossim_uint8*)tile->getBuf(1);
86  ossim_uint8* blu_buf = (ossim_uint8*)tile->getBuf(2);
87  short pixel_buffer[3];
88
89  for (double line=origin.line; line<origin.line+height; line+=1.0)
90  {
91  for (double samp=origin.samp; samp<origin.samp+width; samp+=1.0)
92  {
93  //***
94  // Scan for null pixel before adding remap delta:
95  //***
96  if ((red_buf[offset] != (ossim_uint8) null[0]) &&
97  (grn_buf[offset] != (ossim_uint8) null[1]) &&
98  (blu_buf[offset] != (ossim_uint8) null[2]))
99  {
100  //***
101  // Remap RGB pixel with spatially variant bias value:
102  //***
103  pixel_buffer[0] = red_buf[offset] + (short) gridR(samp,line);
104  pixel_buffer[1] = grn_buf[offset] + (short) gridG(samp,line);
105  pixel_buffer[2] = blu_buf[offset] + (short) gridB(samp,line);
106
107  //***
108  // Clamp:
109  //***
110  if (pixel_buffer[0]<0) red_buf[offset] = 0;
111  else if (pixel_buffer[0]>255) red_buf[offset] = 255;
112  else red_buf[offset] = pixel_buffer[0];
113
114
115  if (pixel_buffer[1]<0) grn_buf[offset] = 0;
116  else if (pixel_buffer[1]>255) grn_buf[offset] = 255;
117  else grn_buf[offset] = pixel_buffer[1];
118
119
120  if (pixel_buffer[2]<0) blu_buf[offset] = 0;
121  else if (pixel_buffer[2]>255) blu_buf[offset] = 255;
122  else blu_buf[offset] = pixel_buffer[2];
123
124  //***
125  // Avoid NULLS:
126  //***
127  if (red_buf[offset] == (ossim_uint8) null[0]) red_buf[offset]++;
128  if (grn_buf[offset] == (ossim_uint8) null[1]) grn_buf[offset]++;
129  if (blu_buf[offset] == (ossim_uint8) null[2]) blu_buf[offset]++;
130  }
131
132  offset++;
133  }
134  }
135  break;
136  }
137
138  default:
139  {
140  ossimNotify(ossimNotifyLevel_WARN) << "WARNING ossimRgbGridRemapEngine::remapTile: Scalar type not handled" << std::endl;
141  break;
142  }
143
144  } // end switch statement
145
146  if (traceExec()) CLOG << "returning..." << endl;
147  return;
148 };
#define CLOG
virtual const ossim_float64 * getNullPix() const
ossimDblGrid * getGrid(unsigned int index)
unsigned char ossim_uint8
8 bit unsigned iteger
