35 static ossimTrace traceDebug(
"ossimRpfToc:debug");
39 return data.
print(out);
57 static const char MODULE[] =
"ossimRpfToc::parseFile";
81 << MODULE <<
" leaving with no nitf header found....." << std::endl;
89 if(traceDebug() && (info.
getTagName() ==
"RPFHDR") )
92 << MODULE <<
" nitf file header print\n";
96 if ( !keepFileHeader )
123 << MODULE <<
" DEBUG: Found RPF HEADER tag\n";
133 <<
"ossimRpfToc::parseFile: Leaving No RPFHDR tag found" <<
"\n";
151 <<
"ossimRpfToc::parseFile: Leaving no RPFHDR " << __LINE__ <<
"\n";
159 <<
"ossimRpfToc::parseFile: Returning with OK." << std::endl;
168 static const char MODULE[] =
"ossimRpfToc::createTocAndCopyFrames";
173 << MODULE <<
" entered..." 174 <<
"\ndot rpf file: " << dotRpfFile
175 <<
"\noutput directory: " << outputDir
183 std::string e = MODULE;
184 e +=
" ERROR:\nCould not create directory: ";
185 e+= outputDir.
c_str();
192 dotRpfStr->open(dotRpfFile.
c_str(), ios_base::in);
193 if ( !dotRpfStr->good() )
198 std::string e = MODULE;
199 e +=
" ERROR:\nCould not open: ";
200 e += dotRpfFile.
c_str();
205 if ( sourceADotTocFile.
empty() )
210 std::string e = MODULE;
211 e +=
" ERROR:\nCould not deduce source a.toc file!";
222 std::string e = MODULE;
223 e +=
224 e += sourceADotTocFile.
c_str();
229 if ( !sourceNitfFileHdr.
valid() )
234 std::string e = MODULE;
235 e +=
" ERROR:\nCould not get nitf file header from: ";
236 e += sourceADotTocFile.
c_str();
241 if ( !sourceRpfHdr.
valid() )
246 std::string e = MODULE;
247 e +=
" ERROR:\nCould not get rpf header from: ";
248 e += sourceADotTocFile.
c_str();
255 if ( !boundaryRectSectionSubheader.
valid() )
260 std::string e = MODULE;
261 e +=
" ERROR:\nCould not pull boundary rect sub header from source file: ";
262 e += sourceADotTocFile.
c_str();
269 if ( !boundaryRectTable.
valid() )
274 std::string e = MODULE;
275 e +=
" ERROR:\nCould not pull boundary rect table from source file: ";
276 e += sourceADotTocFile.
c_str();
283 if ( !frameFileSubHeader.
valid() )
288 std::string e = MODULE;
289 e +=
" ERROR:\nCould not pull frame file sub header from source file: ";
290 e += sourceADotTocFile.
c_str();
297 if ( !frameFileSubSection.
valid() )
302 std::string e = MODULE;
303 e +=
" ERROR:\nCould not pull frame file sub section from source file: ";
304 e += sourceADotTocFile.
c_str();
312 dotTocStr->open( dotTocFile.
c_str(), ios::out|ios::binary );
313 if ( !dotTocStr->good() )
320 std::string e = MODULE;
321 e +=
322 e += dotTocFile.
c_str();
375 fileHdr->
addTag(rpfHdrInfo);
388 std::streampos pos = dotTocStr->tellp();
389 std::streamoff locationSectionOffset = pos;
392 fileHdr->
setHeaderLength( static_cast<ossim_uint64>(locationSectionOffset) );
437 if ( fileHdr->
getTag(rpfHdrInfo,
"RPFHDR") )
512 dotTocStr->seekp(0, ios::beg);
515 dotTocStr->seekp(boundaryRectPosition, ios::beg);
523 <<
"writing boundaryRectSectionSubheader:\n" << *(boundaryRectSectionSubheader.
get())
531 boundaryRectSectionSubheader->
writeStream(*dotTocStr);
536 <<
"Original boundaryRectTable:\n" << *(boundaryRectTable.
get()) <<
"\n";
543 if ( boundaryRectTable->
getEntry( entry, boundaryRectRecord) )
548 <<
"writing boundaryRectTable:\n" << boundaryRectRecord <<
"\n";
555 std::string e = MODULE;
556 e +=
" ERROR:\nCould not get bounding rect record for entry: ";
563 std::string e = MODULE;
564 e +=
" ERROR:\nCould not deduce entry from frame list!";
576 <<
"writing frameFileSubHeader:\n" << *(frameFileSubHeader.
get()) <<
"\n";
585 std::streamoff frameFileIndexSectionStartPos = dotTocStr->tellp();
589 std::streamoff endOfFilePos = dotTocStr->tellp();
593 static_cast<ossim_uint32>(endOfFilePos - frameFileIndexSectionStartPos);
600 fileHdr->
setFileLength(static_cast<ossim_uint64>(endOfFilePos));
601 dotTocStr->seekp(0, ios::beg);
617 const std::string& prefix,
618 bool printOverviews)
const 635 const std::string& prefix )
const 646 const std::string& prefix,
647 bool printOverviews )
const 654 tocEntry->
print(out, prefix);
660 if ( (scale.
contains(
"OVERVIEW") ==
false) || printOverviews )
663 entryPrefix +=
"image";
666 REC.
print(out, entryPrefix);
681 rpfFrame.
731 if ( pEntry != NULL )
742 if ( pEntry != NULL )
755 if ( pEntry != NULL )
757 return pEntry->
getEntry( row, col, result );
768 if ( bResult ==
true )
790 std::vector< ossimRpfTocEntry*>::iterator tocEntry =
809 <<
"ossimRpfToc::buildTocEntryList: entered.....\n";
818 <<
"ossimRpfToc::buildTocEntryList: invalid input leaving..... " << std::endl;
840 std::streamoff current = in.tellg();
849 in.seekg(current, ios::beg);
863 long offsetToIndexSubsection = in.tellg();
864 if(frameFileIndexHead)
876 std::streamoff currentPosition = in.tellg();
903 in.seekg(currentPosition, ios::beg);
907 delete frameFileIndexHead;
908 frameFileIndexHead = 0;
917 <<
"ossimRpfToc::buildTocEntryList: leaving....." << std::endl;
927 for(
ossim_uint32 index = 0; index < numberOfEntries; index++)
948 bool foundEntry =
false;
953 rpfTocEntry->
getEntry(v, h, frameEntry);
972 static const char MODULE[] =
"ossimRpfToc::writeFrameFileIndexSection";
981 ossim_uint32 pathnameRecordOffset = FRAME_FILE_INDEX_RECORD_LENGTH * frames;
988 if ( !dotRpfStr.good() )
994 dotRpfStr.seekg(0, ios_base::beg);
1004 while( dotRpfStr.good() )
1008 if ( dotRpfStr.good() )
1042 <<
"frames written: " << framesWritten
1043 <<
"\nwrote record:\n" << pathRecord
1048 dotRpfStr.seekg(0, ios_base::beg);
1058 static const char MODULE[] =
"ossimRpfToc::copyFrames";
1072 if ( !dotRpfStr.good() )
1078 dotRpfStr.seekg(0, ios_base::beg);
1095 destinationFile = outputDir;
1096 subDir = file.
path();
1097 subDir = subDir.
file();
1098 destinationFile = destinationFile.
dirCat( subDir );
1101 if ( !destinationFile.
exists() )
1108 if ( !dotRpfStr.good() )
1113 dotRpfStr.seekg(0, ios_base::beg);
1118 while( dotRpfStr.good() )
1122 if ( dotRpfStr.good() )
1126 destinationFile = outputDir;
1127 subDir = file.
path();
1128 subDir = subDir.
file();
1129 destinationFile = destinationFile.
dirCat( subDir );
1130 destinationFile = destinationFile.
dirCat( file.
file() );
1147 dotRpfStr.seekg(0, ios_base::beg);
1159 if ( !dotRpfStr.good() )
1165 dotRpfStr.seekg(0, ios_base::beg);
1171 while( dotRpfStr.good() )
1175 if ( dotRpfStr.good() )
1182 dotRpfStr.seekg(0, ios_base::beg);
1191 if ( !dotRpfStr.good() )
1196 dotRpfStr.seekg(0, ios_base::beg);
1210 tocFile = subDir.
dirCat(
"a.toc");
1213 tocFile = subDir.
dirCat(
"A.TOC");
1216 subDir = subDir.
path();
1217 tocFile = subDir.
dirCat(
"a.toc");
1220 tocFile = subDir.
dirCat(
"A.TOC");
1230 if ( !dotRpfStr.good() )
1234 dotRpfStr.seekg(0, ios_base::beg);
1248 bool result =
false;
1250 if ( !dotRpfStr.good() )
1256 dotRpfStr.seekg(0, ios_base::beg);
1276 if ( !dotRpfStr.good() )
1281 dotRpfStr.seekg(0, ios_base::beg);
1293 bool result =
false;
1297 std::vector<ossimString> lineArray;
1298 os.
split(lineArray,
1299 if ( lineArray.size() )
1301 file = lineArray[0];
void clear()
Erases the entire container.
void addComponentRecord(const ossimRpfComponentLocationRecord &record)
Method to add a component location record.
ossim_int32 ossimErrorCode
bool getFrameFileIndexRecordFromFile(const ossimFilename &file, ossimRpfFrameFileIndexRecord &record) const
Gets the record matching file.
ossimErrorCode parseStream(std::istream &in, ossimByteOrder byteOrder)
ossim_uint32 getNumberOfEntries() const
bool getCorespondingEntry(ossimRpfFrameFileIndexSubsection *frameFileSubSection, std::ifstream &dotRpfStr, ossim_uint32 &entry) const
Gets the zero based entry number for the first file in the dot rpf file.
ossimFilename getFilename() const
ossimFilename getSourceTocFile(std::ifstream &dotRpfStr) const
Get a.toc file from the dot rpf file.
std::ostream & operator<<(std::ostream &out, const ossimRpfToc &data)
ossim_uint32 getNumberOfFrames(std::ifstream &dotRpfStr) const
Get the number of frames from the dot rpf file.
std::ostream & print(std::ostream &out, const std::string &prefix=std::string()) const
print method that outputs a key/value type format adding prefix to keys.
static const ossimErrorCode OSSIM_OK
std::basic_ifstream< char > ifstream
Class for char input file streams.
ossimFilename expand() const
Method to do file name expansion.
std::ostream & print(std::ostream &out, const std::string &prefix=std::string(), bool printOverviews=false) const
ossim_uint32 getNumberOfFramesVertical() const
bool contains(char aChar) const
const ossimString getRelativeFramePath(ossim_uint32 entryIdx, ossim_uint32 row, ossim_uint32 col) const
For the given entry index, frame row, and frame column, this routine returns the corresponding name o...
ossimString getScale() const
Numeric to string methods.
ossim_uint32 m_componentLength
std::vector< ossimRpfTocEntry * > m_tocEntryList
void allocateTocEntryList(ossim_uint32 numberOfEntries)
ossimRefPtr< const ossimNitfFileHeader > m_nitfFileHeader
static const ossimErrorCode OSSIM_ERROR
std::istream & getline(std::istream &is, ossimString &str, char delim)
const ossimRpfHeader * getRpfHeader() const
unsigned short ossim_uint16
ossim_uint32 getNumberOfFramesHorizontal(ossim_uint32 idx) const
For the given entry index, this routine returns the number of frames that exist in the horizontal dir...
const ossimRpfBoundaryRectRecord & getBoundaryInformation() const
void setLocationSectionLength(ossim_uint16 length)
const ossimString getPathToFrameFileFromRoot() const
bool copyFileTo(const ossimFilename &outputFile) const
Copies this file to output file.
std::vector< ossimRpfComponentLocationRecord > & getLocationRecordList()
Brief Direct access to the list of records.
void setPathnameRecordOffset(ossim_uint32 offset)
void setLocationRecordLength(ossim_uint16 length)
ossim_uint16 getLocationColNumber() const
void deleteTocEntryList()
void writeStream(std::ostream &out)
Write method.
ossim_uint32 m_componentLocation
void writeFrameFileIndexSection(ossimRpfFrameFileIndexSubsection *frameFileSubSection, std::ifstream &dotRpfStr, std::ofstream &dotTocStr)
Writes the frame file sub section of an a.toc.
const ossimNitfFileHeader * getHeader() const
unsigned int ossim_uint32
void setComponentAggregateLength(ossim_uint32 length)
bool getEntry(ossim_uint32 entry, ossimRpfBoundaryRectRecord &record) const
Gets record for entry.
const ossimRpfTocEntry * getTocEntry(ossim_uint32 index) const
ossim_uint16 m_componentId
void setBoundaryRecNumber(ossim_uint16 entry)
Sets the zero based entry number.
ossimErrorCode parseFile(const ossimFilename &fileName, bool keepFileHeader=false)
Parses a.toc file.
ossimRefPtr< ossimRpfHeader > m_rpfHeader
bool getRpfFrameEntry(ossim_uint32 entryIdx, ossim_uint32 row, ossim_uint32 col, ossimRpfFrameEntry &result) const
For the given entry index, frame row, and frame column, this routine returns the corresponding ossimR...
void createTocAndCopyFrames(const ossimFilename &dotRpfFile, const ossimFilename &outputDir)
Creates a new a.toc file from list of rpf frames in output directory.
ossim_uint32 getNumberOfFramesHorizontal() const
ossimErrorCode parseFile(const ossimFilename &filename, bool minimalParse=false)
void getRootDirectory(ossimFilename &dir) const
Method to get the root directory from the a.toc file name.
ossimString getPathname() const
void copyFrames(std::ifstream &dotRpfStr, const ossimFilename &outputDir)
Copies frame to output directory.
ossim_uint32 getPathnameRecordOffset() const
Write method.
ossim_uint16 getBoundaryRecNumber() const
const ossimNitfFileHeader * getNitfFileHeader() const
Get the nitf file header.
ossimFilename dirCat(const ossimFilename &file) const
void setPathName(const ossimString &path)
Set the pathname and length from string size.
const char * c_str() const
Returns a pointer to a null-terminated array of characters representing the string's contents...
void buildTocEntryList(ossimRpfHeader *rpfHeader)
ossimFilename file() const
bool parseFile(const ossimFilename &file)
std::basic_ofstream< char > ofstream
Class for char output file streams.
bool getEntry(long row, long col, ossimRpfFrameEntry &result) const
void setLocationTableOffset(ossim_uint32 offset)
bool getFile(const std::string &line, ossimFilename &file) const
Gets the filename from line in.
ossim_uint32 getNumberOfFramesVertical(ossim_uint32 idx) const
For the given entry index, this routine returns the number of frames that exist in the vertical direc...
std::ostream & printHeader(std::ostream &out, const std::string &prefix=std::string()) const
bool createDirectory(bool recurseFlag=true, int perm=0775) const
ossim_int32 getTocEntryIndex(const ossimRpfTocEntry *entry)
Returns -1 if not found.
ossimFilename path() const
const ossimFilename & getFullPath() const
Write method.
void getFirstEntry(const ossimRpfTocEntry *rpfTocEntry, ossimRpfFrameEntry &frameEntry) const
Walks through frames to find the first entry that exists...
void clearFields()
Clears records and fields.
std::basic_ostream< char > ostream
Base class for char output streams.
ossim_uint16 getLocationRowNumber() const
void setNumberOfComponentLocationRecords(ossim_uint16 count)
std::ostream & printTocEntry(std::ostream &out, ossim_uint32 entryIndex, const std::string &prefix=std::string(), bool printOverviews=false) const
std::ostream & print(std::ostream &out, ossimString prefix) const
prints to out.
