#include <ossimSharedPluginRegistry.h>
virtual | ~ossimSharedPluginRegistry () |
bool | registerPlugin (const ossimFilename &filename, const ossimString &options="") |
bool | unregisterPlugin (int idx) |
bool | unregisterPlugin (ossimPluginLibrary *plugin) |
const ossimPluginLibrary * | getPlugin (const ossimFilename &filename) const |
ossimPluginLibrary * | getPlugin (const ossimFilename &filename) |
ossim_uint32 | getIndex (const ossimPluginLibrary *lib) const |
ossimPluginLibrary * | getPlugin (ossim_uint32 idx) |
const ossimPluginLibrary * | getPlugin (ossim_uint32 idx) const |
ossim_uint32 | getNumberOfPlugins () const |
bool | isLoaded (const ossimFilename &filename) const |
Checks if filename is already loaded to avoid duplication. More... | |
void | printAllPluginInformation (std::ostream &out) |
static ossimSharedPluginRegistry * | instance () |
ossimSharedPluginRegistry () | |
ossimSharedPluginRegistry (const ossimSharedPluginRegistry &) | |
void | operator= (const ossimSharedPluginRegistry &) |
Protected Attributes | |
std::vector< ossimRefPtr< ossimPluginLibrary > > | theLibraryList |
Definition at line 10 of file ossimSharedPluginRegistry.h.
Definition at line 28 of file ossimSharedPluginRegistry.cpp.
References theLibraryList.
protected |
Definition at line 24 of file ossimSharedPluginRegistry.cpp.
inlineprotected |
Definition at line 41 of file ossimSharedPluginRegistry.h.
ossim_uint32 ossimSharedPluginRegistry::getIndex | ( | const ossimPluginLibrary * | lib | ) | const |
ossim_uint32 ossimSharedPluginRegistry::getNumberOfPlugins | ( | ) | const |
Definition at line 180 of file ossimSharedPluginRegistry.cpp.
Referenced by isLoaded(), and printAllPluginInformation().
const ossimPluginLibrary * ossimSharedPluginRegistry::getPlugin | ( | const ossimFilename & | filename | ) | const |
Definition at line 110 of file ossimSharedPluginRegistry.cpp.
References ossimFilename::file(), and theLibraryList.
Referenced by isLoaded(), printAllPluginInformation(), registerPlugin(), and unregisterPlugin().
Definition at line 125 of file ossimSharedPluginRegistry.cpp.
ossimPluginLibrary * ossimSharedPluginRegistry::getPlugin | ( | ossim_uint32 | idx | ) |
Definition at line 156 of file ossimSharedPluginRegistry.cpp.
const ossimPluginLibrary * ossimSharedPluginRegistry::getPlugin | ( | ossim_uint32 | idx | ) | const |
Definition at line 168 of file ossimSharedPluginRegistry.cpp.
static |
Definition at line 33 of file ossimSharedPluginRegistry.cpp.
Referenced by ossimInit::initializePlugins(), ossimInit::loadPlugins(), ossimInfo::printPlugins(), and ossimInfo::testPlugin().
bool ossimSharedPluginRegistry::isLoaded | ( | const ossimFilename & | filename | ) | const |
filename | The file to check. |
Definition at line 186 of file ossimSharedPluginRegistry.cpp.
References ossimFilename::file(), ossimDynamicLibrary::getName(), getNumberOfPlugins(), and getPlugin().
inlineprotected |
Definition at line 42 of file ossimSharedPluginRegistry.h.
void ossimSharedPluginRegistry::printAllPluginInformation | ( | std::ostream & | out | ) |
Definition at line 207 of file ossimSharedPluginRegistry.cpp.
References ossimPluginLibrary::getClassNames(), ossimPluginLibrary::getDescription(), ossimDynamicLibrary::getName(), getNumberOfPlugins(), and getPlugin().
Referenced by ossimInfo::printPlugins().
bool ossimSharedPluginRegistry::registerPlugin | ( | const ossimFilename & | filename, |
const ossimString & | options = "" |
Definition at line 40 of file ossimSharedPluginRegistry.cpp.
References getPlugin(), ossimDynamicLibrary::getSymbol(), ossimPluginLibrary::initialize(), ossimDynamicLibrary::load(), ossimPluginLibrary::setOptions(), and theLibraryList.
Referenced by ossimInit::initializePlugins(), and ossimInit::loadPlugins().
bool ossimSharedPluginRegistry::unregisterPlugin | ( | int | idx | ) |
Definition at line 88 of file ossimSharedPluginRegistry.cpp.
References getPlugin().
bool ossimSharedPluginRegistry::unregisterPlugin | ( | ossimPluginLibrary * | plugin | ) |
protected |
Definition at line 45 of file ossimSharedPluginRegistry.h.
Referenced by getIndex(), getNumberOfPlugins(), getPlugin(), registerPlugin(), unregisterPlugin(), and ~ossimSharedPluginRegistry().
