Public Member Functions | Private Attributes | Friends | List of all members
ossimRpfFrameFileIndexRecord Class Reference
#include <ossimRpfFrameFileIndexRecord.h>
 ossimRpfFrameFileIndexRecord ()
 default constructor More...
 ossimRpfFrameFileIndexRecord (const ossimRpfFrameFileIndexRecord &obj)
 copy constructor More...
const ossimRpfFrameFileIndexRecordoperator= (const ossimRpfFrameFileIndexRecord &rhs)
 assignment operator More...
ossimErrorCode parseStream (std::istream &in, ossimByteOrder byteOrder)
void writeStream (std::ostream &out)
 Write method. More...
void clearFields ()
std::ostream & print (std::ostream &out) const
ossim_uint16 getBoundaryRecNumber () const
ossim_uint16 getLocationRowNumber () const
ossim_uint16 getLocationColNumber () const
ossim_uint32 getPathnameRecordOffset () const
ossimFilename getFilename () const
void setBoundaryRecNumber (ossim_uint16 entry)
 Sets the zero based entry number. More...
void setPathnameRecordOffset (ossim_uint32 offset)
Private Attributes
ossim_uint16 m_boundaryRectRecordNumber
ossim_uint16 m_locationRowNumber
ossim_uint16 m_locationColumnNumber
ossim_uint32 m_pathnameRecordOffset
char m_filename [13]
char m_geographicLocation [7]
char m_securityClassification
char m_fileSecurityCountryCode [3]
char m_fileSecurityReleaseMarking [3]
Friends
std::ostream & operator<< (std::ostream &out, const ossimRpfFrameFileIndexRecord &data)
Detailed Description
Definition at line 19 of file ossimRpfFrameFileIndexRecord.h.
◆ ossimRpfFrameFileIndexRecord() [1/2]
ossimRpfFrameFileIndexRecord::ossimRpfFrameFileIndexRecord ( )
◆ ossimRpfFrameFileIndexRecord() [2/2]
ossimRpfFrameFileIndexRecord::ossimRpfFrameFileIndexRecord ( const ossimRpfFrameFileIndexRecord obj)
copy constructor
Definition at line 35 of file ossimRpfFrameFileIndexRecord.cpp.
References m_filename, m_fileSecurityCountryCode, m_fileSecurityReleaseMarking, and m_geographicLocation.
36  :
42 {
43  memcpy(m_filename, obj.m_filename, 13);
47 }
Member Function Documentation
◆ clearFields()
void ossimRpfFrameFileIndexRecord::clearFields ( )
Definition at line 186 of file ossimRpfFrameFileIndexRecord.cpp.
References m_boundaryRectRecordNumber, m_filename, m_fileSecurityCountryCode, m_fileSecurityReleaseMarking, m_geographicLocation, m_locationColumnNumber, m_locationRowNumber, m_pathnameRecordOffset, and m_securityClassification.
Referenced by ossimRpfFrameFileIndexRecord(), and parseStream().
187 {
192  memset(m_filename, ' ', 12);
193  memset(m_geographicLocation, ' ', 6);
195  memset(m_fileSecurityCountryCode, ' ', 2);
196  memset(m_fileSecurityReleaseMarking, ' ', 2);
197
198  m_filename[12] = '\0';
199  m_geographicLocation[6] = '\0';
200  m_fileSecurityCountryCode[2] = '\0';
202 }
◆ getBoundaryRecNumber()
ossim_uint16 ossimRpfFrameFileIndexRecord::getBoundaryRecNumber ( ) const
◆ getFilename()
ossimFilename ossimRpfFrameFileIndexRecord::getFilename ( ) const
Definition at line 171 of file ossimRpfFrameFileIndexRecord.cpp.
References m_filename.
◆ getLocationColNumber()
ossim_uint16 ossimRpfFrameFileIndexRecord::getLocationColNumber ( ) const
Definition at line 161 of file ossimRpfFrameFileIndexRecord.cpp.
References m_locationColumnNumber.
162 {
163  return m_locationColumnNumber;
164 }
◆ getLocationRowNumber()
ossim_uint16 ossimRpfFrameFileIndexRecord::getLocationRowNumber ( ) const
Definition at line 156 of file ossimRpfFrameFileIndexRecord.cpp.
References m_locationRowNumber.
157 {
158  return m_locationRowNumber;
159 }
◆ getPathnameRecordOffset()
ossim_uint32 ossimRpfFrameFileIndexRecord::getPathnameRecordOffset ( ) const
Definition at line 166 of file ossimRpfFrameFileIndexRecord.cpp.
References m_pathnameRecordOffset.
167 {
168  return m_pathnameRecordOffset;
169 }
◆ operator=()
const ossimRpfFrameFileIndexRecord & ossimRpfFrameFileIndexRecord::operator= ( const ossimRpfFrameFileIndexRecord rhs)
assignment operator
Definition at line 49 of file ossimRpfFrameFileIndexRecord.cpp.
51 {
52  if ( this != &rhs )
53  {
59
60  memcpy(m_filename, rhs.m_filename, 13);
64  }
65  return *this;
66 }
◆ parseStream()
ossimErrorCode ossimRpfFrameFileIndexRecord::parseStream ( std::istream &  in,
Definition at line 68 of file ossimRpfFrameFileIndexRecord.cpp.
References ossim::byteOrder(), clearFields(), ossimEndian::getSystemEndianType(), m_boundaryRectRecordNumber, m_filename, m_fileSecurityCountryCode, m_fileSecurityReleaseMarking, m_geographicLocation, m_locationColumnNumber, m_locationRowNumber, m_pathnameRecordOffset, m_securityClassification, ossimErrorCodes::OSSIM_ERROR, ossimErrorCodes::OSSIM_OK, and ossimEndian::swap().
70 {
71  if(in)
72  {
73  ossimEndian anEndian;
74
75  clearFields();
76
77  in.read((char*)&m_boundaryRectRecordNumber, 2);
78  in.read((char*)&m_locationRowNumber, 2);
79  in.read((char*)&m_locationColumnNumber, 2);
80  in.read((char*)&m_pathnameRecordOffset, 4);
81  in.read((char*)m_filename, 12);
82  in.read((char*)m_geographicLocation, 6);
83  in.read((char*)&m_securityClassification, 1);
84  in.read((char*)m_fileSecurityCountryCode, 2);
85  in.read((char*)m_fileSecurityReleaseMarking, 2);
86
87  if(anEndian.getSystemEndianType() != byteOrder)
88  {
90  anEndian.swap(m_locationRowNumber);
91  anEndian.swap(m_locationColumnNumber);
92  anEndian.swap(m_pathnameRecordOffset);
93  }
94  }
95  else
96  {
98  }
99
101 }
static const ossimErrorCode OSSIM_OK
OSSIM_DLL ossimByteOrder byteOrder()
Definition: ossimCommon.cpp:54
static const ossimErrorCode OSSIM_ERROR
ossimByteOrder getSystemEndianType() const
Definition: ossimEndian.h:78
void swap(ossim_sint8 &)
Definition: ossimEndian.h:26
◆ print()
std::ostream & ossimRpfFrameFileIndexRecord::print ( std::ostream &  out) const
Definition at line 136 of file ossimRpfFrameFileIndexRecord.cpp.
Referenced by operator<<().
137 {
138  out << "BoundaryRectRecordNumber: " << m_boundaryRectRecordNumber
139  << "\nLocationRowNumber: " << m_locationRowNumber
140  << "\nLocationColumnNumber: " << m_locationColumnNumber
141  << "\nPathnameRecordOffset: " << m_pathnameRecordOffset
142  << "\nFilename: " << m_filename
143  << "\nGeographicLocation: " << m_geographicLocation
144  << "\nSecurityClassification: " << m_securityClassification
145  << "\nFileSecurityCountryCode: " << m_fileSecurityCountryCode
146  << "\nFileSecurityReleaseMarking: " << m_fileSecurityReleaseMarking
147  << std::endl;
148  return out;
149 }
◆ setBoundaryRecNumber()
void ossimRpfFrameFileIndexRecord::setBoundaryRecNumber ( ossim_uint16  entry)
Definition at line 176 of file ossimRpfFrameFileIndexRecord.cpp.
References m_boundaryRectRecordNumber.
177 {
179 }
◆ setPathnameRecordOffset()
void ossimRpfFrameFileIndexRecord::setPathnameRecordOffset ( ossim_uint32  offset)
Definition at line 181 of file ossimRpfFrameFileIndexRecord.cpp.
182 {
183  m_pathnameRecordOffset = offset;
184 }
◆ writeStream()
void ossimRpfFrameFileIndexRecord::writeStream ( std::ostream &  out)
Write method.
Parameters
outStream to write to.
Definition at line 103 of file ossimRpfFrameFileIndexRecord.cpp.
References ossimEndian::getSystemEndianType(), m_boundaryRectRecordNumber, m_filename, m_fileSecurityCountryCode, m_fileSecurityReleaseMarking, m_geographicLocation, m_locationColumnNumber, m_locationRowNumber, m_pathnameRecordOffset, m_securityClassification, OSSIM_BIG_ENDIAN, and ossimEndian::swap().
104 {
105  ossimEndian anEndian;
106
107  if( anEndian.getSystemEndianType() != OSSIM_BIG_ENDIAN )
108  {
109  // Always write out big endian.
111  anEndian.swap(m_locationRowNumber);
112  anEndian.swap(m_locationColumnNumber);
113  anEndian.swap(m_pathnameRecordOffset);
114  }
115
116  out.write((char*)&m_boundaryRectRecordNumber, 2);
117  out.write((char*)&m_locationRowNumber, 2);
118  out.write((char*)&m_locationColumnNumber, 2);
119  out.write((char*)&m_pathnameRecordOffset, 4);
120  out.write((char*)m_filename, 12);
121  out.write((char*)m_geographicLocation, 6);
122  out.write((char*)&m_securityClassification, 1);
123  out.write((char*)m_fileSecurityCountryCode, 2);
124  out.write((char*)m_fileSecurityReleaseMarking, 2);
125
126  if( anEndian.getSystemEndianType() != OSSIM_BIG_ENDIAN )
127  {
128  // Swap back to native.
130  anEndian.swap(m_locationRowNumber);
131  anEndian.swap(m_locationColumnNumber);
132  anEndian.swap(m_pathnameRecordOffset);
133  }
134 }
◆ operator<<
std::ostream& operator<< ( std::ostream &  out,
const ossimRpfFrameFileIndexRecord data
friend
Definition at line 20 of file ossimRpfFrameFileIndexRecord.cpp.
21 {
22  return data.print(out);
23 }
std::ostream & print(std::ostream &out) const
Member Data Documentation
◆ m_boundaryRectRecordNumber
ossim_uint16 ossimRpfFrameFileIndexRecord::m_boundaryRectRecordNumber
private
◆ m_filename
char ossimRpfFrameFileIndexRecord::m_filename[13]
private
This is a 12 byte asci field.
Definition at line 67 of file ossimRpfFrameFileIndexRecord.h.
Referenced by clearFields(), getFilename(), operator=(), ossimRpfFrameFileIndexRecord(), parseStream(), print(), and writeStream().
◆ m_fileSecurityCountryCode
char ossimRpfFrameFileIndexRecord::m_fileSecurityCountryCode[3]
private
is a 2 byte field.
Definition at line 79 of file ossimRpfFrameFileIndexRecord.h.
Referenced by clearFields(), operator=(), ossimRpfFrameFileIndexRecord(), parseStream(), print(), and writeStream().
◆ m_fileSecurityReleaseMarking
char ossimRpfFrameFileIndexRecord::m_fileSecurityReleaseMarking[3]
private
This is a 2 byte field.
Definition at line 84 of file ossimRpfFrameFileIndexRecord.h.
◆ m_geographicLocation
char ossimRpfFrameFileIndexRecord::m_geographicLocation[7]
private
this is a 6 byte asci field.
Definition at line 72 of file ossimRpfFrameFileIndexRecord.h.
◆ m_locationColumnNumber
ossim_uint16 ossimRpfFrameFileIndexRecord::m_locationColumnNumber
private
◆ m_locationRowNumber
ossim_uint16 ossimRpfFrameFileIndexRecord::m_locationRowNumber
private
◆ m_pathnameRecordOffset
ossim_uint32 ossimRpfFrameFileIndexRecord::m_pathnameRecordOffset
private
◆ m_securityClassification
char ossimRpfFrameFileIndexRecord::m_securityClassification
private
